je suis allé cherché là où ça semble partir en sucette avec un plantage vers 10h et un redemerrage à 10:49
2025-06-29 09:59:58,180 INFO :b'UpdateDevice - (ZAmperage6 - PompePiscine) 0:2.76'
2025-06-29 09:59:59,246 INFO :b'UpdateDevice - (ZAmperage6 - PompePiscine) 0:2.77'
2025-06-29 10:00:00,131 WARNING :Executing <Task pending name='Task-1' coro=<start_zigpy_task() running at /home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/zigpyThread.py:162> wait_for=<Future pending cb=[Task.__wakeup()] created at /usr/lib/python3.11/asyncio/base_events.py:427> cb=[_run_until_complete_cb() at /usr/lib/python3.11/asyncio/base_events.py:180] created at /usr/lib/python3.11/asyncio/tasks.py:670> took 0.239 seconds
2025-06-29 10:00:00,180 INFO :b'UpdateDevice - (ZAmperage6 - PompePiscine) 0:2.76'
2025-06-29 10:00:16,326 WARNING :+ Connection to the radio was lost: <class 'bellows.ash.NcpFailure'> <NcpFailure(code=<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>)>
2025-06-29 10:00:16,327 ERROR :NCP reset due to exceeded maximum ACK timeout count, plugin restart required
2025-06-29 10:00:22,936 ERROR : [ZigpyCom_64 1441498] [ Plugin] Connection lost with coordinator, restarting plugin
2025-06-29 10:00:44,780 DEBUG :Starting new HTTPS connection (1): z4d.pipiche.net:443
2025-06-29 10:00:44,787 INFO :b'UpdateDevice - (ZAmperage6 - PompePiscine) 0:2.77'
2025-06-29 10:00:45,001 INFO :b'UpdateDevice - (ZAmperage6 - PompePiscine) 0:2.76'
2025-06-29 10:00:45,653 DEBUG :https://z4d.pipiche.net:443 "GET /matomo.php?idsite=9&rec=1&apiv=1&action_name=Plugin+Action&uid=d9d05611dd812fd6f3357f8c1e1f51d288fec96d6fafda82c7637ca1ad8b574f&e_c=Plugin&e_a=Restart&e_n=Plugin+Restart HTTP/1.1" 200 43
2025-06-29 10:00:46,039 WARNING :Executing <Handle ThreadsafeProxy.__getattr__.<locals>.func_wrapper.<locals>.check_result_wrapper() at /home/pi/Domoticz_Python_Environment/bellows/thread.py:110 created at /home/pi/Domoticz_Python_Environment/bellows/thread.py:120> took 29.713 seconds
2025-06-29 10:00:46,052 WARNING :+ Connection to the radio was lost: <class 'bellows.ash.NcpFailure'> <NcpFailure(code=<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>)>
2025-06-29 10:00:46,080 WARNING :+ shutdown or restart in progress
2025-06-29 10:00:46,080 WARNING :+ Connection to the radio was lost: <class 'bellows.ash.NcpFailure'> <NcpFailure(code=<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>)>
2025-06-29 10:00:46,081 WARNING :+ shutdown or restart in progress
2025-06-29 10:00:46,086 WARNING :+ Connection to the radio was lost: <class 'bellows.ash.NcpFailure'> <NcpFailure(code=<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>)>
2025-06-29 10:00:46,087 WARNING :+ shutdown or restart in progress
2025-06-29 10:00:46,098 WARNING :+ Connection to the radio was lost: <class 'bellows.ash.NcpFailure'> <NcpFailure(code=<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>)>
2025-06-29 10:00:46,098 WARNING :+ shutdown or restart in progress
2025-06-29 10:00:46,099 WARNING :+ Connection to the radio was lost: <class 'bellows.ash.NcpFailure'> <NcpFailure(code=<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>)>
2025-06-29 10:00:46,172 WARNING :+ shutdown or restart in progress
2025-06-29 10:00:46,172 WARNING :+ Connection to the radio was lost: <class 'bellows.ash.NcpFailure'> <NcpFailure(code=<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>)>
2025-06-29 10:00:46,173 WARNING :+ shutdown or restart in progress
2025-06-29 10:00:46,173 WARNING :+ Connection to the radio was lost: <class 'bellows.ash.NcpFailure'> <NcpFailure(code=<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>)>
2025-06-29 10:00:46,174 WARNING :+ shutdown or restart in progress
2025-06-29 10:00:46,196 INFO :b'UpdateDevice - (ZAmperage6 - PompePiscine) 0:2.77'
2025-06-29 10:00:46,250 INFO :b'UpdateDevice - (ZAmperage6 - PompePiscine) 0:2.76'
