Bonjour à tous.
Je viens d'initier quelques tests et pour l'instant tout ne marche pas au mieux pour moi.
Après avoir suivi les recommandations de pipiche, à savoir passer sur la branche beta6 du plugin, ça ok pas de problème, ma configuration marche parfaitement avec ce plugin, tous les objets sont reconnus, ça roule.
Je lance donc la procédure d'apairage du module tuya :
2022-09-06 14:52:59.054 Status: PiZiGate: [None] NEW OBJECT: aa13 None
2022-09-06 14:52:59.168 Status: PiZiGate: [-] NEW OBJECT: aa13 Active Endpoint Response Ep: 01 LQI: 153
2022-09-06 14:52:59.169 Status: PiZiGate: [-] NEW OBJECT: aa13 Active Endpoint Response Ep: f2 LQI: 153
2022-09-06 14:52:59.176 Status: PiZiGate: [-] NEW OBJECT: aa13 Request Simple Descriptor for Ep: 01
2022-09-06 14:52:59.418 Status: PiZiGate: [-] NEW OBJECT: aa13 Simple Descriptor Response EP: 0x01 LQI: 150
2022-09-06 14:52:59.419 Status: PiZiGate: [-] NEW OBJECT: aa13 ProfileID 0104
2022-09-06 14:52:59.421 Status: PiZiGate: [-] NEW OBJECT: aa13 ZDeviceID 0202
2022-09-06 14:52:59.422 Status: PiZiGate: [-] NEW OBJECT: aa13 Application Version 0001
2022-09-06 14:52:59.423 Status: PiZiGate: [-] NEW OBJECT: aa13 Cluster IN Count: 05
2022-09-06 14:52:59.424 Status: PiZiGate: [-] NEW OBJECT: aa13 Cluster In 1: 0004 (Groups)
2022-09-06 14:52:59.425 Status: PiZiGate: [-] NEW OBJECT: aa13 Cluster In 2: 0005 (Scenes)
2022-09-06 14:52:59.427 Status: PiZiGate: [-] NEW OBJECT: aa13 Cluster In 3: 0006 (On/Off)
2022-09-06 14:52:59.428 Status: PiZiGate: [-] NEW OBJECT: aa13 Cluster In 4: 0102 (Window Covering)
2022-09-06 14:52:59.429 Status: PiZiGate: [-] NEW OBJECT: aa13 Cluster In 5: 0000 (Basic)
2022-09-06 14:52:59.430 Status: PiZiGate: [-] NEW OBJECT: aa13 Cluster OUT Count: 02
2022-09-06 14:52:59.432 Status: PiZiGate: [-] NEW OBJECT: aa13 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2022-09-06 14:52:59.433 Status: PiZiGate: [-] NEW OBJECT: aa13 Cluster Out 2: 000a (Time)
2022-09-06 14:52:59.434 Status: PiZiGate: [-] NEW OBJECT: aa13 Request Simple Descriptor for Ep: f2
2022-09-06 14:52:59.531 Status: PiZiGate: [-] NEW OBJECT: aa13 Simple Descriptor Response EP: 0xf2 LQI: 153
2022-09-06 14:52:59.533 Status: PiZiGate: [-] NEW OBJECT: aa13 ProfileID a1e0
2022-09-06 14:52:59.534 Status: PiZiGate: [-] NEW OBJECT: aa13 ZDeviceID 0061
2022-09-06 14:52:59.535 Status: PiZiGate: [-] NEW OBJECT: aa13 Application Version 0000
2022-09-06 14:52:59.537 Status: PiZiGate: [-] NEW OBJECT: aa13 Cluster IN Count: 00
2022-09-06 14:52:59.539 Status: PiZiGate: [-] NEW OBJECT: aa13 Cluster OUT Count: 01
2022-09-06 14:52:59.540 Status: PiZiGate: [-] NEW OBJECT: aa13 Cluster Out 1: 0021
2022-09-06 14:53:03.105 Status: PiZiGate: [0] NEW OBJECT: aa13 Model Name: TS130F
2022-09-06 14:53:03.111 Status: PiZiGate: [0] NEW OBJECT: aa13 Manufacturer Name: _TZ3000_zirycpws
2022-09-06 14:53:03.115 Status: PiZiGate: [None] NEW OBJECT: aa13 Request Node Descriptor
2022-09-06 14:53:08.121 Status: PiZiGate: [1] NEW OBJECT: aa13 Model Name: TS130F
2022-09-06 14:53:08.122 Status: PiZiGate: [1] NEW OBJECT: aa13 Manufacturer Name: _TZ3000_zirycpws
2022-09-06 14:53:13.120 Status: PiZiGate: [2] NEW OBJECT: aa13 Model Name: TS130F
2022-09-06 14:53:13.121 Status: PiZiGate: [2] NEW OBJECT: aa13 Manufacturer Name: _TZ3000_zirycpws
2022-09-06 14:53:18.139 Status: PiZiGate: [3] NEW OBJECT: aa13 Model Name: TS130F
2022-09-06 14:53:18.140 Status: PiZiGate: [3] NEW OBJECT: aa13 Manufacturer Name: _TZ3000_zirycpws
A priori c'est reconnu.
Voici le dispositif que j'ai pu creer dans domoticz :
- Capture d’écran du 2022-09-06 15-12-54.png (18.9 Kio) Consulté 1062 fois
Voici le dispositif du point de vue du plugin zigate :
- Capture d’écran du 2022-09-06 15-00-39.png (81.3 Kio) Consulté 1062 fois
Enfin voici le dispositif dans le dashboard :
- Capture d’écran du 2022-09-06 15-12-20.png (26.83 Kio) Consulté 1062 fois
Je n'ai pas encore cablé, mais avec un voltmètre, je devrais voir du 220V lorsque j'actionne la montée ou la descente du volet en me connectant entre la borne Neutre et une borne montée ou descente. Mais il n'en est rien, pas de réaction du module lorsque j'envoie un ordre de montée ou de descente.
Je vous tiens au courant dès que j'aurais fait le test sur mon volet roulant, mais je ne suis pas très optimiste au vu des résultats.
Alors ma première interrogation va a pipiche.
Quel a été ton protocole de test ? as tu fait comme moi un branchement au voltmètre pour voir une activité lors d'une requete d'ouverture/fermeture du volet ?
Quel type as tu créé (j'ai testé : Blinds, Blinds Percentage... ça ne fonctionne pas)
Voici la log lorsque j'actionne le module :
2022-09-06 15:22:46.894 PiZiGate: UpdateDevice - ( tuya_volets) 0:0
2022-09-06 15:22:46.782 Status: User: xxxx (IP: xx.xx.xx.xx) initiated a switch command (278/tuya_volets/Off)
2022-09-06 15:22:48.622 PiZiGate: UpdateDevice - ( tuya_volets) 1:100
2022-09-06 15:22:48.522 Status: User: xxxx (IP: xx.xx.xx.xx) initiated a switch command (278/tuya_volets/On)
Si vous avez une idée
Merci d'avance à tous !
