[Résolu] Probléme passage vers stable7
Matthias
Re: [Résolu] Probléme passage vers stable7
Message par Matthias »
Je suis en version 2023.2 fraichement installée et j'essaie péniblement d'installer le plugin ZigbeeForDomoticz.
J'obtiens ce message d'erreur que je ne sais pas interpreter. J'ai testé les solutions proposées dans ce post sans succès.
Quelqu'un peut il m'aider ?
Merci d'avance.
2023-11-12 09:56:32.398 Status: ZigbeeForDomoticz: Entering work loop.
2023-11-12 09:56:32.398 Status: ZigbeeForDomoticz: Started.
2023-11-12 09:56:34.618 Status: ZigbeeForDomoticz: Initialized version 7.1, author 'pipiche38'
2023-11-12 09:56:34.621 Status: ZigbeeForDomoticz: Zigbee for Domoticz plugin starting
2023-11-12 09:56:34.621 Status: ZigbeeForDomoticz: Z4D plugin requires python3 3.8 or above and you are running 3.9
2023-11-12 09:56:34.621 Status: ZigbeeForDomoticz: Checking Python modules /home/diaz/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2023-11-12 09:56:36.064 ZigbeeForDomoticz: load PluginConf
2023-11-12 09:56:36.067 ZigbeeForDomoticz: Loading PluginConf - from Domoticz sqlite Db
2023-11-12 09:56:36.067 ZigbeeForDomoticz: /home/diaz/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-03.json timestamp is 1699777102.533214
2023-11-12 09:56:36.067 ZigbeeForDomoticz: Dz PluginConf is older than Json Dz: 0 Json: 1699777102.533214
2023-11-12 09:56:36.070 ZigbeeForDomoticz: Installing plugin custom page /home/diaz/domoticz/www/templates/ZigbeeForDomoticz.html
2023-11-12 09:56:36.071 ZigbeeForDomoticz: Starting LoggingManagement thread
2023-11-12 09:56:36.071 ZigbeeForDomoticz: zigpy_login_mode(30)
2023-11-12 09:56:36.075 ZigbeeForDomoticz: start_logging_thread
2023-11-12 09:56:36.075 ZigbeeForDomoticz: logging_thread - listening
2023-11-12 09:56:36.070 Status: ZigbeeForDomoticz: filename set to /home/diaz/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-03.json
2023-11-12 09:56:36.070 Status: ZigbeeForDomoticz: pluginHome set to /home/diaz/domoticz/plugins/Domoticz-Zigbee
2023-11-12 09:56:36.070 Status: ZigbeeForDomoticz: homedirectory set to /home/diaz/domoticz/plugins/Domoticz-Zigbee
2023-11-12 09:56:36.070 Status: ZigbeeForDomoticz: pluginData set to /home/diaz/domoticz/plugins/Domoticz-Zigbee/Data
2023-11-12 09:56:36.070 Status: ZigbeeForDomoticz: pluginConfig set to /home/diaz/domoticz/plugins/Domoticz-Zigbee/Conf
2023-11-12 09:56:36.070 Status: ZigbeeForDomoticz: pluginOTAFirmware set to /home/diaz/domoticz/plugins/Domoticz-Zigbee/OTAFirmware
2023-11-12 09:56:36.070 Status: ZigbeeForDomoticz: pluginReports set to /home/diaz/domoticz/plugins/Domoticz-Zigbee/Reports
2023-11-12 09:56:36.070 Status: ZigbeeForDomoticz: pluginWWW set to /home/diaz/domoticz/plugins/Domoticz-Zigbee/www
2023-11-12 09:56:36.070 Status: ZigbeeForDomoticz: pluginLogs set to /home/diaz/domoticz/plugins/Domoticz-Zigbee/Logs
2023-11-12 09:56:36.070 Status: ZigbeeForDomoticz: expJsonDatabase set to 0
2023-11-12 09:56:36.076 Status: ZigbeeForDomoticz: Please watch plugin log into /home/diaz/domoticz/plugins/Domoticz-Zigbee/Logs/PluginZigbee_03.log
2023-11-12 09:56:36.090 Status: ZigbeeForDomoticz: Zigbee for Domoticz (z4d) plugin stable7-7.1.004 started
2023-11-12 09:56:36.115 Status: ZigbeeForDomoticz: Loading ZCL Cluster definitions
2023-11-12 09:56:36.119 Status: ZigbeeForDomoticz: - ZCL Cluster 0000 - (V1) Basic loaded
