Erreur - zigate import z4d_certified_devices stable7
Re: Erreur - zigate import z4d_certified_devices stable7
Redémarre DomoticZ et poste-nous les logs de démarrage stp.
log du démarrage
Merci.
Merci.
2024-02-06 20:37:10.920 Sunrise: 08:14:00 SunSet: 17:55:00
2024-02-06 20:37:10.920 Day length: 09:41:00 Sun at south: 13:05:00
2024-02-06 20:37:10.920 Civil twilight start: 07:41:00 Civil twilight end: 18:29:00
2024-02-06 20:37:10.920 Nautical twilight start: 07:03:00 Nautical twilight end: 19:06:00
2024-02-06 20:37:10.920 Astronomical twilight start: 06:26:00 Astronomical twilight end: 19:43:00
2024-02-06 20:37:10.975 Active notification Subsystems: telegram (1/13)
2024-02-06 20:37:10.980 Starting shared server on: :::6144
2024-02-06 20:37:10.893 Status: Domoticz V2024.4 (c)2012-2024 GizMoCuz
2024-02-06 20:37:10.893 Status: Build Hash: 731719420, Date: 2024-01-30 09:16:34
2024-02-06 20:37:10.893 Status: Startup Path: /home/user/domoticz/
2024-02-06 20:37:10.973 Status: PluginSystem: Started, Python version '3.9.5', 3 plugin definitions loaded.
2024-02-06 20:37:10.976 Status: WebServer(HTTP) started on address: :: with port 7080
2024-02-06 20:37:10.979 Status: WebServer(SSL) started on address: :: with port 7443
2024-02-06 20:37:10.979 Status: Camera: settings (re)loaded
2024-02-06 20:37:10.980 Status: TCPServer: shared server started...
2024-02-06 20:37:10.980 Status: RxQueue: queue worker started...
2024-02-06 20:37:12.981 zigate: Worker thread started.
2024-02-06 20:37:12.981 Status: zigate: Started.
2024-02-06 20:37:12.981 Status: TeleinfoUSB: Teleinfo device uses serial port: /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0 at 1200 bauds
2024-02-06 20:37:12.981 Status: zigate: Entering work loop.
2024-02-06 20:37:13.011 deconz: Worker thread started.
2024-02-06 20:37:13.275 deconz: You are not using 127.0.0.1 as IP, so I suppose deCONZ and Domoticz aren't on same machine
2024-02-06 20:37:13.275 deconz: Taking 192.168.1.125 as Domoticz IP
2024-02-06 20:37:13.275 deconz: Adding banned device : 00:15:8d:00:02:36:c2:3f-01-0500
2024-02-06 20:37:13.010 Status: TeleinfoUSB: CRC checks will be performed on incoming data
2024-02-06 20:37:13.011 Status: deconz: Started.
2024-02-06 20:37:13.011 Status: NotificationSystem: thread started...
2024-02-06 20:37:13.011 Status: EventSystem: reset all events...
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_camera.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_tv_salon_on.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_simple.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_bebe.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_salle_de_bain_disco.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_salle_de_bain_mirroir.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_salle_de_bain_prise.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_cuisine.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_dyson.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_canape.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_ventilateur.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_fenetre.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_test_couleur.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_buanderie_mirroir.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_buanderie.lua
2024-02-06 20:37:13.013 Status: EventSystem: reset all device statuses...
2024-02-06 20:37:13.013 Status: deconz: Entering work loop.
2024-02-06 20:37:13.191 Status: rflink: Using serial port: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
2024-02-06 20:37:13.239 Status: Python EventSystem: Initializing event module.
2024-02-06 20:37:13.240 Status: EventSystem: Queue thread started...
2024-02-06 20:37:13.249 Status: EventSystem: Started
2024-02-06 20:37:13.263 Status: TeleinfoUSB: CRC check mode set to 1
2024-02-06 20:37:13.273 Status: deconz: Initialized version 1.0.29, author 'Smanar'
2024-02-06 20:37:13.276 Status: deconz: Plugin custom pages in date
2024-02-06 20:37:13.426 Status: PluginSystem: 2 plugins started.
2024-02-06 20:37:13.982 Status: 3D: Connecting to 192.168.1.123:1883
2024-02-06 20:37:13.982 Status: 3D: enabled TLS mode
2024-02-06 20:37:13.079 Error: zigate: (Zigate) failed to load 'plugin.py', Python Path used was '/home/user/domoticz/plugins/Domoticz-Zigbee/:/usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload:/usr/local/lib/python3.9/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.9/dist-packages'.
