Page 2 sur 4
Re: Erreur - zigate import z4d_certified_devices stable7
Publié : 06 févr. 2024, 20:35
Redémarre DomoticZ et poste-nous les logs de démarrage stp.
Publié : 06 févr. 2024, 20:39
par Kouki31
log du démarrage
2024-02-06 20:37:10.920 Sunrise: 08:14:00 SunSet: 17:55:00
2024-02-06 20:37:10.920 Day length: 09:41:00 Sun at south: 13:05:00
2024-02-06 20:37:10.920 Civil twilight start: 07:41:00 Civil twilight end: 18:29:00
2024-02-06 20:37:10.920 Nautical twilight start: 07:03:00 Nautical twilight end: 19:06:00
2024-02-06 20:37:10.920 Astronomical twilight start: 06:26:00 Astronomical twilight end: 19:43:00
2024-02-06 20:37:10.975 Active notification Subsystems: telegram (1/13)
2024-02-06 20:37:10.980 Starting shared server on: :::6144
2024-02-06 20:37:10.893 Status: Domoticz V2024.4 (c)2012-2024 GizMoCuz
2024-02-06 20:37:10.893 Status: Build Hash: 731719420, Date: 2024-01-30 09:16:34
2024-02-06 20:37:10.893 Status: Startup Path: /home/user/domoticz/
2024-02-06 20:37:10.973 Status: PluginSystem: Started, Python version '3.9.5', 3 plugin definitions loaded.
2024-02-06 20:37:10.976 Status: WebServer(HTTP) started on address: :: with port 7080
2024-02-06 20:37:10.979 Status: WebServer(SSL) started on address: :: with port 7443
2024-02-06 20:37:10.979 Status: Camera: settings (re)loaded
2024-02-06 20:37:10.980 Status: TCPServer: shared server started...
2024-02-06 20:37:10.980 Status: RxQueue: queue worker started...
2024-02-06 20:37:12.981 zigate: Worker thread started.
2024-02-06 20:37:12.981 Status: zigate: Started.
2024-02-06 20:37:12.981 Status: TeleinfoUSB: Teleinfo device uses serial port: /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0 at 1200 bauds
2024-02-06 20:37:12.981 Status: zigate: Entering work loop.
2024-02-06 20:37:13.011 deconz: Worker thread started.
2024-02-06 20:37:13.275 deconz: You are not using 127.0.0.1 as IP, so I suppose deCONZ and Domoticz aren't on same machine
2024-02-06 20:37:13.275 deconz: Taking 192.168.1.125 as Domoticz IP
2024-02-06 20:37:13.275 deconz: Adding banned device : 00:15:8d:00:02:36:c2:3f-01-0500
2024-02-06 20:37:13.010 Status: TeleinfoUSB: CRC checks will be performed on incoming data
2024-02-06 20:37:13.011 Status: deconz: Started.
2024-02-06 20:37:13.011 Status: NotificationSystem: thread started...
2024-02-06 20:37:13.011 Status: EventSystem: reset all events...
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_camera.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_tv_salon_on.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_simple.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_bebe.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_salle_de_bain_disco.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_salle_de_bain_mirroir.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_salle_de_bain_prise.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_cuisine.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_dyson.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_canape.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_ventilateur.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_fenetre.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_test_couleur.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_buanderie_mirroir.lua
2024-02-06 20:37:13.013 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_buanderie.lua
2024-02-06 20:37:13.013 Status: EventSystem: reset all device statuses...
2024-02-06 20:37:13.013 Status: deconz: Entering work loop.
2024-02-06 20:37:13.191 Status: rflink: Using serial port: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
2024-02-06 20:37:13.239 Status: Python EventSystem: Initializing event module.
2024-02-06 20:37:13.240 Status: EventSystem: Queue thread started...
