(PiZigate) No Firmware Version received from Zigate
tonio1005
Re: (PiZigate) No Firmware Version received from Zigate
Message par tonio1005 »
Sunrise: 08:29:00 SunSet: 17:21:00
Day length: 08:52:00 Sun at south: 12:55:00
Civil twilight start: 07:54:00 Civil twilight end: 17:55:00
Nautical twilight start: 07:16:00 Nautical twilight end: 18:33:00
Astronomical twilight start: 06:39:00 Astronomical twilight end: 19:10:00
Active notification Subsystems: email (1/13)
Starting shared server on: :::6144
Status: Domoticz V4.0 (c)2012-1970 GizMoCuz
Status: Build Hash: 0, Date: 1970-01-01 01:00:00
Status: Startup Path: /usr/lib/domoticz/
Status: PluginSystem: Started, Python version '3.7.3'.
Status: WebServer(HTTP) started on address: :: with port 8080
Status: TCPServer: shared server started...
Status: RxQueue: queue worker started...
Status: RFXCOM: Worker started...
Status: (PiZigate) Started.
Status: EventSystem: reset all events...
Status: EventSystem: reset all device statuses...
Status: Python EventSystem: Initalizing event module.
Status: EventSystem: Started
Status: EventSystem: Queue thread started...
Status: PluginSystem: Entering work loop.
(PiZigate) Debug: 0
(PiZigate) + Checkint GPIO PINs
Status: (PiZigate) Entering work loop.
Status: (PiZigate) Initialized version beta-4.4, author 'zaraki673 pipiche38'
Status: (PiZigate) Zigate plugin beta-4.4.11 started
Status: (PiZigate) Python Version - 3.7.3 (default, Apr 3 2019, 05:39:12)
Status: (PiZigate) [GCC 8.2.0]
Status: (PiZigate) Switching Heartbeat to 5 s interval
Status: (PiZigate) DomoticzVersion: 4.0
Status: (PiZigate) DomoticzHash: 0
Status: (PiZigate) DomoticzBuildTime: 1970-01-01 01:00:00
Status: (PiZigate) load PluginConf
Status: (PiZigate) filename set to /etc/domoticz/plugins/Domoticz-Zigate/PluginConf-06.json
Status: (PiZigate) pluginHome set to /usr/lib/domoticz/plugins/Domoticz-Zigate/
Status: (PiZigate) homedirectory set to /usr/lib/domoticz/plugins/Domoticz-Zigate/
Status: (PiZigate) pluginData set to /var/lib/domoticz/plugins/Domoticz-Zigate/Data/
Status: (PiZigate) pluginConfig set to /etc/domoticz/plugins/Domoticz-Zigate/
Status: (PiZigate) pluginOTAFirmware set to /usr/lib/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
Status: (PiZigate) pluginReports set to /var/lib/domoticz/plugins/Domoticz-Zigate/Reports/
Status: (PiZigate) pluginWWW set to /usr/lib/domoticz/plugins/Domoticz-Zigate/www/
Status: (PiZigate) Plugin Database: DeviceList-6.txt
Status: (PiZigate) DeviceConf loaded
Status: (PiZigate) load ListOfDevice
Status: (PiZigate) Entries loaded from /var/lib/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-6.txt : 0
Status: (PiZigate) Transport mode: PI
Status: (PiZigate) Python version: ['3.7.3 (default, Apr 3 2019, 05:39:12) ', '[GCC 8.2.0]'] dist: ('debian', '10.2', '') linux_distribution: ('debian', '10.2', '') system: Linux machine: armv7l platform: Linux-4.19.75-v7l+-armv7l-with-debian-10.2 uname: uname_result(system='Linux', node='raspberrypi', release='4.19.75-v7l+', version='#1270 SMP Tue Sep 24 18:51:41 BST 2019', machine='armv7l', processor='') version: #1270 SMP Tue Sep 24 18:51:41 BST 2019 mac_ver: ('', ('', '', ''), '')
Status: RFXCOM: Using serial port: /dev/serial/by-id/usb-RFXCOM_RFXtrx433XL_DO3O3OG2-if00-port0
Error: (PiZigate) 'onStart' failed 'CalledProcessError'.