2025-06-29 10:00:46,303 INFO :b'UpdateDevice - (ZAmperage6 - PompePiscine) 0:2.77'
2025-06-29 10:00:46,310 INFO :b'UpdateDevice - (ZAmperage6 - PompePiscine) 0:2.76'
2025-06-29 10:00:46,454 DEBUG :Starting new HTTPS connection (1): z4d.pipiche.net:443
2025-06-29 10:00:46,464 WARNING :Executing <Task pending name='_unicast_command-zcl_raw_default_response-<Device model=None manuf=None nwk=0x9EFE ieee=a4:c1:38:00:a0:84:3c:a7 is_initialized=False>-0-106' coro=<measure_execution_time.<locals>.wrapper() running at /home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/zigpyThread.py:748> wait_for=<Future pending cb=[Task.__wakeup()] created at /usr/lib/python3.11/asyncio/base_events.py:427> created at /usr/lib/python3.11/asyncio/tasks.py:374> took 0.138 seconds
2025-06-29 10:00:46,493 WARNING :Watchdog failure
File "/home/pi/Domoticz_Python_Environment/zigpy/application.py", line 661, in _watchdog_loop
await self.watchdog_feed()
File "/home/pi/Domoticz_Python_Environment/zigpy/application.py", line 647, in watchdog_feed
await self._watchdog_feed()
File "/home/pi/Domoticz_Python_Environment/bellows/zigbee/application.py", line 1004, in _watchdog_feed
current_counters = await self._ezsp.read_counters()
File "/home/pi/Domoticz_Python_Environment/bellows/ezsp/v4/__init__.py", line 191, in read_counters
(res,) = await self.readCounters()
File "/home/pi/Domoticz_Python_Environment/bellows/ezsp/protocol.py", line 129, in command
await self._gw.send_data(data)
File "/usr/lib/python3.11/asyncio/futures.py", line 287, in __await__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.11/asyncio/tasks.py", line 339, in __wakeup
future.result()
File "/usr/lib/python3.11/asyncio/futures.py", line 203, in result
raise self._exception.with_traceback(self._exception_tb)
File "/usr/lib/python3.11/asyncio/tasks.py", line 269, in __step
result = coro.throw(exc)
File "/home/pi/Domoticz_Python_Environment/bellows/uart.py", line 31, in send_data
await self._transport.send_data(data)
File "/home/pi/Domoticz_Python_Environment/bellows/ash.py", line 708, in send_data
await asyncio.shield(
future.result()
File "/usr/lib/python3.11/asyncio/tasks.py", line 267, in __step
result = coro.send(None)
File "/home/pi/Domoticz_Python_Environment/bellows/ash.py", line 633, in _send_data_frame
raise NcpFailure(
bellows.ash.NcpFailure: NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT
2025-06-29 10:00:46,945 WARNING :+ Connection to the radio was lost: <class 'bellows.ash.NcpFailure'> <NcpFailure(code=<NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT: 81>)>
2025-06-29 10:00:46,946 WARNING :+ shutdown or restart in progress
2025-06-29 10:00:46,946 WARNING :Executing <Task finished name='watchdog_loop' coro=<ControllerApplication._watchdog_loop() done, defined at /home/pi/Domoticz_Python_Environment/bellows/zigbee/application.py:985> result=None created at /usr/lib/python3.11/asyncio/tasks.py:374> took 0.454 seconds
2025-06-29 10:00:46,952 INFO :b"Warning while submitting - rawaps_read_attribute_req a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0xB04 payload: b'\\x10I\\x00\\x05\\x05\\x08\\x05\\x0b\\x05' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:46,959 INFO :b"Warning while submitting - rawaps_read_attribute_req a4:c1:38:b0:34:d1:5a:f3/0x59c1 0x104 0xB04 payload: b'\\x10$\\x00\\x05\\x05\\x08\\x05\\x0b\\x05' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:46,965 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:46,974 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:46,982 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:46,990 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:46,996 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:47,010 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:47,017 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:47,024 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:47,033 DEBUG :https://z4d.pipiche.net:443 "GET /matomo.php?idsite=9&rec=1&apiv=1&action_name=Plugin+Action&uid=d9d05611dd812fd6f3357f8c1e1f51d288fec96d6fafda82c7637ca1ad8b574f&e_c=Plugin&e_a=Shutdown&e_n=Plugin+Shutdown HTTP/1.1" 200 43
