Meteoconcept
Re: Meteoconcept
Les limitations sont sur les commandes shell. Logique en soit.
will
Re: Meteoconcept
Message par will »
J'avance un peu dans la réalisation du script et l'apprentissage de dz vent mais y'a quelque choses qui cloche
Je comprend pas encore tous de ce script mais la chaine XML semble posé un problème :?:
return
	on =
		timer = {
			'every 1 minutes' -- just an example to trigger the request
		httpResponses = {
			'trigger' -- must match with the callback passed to the openURL command
	logging =
		level = domoticz.LOG_INFO,
		marker = 'template',
        if item.isTimer then
			domoticz.openURL(
				url = 'https://api.meteo-concept.com/api/forecast/daily/0?token=XXX&insee=XXX',
				method = 'GET',
				callback = 'trigger', -- see httpResponses above.
			elseif item.ok then -- statusCode == 2xx
			local rt =  domoticz.utils.fromXML(item.data)
			domoticz.utils.dumpTable(rt)
            local dsl = rt.rsp.dsl._attr
            -- get one value
            domoticz.log('line-status: ' .. dsl.line_status,domoticz.LOG_DEBUG)
            -- get all values
           for key, value in pairs(dsl) do
                domoticz.log(key .. ': '.. value,domoticz.LOG_DEBUG)
				domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
et le log associé
2023-01-19 18:57:00.226 Error: dzVents: Error: (3.1.8) template: Error parsing xml to LUA table: (invalid xml string) {"city":{"insee":"83126","cp":83500,"name":"La Seyne-sur-Mer","latitude":43.088,"longitude":5.8709,"altitude":45},"update":"2023-01-19T11:07:09+01:00","forecast":{"insee":"83126","cp":83500,"latitude":43.088,"longitude":5.8709,"day":0,"datetime":"2023-01-19T01:00:00+0100","wind10m":40,"gust10m":102,"dirwind10m":314,"rr10":0,"rr1":0,"probarain":10,"weather":1,"tmin":4,"tmax":8,"sun_hours":6,"etp":2,"probafrost":10,"probafog":0,"probawind70":70,"probawind100":10,"gustx":102}}
2023-01-19 18:57:00.226 Error: dzVents: Error: (3.1.8) template: An error occurred when calling event handler essais meteo
2023-01-19 18:57:00.226 Error: dzVents: Error: (3.1.8) template: ...oticz\scripts\dzVents\generated_scripts/essais meteo.lua:31: attempt to index a nil value (local 'rt')
Merci à l'âme charitable qui pourrait m'aider à avancer ...
Re: Meteoconcept
Le fichier XML retourné par l'API semble pas très valide.
Peux-tu poster un exemple complet de l'XML renvoyé ?
will
Re: Meteoconcept
Message par will »
le retour de la requête par mon navigateur
<response>
<city>
<insee>83126</insee>
<cp>83500</cp>
<name>La Seyne-sur-Mer</name>
<latitude>43.088</latitude>
<longitude>5.8709</longitude>
<altitude>45</altitude>
</city>
<update>2023-01-19T11:07:09+01:00</update>
<forecast>
<cp>83500</cp>
<day>0</day>
<datetime>2023-01-19T01:00:00+0100</datetime>
<wind10m>40</wind10m>
<gust10m>102</gust10m>
<dirwind10m>314</dirwind10m>
<rr10>0</rr10>
<rr1>0</rr1>
<probarain>10</probarain>
<weather>1</weather>
<tmin>4</tmin>
<tmax>8</tmax>
<sun_hours>6</sun_hours>
<etp>2</etp>
<probafrost>10</probafrost>
<probafog>0</probafog>
<probawind70>70</probawind70>
<probawind100>10</probawind100>
<gustx>102</gustx>
</forecast>
</response>
Re: Meteoconcept
L'XML est valide.
A la relecture du message d'erreur, j'ai l'impression que ton API revoie du JSON. :shock:
will
Re: Meteoconcept
Message par will »
Un grand merci .
oui c'est du Json.....