2024-02-06 20:37:13.249 Status: EventSystem: Started
2024-02-06 20:37:13.263 Status: TeleinfoUSB: CRC check mode set to 1
2024-02-06 20:37:13.273 Status: deconz: Initialized version 1.0.29, author 'Smanar'
2024-02-06 20:37:13.276 Status: deconz: Plugin custom pages in date
2024-02-06 20:37:13.426 Status: PluginSystem: 2 plugins started.
2024-02-06 20:37:13.982 Status: 3D: Connecting to 192.168.1.123:1883
2024-02-06 20:37:13.982 Status: 3D: enabled TLS mode
2024-02-06 20:37:13.079 Error: zigate: (Zigate) failed to load 'plugin.py', Python Path used was '/home/user/domoticz/plugins/Domoticz-Zigbee/:/usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload:/usr/local/lib/python3.9/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.9/dist-packages'.
2024-02-06 20:37:13.090 Error: zigate: Traceback (most recent call last):
2024-02-06 20:37:13.090 Error: zigate: File "/home/user/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 103, in <module>
2024-02-06 20:37:13.090 Error: zigate: import z4d_certified_devices
2024-02-06 20:37:13.090 Error: zigate: ModuleNotFoundError: No module named 'z4d_certified_devices'
2024-02-06 20:37:14.083 Status: 3D: connected to: 192.168.1.123:1883
2024-02-06 20:37:14.113 Status: rflink: Controller Initialized!...
2024-02-06 20:37:14.184 Status: 3D: Subscribed
2024-02-06 20:37:14.188 Status: rflink: RFLink Detected, Version: 1.1 Revision: 48 Build: 4
2024-02-06 20:37:19.755 rflink: General/kWh (owl_salon)
2024-02-06 20:37:20.685 rflink: General/kWh (owl_garage)
2024-02-06 20:37:23.101 deconz: ### Request config
2024-02-06 20:37:23.101 Error: deconz: Your python version is missing the requests library
2024-02-06 20:37:23.101 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-06 20:37:31.754 rflink: General/kWh (owl_salon)
2024-02-06 20:37:33.078 deconz: ### Request config
2024-02-06 20:37:33.078 Error: deconz: Your python version is missing the requests library
2024-02-06 20:37:33.078 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-06 20:37:43.056 deconz: ### Request config
2024-02-06 20:37:43.056 Error: deconz: Your python version is missing the requests library
2024-02-06 20:37:43.056 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip installrequests
2024-02-06 20:38:21.258 Error: zigate hardware (9) thread seems to have ended unexpectedly
Publié : 06 févr. 2024, 20:50
Je vois des erreurs pour DeConz. Tu n'as pas Deconz et ZigBeeForDomoticZ qui essayent de fonctionner en même temps sur un même coordinateur ?
Sinon, désolé, je cale. Je ne vois pas pourquoi z4d_certified_devices n'est pas trouvé alors qu'il a été installé juste avant.
Attends le retour de Pipiche.
Publié : 06 févr. 2024, 20:53
par Kouki31
Merci d'avoir regardé.
Jai une clé Zigate et une conbee.
et ca marche avec le plug in 5 RAS...
par contre avec le 7 impossible, z4d_certified_devices en PLS...
Publié : 06 févr. 2024, 20:57
par Kouki31
J'ai essayer
sudo python3 -m pip install git+https://github.com/zigbeefordomoticz/z4 ... ed-devices
Pas mieux...
