[Résolu] Capteur de qualité de l'air IKEA VINDSTYRKA
fjum
Re: Capteur de qualité de l'air IKEA VINDSTYRKA
Message par fjum »
5 devices créés : Temp+Hum, Temp, Hum, PM25, Voc
les logs domoticz :
2023-04-01 18:59:06.796 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum-943469fffec1dd42-01) 0:24.0;49.0;1
2023-04-01 18:59:06.803 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi-943469fffec1dd42-01) 49.0:1
2023-04-01 18:59:13.959 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum-943469fffec1dd42-01) 0:23.0;49.0;1
2023-04-01 18:59:13.965 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp-943469fffec1dd42-01) 23.0:23.0
2023-04-01 18:59:17.986 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum-943469fffec1dd42-01) 0:23.0;50.0;1
2023-04-01 18:59:17.991 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi-943469fffec1dd42-01) 50.0:1
2023-04-01 18:59:18.026 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Voc-943469fffec1dd42-01) 0:97.0
2023-04-01 18:59:20.054 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_PM25-943469fffec1dd42-01) 5.0:5.0
2023-04-01 18:59:23.122 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Voc-943469fffec1dd42-01) 0:99.0
Les updateDevice se font quasiment toutes les 30 secondes. ça fait beaucoup mais c'est peut-être normal.
Les logs domoticz à l'appairage :
2023-04-01 18:56:41.733 Status: Zigate: [None] NEW OBJECT: 713a None
2023-04-01 18:56:42.002 Status: Zigate: [-] NEW OBJECT: 713a Active Endpoint Response Ep: 01 LQI: 96
2023-04-01 18:56:42.003 Status: Zigate: [-] NEW OBJECT: 713a Active Endpoint Response Ep: f2 LQI: 96
2023-04-01 18:56:42.007 Status: Zigate: [-] NEW OBJECT: 713a Request Simple Descriptor for Ep: 01
2023-04-01 18:56:42.270 Status: Zigate: [-] NEW OBJECT: 713a Simple Descriptor Response EP: 0x01 LQI: 92
2023-04-01 18:56:42.271 Status: Zigate: [-] NEW OBJECT: 713a ProfileID 0104
2023-04-01 18:56:42.271 Status: Zigate: [-] NEW OBJECT: 713a ZDeviceID 0302
2023-04-01 18:56:42.272 Status: Zigate: [-] NEW OBJECT: 713a Application Version 0001
2023-04-01 18:56:42.272 Status: Zigate: [-] NEW OBJECT: 713a Cluster IN Count: 09
2023-04-01 18:56:42.272 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 1: 0000 (Basic)
2023-04-01 18:56:42.273 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 2: 0003 (Identify)
2023-04-01 18:56:42.273 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 3: 0004 (Groups)
2023-04-01 18:56:42.273 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 4: 0402 (Temperature Measurement)
2023-04-01 18:56:42.274 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 5: 0405 (Relative Humidity Measurement)
2023-04-01 18:56:42.274 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 6: fc57
2023-04-01 18:56:42.275 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 7: fc7c
2023-04-01 18:56:42.275 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 8: 042a
2023-04-01 18:56:42.275 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 9: fc7e
2023-04-01 18:56:42.276 Status: Zigate: [-] NEW OBJECT: 713a Cluster OUT Count: 04
2023-04-01 18:56:42.276 Status: Zigate: [-] NEW OBJECT: 713a Cluster Out 1: 0003 (Identify)
2023-04-01 18:56:42.277 Status: Zigate: [-] NEW OBJECT: 713a Cluster Out 2: 0019 (Over-the-Air Upgrade)
2023-04-01 18:56:42.277 Status: Zigate: [-] NEW OBJECT: 713a Cluster Out 3: 0020 (Poll Control)
2023-04-01 18:56:42.277 Status: Zigate: [-] NEW OBJECT: 713a Cluster Out 4: 0202 (Fan Control)
2023-04-01 18:56:43.093 Status: Zigate: [0] NEW OBJECT: 713a Model Name: VINDSTYRKA
2023-04-01 18:56:43.093 Status: Zigate: [0] NEW OBJECT: 713a Manufacturer Name: IKEA of Sweden
2023-04-01 18:56:43.094 Status: Zigate: [None] NEW OBJECT: 713a Request Node Descriptor
Pas d'erreur pour le moment après 20 mn de fonctionnement.
En PJ la liste des objets RAW.
Et un grand merci pour le coup de main.
export-2.json.zip
(7.11 Kio) Téléchargé 51 fois
Dernière modification par Keros le 01 avr. 2023, 20:59, modifié 1 fois.
NUC NiPoGi CK10 / i5-12450H CPU 4,4GHz / RAM 32 Go
Ubuntu Server 22.04.4 LTS
Domoticz 2025.1 beta build 16729
Zigbee : ConbeeIII 0x26550900 / Zigbee2MQTT 2.6.2-dev
Zwave : Aeon labs Gen5+ / zwave-js-ui 9.28.0 zwave-js: 14.3.7
Peux-tu activer 'trackZclClusters' dans Tools > Debug ?
Screenshot 2023-04-01 at 21.05.30.png (135.25 Kio) Consulté 655 fois
tu laisses tourner 30 minutes , et tu me droppes les logs.
