(Reading database ... 126525 files and directories currently installed.)
Preparing to unpack node-mydomoathome-0.2.45.deb ...
/usr/local/bin/forever -> /usr/local/lib/node_modules/forever/bin/forever
forever@4.0.1 /usr/local/lib/node_modules/forever
├── object-assign@4.1.1
├── clone@2.1.2
├── eventemitter2@6.4.4
├── colors@0.6.2
├── async@1.5.2
├── mkdirp@0.5.5 (minimist@1.2.5)
├── configstore@4.0.0 (xdg-basedir@3.0.0, graceful-fs@4.2.8, dot-prop@4.2.1, unique-string@1.0.0, make-dir@1.3.0, write-file-atomic@2.4.3)
├── nssocket@0.6.0 (eventemitter2@0.4.14, lazy@1.0.11)
├── cliff@0.1.10 (eyes@0.1.8, colors@1.0.3)
├── prettyjson@1.2.1 (minimist@1.2.5, colors@1.4.0)
├── winston@0.8.3 (cycle@1.0.3, eyes@0.1.8, async@0.2.10, stack-trace@0.0.10, isstream@0.1.2, pkginfo@0.3.1)
├── shush@1.0.0 (strip-json-comments@0.1.3, caller@0.0.1)
├── forever-monitor@3.0.3 (minimatch@3.0.4, ps-tree@1.2.0, chokidar@2.1.8)
└── flatiron@0.4.3 (director@1.2.7, optimist@0.6.0, broadway@0.3.6, prompt@0.2.14)
> bufferutil@4.0.5 install /usr/local/lib/node_modules/pm2/node_modules/@pm2/js-api/node_modules/bufferutil
> node-gyp-build
make: Entering directory '/usr/local/lib/node_modules/pm2/node_modules/@pm2/js-api/node_modules/bufferutil/build'
CC(target) Release/obj.target/bufferutil/src/bufferutil.o
SOLINK_MODULE(target) Release/obj.target/bufferutil.node
COPY Release/bufferutil.node
make: Leaving directory '/usr/local/lib/node_modules/pm2/node_modules/@pm2/js-api/node_modules/bufferutil/build'
> bufferutil@4.0.5 install /usr/local/lib/node_modules/pm2/node_modules/@pm2/agent/node_modules/bufferutil
> node-gyp-build
make: Entering directory '/usr/local/lib/node_modules/pm2/node_modules/@pm2/agent/node_modules/bufferutil/build'
make: Leaving directory '/usr/local/lib/node_modules/pm2/node_modules/@pm2/agent/node_modules/bufferutil/build'
> utf-8-validate@5.0.7 install /usr/local/lib/node_modules/pm2/node_modules/@pm2/js-api/node_modules/utf-8-validate
> node-gyp-build
make: Entering directory '/usr/local/lib/node_modules/pm2/node_modules/@pm2/js-api/node_modules/utf-8-validate/build'
CC(target) Release/obj.target/validation/src/validation.o
SOLINK_MODULE(target) Release/obj.target/validation.node
COPY Release/validation.node
make: Leaving directory '/usr/local/lib/node_modules/pm2/node_modules/@pm2/js-api/node_modules/utf-8-validate/build'
> utf-8-validate@5.0.7 install /usr/local/lib/node_modules/pm2/node_modules/@pm2/agent/node_modules/utf-8-validate
> node-gyp-build
make: Entering directory '/usr/local/lib/node_modules/pm2/node_modules/@pm2/agent/node_modules/utf-8-validate/build'
make: Leaving directory '/usr/local/lib/node_modules/pm2/node_modules/@pm2/agent/node_modules/utf-8-validate/build'
/usr/local/bin/pm2 -> /usr/local/lib/node_modules/pm2/bin/pm2
/usr/local/bin/pm2-dev -> /usr/local/lib/node_modules/pm2/bin/pm2-dev
/usr/local/bin/pm2-docker -> /usr/local/lib/node_modules/pm2/bin/pm2-docker
/usr/local/bin/pm2-runtime -> /usr/local/lib/node_modules/pm2/bin/pm2-runtime
pm2@5.1.2 /usr/local/lib/node_modules/pm2
├── @pm2/pm2-version-check@1.0.4
├── cli-tableau@2.0.1
├── commander@2.15.1
├── eventemitter2@5.0.1
├── pm2-axon-rpc@0.7.1
├── sprintf-js@1.1.2
├── mkdirp@1.0.4
├── fclone@1.0.11
├── debug@4.3.3 (ms@2.1.2)
├── pidusage@2.0.21 (safe-buffer@5.2.1)
├── pm2-deploy@1.0.2 (run-series@1.1.9, tv4@1.3.0)
├── pm2-multimeter@0.1.2 (charm@0.1.2)
├── promptly@2.2.0 (read@1.0.7)
├── pm2-axon@4.0.1 (amp-message@0.1.2, escape-string-regexp@4.0.0, amp@0.3.1)
├── source-map-support@0.5.19 (buffer-from@1.1.2, source-map@0.6.1)
├── chalk@3.0.0 (supports-color@7.2.0, ansi-styles@4.3.0)
├── enquirer@2.3.6 (ansi-colors@4.1.1)
├── pm2-sysmonit@1.2.8 (systeminformation@5.9.17, tx2@1.0.5)
├── chokidar@3.5.2 (normalize-path@3.0.0, glob-parent@5.1.2, is-glob@4.0.3, is-binary-path@2.1.0, anymatch@3.1.2, readdirp@3.6.0, braces@3.0.2)
├── semver@7.3.5 (lru-cache@6.0.0)
├── blessed@0.1.81
├── needle@2.4.0 (sax@1.2.4, debug@3.2.7, iconv-lite@0.4.24)
├── yamljs@0.3.0 (glob@7.2.0, argparse@1.0.10)
├── async@3.2.2
├── dayjs@1.8.36
├── cron@1.8.2 (moment-timezone@0.5.34)
├── vizion@2.2.1 (ini@1.3.8, git-node-fs@1.0.0, js-git@0.7.8, async@2.6.3)
├── @pm2/io@5.0.0 (signal-exit@3.0.6, eventemitter2@6.4.5, semver@6.3.0, shimmer@1.2.1, tslib@1.9.3, require-in-the-middle@5.1.0, @opencensus/core@0.0.9, @opencensus/propagation-b3@0.0.8, async@2.6.3)
├── @pm2/js-api@0.6.7 (eventemitter2@6.4.5, axios@0.21.4, async@2.6.3, bufferutil@4.0.5, utf-8-validate@5.0.7, ws@7.5.6)
└── @pm2/agent@2.0.1 (fast-json-patch@3.1.0, semver@7.2.3, nssocket@0.6.0, proxy-agent@5.0.0, bufferutil@4.0.5, utf-8-validate@5.0.7, ws@7.4.6)
Unpacking mydomoathome (0.2.45) ...
dpkg: dependency problems prevent configuration of mydomoathome:
mydomoathome depends on npm (>= 3.5.2); however:
Version of npm on system is 2.14.7.
dpkg: error processing package mydomoathome (--install):
dependency problems - leaving unconfigured
Processing triggers for systemd (232-25+deb9u1) ...
Errors were encountered while processing:
mydomoathome