root@domotique:/home/user/domoticz/plugins/Domoticz-Zigbee# sudo python3 -m pip install -r requirements.txt --upgrade
Requirement already satisfied: zigpy==0.59.0 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 1)) (0.59.0)
Requirement already satisfied: zigpy_znp==0.11.6 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 2)) (0.11.6)
Requirement already satisfied: zigpy_deconz==0.21.1 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 3)) (0.21.1)
Requirement already satisfied: bellows==0.36.8 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 4)) (0.36.8)
Requirement already satisfied: zigpy-cli==1.0.4 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 5)) (1.0.4)
Requirement already satisfied: dnspython==2.3.0 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 6)) (2.3.0)
Requirement already satisfied: pyserial>=3.5 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 7)) (3.5)
Requirement already satisfied: z4d-certified-devices in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 8)) (3.212)
Collecting z4d-certified-devices (from -r requirements.txt (line 8))
  Downloading z4d_certified_devices-3.213-py3-none-any.whl.metadata (36 kB)
Requirement already satisfied: charset-normalizer==2.0.11 in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 9)) (2.0.11)
Requirement already satisfied: distro in /usr/local/lib/python3.8/dist-packages (from -r requirements.txt (line 10)) (1.9.0)
Requirement already satisfied: attrs in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (23.2.0)
Requirement already satisfied: aiohttp in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (3.9.3)
Requirement already satisfied: aiosqlite>=0.16.0 in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (0.19.0)
Requirement already satisfied: async-timeout in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (4.0.3)
Requirement already satisfied: crccheck in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (1.3.0)
Requirement already satisfied: cryptography in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (42.0.2)
Requirement already satisfied: voluptuous in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (0.14.2)
Requirement already satisfied: typing-extensions in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (4.9.0)
Requirement already satisfied: pyserial-asyncio in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (0.6)
Requirement already satisfied: importlib-resources in /usr/local/lib/python3.8/dist-packages (from zigpy==0.59.0->-r requirements.txt (line 1)) (6.1.1)
Requirement already satisfied: coloredlogs in /usr/local/lib/python3.8/dist-packages (from zigpy_znp==0.11.6->-r requirements.txt (line 2)) (15.0.1)
Requirement already satisfied: jsonschema in /usr/local/lib/python3.8/dist-packages (from zigpy_znp==0.11.6->-r requirements.txt (line 2)) (4.21.1)
Requirement already satisfied: click in /usr/local/lib/python3.8/dist-packages (from bellows==0.36.8->-r requirements.txt (line 4)) (8.1.7)
Requirement already satisfied: click-log>=0.2.1 in /usr/local/lib/python3.8/dist-packages (from bellows==0.36.8->-r requirements.txt (line 4)) (0.4.0)
Requirement already satisfied: pure-pcapy3==1.0.1 in /usr/local/lib/python3.8/dist-packages (from bellows==0.36.8->-r requirements.txt (line 4)) (1.0.1)
Requirement already satisfied: scapy in /usr/local/lib/python3.8/dist-packages (from zigpy-cli==1.0.4->-r requirements.txt (line 5)) (2.5.0)
Requirement already satisfied: zigpy-xbee>=0.18.0 in /usr/local/lib/python3.8/dist-packages (from zigpy-cli==1.0.4->-r requirements.txt (line 5)) (0.19.1)
Requirement already satisfied: zigpy-zigate>=0.11.0 in /usr/local/lib/python3.8/dist-packages (from zigpy-cli==1.0.4->-r requirements.txt (line 5)) (0.11.0)