2024-02-06 20:37:13.090 Error: zigate: Traceback (most recent call last):
2024-02-06 20:37:13.090 Error: zigate: File "/home/user/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 103, in <module>
2024-02-06 20:37:13.090 Error: zigate: import z4d_certified_devices
2024-02-06 20:37:13.090 Error: zigate: ModuleNotFoundError: No module named 'z4d_certified_devices'
2024-02-06 20:37:14.083 Status: 3D: connected to: 192.168.1.123:1883
2024-02-06 20:37:14.113 Status: rflink: Controller Initialized!...
2024-02-06 20:37:14.184 Status: 3D: Subscribed
2024-02-06 20:37:14.188 Status: rflink: RFLink Detected, Version: 1.1 Revision: 48 Build: 4
2024-02-06 20:37:19.755 rflink: General/kWh (owl_salon)
2024-02-06 20:37:20.685 rflink: General/kWh (owl_garage)
2024-02-06 20:37:23.101 deconz: ### Request config
2024-02-06 20:37:23.101 Error: deconz: Your python version is missing the requests library
2024-02-06 20:37:23.101 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-06 20:37:31.754 rflink: General/kWh (owl_salon)
2024-02-06 20:37:33.078 deconz: ### Request config
2024-02-06 20:37:33.078 Error: deconz: Your python version is missing the requests library
2024-02-06 20:37:33.078 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-06 20:37:43.056 deconz: ### Request config
2024-02-06 20:37:43.056 Error: deconz: Your python version is missing the requests library
2024-02-06 20:37:43.056 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip installrequests
2024-02-06 20:38:21.258 Error: zigate hardware (9) thread seems to have ended unexpectedly
Je vois des erreurs pour DeConz. Tu n'as pas Deconz et ZigBeeForDomoticZ qui essayent de fonctionner en même temps sur un même coordinateur ?
Sinon, désolé, je cale. Je ne vois pas pourquoi z4d_certified_devices n'est pas trouvé alors qu'il a été installé juste avant.
Attends le retour de Pipiche.
Merci d'avoir regardé.
Jai une clé Zigate et une conbee.
et ca marche avec le plug in 5 RAS...
par contre avec le 7 impossible, z4d_certified_devices en PLS...
J'ai essayer
sudo python3 -m pip install git+https://github.com/zigbeefordomoticz/z4 ... ed-devices
Pas mieux...
Pas mieux...
root@domotique:/home/user/domoticz/plugins/Domoticz-Zigbee# sudo python3 -m pip install -r requirements.txt --upgrade
Requirement already satisfied: zigpy==0.59.0 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 1)) (0.59.0)
Requirement already satisfied: zigpy_znp==0.11.6 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 2)) (0.11.6)
Requirement already satisfied: zigpy_deconz==0.21.1 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 3)) (0.21.1)
Requirement already satisfied: bellows==0.36.8 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 4)) (0.36.8)
Requirement already satisfied: zigpy-cli==1.0.4 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 5)) (1.0.4)
Requirement already satisfied: dnspython==2.3.0 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 6)) (2.3.0)
Requirement already satisfied: pyserial>=3.5 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 7)) (3.5)
Requirement already satisfied: z4d-certified-devices in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 8)) (3.212)
Collecting z4d-certified-devices (from -r requirements.txt (line 8))
Downloading z4d_certified_devices-3.213-py3-none-any.whl.metadata (36 kB)
Requirement already satisfied: charset-normalizer==2.0.11 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 9)) (2.0.11)
Requirement already satisfied: distro in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 10)) (1.9.0)
Requirement already satisfied: attrs in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (23.2.0)
Requirement already satisfied: aiohttp in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (3.9.3)
Requirement already satisfied: aiosqlite>=0.16.0 in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (0.19.0)
Requirement already satisfied: async-timeout in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (4.0.3)
Requirement already satisfied: crccheck in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (1.3.0)
Requirement already satisfied: cryptography in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (42.0.2)
Requirement already satisfied: voluptuous in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (0.14.2)
Requirement already satisfied: typing-extensions in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (4.9.0)
Requirement already satisfied: pyserial-asyncio in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (0.6)
Requirement already satisfied: importlib-resources in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (6.1.1)
