Re: Capteur de qualité de l'air IKEA VINDSTYRKA
Publié : 01 avr. 2023, 19:12
5 devices créés : Temp+Hum, Temp, Hum, PM25, Voc
les logs domoticz :
Les updateDevice se font quasiment toutes les 30 secondes. ça fait beaucoup mais c'est peut-être normal.
Les logs domoticz à l'appairage :
Pas d'erreur pour le moment après 20 mn de fonctionnement.
En PJ la liste des objets RAW.
Et un grand merci pour le coup de main.
les logs domoticz :
2023-04-01 18:59:06.796 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum-943469fffec1dd42-01) 0:24.0;49.0;1
2023-04-01 18:59:06.803 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi-943469fffec1dd42-01) 49.0:1
2023-04-01 18:59:13.959 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum-943469fffec1dd42-01) 0:23.0;49.0;1
2023-04-01 18:59:13.965 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp-943469fffec1dd42-01) 23.0:23.0
2023-04-01 18:59:17.986 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Temp+Hum-943469fffec1dd42-01) 0:23.0;50.0;1
2023-04-01 18:59:17.991 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Humi-943469fffec1dd42-01) 50.0:1
2023-04-01 18:59:18.026 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Voc-943469fffec1dd42-01) 0:97.0
2023-04-01 18:59:20.054 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_PM25-943469fffec1dd42-01) 5.0:5.0
2023-04-01 18:59:23.122 Zigate: UpdateDevice - (Zigate - VINDSTYRKA_Voc-943469fffec1dd42-01) 0:99.0Les logs domoticz à l'appairage :
2023-04-01 18:56:41.733 Status: Zigate: [None] NEW OBJECT: 713a None
2023-04-01 18:56:42.002 Status: Zigate: [-] NEW OBJECT: 713a Active Endpoint Response Ep: 01 LQI: 96
2023-04-01 18:56:42.003 Status: Zigate: [-] NEW OBJECT: 713a Active Endpoint Response Ep: f2 LQI: 96
2023-04-01 18:56:42.007 Status: Zigate: [-] NEW OBJECT: 713a Request Simple Descriptor for Ep: 01
2023-04-01 18:56:42.270 Status: Zigate: [-] NEW OBJECT: 713a Simple Descriptor Response EP: 0x01 LQI: 92
2023-04-01 18:56:42.271 Status: Zigate: [-] NEW OBJECT: 713a ProfileID 0104
2023-04-01 18:56:42.271 Status: Zigate: [-] NEW OBJECT: 713a ZDeviceID 0302
2023-04-01 18:56:42.272 Status: Zigate: [-] NEW OBJECT: 713a Application Version 0001
2023-04-01 18:56:42.272 Status: Zigate: [-] NEW OBJECT: 713a Cluster IN Count: 09
2023-04-01 18:56:42.272 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 1: 0000 (Basic)
2023-04-01 18:56:42.273 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 2: 0003 (Identify)
2023-04-01 18:56:42.273 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 3: 0004 (Groups)
2023-04-01 18:56:42.273 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 4: 0402 (Temperature Measurement)
2023-04-01 18:56:42.274 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 5: 0405 (Relative Humidity Measurement)
2023-04-01 18:56:42.274 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 6: fc57
2023-04-01 18:56:42.275 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 7: fc7c
2023-04-01 18:56:42.275 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 8: 042a
2023-04-01 18:56:42.275 Status: Zigate: [-] NEW OBJECT: 713a Cluster In 9: fc7e
2023-04-01 18:56:42.276 Status: Zigate: [-] NEW OBJECT: 713a Cluster OUT Count: 04
2023-04-01 18:56:42.276 Status: Zigate: [-] NEW OBJECT: 713a Cluster Out 1: 0003 (Identify)
2023-04-01 18:56:42.277 Status: Zigate: [-] NEW OBJECT: 713a Cluster Out 2: 0019 (Over-the-Air Upgrade)
2023-04-01 18:56:42.277 Status: Zigate: [-] NEW OBJECT: 713a Cluster Out 3: 0020 (Poll Control)
2023-04-01 18:56:42.277 Status: Zigate: [-] NEW OBJECT: 713a Cluster Out 4: 0202 (Fan Control)
2023-04-01 18:56:43.093 Status: Zigate: [0] NEW OBJECT: 713a Model Name: VINDSTYRKA
2023-04-01 18:56:43.093 Status: Zigate: [0] NEW OBJECT: 713a Manufacturer Name: IKEA of Sweden
2023-04-01 18:56:43.094 Status: Zigate: [None] NEW OBJECT: 713a Request Node DescriptorPas d'erreur pour le moment après 20 mn de fonctionnement.