Requirement already satisfied: setuptools in /usr/local/lib/python3.8/dist-packages (from pure-pcapy3==1.0.1->bellows==0.36.8->-r requirements.txt (line 4)) (69.0.3)
Requirement already satisfied: gpiozero in /usr/local/lib/python3.8/dist-packages (from zigpy-zigate>=0.11.0->zigpy-cli==1.0.4->-r requirements.txt (line 5)) (2.0)
Requirement already satisfied: pyusb>=1.1.0 in /usr/local/lib/python3.8/dist-packages (from zigpy-zigate>=0.11.0->zigpy-cli==1.0.4->-r requirements.txt (line 5)) (1.2.1)
Requirement already satisfied: aiosignal>=1.1.2 in /usr/local/lib/python3.8/dist-packages (from aiohttp->zigpy==0.59.0->-r requirements.txt (line 1)) (1.3.1)
Requirement already satisfied: frozenlist>=1.1.1 in /usr/local/lib/python3.8/dist-packages (from aiohttp->zigpy==0.59.0->-r requirements.txt (line 1)) (1.4.1)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.8/dist-packages (from aiohttp->zigpy==0.59.0->-r requirements.txt (line 1)) (6.0.5)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.8/dist-packages (from aiohttp->zigpy==0.59.0->-r requirements.txt (line 1)) (1.9.4)
Requirement already satisfied: humanfriendly>=9.1 in /usr/local/lib/python3.8/dist-packages (from coloredlogs->zigpy_znp==0.11.6->-r requirements.txt (line 2)) (10.0)
Requirement already satisfied: cffi>=1.12 in /usr/local/lib/python3.8/dist-packages (from cryptography->zigpy==0.59.0->-r requirements.txt (line 1)) (1.16.0)
Requirement already satisfied: zipp>=3.1.0 in /usr/local/lib/python3.8/dist-packages (from importlib-resources->zigpy==0.59.0->-r requirements.txt (line 1)) (3.17.0)
Requirement already satisfied: jsonschema-specifications>=2023.03.6 in /usr/local/lib/python3.8/dist-packages (from jsonschema->zigpy_znp==0.11.6->-r requirements.txt (line 2)) (2023.12.1)
Requirement already satisfied: pkgutil-resolve-name>=1.3.10 in /usr/local/lib/python3.8/dist-packages (from jsonschema->zigpy_znp==0.11.6->-r requirements.txt (line 2)) (1.3.10)
Requirement already satisfied: referencing>=0.28.4 in /usr/local/lib/python3.8/dist-packages (from jsonschema->zigpy_znp==0.11.6->-r requirements.txt (line 2)) (0.33.0)
Requirement already satisfied: rpds-py>=0.7.1 in /usr/local/lib/python3.8/dist-packages (from jsonschema->zigpy_znp==0.11.6->-r requirements.txt (line 2)) (0.17.1)
Requirement already satisfied: pycparser in /usr/local/lib/python3.8/dist-packages (from cffi>=1.12->cryptography->zigpy==0.59.0->-r requirements.txt (line 1)) (2.21)
Requirement already satisfied: idna>=2.0 in /usr/local/lib/python3.8/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy==0.59.0->-r requirements.txt (line 1)) (3.6)
Requirement already satisfied: colorzero in /usr/local/lib/python3.8/dist-packages (from gpiozero->zigpy-zigate>=0.11.0->zigpy-cli==1.0.4->-r requirements.txt (line 5)) (2.0)
Downloading z4d_certified_devices-3.213-py3-none-any.whl (377 kB)
   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 377.2/377.2 kB 4.9 MB/s eta 0:00:00
Installing collected packages: z4d-certified-devices
  Attempting uninstall: z4d-certified-devices
    Found existing installation: z4d-certified-devices 3.212
    Uninstalling z4d-certified-devices-3.212:
      Successfully uninstalled z4d-certified-devices-3.212
Successfully installed z4d-certified-devices-3.213
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
root@domotique:/home/user/domoticz/plugins/Domoticz-Zigbee# ^C
Publié : 06 févr. 2024, 21:51
par Kouki31
Re J'ai refais quelque essai KO...
je remet une copie du dossier du plugin en 5 et la ca marche...
Mais impossible de mettre le plugin en Stable 7...
Publié : 06 févr. 2024, 23:51
par Kouki31
Divers essai...