Requirement already satisfied: coloredlogs in /usr/local/lib/python3.8/dist-packages (from zigpy_znp==0.11.6->-r requirements.txt (line 2)) (15.0.1)
Requirement already satisfied: jsonschema in /usr/local/lib/python3.8/dist-packages (from zigpy_znp==0.11.6->-r requirements.txt (line 2)) (4.21.1)
Requirement already satisfied: click in /usr/local/lib/python3.8/dist-packages (from bellows==0.36.8->-r requirements.txt (line 4)) (8.1.7)
Requirement already satisfied: click-log>=0.2.1 in /usr/local/lib/python3.8/dist-packages (from bellows==0.36.8->-r requirements.txt (line 4)) (0.4.0)
Requirement already satisfied: pure-pcapy3==1.0.1 in /usr/local/lib/python3.8/dist-packages (from bellows==0.36.8->-r requirements.txt (line 4)) (1.0.1)
Requirement already satisfied: scapy in /usr/local/lib/python3.8/dist-packages (from zigpy-cli==1.0.4->-r requirements.txt (line 5)) (2.5.0)
Requirement already satisfied: zigpy-xbee>=0.18.0 in /usr/local/lib/python3.8/dist-packages (from zigpy-cli==1.0.4->-r requirements.txt (line 5)) (0.19.1)
Requirement already satisfied: zigpy-zigate>=0.11.0 in /usr/local/lib/python3.8/dist-packages (from zigpy-cli==1.0.4->-r requirements.txt (line 5)) (0.11.0)
Requirement already satisfied: setuptools in /usr/local/lib/python3.8/dist-packages (from pure-pcapy3==1.0.1->bellows==0.36.8->-r requirements.txt (line 4)) (69.0.3)
Requirement already satisfied: gpiozero in /usr/local/lib/python3.8/dist-packages (from zigpy-zigate>=0.11.0->zigpy-cli==1.0.4->-r requirements.txt (line 5)) (2.0)
Requirement already satisfied: pyusb>=1.1.0 in /usr/local/lib/python3.8/dist-packages (from zigpy-zigate>=0.11.0->zigpy-cli==1.0.4->-r requirements.txt (line 5)) (1.2.1)
Requirement already satisfied: aiosignal>=1.1.2 in /usr/local/lib/python3.8/dist-packages (from aiohttp->zigpy==0.59.0->-r requirements.txt (line 1)) (1.3.1)
Requirement already satisfied: frozenlist>=1.1.1 in /usr/local/lib/python3.8/dist-packages (from aiohttp->zigpy==0.59.0->-r requirements.txt (line 1)) (1.4.1)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.8/dist-packages (from aiohttp->zigpy==0.59.0->-r requirements.txt (line 1)) (6.0.5)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.8/dist-packages (from aiohttp->zigpy==0.59.0->-r requirements.txt (line 1)) (1.9.4)
Requirement already satisfied: humanfriendly>=9.1 in /usr/local/lib/python3.8/dist-packages (from coloredlogs->zigpy_znp==0.11.6->-r requirements.txt (line 2)) (10.0)
Requirement already satisfied: cffi>=1.12 in /usr/local/lib/python3.8/dist-packages (from cryptography->zigpy==0.59.0->-r requirements.txt (line 1)) (1.16.0)
Requirement already satisfied: zipp>=3.1.0 in /usr/local/lib/python3.8/dist-packages (from importlib-resources->zigpy==0.59.0->-r requirements.txt (line 1)) (3.17.0)
Requirement already satisfied: jsonschema-specifications>=2023.03.6 in /usr/local/lib/python3.8/dist-packages (from jsonschema->zigpy_znp==0.11.6->-r requirements.txt (line 2)) (2023.12.1)
Requirement already satisfied: pkgutil-resolve-name>=1.3.10 in /usr/local/lib/python3.8/dist-packages (from jsonschema->zigpy_znp==0.11.6->-r requirements.txt (line 2)) (1.3.10)
Requirement already satisfied: referencing>=0.28.4 in /usr/local/lib/python3.8/dist-packages (from jsonschema->zigpy_znp==0.11.6->-r requirements.txt (line 2)) (0.33.0)
Requirement already satisfied: rpds-py>=0.7.1 in /usr/local/lib/python3.8/dist-packages (from jsonschema->zigpy_znp==0.11.6->-r requirements.txt (line 2)) (0.17.1)
Requirement already satisfied: pycparser in /usr/local/lib/python3.8/dist-packages (from cffi>=1.12->cryptography->zigpy==0.59.0->-r requirements.txt (line 1)) (2.21)
Requirement already satisfied: idna>=2.0 in /usr/local/lib/python3.8/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy==0.59.0->-r requirements.txt (line 1)) (3.6)
Requirement already satisfied: colorzero in /usr/local/lib/python3.8/dist-packages (from gpiozero->zigpy-zigate>=0.11.0->zigpy-cli==1.0.4->-r requirements.txt (line 5)) (2.0)
Downloading z4d_certified_devices-3.213-py3-none-any.whl (377 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 377.2/377.2 kB 4.9 MB/s eta 0:00:00
Installing collected packages: z4d-certified-devices
Attempting uninstall: z4d-certified-devices
Found existing installation: z4d-certified-devices 3.212
Uninstalling z4d-certified-devices-3.212:
Successfully uninstalled z4d-certified-devices-3.212
Successfully installed z4d-certified-devices-3.213
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
root@domotique:/home/user/domoticz/plugins/Domoticz-Zigbee# ^C
Re J'ai refais quelque essai KO...
je remet une copie du dossier du plugin en 5 et la ca marche...
