Plugin Rfplayer Rfp1000
Beastie
Re: Plugin Rfplayer Rfp1000
Message par Beastie »
Bonsoir
J'essaye d'ajouter un détecteur de mouvement compatible Visonic 868
Je rencontre une erreur.
2021-04-29 19:28:07.021 RFPlayer: (RFPlayer) ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-77", "floorNoise": "-106", "rfQuality": "7", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "1800233760", "qualifier": "2", "qualifierMeaning": { "flags": ["Alarm"]}}}}
2021-04-29 19:28:07.021 RFPlayer: (RFPlayer) ReadData - ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-77", "floorNoise": "-106", "rfQuality": "7", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "1800233760", "qualifier": "2", "qualifierMeaning": { "flags": ["Alarm"]}}}}
2021-04-29 19:28:07.021 RFPlayer: (RFPlayer) infoType : 2
2021-04-29 19:28:07.021 RFPlayer: (RFPlayer) Protocol : 2
2021-04-29 19:28:07.021 RFPlayer: (RFPlayer) id : 1800233760 qualifier :2
2021-04-29 19:28:07.021 RFPlayer: (RFPlayer) Options to find or set : {'infoType': '2', 'id': '1800233760', 'protocol': '2', 'subType': '0', 'LevelActions': '||||', 'LevelNames': 'Off|Tamper|Alarm|Tamper+Alarm', 'LevelOffHidden': 'False', 'SelectorStyle': '0'}
2021-04-29 19:28:07.021 RFPlayer: (RFPlayer) Error while reading JSON Infotype
2021-04-29 19:28:07.022 RFPlayer: (RFPlayer) Debug : Error Decoding/Reading { "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "1", "rfLevel": "-77", "floorNoise": "-106", "rfQuality": "7", "protocol": "2", "protocolMeaning": "VISONIC", "infoType": "2", "frequency": "868950"},"infos": {"subType": "0", "subTypeMeaning": "Detector/Sensor", "id": "1800233760", "qualifier": "2", "qualifierMeaning": { "flags": ["Alarm"]}}}}
ogulf
Message par ogulf »
Le plugin de zaraki673 reste à finaliser pour les devices dont il ne disposait pas à l'époque.
Il me semble que GCE, reprendre du RFPlayer va le maintenir ou le faire évoluer.
- 11 x RF660P
- 1 x FGSD-002
- 10 x F007TH
- 4 x NAS-PD02Z
- 1 x Shelly 1PM
Beastie
Merci.
J'espère qu'il pourra lire le message pour voir s'il continue à le maintenir ou pas.
Je suis pret à aider.
gebleau
Message par gebleau »
J'ai tester l'ancien RFPlayer avec DOMOTICZ/NAS/plugin.py
= réception et émission OK (protocole CHARON)
Avec le nouveau modèle (CGE)
= réception OK, émission ne fonction pas en protocole CHARON (?)
mais fonctionne en protocole X10.
Une idée ?
Beastie
Non, désolé.
Je constate aussi le meme problème. Si le capteur est modifié, il ne fonctionne plus
Dernière modification par Keros le 06 mai 2021, 06:27, modifié 1 fois.
Raison : Merci de ne pas citer le message précédent lors d'une réponse directe. Merci d'éditer le dernier message pour y rajouter l'information supplémentaire
FTN1
Message par FTN1 »
Je vais peut-être poser une question idiote mais quand j’essaye de faire un ajout manuel d’un interrupteur, ma liste de Matériel reste vide malgré le fait d’avoir ajouté le fichier ‹ plugin.py › (Version modifié par Damien en 2019) du RFPlayer (sous domoticz/plugins/rfplayer) et d’avoir ajouté le RFPlayer dans Matériel avec le Nom : RFplayer.
Connaissez-vous ce problème ? Si oui, avez-vous une solution ?