2025-06-29 10:00:47,050 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:47,084 DEBUG :Starting new HTTPS connection (1): z4d.pipiche.net:443
2025-06-29 10:00:47,138 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:47,175 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:47,192 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:47,218 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:47,240 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:47,256 DEBUG :https://z4d.pipiche.net:443 "GET /matomo.php?idsite=9&rec=1&apiv=1&action_name=Z4DPluginInfos&uid=d9d05611dd812fd6f3357f8c1e1f51d288fec96d6fafda82c7637ca1ad8b574f&dimension1=2025.1+build+16729&dimension2=Unknown+Silicon+Labs&dimension3=7.1.022&dimension4=UNK+-+7.3.1.0+build+176&dimension5=Medium&dimension6=6.466&dimension7=Debian+GNU+Linux+12&dimension8=python+3.11.2+arch+64bit+machine+aarch64+processor&dimension9=1+day&dimension11=Raspberry+Pi+4+Model+B+Rev+1.1 HTTP/1.1" 200 43
2025-06-29 10:00:47,276 INFO :b'Flushing plugin database onto disk'
2025-06-29 10:00:47,279 INFO :b"Warning while submitting - zcl_raw_default_response a4:c1:38:00:a0:84:3c:a7/0x9efe 0x104 0x0 payload: b'\\x08j\\x0b\\n\\x00' AckIsDisable: True extended_timeout: False Attempt: 1 Exception: 'NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT' (NcpFailure)"
2025-06-29 10:00:47,338 INFO :b'onStop called'
2025-06-29 10:00:47,506 INFO :b'Shutding down zigpy thread'
2025-06-29 10:00:47,763 WARNING :Executing <Task pending name='Task-1' coro=<start_zigpy_task() running at /home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/zigpyThread.py:179> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/lib/python3.11/asyncio/futures.py:387, Task.__wakeup()] created at /usr/lib/python3.11/asyncio/base_events.py:427> cb=[_run_until_complete_cb() at /usr/lib/python3.11/asyncio/base_events.py:180] created at /usr/lib/python3.11/asyncio/tasks.py:670> took 0.259 seconds
2025-06-29 10:00:47,765 WARNING :Failed to create backup
2025-06-29 10:00:47,771 WARNING :+ Connection to the radio was lost: <class 'NoneType'> None
2025-06-29 10:00:47,772 WARNING :+ shutdown or restart in progress
2025-06-29 10:00:48,810 INFO :b'Cancelling 0 outstanding tasks'
2025-06-29 10:00:49,814 DEBUG :Close <_UnixSelectorEventLoop running=False closed=False debug=True>
2025-06-29 10:00:50,542 INFO :b'Event loop closed successfully in zigpy_thread.'
2025-06-29 10:00:58,931 INFO :b'Closing all client connections...'
2025-06-29 10:00:58,931 INFO :b'++ WebUI - server stopped'
2025-06-29 10:00:58,942 INFO :b'WebUI shutdown completed'
2025-06-29 10:00:59,085 INFO :b'Closing Logging Management'
2025-06-29 10:49:19,482 INFO :b'Z4D is starting with stable7-7.1.022'
2025-06-29 10:49:19,489 INFO :b"Z4D Multi-instances detected. Enabling 'asyncio' workaround"
2025-06-29 10:49:19,495 INFO :b'Z4D Database found: DeviceList-64.txt'
2025-06-29 10:49:19,495 INFO :b'Z4D Certified devices database /home/pi/Domoticz_Python_Environment/z4d_certified_devices/'
2025-06-29 10:49:19,496 INFO :b'Z4D loads ZCL Cluster definitions'
2025-06-29 10:49:19,538 INFO :b'Z4D loaded 16 configuration from legacy database.'
2025-06-29 10:49:19,539 INFO :b'Z4D loads 0 configuration from the local certified Db.'
2025-06-29 10:49:20,045 INFO :b'Z4D loads 644 certified devices from repository version [6.466]'
2025-06-29 10:49:20,046 INFO :b'Z4D loading plugin database'
2025-06-29 10:49:20,408 INFO :b'Z4D loads 22 entries from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-64.txt'
2025-06-29 10:49:20,449 INFO :b"Z4D is starting transport Mode: 'ZigpyEZSP' Serial: '/dev/serial1' IP: '192.168.0.97 'Port: '6640'"
2025-06-29 10:49:23,574 INFO :b'Z4D starting EZSP'