Mais impossible de mettre le plugin en Stable 7...
Divers essai...
pip freeze
pip list
pip uninstall z4d_certified_devices
root@domotique:~# sudo python3 -m pip install z4d-certified-devices --upgrade
Requirement already satisfied: z4d-certified-devices in /usr/local/lib/python3.8/dist-packages (3.213)
root@domotique:~# pip freeze
aiohttp==3.9.3
aiosignal==1.3.1
aiosqlite==0.19.0
async-timeout==4.0.3
attrs==23.2.0
Automat==0.8.0
bellows==0.36.8
blinker==1.4
certifi==2019.11.28
cffi==1.16.0
chardet==3.0.4
click==8.1.7
click-log==0.4.0
cloud-init==23.3.3
colorama==0.4.3
coloredlogs==15.0.1
colorzero==2.0
command-not-found==0.3
configobj==5.0.6
constantly==15.1.0
crccheck==1.3.0
cryptography==42.0.2
dbus-python==1.2.16
distro==1.9.0
distro-info==0.23+ubuntu1.1
dnspython==2.3.0
entrypoints==0.3
frozenlist==1.4.1
gpiozero==2.0
httplib2==0.14.0
humanfriendly==10.0
hyperlink==19.0.0
idna==3.6
importlib-metadata==1.5.0
importlib-resources==6.1.1
incremental==16.10.1
Jinja2==2.10.1
jsonpatch==1.22
jsonpointer==2.0
jsonschema==4.21.1
jsonschema-specifications==2023.12.1
keyring==18.0.1
language-selector==0.1
launchpadlib==1.10.13
lazr.restfulclient==0.14.2
lazr.uri==1.0.3
MarkupSafe==1.1.0
more-itertools==4.2.0
multidict==6.0.5
netifaces==0.10.4
oauthlib==3.1.0
pexpect==4.6.0
pkgutil_resolve_name==1.3.10
pure-pcapy3==1.0.1
pyasn1==0.4.2
pyasn1-modules==0.2.1
pycparser==2.21
PyGObject==3.36.0
PyHamcrest==1.9.0
PyJWT==1.7.1
pymacaroons==0.13.0
PyNaCl==1.3.0
pyOpenSSL==19.0.0
pyrsistent==0.15.5
pyserial==3.5
pyserial-asyncio==0.6
python-apt==2.0.1+ubuntu0.20.4.1
python-debian==0.1.36+ubuntu1.1
pyusb==1.2.1
PyYAML==5.3.1
referencing==0.33.0
requests==2.22.0
requests-unixsocket==0.2.0
rpds-py==0.17.1
scapy==2.5.0
SecretStorage==2.3.1
service-identity==18.1.0
simplejson==3.16.0
six==1.14.0
sos==4.5.6
ssh-import-id==5.10
systemd-python==234
Twisted==18.9.0
typing_extensions==4.9.0
ubuntu-advantage-tools==8001
ufw==0.36
unattended-upgrades==0.1
urllib3==1.25.8
voluptuous==0.14.2
wadllib==1.3.3
yarl==1.9.4
z4d-certified-devices==3.213
zigpy==0.59.0
zigpy-cli==1.0.4
zigpy-deconz==0.21.1
zigpy-xbee==0.19.1
zigpy-zigate==0.11.0
zigpy-znp==0.11.6
zipp==3.17.0
zope.interface==4.7.1
root@domotique:~#
pip list
Package Version
aiohttp 3.9.3
aiosignal 1.3.1
aiosqlite 0.19.0
async-timeout 4.0.3
attrs 23.2.0
Automat 0.8.0
bellows 0.36.8
blinker 1.4
certifi 2019.11.28
cffi 1.16.0
chardet 3.0.4
charset-normalizer 2.0.11
click 8.1.7
click-log 0.4.0
cloud-init 23.3.3
colorama 0.4.3
coloredlogs 15.0.1
colorzero 2.0
command-not-found 0.3
configobj 5.0.6
constantly 15.1.0
crccheck 1.3.0
cryptography 42.0.2
dbus-python 1.2.16
distro 1.9.0
distro-info 0.23+ubuntu1.1
dnspython 2.3.0
entrypoints 0.3
frozenlist 1.4.1
gpiozero 2.0
httplib2 0.14.0
humanfriendly 10.0
hyperlink 19.0.0
idna 3.6
importlib-metadata 1.5.0
importlib-resources 6.1.1
incremental 16.10.1
Jinja2 2.10.1
jsonpatch 1.22
