Node-red function
dokho
Re: Node-red function
Message par dokho »
En effet, ça fonctionne bien avec
msg.payload = parseInt(msg.payload.svalue5)
J'avais jeté un œil sur google mais apparemment pas avec les bons termes ...
Merci.
dokho
Message par dokho »
Je déterre ce topic car je suis de nouveau à la recherche d'une fonction node-red.
J'ai créé un flow pour récupérer la valeur "CounterToday" de mon P1 Smart Meter mais je pense qu'il est possible de l'améliorer (ou de le rendre plus "propre").
Si une âme charitable passe par là :)
[{"id":"75c9b23.4fe0e4c","type":"debug","z":"bd273552.0272f","name":"","active":false,"console":"false","complete":"false","x":1904.5,"y":917,"wires":[]},{"id":"13ce0c3b.05934c","type":"http request","z":"bd273552.0272f","name":"","method":"GET","ret":"txt","url":"http://192.168.0.232:8080/json.htm?type=devices&rid=4065","tls":"","x":758.5,"y":913,"wires":[["512e4a85.11c81c"]]},{"id":"1af3d7ab.4f2e1","type":"inject","z":"bd273552.0272f","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":563.5,"y":911,"wires":[["13ce0c3b.05934c"]]},{"id":"512e4a85.11c81c","type":"json","z":"bd273552.0272f","name":"","pretty":false,"x":951.5,"y":913,"wires":[["2d39b737.0f36a"]]},{"id":"2d39b737.0f36a","type":"function","z":"bd273552.0272f","name":"","func":"msg.payload = msg.payload.result[0].CounterToday;\nreturn msg;","outputs":1,"noerr":0,"x":1120,"y":913,"wires":[["d4fc1407.977ab8"]]},{"id":"2c4e5d42.8445a2","type":"change","z":"bd273552.0272f","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number(payload)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1688.5,"y":918,"wires":[["75c9b23.4fe0e4c","f7a9ebc5.40ebf"]]},{"id":"d4fc1407.977ab8","type":"split","z":"bd273552.0272f","name":"","splt":" ","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":1287.5,"y":913,"wires":[["f26aefcd.41b938"]]},{"id":"f26aefcd.41b938","type":"switch","z":"bd273552.0272f","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"kWh","vt":"str"},{"t":"else"}],"checkall":"true","outputs":2,"x":1475.5,"y":912,"wires":[[],["2c4e5d42.8445a2"]]},{"id":"f7a9ebc5.40ebf","type":"mqtt out","z":"bd273552.0272f","name":"","topic":"afficheur1/consojour","qos":"","retain":"","broker":"a53b9be.1ee3668","x":1949,"y":799,"wires":[]},{"id":"a53b9be.1ee3668","type":"mqtt-broker","z":"","broker":"192.168.0.232","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""}]
Le "http request" renvoi une valeur du style: "12.275 kWh"
Le but est de virer les "" et le kWh.
A votre bon coeur :)
Jeff
Message par Jeff »
Avec ceci dans ta fonction, ca fait le job.
msg.payload = msg.payload.result[0].Counter;
msg.payload=parseFloat(msg.payload.substr(0,6));
return msg;
Moi j'ai counter et pas countertoday pour mon essai...
Tu peux choisir le nombre de decimal après la virgule avec (0,6), à adapter si <10 Kwh ou >99 Kwh ce qui ne devrait pas arriver
Jeff
Message par Jeff »
Alors @dokho as tu eu le temps de tester ?
dokho
Message par dokho »
Jeff a écrit :Alors @dokho as tu eu le temps de tester ?
J'ai fait le test avec:
msg.payload = parseFloat(msg.payload.result[0].CounterToday);
Ça a l'air de fonctionner.
Merci Image
Jeff
Message par Jeff »
Yes nickel, encore plus simple :D
Et ca marche avec tout apparemment, test sur Azimuth...