root@domotique:~# sudo python3 -m pip install z4d-certified-devices --upgrade
Requirement already satisfied: z4d-certified-devices in /usr/local/lib/python3.8/dist-packages (3.213)
pip freeze
root@domotique:~# pip freeze
aiohttp==3.9.3
aiosignal==1.3.1
aiosqlite==0.19.0
async-timeout==4.0.3
attrs==23.2.0
Automat==0.8.0
bellows==0.36.8
blinker==1.4
certifi==2019.11.28
cffi==1.16.0
chardet==3.0.4
click==8.1.7
click-log==0.4.0
cloud-init==23.3.3
colorama==0.4.3
coloredlogs==15.0.1
colorzero==2.0
command-not-found==0.3
configobj==5.0.6
constantly==15.1.0
crccheck==1.3.0
cryptography==42.0.2
dbus-python==1.2.16
distro==1.9.0
distro-info==0.23+ubuntu1.1
dnspython==2.3.0
entrypoints==0.3
frozenlist==1.4.1
gpiozero==2.0
httplib2==0.14.0
humanfriendly==10.0
hyperlink==19.0.0
idna==3.6
importlib-metadata==1.5.0
importlib-resources==6.1.1
incremental==16.10.1
Jinja2==2.10.1
jsonpatch==1.22
jsonpointer==2.0
jsonschema==4.21.1
jsonschema-specifications==2023.12.1
keyring==18.0.1
language-selector==0.1
launchpadlib==1.10.13
lazr.restfulclient==0.14.2
lazr.uri==1.0.3
MarkupSafe==1.1.0
more-itertools==4.2.0
multidict==6.0.5
netifaces==0.10.4
oauthlib==3.1.0
pexpect==4.6.0
pkgutil_resolve_name==1.3.10
pure-pcapy3==1.0.1
pyasn1==0.4.2
pyasn1-modules==0.2.1
pycparser==2.21
PyGObject==3.36.0
PyHamcrest==1.9.0
PyJWT==1.7.1
pymacaroons==0.13.0
PyNaCl==1.3.0
pyOpenSSL==19.0.0
pyrsistent==0.15.5
pyserial==3.5
pyserial-asyncio==0.6
python-apt==2.0.1+ubuntu0.20.4.1
python-debian==0.1.36+ubuntu1.1
pyusb==1.2.1
PyYAML==5.3.1
referencing==0.33.0
requests==2.22.0
requests-unixsocket==0.2.0
rpds-py==0.17.1
scapy==2.5.0
SecretStorage==2.3.1
service-identity==18.1.0
simplejson==3.16.0
six==1.14.0
sos==4.5.6
ssh-import-id==5.10
systemd-python==234
Twisted==18.9.0
typing_extensions==4.9.0
ubuntu-advantage-tools==8001
ufw==0.36
unattended-upgrades==0.1
urllib3==1.25.8
voluptuous==0.14.2
wadllib==1.3.3
yarl==1.9.4
z4d-certified-devices==3.213
zigpy==0.59.0
zigpy-cli==1.0.4
zigpy-deconz==0.21.1
zigpy-xbee==0.19.1
zigpy-zigate==0.11.0
zigpy-znp==0.11.6
zipp==3.17.0
zope.interface==4.7.1
root@domotique:~#
pip list
 pip list
Package                   Version
aiohttp                   3.9.3
aiosignal                 1.3.1
aiosqlite                 0.19.0
async-timeout             4.0.3
attrs                     23.2.0
Automat                   0.8.0
bellows                   0.36.8
blinker                   1.4
certifi                   2019.11.28
cffi                      1.16.0
chardet                   3.0.4
charset-normalizer        2.0.11
click                     8.1.7
click-log                 0.4.0
cloud-init                23.3.3
colorama                  0.4.3
coloredlogs               15.0.1
colorzero                 2.0
command-not-found         0.3
configobj                 5.0.6
constantly                15.1.0
crccheck                  1.3.0
cryptography              42.0.2
dbus-python               1.2.16
distro                    1.9.0
distro-info               0.23+ubuntu1.1
dnspython                 2.3.0
entrypoints               0.3
frozenlist                1.4.1
gpiozero                  2.0
httplib2                  0.14.0
humanfriendly             10.0
hyperlink                 19.0.0
idna                      3.6
importlib-metadata        1.5.0
importlib-resources       6.1.1
incremental               16.10.1
Jinja2                    2.10.1
jsonpatch                 1.22
jsonpointer               2.0
jsonschema                4.21.1
jsonschema-specifications 2023.12.1
keyring                   18.0.1
language-selector         0.1
launchpadlib              1.10.13
lazr.restfulclient        0.14.2
lazr.uri                  1.0.3