2023-11-12 09:56:36.120 Status: ZigbeeForDomoticz: - ZCL Cluster 0001 - (V1) Power loaded
2023-11-12 09:56:36.122 Status: ZigbeeForDomoticz: - ZCL Cluster 0002 - (V1) Device Temperature Configuration loaded
2023-11-12 09:56:36.123 Status: ZigbeeForDomoticz: - ZCL Cluster 0003 - (V1) Identify loaded
2023-11-12 09:56:36.124 Status: ZigbeeForDomoticz: - ZCL Cluster 0004 - (V1) Groups loaded
2023-11-12 09:56:36.125 Status: ZigbeeForDomoticz: - ZCL Cluster 0005 - (V1) Scenes loaded
2023-11-12 09:56:36.127 Status: ZigbeeForDomoticz: - ZCL Cluster 0006 - (V1) On/Off loaded
2023-11-12 09:56:36.128 Status: ZigbeeForDomoticz: - ZCL Cluster 0007 - (V1) On/Off Switch Configuration loaded
2023-11-12 09:56:36.129 Status: ZigbeeForDomoticz: - ZCL Cluster 0008 - (V1) Level loaded
2023-11-12 09:56:36.130 Status: ZigbeeForDomoticz: - ZCL Cluster 0009 - (V1) Alarms loaded
2023-11-12 09:56:36.132 Status: ZigbeeForDomoticz: - ZCL Cluster 000a - (V1) Time loaded
2023-11-12 09:56:36.133 Status: ZigbeeForDomoticz: - ZCL Cluster 000d - (V1) Analog Output loaded
2023-11-12 09:56:36.135 Status: ZigbeeForDomoticz: - ZCL Cluster 000f - (V1) Binary Input loaded
2023-11-12 09:56:36.136 Status: ZigbeeForDomoticz: - ZCL Cluster 0013 - (V1) Multistate Output loaded
2023-11-12 09:56:36.137 Status: ZigbeeForDomoticz: - ZCL Cluster 0019 - (V1) OTA Upgrade loaded
2023-11-12 09:56:36.139 Status: ZigbeeForDomoticz: - ZCL Cluster 0020 - (V1) Poll Control loaded
2023-11-12 09:56:36.140 Status: ZigbeeForDomoticz: - ZCL Cluster 0102 - (V1) Window Covering loaded
2023-11-12 09:56:36.141 Status: ZigbeeForDomoticz: - ZCL Cluster 0202 - (V1) Fan Control loaded
2023-11-12 09:56:36.143 Status: ZigbeeForDomoticz: - ZCL Cluster 0204 - (V1) Thermostat User Interface Configuration loaded
2023-11-12 09:56:36.144 Status: ZigbeeForDomoticz: - ZCL Cluster 0300 - (V1) Color Control loaded
2023-11-12 09:56:36.146 Status: ZigbeeForDomoticz: - ZCL Cluster 0301 - (V1) Ballast Configuration loaded
2023-11-12 09:56:36.147 Status: ZigbeeForDomoticz: - ZCL Cluster 0400 - (V1) Illuminance Level Sensing loaded
2023-11-12 09:56:36.148 Status: ZigbeeForDomoticz: - ZCL Cluster 0402 - (V1) Temperature Measurement loaded
2023-11-12 09:56:36.150 Status: ZigbeeForDomoticz: - ZCL Cluster 0403 - (V1) Pressure Measurement loaded
2023-11-12 09:56:36.151 Status: ZigbeeForDomoticz: - ZCL Cluster 0405 - (V1) Relative Humidity Measurement loaded
2023-11-12 09:56:36.153 Status: ZigbeeForDomoticz: - ZCL Cluster 0406 - (V1) Occupancy Sensing loaded
2023-11-12 09:56:36.158 Status: ZigbeeForDomoticz: - ZCL Cluster 0700 - (V1) Price loaded
2023-11-12 09:56:36.161 Status: ZigbeeForDomoticz: - ZCL Cluster 0702 - (V1) Metering (Smart Energy) loaded
2023-11-12 09:56:36.162 Status: ZigbeeForDomoticz: - ZCL Cluster 0b01 - (V1) Meter Identification loaded
2023-11-12 09:56:36.165 Status: ZigbeeForDomoticz: - ZCL Cluster 0b04 - (V1) Electrical Measurement loaded
2023-11-12 09:56:36.167 Status: ZigbeeForDomoticz: - ZCL Cluster 0b05 - (V1) Diagnostics loaded
2023-11-12 09:56:36.168 Status: ZigbeeForDomoticz: - ZCL Cluster e000 - (V1) Tuya E000 Private Cluster loaded
2023-11-12 09:56:36.169 Status: ZigbeeForDomoticz: - ZCL Cluster e001 - (V1) Tuya E001 Private Cluster loaded
2023-11-12 09:56:36.170 Status: ZigbeeForDomoticz: - ZCL Cluster e002 - (V1) Tuya E002 Private Cluster loaded
2023-11-12 09:56:36.172 Status: ZigbeeForDomoticz: - ZCL Cluster fcc0 - (V1) LUMI Private Cluster loaded