La frequence de reporting peut-etre liée à 2 choses, la variation de valeur ou la frequence demandée
tu vas voir apparaître une ligne du genre
2023-04-01 21:09:10,778 INFO : [ZigpyForwarder_3 1715] Attribute Report | 7feb | 01 | 0b04 | Electrical Measurement | 050b | ActivePower | 29 | 0002 | Connected outlet | None | None | ['check_store_value', 'upd_domo_device'] | None | 11.0
fjum
Message par fjum »
C'est fait.
En attendant les 30 minutes, voici les logs actuels. Très rapprochés. Mais ça correspond à chaque fois à un changement de mesure.
2023-04-01 21:08:25.124 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;64.0;1
2023-04-01 21:08:25.130 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 64.0:1
2023-04-01 21:08:30.223 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;65.0;1
2023-04-01 21:08:30.227 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 65.0:1
2023-04-01 21:08:31.230 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;64.0;1
2023-04-01 21:08:31.235 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 64.0:1
2023-04-01 21:08:55.675 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;65.0;1
2023-04-01 21:08:55.681 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 65.0:1
2023-04-01 21:09:09.937 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;64.0;1
2023-04-01 21:09:09.943 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 64.0:1
2023-04-01 21:09:10.946 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_PM25) 5.0:5.0
2023-04-01 21:09:13.250 MQTT Auto Discovery: Light/Switch/Switch (nodeID_5_motion_sensor_status)
2023-04-01 21:09:15.282 Zigate: UpdateDevice - (Zigate - Lux salon) 10:10
2023-04-01 21:09:18.055 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;65.0;1
2023-04-01 21:09:18.060 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 65.0:1
2023-04-01 21:09:19.063 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;64.0;1
2023-04-01 21:09:19.067 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 64.0:1
2023-04-01 21:09:31.312 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_PM25) 4.0:4.0
2023-04-01 21:09:32.723 Zigate: UpdateDevice - (Zigate - Hue Lux 2) 0:0
2023-04-01 21:09:41.493 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;65.0;1
2023-04-01 21:09:41.499 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 65.0:1
2023-04-01 21:09:43.510 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;64.0;1
2023-04-01 21:09:43.515 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 64.0:1
2023-04-01 21:09:46.587 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Voc) 0:258.0
2023-04-01 21:10:00.246 Zigate: UpdateDevice - (Zigate - Lux sam) 7:7
2023-04-01 21:10:04.890 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Voc) 0:253.0
2023-04-01 21:10:14.062 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;65.0;1
2023-04-01 21:10:14.067 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 65.0:1
2023-04-01 21:10:25.251 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;66.0;1
2023-04-01 21:10:25.256 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 66.0:1
2023-04-01 21:10:29.334 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;65.0;1
2023-04-01 21:10:29.339 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 65.0:1
2023-04-01 21:10:33.367 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;64.0;1
2023-04-01 21:10:33.371 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 64.0:1
2023-04-01 21:10:43.546 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_PM25) 5.0:5.0
2023-04-01 21:10:47.629 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;65.0;1
2023-04-01 21:10:47.635 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 65.0:1
2023-04-01 21:10:53.726 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;64.0;1
2023-04-01 21:10:53.732 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 64.0:1
2023-04-01 21:11:07.990 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;65.0;1
2023-04-01 21:11:07.995 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 65.0:1
2023-04-01 21:11:11.069 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Voc) 0:258.0
2023-04-01 21:11:13.084 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;64.0;1
2023-04-01 21:11:13.090 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 64.0:1
2023-04-01 21:11:19.186 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_PM25) 4.0:4.0
2023-04-01 21:11:24.278 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_PM25) 5.0:5.0
2023-04-01 21:11:25.285 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum) 0:22.0;65.0;1
2023-04-01 21:11:25.291 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi) 65.0:1
Dernière modification par Keros le 01 avr. 2023, 21:49, modifié 1 fois.
Raison : Ajout des balises code
j'ai besoin des logs du plugin pour comprendre,
fjum
Message par fjum »
J'ai activé 'trackZclClusters'. J'ai attendu toute la soirée mais je n'ai rien eu dans les logs.
Dernière modification par Keros le 02 avr. 2023, 09:54, modifié 1 fois.
On parle des logs du Plugin qui se trouvent dans Logs/PluginZigbee-xx.log
Bibi49
Message par Bibi49 »
Je pense que pipiche voudrait les logs qui sont dans le plugin Outil/outils/Logs du plugin ;)
RPI 2 -> Bullseye Lite
DomoticZ -> 2024.7
RFXCom 433E -> Pro1 1041
PiTInfo v1.4
USB->ùSD = Rpi-clones
fjum
Message par fjum »
Donc, j'ai passé toute la soirée à regarder les logs Domoticz comme un con ... :shock:
En PJ le fichier compressé
_PluginZigbee_74.log.zip
(101.49 Kio) Téléchargé 50 fois
Merci ...
peux-tu récupérer la dernière version 6.4.406
ensuite tu relances, et on voit comment ça évolue.
j'ai changé le reporting minimum à pas plus de 1 chaque minute.
Drop moi le fichier de log après que je vérifie également comment ca se comporte
fjum
Message par fjum »
Comme convenu, en PJ le fichier de logs.
Les remontées de l'humidité se font à intervalle régulier.
Mais les remontées de Temp, PM25 et VOC sont très rares, et il y a un décalage temporel entre ce qu'affiche le capteur et ce qu'affiche le device.
_PluginZigbee_74-2.log.zip
(157.02 Kio) Téléchargé 46 fois