Error: (PiZigate) ----> Line 779 in '/usr/lib/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
Error: (PiZigate) ----> Line 303 in '/usr/lib/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
Error: (PiZigate) ----> Line 75 in '/usr/lib/domoticz/plugins/Domoticz-Zigate/Modules/piZigate.py', function switchPiZigate_mode
Error: (PiZigate) ----> Line 487 in '/usr/lib/python3.7/subprocess.py', function run
subtype = Interface Response
subtype Sequence nbr = 2
subtype response on cmnd = Get Status
subtype Transceiver type = 433.92MHz
subtype Firmware version = 1041
subtype Firmware type = Pro XL1
subtype Noise Level: 85
subtype Hardware version = 3.0
subtype Undec off
subtype X10 enabled
subtype ARC enabled
subtype AC enabled
subtype HomeEasy EU disabled
subtype Meiantech/Atlantic disabled
subtype Oregon Scientific enabled
subtype ATI/Cartelectronic disabled
subtype Visonic disabled
subtype Mertik disabled
subtype AD disabled
subtype Hideki disabled
subtype La Crosse disabled
subtype Legrand disabled
subtype MSG4Reserved5 disabled
subtype BlindsT0 enabled
subtype BlindsT1 enabled
subtype AE disabled
subtype RUBiCSON disabled
subtype FineOffset disabled
subtype Lighting4 disabled
subtype Conrad RSL disabled
subtype ByronSX disabled
subtype IMAGINTRONIX disabled
subtype KEELOQ disabled
subtype Home Confort disabled
Status: RFXCOM: Async Disabled
Error: SMTP Mailer: Error sending Email to: <domotiquecoueron@gmail.com> !
Error: Notification failed (Email)
(RFXCOM) Energy (Wattmetre)
Status: EventSystem: Script event triggered: Amperage
Error: (PiZigate) 'onHeartbeat' failed 'AttributeError':''NoneType' object has no attribute 'sendData''.
Error: (PiZigate) ----> Line 807 in '/usr/lib/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
Error: (PiZigate) ----> Line 549 in '/usr/lib/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
Error: (PiZigate) ----> Line 76 in '/usr/lib/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function sendZigateCmd
Status: (PiZigate) ZigateConf setting Channel(s) to: 0
Status: (PiZigate) setChannel - Channel set to : 00000000
Error: (PiZigate) ----> Line 551 in '/usr/lib/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
Error: (PiZigate) ----> Line 56 in '/usr/lib/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function start_Zigate
Error: (PiZigate) ----> Line 1011 in '/usr/lib/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function setChannel
qu'avez vous mis comme configuration pour du plugin dans le menu Hardware Domoticz ?
Zigate Model:
Port Série:
tonio1005
Zigate Model: Pi
Port serie: serial0
tonio1005 a écrit : 28 nov. 2019, 10:49 Zigate Model: Pi
Port serie: serial0
est-ce serial0 ou /dev/serial0 ?
tonio1005
/dev/serial0
Dans les logs, je vois que vous etes sur une veille version du plugin .
Donc je vous proposes l'approche suivante:
(1) arret de domoticz
(2) aller dans le repertoire des plugins Domoticz
cd plugins
(3) supprimer le repertoire Domoticz-Zigate
 rm -rf Domoticz-Zigate
(4) installer la dernière version du plugin
git clone https://github.com/pipiche38/Domoticz-Zigate.git
(5) relancer Domoticz
- desactiver tous les plugins
- et regarder ce qu'il se passe en activement seulement le plugin zigate
tonio1005
toute la procédure s'est passée correctement, voici les logs:
(PiZigate) Debug: 0
PS: je vous ai envoyé un MP si ça peut aider...
Dernière modification par tonio1005 le 28 nov. 2019, 11:16, modifié 1 fois.
tonio1005 a écrit : 28 nov. 2019, 11:13 toute la procédure s'est passée correctement, voici les logs:
(PiZigate) Debug: 0
Ce n'est pas la bonne version du plugin. Donc soit il y a des choses qui traine d'une autre version du firmware, soit ce ne sont pas les bon logs.
