ZW074 - Aeon Labs Multisensor Gen5 et OpenZwav
Re: ZW074 - Aeon Labs Multisensor Gen5 et OpenZwav
Pourquoi toucher au fichier xml ?
L'interface de domoticz suffit normalement.
De plus ça ne montre pas la conf du module.
Oui il y a certainement d'autres choses à modifier..
La fréquence des mesures/rapports etc..
chrisG4269
d autre personne rencontre le problème impossible de modifier la conf à partir de l interface domoticz
https://www.domotique-fibaro.fr/topic/4 ... nsor-gen5/
chrisG4269
votre avis merci
<?xml version="1.0" encoding="utf-8"?>
Aeotec ZW074 MultiSensor Gen5
https://aeotec.freshdesk.com/helpdesk/a ... 6009584696
<Product xmlns='http://code.google.com/p/open-zwave/'>
<!-- Configuration Parameters -->
<CommandClass id="112">
<Value type="list" index="2" genre="config" label="Wake up 10 minutes on Power On" min="0" max="1" value="1" size="1">
<Help>Stay awake for 10 minutes after batteries are inserted</Help>
<Item label="No" value="0" />
<Item label="Yes" value="1" />
</Value>
<Value type="short" index="3" genre="config" label="On time" units="seconds" min="1" max="15300" value="900">
<Help>How long should the device associated to multi sensor keep state On before sending it Off command (if the value is bigger than 255, the value would be rounded to next integer in minutes)</Help>
</Value>
<Value type="list" index="4" genre="config" label="Enable Motion Sensor" min="0" max="1" value="1" size="1">
<Help>Enable Motion Sensor</Help>
<Item label="Disabled" value="0" />
<Item label="Enabled" value="1" />
</Value>
<Value type="list" index="5" genre="config" label="Command Options" min="1" max="2" value="1" size="1">
<Help>Which commands to send when PIR motion sensor triggered
OZW Ideal Value is Binary Sensor Report</Help>
<Item label="Basic Set (default) " value="1" />
<Item label="Binary Sensor Report" value="2" />
</Value>
<Value type="list" index="40" genre="config" label="Reporting Threshold" min="0" max="1" value="0" size="1">
<Help>Enable/disable the selective reporting only when measurements reach a certain threshold or percentage
set in the threshold settings. This is used to reduce network
traffic.</Help>
</Value>
<Value type="short" index="41" genre="config" label="Temperature Reporting Threshold" units="%" min="0" max="39321" value="256" size="2">
<Help>Threshold change in temperature to induce an automatic report.
Note:
1. When the unit is Celsius, threshold=Value.
2. When the unit is Fahrenheit, threshold=Value*1.8. The accuracy is 0.1.
3. The high byte is the part of integer, the low byte is the fractional part.
</Help>
</Value>
<Value type="short" index="42" genre="config" label="Humidity Reporting Threshold" units="%" min="0" max="39321" value="1280" size="2">
<Help>Threshold change in humidity to induce an automatic report.
Note:
</Help>
</Value>
<Value type="short" index="43" genre="config" label="Luminance Reporting Threshold" units="LUX" min="0" max="65535" value="25600" size="2">
<Help>Threshold change in luminance to induce an automatic report. </Help>
</Value>
<Value type="short" index="44" genre="config" label="Battery Reporting Threshold" units="%" min="0" max="39321" value="1280" size="2">
<Help>Threshold change in battery level to induce an automatic report.
Note:
</Help>
</Value>
<Value type="list" index="46" genre="config" label="Low Temp Alarm" min="0" max="1" value="0" size="1">
<Help>Enable/disable to send the alarm report of low temperature(Less than 15 Degress C)
... je n est pas modifier la suite
</Value>
</Value>
</Value>
</Value>
traffic.</Help>
</Value>
Note:
</Help>
</Value>
Note:
</Help>
</Value>
</Value>
Note:
</Help>
</Value>
chrisG4269
j'ai l impression que ça n a rien changé ...
http://prntscr.com/expv04
Tu confonds zwave et la carte raspberry ?
Que sommes nous sensé voir dans tout ça ?
chrisG4269
mes piles s'usent, je pensais que cette log représentait la connexion de mes sondes à la clef zawve ..
malgré les changement effectués mes piles que j ai changé vendredi sont passé de 100 à 97% en deux jours
C'est normal ça, la vraie question est, combien de temps tiennent elles ?
et ton xml est pris en compte ou non ?
viewtopic.php?p=29645#p29645
chrisG4269
je ne suis pas persuadé que mes capteurs on pris la bonne config ..
mais comment le savoir ?
Bah via l'interface de domoticz..
Ou le panneau de contrôle zwave si tu préfères
Bernouillard
Merci pour la réponse.
Mais çà je sais faire depuis un certain temps.
Je cherche un moyen simple pour agir sur le paramètre 4 du nœud le but est de l'ajouter dans un programme existant d'intrusion..
Et surtout ne pas remplir des pages et des pages de journaux si nous sommes à la maison .