La compilation est bizzare :
/home/pi/domoticz/plugins/rfplayer# python3.7 plugin.py version
Sort en erreur :
File « plugin.py », line 59, in
import Domoticz
ModuleNotFoundError: No module named ‹ Domoticz ›
Beastie
benoit.divers.91 a écrit : 23 oct. 2019, 14:10 Salut,
Pour mes devices Visonic, j'ai changé le script pour avoir un type de device différent dans Domoticz car, en effet, si tu le fais dans l'interface ton device ne fonctionnera plus.
D'ailleurs, il y a en ici qui ont interfacé du Visonic avec le rfp1000 ?
Perso, je n'arrive pas à écouter tous mes devices et je doute que ce soit un problème de porté.
Je suis intéressé par tout retour d'expérience !!!
Ciao.
Bonjour Benoit. As tu réussi au final ? Je galère sérieux avec mes détecteurs de mouvemet Visonic :/
Damien
Message par Damien »
FTN1 a écrit : 12 mai 2021, 21:38 Hello,
Sort en erreur :
import Domoticz
Salut, quelques points à vérifier:
Utilises-tu domoticz en mode Beta ?
Pour ajouter un interrupteur manuellement il faut utiliser le bouton Update et non pas Add (le boutton add ajoute un nouveau périphérique rfplayerbeta et non pas un nouvel interrupteur...).
De mon coté j'arrive à détecter automatiquement les nouveaux boutons/détecteurs/sondes dans la liste des Devices, je peux aussi les ajouter manuellement si je connais l'id. J'arrive également à les modifier après coup.
Le plugin est à jour :
https://github.com/daafunky/Domoticz-Rfplayer
Quelques posts à relire :
viewtopic.php?f=8&t=3934&p=80530#p80530
viewtopic.php?f=8&t=3934&p=74371#p74371
viewtopic.php?f=8&t=3934&p=74186#p74186
viewtopic.php?f=8&t=3934&p=73867#p73867
docmagou
Message par docmagou »
Bonsoir à tous,
Je relance le sujet car je n'arrive plus à commander mes volets avec mes interrupteurs blyss depuis les dernières mises à jour de la béta et du comportement des volets et notamment la disparition du inverted blinds. Quand j'appuie sur Open ou Close, il ne se passe rien.
En passant en mode debug du plugin RFplayer (version daafunky), je retrouve
ZIA--.error.request.number=0.Syntax.error:.CLOSE.BLYSS.ID.42
Quand je modifie le type de volet, l'erreur est différente :
2022-11-11 23:35:47.428 Error: RFPLAYER: Call to function 'onCommand' failed, exception details:
2022-11-11 23:35:47.473 Error: RFPLAYER: Traceback (most recent call last):
2022-11-11 23:35:47.473 Error: RFPLAYER: File "/home/pi/domoticz/plugins/rfplayer/plugin.py", line 331, in onCommand
2022-11-11 23:35:47.473 Error: RFPLAYER: _plugin.onCommand(Unit, Command, Level, Hue)
2022-11-11 23:35:47.473 Error: RFPLAYER: File "/home/pi/domoticz/plugins/rfplayer/plugin.py", line 253, in onCommand
2022-11-11 23:35:47.473 Error: RFPLAYER: SendtoRfplayer(Unit, Command, Level, Hue)
2022-11-11 23:35:47.473 Error: RFPLAYER: File "/home/pi/domoticz/plugins/rfplayer/plugin.py", line 482, in SendtoRfplayer
2022-11-11 23:35:47.473 Error: RFPLAYER: if str(Options['id'])[0].isdigit() : fulltextid = " ID "+ Options['id']
2022-11-11 23:35:47.473 Error: RFPLAYER: KeyError: 'id'
A priori il y aurait des modifications à faire au plugin et notamment passer du on/off au Open/Close.
Certains d'entre vous ont-ils déjà fait la modification et pourraient ils la partager?
Merci à tous et bonne soirée
gaston
Message par gaston »
Elo,
j'explique ça ICI