2023-11-12 09:56:36.174 Status: ZigbeeForDomoticz: - ZCL Cluster ff66 - (V1) Lixee Zlinky private cluster loaded
2023-11-12 09:56:36.180 Status: ZigbeeForDomoticz: DeviceConf loaded - 16 confs loaded
2023-11-12 09:56:36.187 Status: ZigbeeForDomoticz: Local-Device conf loaded - 21 confs loaded
2023-11-12 09:56:36.647 Status: ZigbeeForDomoticz: Certified Devices loaded - 532 confs loaded
2023-11-12 09:56:36.648 Status: ZigbeeForDomoticz: load ListOfDevice
2023-11-12 09:56:36.650 Status: ZigbeeForDomoticz: 0 Entries loaded from /home/diaz/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-3.txt
2023-11-12 09:56:36.655 Status: ZigbeeForDomoticz: Transport mode: ZigpyZNP
2023-11-12 09:56:36.916 Error: ZigbeeForDomoticz: Call to function 'onStart' failed, exception details:
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: Traceback (most recent call last):
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: File "/home/diaz/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1563, in onStart
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: _plugin.onStart()
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: File "/home/diaz/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 593, in onStart
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: from zigpy.config import (CONF_DEVICE, CONF_DEVICE_PATH,
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: File "/usr/local/lib/python3.9/dist-packages/zigpy/config/__init__.py", line 34, in <module>
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: from zigpy.config.validators import (
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: File "/usr/local/lib/python3.9/dist-packages/zigpy/config/validators.py", line 9, in <module>
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: import zigpy.zdo.types as zdo_t
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: File "/usr/local/lib/python3.9/dist-packages/zigpy/zdo/__init__.py", line 10, in <module>
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: import zigpy.util
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: File "/usr/local/lib/python3.9/dist-packages/zigpy/util.py", line 15, in <module>
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: from cryptography.hazmat.primitives.ciphers import Cipher
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: File "/usr/local/lib/python3.9/dist-packages/cryptography/hazmat/primitives/ciphers/__init__.py", line 11, in <module>
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: from cryptography.hazmat.primitives.ciphers.base import (
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: File "/usr/local/lib/python3.9/dist-packages/cryptography/hazmat/primitives/ciphers/base.py", line 10, in <module>
2023-11-12 09:56:36.922 Error: ZigbeeForDomoticz: from cryptography.exceptions import (
2023-11-12 09:56:36.923 Error: ZigbeeForDomoticz: File "/usr/local/lib/python3.9/dist-packages/cryptography/exceptions.py", line 9, in <module>
2023-11-12 09:56:36.923 Error: ZigbeeForDomoticz: from cryptography.hazmat.bindings._rust import exceptions as rust_exceptions
2023-11-12 09:56:36.923 Error: ZigbeeForDomoticz: ImportError: PyO3 modules may only be initialized once per interpreter process
Cozytouch_v3
Roborock S6
H801 LED
Onkyo AV
RFXCOM (Somfy)
ESPeasy (SonOff)
Zigbee2mqtt (Aqara, Mija, Xiaomi, IKEA, Honeywell)
Broadlink
Foscam - Reolink
as-tu essayé ca ?
