Page 2 sur 3
Re: Notifications telegram : emoji et multi destinataire
Publié : 19 mai 2019, 17:12
par papoo
en dzvents
-- managedNotify test script
return {
        active = true,
   on = { timer = { "every 5 minutes" }},
   execute = function(domoticz)
           --local notificationTable = { domoticz.NSS_PUSHBULLET, domoticz.NSS_TELEGRAM } --Systèmes de notification disponibles : "PUSHBULLET", "HTTP", "GCM", "KODI", "LMS", "PROWL", "PUSHALOT"
           local SubSystem = "TELEGRAM,PUSHBULLET"
                            --[[ Systèmes de notification disponibles :
                                NSS_GOOGLE_CLOUD_MESSAGING NSS_HTTP NSS_KODI NSS_LOGITECH_MEDIASERVER NSS_NMA NSS_PROWL NSS_PUSHALOT NSS_PUSHBULLET NSS_PUSHOVER NSS_PUSHSAFER
                                Pour une notification sur plusieurs systèmes, séparez les systèmes par une virgule et entourez l'ensemble par des {}.
                                Exemple :{domoticz.NSS_PUSHBULLET, domoticz.NSS_HTTP}
        function split(s, delimiter)
        result = {};
        for match in (s..delimiter):gmatch("(.-)"..delimiter) do
            table.insert(result, match);
        return result;
        function notificationTable(str)
        --NSS_GOOGLE_CLOUD_MESSAGING, NSS_HTTP, NSS_KODI, NSS_LOGITECH_MEDIASERVER, NSS_NMA,NSS_PROWL, NSS_PUSHALOT, NSS_PUSHBULLET, NSS_PUSHOVER, NSS_PUSHSAFER, NSS_TELEGRAM
            if (str) then
            str = string.gsub (str,"GCM", domoticz.NSS_GOOGLE_CLOUD_MESSAGING)
            str = string.gsub (str,"HTTP", domoticz.NSS_HTTP)
            str = string.gsub (str,"LMS", domoticz.NSS_LOGITECH_MEDIASERVER)
            str = string.gsub (str,"NMA", domoticz.NSS_NMA)
            str = string.gsub (str,"PROWL", domoticz.NSS_PROWL)
            str = string.gsub (str,"PUSHALOT", domoticz.NSS_PUSHALOT)
            str = string.gsub (str,"PUSHOVER", domoticz.NSS_PUSHOVER)
            str = string.gsub (str,"PUSHSAFER", domoticz.NSS_PUSHSAFER)
            str = string.gsub (str,"PUSHBULLET", domoticz.NSS_PUSHBULLET)
            str = string.gsub (str,"TELEGRAM", domoticz.NSS_TELEGRAM)
        return (split(str,','))
           domoticz.notify("Test Notification \xF0\x9F\x98\x81", "Test Notification \xF0\x9F\x98\x81 : \n"..tostring(domoticz.time.raw), domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "" , notificationTable(SubSystem) )
Publié : 19 mai 2019, 17:15
par papoo
simplifié
-- Notify test script
return {
        active = true,
           domoticz.notify("Test Notification \xF0\x9F\x98\x81", "Test Notification \xF0\x9F\x98\x81 ", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "" ,domoticz.NSS_TELEGRAM) )
Publié : 19 mai 2019, 19:07
par Loky31200
Cool merci !
Le script de test marche bien :)
Me reste plus qu'a trouver "dzvents pour les nuls" pour voir comment je fait un déclenchement via blokly en passant un paramètre pour choisir ma notif :)
Publié : 19 mai 2019, 19:18
par papoo
Heuuuuu
Moi je ferais tout en dzvents
C’est comme le reste il suffit de s’y mettre
Publié : 19 mai 2019, 19:20
par denis_brasseur
A commencer, autant tout faire en Dzvents
Publié : 19 mai 2019, 20:19
par Loky31200
Ok merci du conseil !
Bon j'ai réussi a faire mon premier et extrêmement simple Dzvents :)
-- Notify BAL test script
return {
        active = true,
   on = { devices = { 116 }},
   execute = function(domoticz, device)
    if (device.state == 'Vibrate') then
           domoticz.notify("\xF0\x9F\x93\xAC", "Le facteur est passé! ", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "" ,domoticz.NSS_HTTP)
Ma principale question, et surement la plus basique, si je rajoute des devices dans la liste au début comment je fait pour tester su un en particulier?
Par exemple si je 117, comment mon test "device.state ==" saura qu'il faut vérifier le 117 et pas le 116 ?
Désolé je pars vraiment de loin !
Publié : 19 mai 2019, 20:29
par papoo
vibrate n'est pas un état disponible dans dzvents.
au lieu des idx tu devrais mettre le nom de tes devices.
ensuite si tu mets plusieurs devices dans la liste de ceux à surveiller
mets dans ton if une condition supplémentaire exemple
return {
        active = true,
   on = { devices = {'boite aux lettres', 'sonnette', 'porte entrée'}},
    if (device.name == 'boite aux lettres' and device.state == 'On') then
Publié : 19 mai 2019, 22:10
par Loky31200
Merci papoo !
Alors pour ma part l'état "Vibrate" est bien pris en compte :) Surement ajouté par un plugin.
Bon il me reste un dernier point a résoudre, comment mettre dans ma notification l'état d'un device?
La aussi le format n'est pas limpide de prime abord....
Je voudrais dans ma notification mettre le "nom du niveau" d'un switch sélecteur.
Je cherche mais j'ai pas encore d'exemple...
Sacré boulet que je fais :(
Publié : 21 mai 2019, 22:09
par Loky31200
Sauriez vous me donner le format pour mettre dans ma notif "blablabla nom_du_niveau_du_capteur blalbla" ?
C'est basique mais je trouve pas :(
Publié : 21 mai 2019, 22:15
par papoo
domoticz.notify("\xF0\x9F\x93\xAC", "blablabla".. device.state .."blalbla", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "" ,domoticz.NSS_telegram)
