Ce que je ne comprends pas très bien c'est que j'ai installé Python3.5.2, que pip3 -V me retourne
pip 8.1.1 from /usr/local/lib/python3.5/site-packages (python 3.5)
2019-01-13 20:19:46.135 Status: Domoticz V4.10353 (c)2012-2019 GizMoCuz
2019-01-13 20:19:46.136 Status: Build Hash: 0fa125f6, Date: 2019-01-12 23:12:34
2019-01-13 20:19:46.136 Status: Startup Path: /home/domoticz/
2019-01-13 20:19:46.868 Status: PluginSystem: Started, Python version '3.4.2'.
2019-01-13 20:19:46.938 Status: WebServer(HTTP) started on address: :: with port 8080
2019-01-13 20:19:46.949 Status: WebServer(SSL) started on address: :: with port 443
2019-01-13 20:19:46.950 Status: Proxymanager started.
2019-01-13 20:19:46.951 Status: RxQueue: queue worker started...
2019-01-13 20:19:46.951 Status: TCPServer: shared server started...
2019-01-13 20:19:48.951 Status: EventSystem: reset all events...
2019-01-13 20:19:48.968 Status: EventSystem: reset all device statuses...
2019-01-13 20:19:48.984 Status: Python EventSystem: Initalizing event module.
2019-01-13 20:19:48.984 Status: EventSystem: Queue thread started...
2019-01-13 20:19:48.984 Status: EventSystem: Started
2019-01-13 20:19:49.448 Status: PluginSystem: Entering work loop.
2019-01-13 20:21:48.173 Status: Incoming connection from: 192.168.0.9
2019-01-13 20:22:44.760 Status: (Zigate) Started.
2019-01-13 20:22:44.989 Status: (Zigate) Initialized version 4.0.6, author 'zaraki673 pipiche38'
2019-01-13 20:22:44.989 Status: (Zigate) onStart called - Zigate plugin V 4.0.6
2019-01-13 20:22:44.990 Status: (Zigate) load PluginConf
2019-01-13 20:22:44.990 Status: (Zigate) Entering work loop.
2019-01-13 20:22:44.990 Status: (Zigate) ZigateMode: ZigBee sendDelay: 0 reTransmit: 1 zTimeOut: 2
2019-01-13 20:22:44.990 Status: (Zigate) logFORMAT: 0 logLQI: 0 allowRemoveZigateDevice: 0
2019-01-13 20:22:44.990 Status: (Zigate) allowStoreDiscoveryFrames: 0 forceCreationDevice: 0 networkScan: 0 channel: ['0']
2019-01-13 20:22:44.992 Status: (Zigate) load ListOfDevice
2019-01-13 20:22:44.992 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2019-01-13 20:22:45.093 Status: (Zigate) onConnect called
2019-01-13 20:22:45.093 Status: (Zigate) ZigateConf - Setting UTC Time to : 1547407365
2019-01-13 20:22:45.093 Status: (Zigate) Start network
2019-01-13 20:22:45.093 Status: (Zigate) Zigate enter in discover mode for 254 Secs
2019-01-13 20:22:45.152 Status: (Zigate) Major Version Num: 0002
2019-01-13 20:22:45.152 Status: (Zigate) Installer Version Number: 030e
2019-01-13 20:22:45.203 Status: (Zigate) Decode8015 : Number of devices recently active in Zigate = 0
2019-01-13 20:22:45.305 Status: (Zigate) Decode8009 : Zigate addresses ieee: 00158d0001ed466c , short addr: ffff
2019-01-13 20:22:45.305 Status: (Zigate) Decode8009 - Network state UP, PANID: 7eea extPANID: 0x0000000000000000 Channel: 11
2019-01-13 20:22:47.813 Status: (Zigate) Decode8024 - Network joined / formed - IEEE: 00158d0001ed466c, NetworkID: 0000, Channel: 0b, Status: 01: Formed new network
2019-01-13 20:22:47.914 Status: (Zigate) Permit Join is On
2019-01-13 20:23:30.987 Status: (Zigate) [0] NEW OBJECT: 5b8b Device Annouce
2019-01-13 20:23:31.188 Status: (Zigate) [0] NEW OBJECT: 5b8b Device Annouce
2019-01-13 20:23:35.051 Status: (Zigate) [0] NEW OBJECT: 5b8b (re)Starting process
2019-01-13 20:23:40.015 Status: (Zigate) [0] NEW OBJECT: 5b8b Ox8045 received Infos
2019-01-13 20:23:40.015 Status: (Zigate) [0] NEW OBJECT: 5b8b Request Simple Descriptor for Ep: 01
2019-01-13 20:23:40.015 Status: (Zigate) [0] NEW OBJECT: 5b8b Request Attributes for Cluster 0x0001
2019-01-13 20:23:43.025 Status: (Zigate) [-] NEW OBJECT: 5b8b Simple Descriptor EP 01
2019-01-13 20:23:43.025 Status: (Zigate) [-] NEW OBJECT: 5b8b ProfileID 0104
2019-01-13 20:23:43.025 Status: (Zigate) [-] NEW OBJECT: 5b8b ZDeviceID 5f01
2019-01-13 20:23:43.025 Status: (Zigate) [-] NEW OBJECT: 5b8b Cluster IN Count: 04
2019-01-13 20:23:43.025 Status: (Zigate) [-] NEW OBJECT: 5b8b Cluster In 1: 0000
2019-01-13 20:23:43.025 Status: (Zigate) [-] NEW OBJECT: 5b8b Cluster In 2: 0003
2019-01-13 20:23:43.025 Status: (Zigate) [-] NEW OBJECT: 5b8b Cluster In 3: ffff
2019-01-13 20:23:43.025 Status: (Zigate) [-] NEW OBJECT: 5b8b Cluster In 4: 0006
2019-01-13 20:23:43.025 Status: (Zigate) [-] NEW OBJECT: 5b8b Cluster OUT Count: 03
2019-01-13 20:23:43.025 Status: (Zigate) [-] NEW OBJECT: 5b8b Cluster Out 1: 0000
2019-01-13 20:23:43.025 Status: (Zigate) [-] NEW OBJECT: 5b8b Cluster Out 2: 0004
2019-01-13 20:23:43.025 Status: (Zigate) [-] NEW OBJECT: 5b8b Cluster Out 3: ffff
2019-01-13 20:23:45.031 Status: (Zigate) [0] NEW OBJECT: 5b8b Ox8043 received Infos
2019-01-13 20:23:45.031 Status: (Zigate) [0] NEW OBJECT: 5b8b Trying to create Domoticz device(s)
Je vais voir si je tourne avec 2 instances Domoticz ou si je merge les 2 sur cette nouvelle (j'ai fait une partition root de 40 Go ... il devrait y avoir suffisamment de place pour les logs !
Encore merci pour ton aide !