MarkupSafe                1.1.0
more-itertools            4.2.0
multidict                 6.0.5
netifaces                 0.10.4
oauthlib                  3.1.0
pexpect                   4.6.0
pip                       24.0
pkgutil_resolve_name      1.3.10
pure-pcapy3               1.0.1
pyasn1                    0.4.2
pyasn1-modules            0.2.1
pycparser                 2.21
PyGObject                 3.36.0
PyHamcrest                1.9.0
PyJWT                     1.7.1
pymacaroons               0.13.0
PyNaCl                    1.3.0
pyOpenSSL                 19.0.0
pyrsistent                0.15.5
pyserial                  3.5
pyserial-asyncio          0.6
python-apt                2.0.1+ubuntu0.20.4.1
python-debian             0.1.36+ubuntu1.1
pyusb                     1.2.1
PyYAML                    5.3.1
referencing               0.33.0
requests                  2.22.0
requests-unixsocket       0.2.0
rpds-py                   0.17.1
scapy                     2.5.0
SecretStorage             2.3.1
service-identity          18.1.0
setuptools                69.0.3
simplejson                3.16.0
six                       1.14.0
sos                       4.5.6
ssh-import-id             5.10
systemd-python            234
Twisted                   18.9.0
typing_extensions         4.9.0
ubuntu-advantage-tools    8001
ufw                       0.36
unattended-upgrades       0.1
urllib3                   1.25.8
voluptuous                0.14.2
wadllib                   1.3.3
wheel                     0.34.2
yarl                      1.9.4
z4d-certified-devices     3.213
zigpy                     0.59.0
zigpy-cli                 1.0.4
zigpy-deconz              0.21.1
zigpy-xbee                0.19.1
zigpy-zigate              0.11.0
zigpy-znp                 0.11.6
zipp                      3.17.0
zope.interface            4.7.1
root@domotique:~#
pip uninstall z4d_certified_devices
root@domotique:~# pip uninstall z4d_certified_devices
Found existing installation: z4d-certified-devices 3.213
Uninstalling z4d-certified-devices-3.213:
  Would remove:
    /usr/local/lib/python3.8/dist-packages/z4d_certified_devices-3.213.dist-info/*
    /usr/local/lib/python3.8/dist-packages/z4d_certified_devices/*
Proceed (Y/n)? Y
  Successfully uninstalled z4d-certified-devices-3.213
Publié : 07 févr. 2024, 00:00
par Kouki31
Re install
root@domotique:/# cd home/user/domoticz/plugins/
root@domotique:/home/user/domoticz/plugins# git clone https://github.com/zigbeefordomoticz/Domoticz-Zigbee.git
Cloning into 'Domoticz-Zigbee'...
remote: Enumerating objects: 52408, done.
remote: Counting objects: 100% (3485/3485), done.
remote: Compressing objects: 100% (1278/1278), done.
remote: Total 52408 (delta 2257), reused 3169 (delta 2016), pack-reused 48923
Receiving objects: 100% (52408/52408), 103.61 MiB | 20.90 MiB/s, done.
Resolving deltas: 100% (35373/35373), done.
root@domotique:/home/user/domoticz/plugins# cd Domoticz-Zigbee/
root@domotique:/home/user/domoticz/plugins/Domoticz-Zigbee# sudo pip3 install -r requirements.txt
  Using cached z4d_certified_devices-3.213-py3-none-any.whl.metadata (36 kB)
Using cached z4d_certified_devices-3.213-py3-none-any.whl (377 kB)
Jai re tout supprimer et remis le plugin en V5.
Je vais dormir...
Publié : 07 févr. 2024, 18:54
par pipiche
peux-tu mettre les logs de domoticz et du plugin ?
Domoticz tourne sous quel utilisateur ?
Publié : 07 févr. 2024, 18:59
par pipiche
j'ai compris ton problème.
A priori tu as python3.8 et python3.9 installé sur ton système.
Quand tu lances domoticz il utilise python3.9
quand tu lances les commandes à la main il utilise python3.8
sudo python3.9 -m pip install -r requirements.txt --upgrade