jsonpointer 2.0
jsonschema 4.21.1
jsonschema-specifications 2023.12.1
keyring 18.0.1
language-selector 0.1
launchpadlib 1.10.13
lazr.restfulclient 0.14.2
lazr.uri 1.0.3
MarkupSafe 1.1.0
more-itertools 4.2.0
multidict 6.0.5
netifaces 0.10.4
oauthlib 3.1.0
pexpect 4.6.0
pip 24.0
pkgutil_resolve_name 1.3.10
pure-pcapy3 1.0.1
pyasn1 0.4.2
pyasn1-modules 0.2.1
pycparser 2.21
PyGObject 3.36.0
PyHamcrest 1.9.0
PyJWT 1.7.1
pymacaroons 0.13.0
PyNaCl 1.3.0
pyOpenSSL 19.0.0
pyrsistent 0.15.5
pyserial 3.5
pyserial-asyncio 0.6
python-apt 2.0.1+ubuntu0.20.4.1
python-debian 0.1.36+ubuntu1.1
pyusb 1.2.1
PyYAML 5.3.1
referencing 0.33.0
requests 2.22.0
requests-unixsocket 0.2.0
rpds-py 0.17.1
scapy 2.5.0
SecretStorage 2.3.1
service-identity 18.1.0
setuptools 69.0.3
simplejson 3.16.0
six 1.14.0
sos 4.5.6
ssh-import-id 5.10
systemd-python 234
Twisted 18.9.0
typing_extensions 4.9.0
ubuntu-advantage-tools 8001
ufw 0.36
unattended-upgrades 0.1
urllib3 1.25.8
voluptuous 0.14.2
wadllib 1.3.3
wheel 0.34.2
yarl 1.9.4
z4d-certified-devices 3.213
zigpy 0.59.0
zigpy-cli 1.0.4
zigpy-deconz 0.21.1
zigpy-xbee 0.19.1
zigpy-zigate 0.11.0
zigpy-znp 0.11.6
zipp 3.17.0
zope.interface 4.7.1
root@domotique:~#
root@domotique:~# pip uninstall z4d_certified_devices
Found existing installation: z4d-certified-devices 3.213
Uninstalling z4d-certified-devices-3.213:
Would remove:
/usr/local/lib/python3.8/dist-packages/z4d_certified_devices-3.213.dist-info/*
/usr/local/lib/python3.8/dist-packages/z4d_certified_devices/*
Proceed (Y/n)? Y
Successfully uninstalled z4d-certified-devices-3.213
Re install
Jai re tout supprimer et remis le plugin en V5.
Je vais dormir...
root@domotique:/# cd home/user/domoticz/plugins/
root@domotique:/home/user/domoticz/plugins# git clone https://github.com/zigbeefordomoticz/Domoticz-Zigbee.git
Cloning into 'Domoticz-Zigbee'...
remote: Enumerating objects: 52408, done.
remote: Counting objects: 100% (3485/3485), done.
remote: Compressing objects: 100% (1278/1278), done.
remote: Total 52408 (delta 2257), reused 3169 (delta 2016), pack-reused 48923
Receiving objects: 100% (52408/52408), 103.61 MiB | 20.90 MiB/s, done.
Resolving deltas: 100% (35373/35373), done.
root@domotique:/home/user/domoticz/plugins# cd Domoticz-Zigbee/
root@domotique:/home/user/domoticz/plugins/Domoticz-Zigbee# sudo pip3 install -r requirements.txt
Using cached z4d_certified_devices-3.213-py3-none-any.whl.metadata (36 kB)
Using cached z4d_certified_devices-3.213-py3-none-any.whl (377 kB)
Je vais dormir...
peux-tu mettre les logs de domoticz et du plugin ?
Domoticz tourne sous quel utilisateur ?
j'ai compris ton problème.
A priori tu as python3.8 et python3.9 installé sur ton système.
Quand tu lances domoticz il utilise python3.9
quand tu lances les commandes à la main il utilise python3.8
sudo python3.9 -m pip install -r requirements.txt --upgradeZigbee for Domoticz - Clef zzh-p (electrolama) 45 devices.