Et voici le script qui tourne: monpremier :lol:
return {
	on = {
		timer = {
		httpResponses = {
	logging = {
		if (item.isTimer) then
			domoticz.openURL({
				url = 'https://api.meteo-concept.com/api/forecast/daily/0?token=xxx&insee=83126',
				method = 'GET',
		if (item.isHTTPResponse) then
			if (item.ok) then
				if (item.isJSON) then
					local tempmini = item.json.forecast.tmin  --  temp mini de la journée
					-- update some device in Domoticz
					domoticz.devices('tempmini').updateText(tempmini)
Re: Meteoconcept
Commencer par un script avec un traitement Json, ce n'est pas le plus facile. Bravo :)
will
Re: Meteoconcept
Message par will »
J'ai complété le script pour le mettre en production :
return {
	on = {
		timer = {
		httpResponses = {
	logging = {
			domoticz.openURL({
				url = 'https://api.meteo-concept.com/api/forecast/daily/1?token=xxx&insee=83126',
				method = 'GET',
			if (item.ok) then
                    --Température
                    local tempmaxi = item.json.forecast.tmax
                   --Temps sensible
                    local temps  = item.json.forecast.weather
                    --Vent
                    local vitvent  = item.json.forecast.wind10m --km/h
                    local vitventms = (vitvent * 1000)/3600  --m/s
                    local vitrafale  = item.json.forecast.gust10m --km/h
                     local vitrafalems = (vitrafale * 1000)/3600 --m/s
                    local dirvent  = item.json.forecast.dirwind10m
                    --Cumul de pluie
                    local cumulmm  = item.json.forecast.rr10
                    local cumulmaxi  = item.json.forecast.rr1
                    local Probapluie  = item.json.forecast.probarain
                    --Ensoleillement
                    local Hsoleil  = item.json.forecast.sunHours
                    --Probabilité de gel entre 0 et 100%
                    local probagel  = item.json.forecast.probafrost
                    local probabrouill  = item.json.forecast.probafog
                    --Probabilité de vent
                    local probaventsup70  = item.json.forecast.probawind70
                    local probaventsup100  = item.json.forecast.probawind100
                 --Rafale de vent potentielle sous orage ou grain en km/h
                    local probaventsouspluie  = item.json.forecast.gustx
					domoticz.devices('Prévision temp mini pour demain').updateTemperature(tempmini)
					domoticz.devices('Prévision vent pour demain').updateWind(dirvent,'',vitventms,vitrafalems)
					domoticz.devices('Prévision cumul pluie pour demain').updateRain(cumulmm,cumulmaxi)
Il marche bien sur mon Domoticz d'essais à la dernier version mais( y'a toujours un mais :evil: )
sur ma version V3.815 (DZ vent 2.2.0) celui que j'exploite j'ai un log d'erreur qui empêche le script de tourner
2023-01-22 10:59:54.310 Error: EventSystem: in C:\Program Files\Domoticz\scripts\dzVents\runtime\dzVents.lua: ...m Files\Domoticz\scripts\dzVents\runtime/persistence.lua:24: C:\Program Files\Domoticz\scripts\dzVents\/domoticzData.lua: Permission denied
Qu'est que c'est que ce truc :?: :?:
J'ai bien autorisé les script DZ vent dans ls paramètres dans domoticz, est ce qu'il y'a une manip particulière que j'aurais raté pour les autorisation? ( je suis sous w7) :idea:
Merci et bon weekend
Re: Meteoconcept
C'est un problème d'autorisation.
Domoticz n'a pas les droits pour écrire dans un répertoire ou alors c'est un bug de ta version.
will
Re: Meteoconcept
Message par will »
J'ai corrigé le problème en déposant le fichier directement dans le dossier script.
Depuis l'éditeur ça devait posé un problème d'enregistrement...
Par contre nouveaux problème peut être dut a la vielle version de DZ vents que j'utilise , il semble ne pas comprendre ça
2023-01-22 11:28:00.375 Error: dzVents: Error: template: An error occured when calling event handler Prevision meteo demain
2023-01-22 11:28:00.375 Error: dzVents: Error: template: ...oticz\scripts\dzVents\scripts/Prevision meteo demain.lua:16: attempt to index local 'item' (a nil value)
Pourtant ça fonctionne sur la derniére version de domoticz...
Un problème de syntaxe avec la fonction?