sudo python3 -m pip install cryptography==41.0.01 --upgrade
Source: https://www.domoticz.com/forum/viewtopic.php?t=40417
Matthias
C'est très curieux, je n'ai que 2 plugins sur mon domoticz de test :
Broadlink et ZigbeeForDomoticz et je viens de remarquer que quand je désactive le plugin Broadlink, zigbeeForDomoticz fonctionne et évidemment quand Braodlink est activé ZigbeeForDomoticz ne fonctionne plus.
D'où peux venir ce problème svp ?
Cozytouch_v3
Roborock S6
H801 LED
Onkyo AV
RFXCOM (Somfy)
ESPeasy (SonOff)
Broadlink
Foscam - Reolink
vois mon post précédent et fais la manip demandée
Matthias
Déjà fait avant de poster. J'ai suivi tout le post à la lettre !
Cozytouch_v3
Roborock S6
H801 LED
Onkyo AV
RFXCOM (Somfy)
ESPeasy (SonOff)
Broadlink
Foscam - Reolink
Et c’est quoi le retour de la commande?
Matthias
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting cryptography==41.0.01
Downloading https://www.piwheels.org/simple/cryptog ... armv7l.whl (2.1 MB)
|████████████████████████████████| 2.1 MB 542 kB/s
Requirement already satisfied: cffi>=1.12 in /usr/local/lib/python3.9/dist-packages (from cryptography==41.0.01) (1.16.0)
Requirement already satisfied: pycparser in /usr/local/lib/python3.9/dist-packages (from cffi>=1.12->cryptography==41.0.01) (2.21)
Installing collected packages: cryptography
Attempting uninstall: cryptography
Found existing installation: cryptography 41.0.5
Uninstalling cryptography-41.0.5:
Successfully uninstalled cryptography-41.0.5
Successfully installed cryptography-41.0.1
Cozytouch_v3
Roborock S6
H801 LED
Onkyo AV
RFXCOM (Somfy)
ESPeasy (SonOff)
Broadlink
Foscam - Reolink
désolé, autnta pour moi.
sudo python3 pip install cryptography==40.0.2 --upgrade
Matthias
c'est plutôt ca :
sudo python3 -m pip install cryptography==40.0.2 --upgrade
et le résultat :
Collecting cryptography==40.0.2
Downloading https://www.piwheels.org/simple/cryptog ... armv7l.whl (1.5 MB)
|████████████████████████████████| 1.5 MB 502 kB/s
Requirement already satisfied: cffi>=1.12 in /usr/local/lib/python3.9/dist-packages (from cryptography==40.0.2) (1.16.0)
Requirement already satisfied: pycparser in /usr/local/lib/python3.9/dist-packages (from cffi>=1.12->cryptography==40.0.2) (2.21)
Found existing installation: cryptography 41.0.1
Uninstalling cryptography-41.0.1:
Successfully uninstalled cryptography-41.0.1
Successfully installed cryptography-40.0.2
Cozytouch_v3
Roborock S6
H801 LED
Onkyo AV
RFXCOM (Somfy)
ESPeasy (SonOff)
Broadlink
Foscam - Reolink
Matthias
Je viens de trouver la solution.
Je fais une petite synthèse :
Domoticz 2023.2 sur rpi3b+
Clef zigbee CC2531
Plugin Broadlink installé (https://github.com/zak-45/Broadlink-Domoticz-plugin)
Plugin ZigbeeForDomoticz installé
Problématique :
Quand Broadlink est activé ZigbeeForDomoticz ne démarre pas.
Solution :
Précisez l'IP exact du domoticz dans API base url dans les paramètres de ZigbeeForDomoticz et non 127.0.0.1:8080
Dès fois il en faut pas chercher trop loin.
Merci Pipiche pour ton aide un dimanche matin.
Cozytouch_v3
Roborock S6
H801 LED
Onkyo AV
RFXCOM (Somfy)
ESPeasy (SonOff)
Broadlink
Foscam - Reolink
