Re: interrupteur 3 touches 9 scenes
Publié : 16 nov. 2021, 19:01
Ha non, pas possible sur windows, la par contre pas de solution avant je dirais 2 mois, que les fichiers DDF soient en place.
Reprenez le contrôle de votre domotique
https://easydomoticz.com/forum/
manufacturer: _TZ3000_gbm10jnj
model id: TS0043 Code : Tout sélectionner
"schema": "devcap1.schema.json",
"manufacturername": "_TZ3000_gbm10jnj",
"modelid": "TS0043",
"product": "Tuya 3 gangs switch battery",
"sleeper": false,
"status": "Gold",
"subdevices": [
"type": "$TYPE_SWITCH",
"restapi": "/sensors",
"uuid": [
"$address.ext",
"0x01",
"0x0006"
"items": [
"name": "attr/id"
"name": "attr/lastannounced"
"name": "attr/lastseen"
"name": "attr/manufacturername"
"name": "attr/modelid"
"name": "attr/name"
"name": "attr/swversion"
"name": "attr/type"
"name": "attr/uniqueid"
"name": "config/battery",
"awake": true,
"refresh.interval": 4000,
"read": {
"at": "0x0021",
"cl": "0x0001",
"ep": 1,
"fn": "zcl"
"parse": {
"at": "0x0021",
"cl": "0x0001",
"ep": 1,
"eval": "Item.val = Attr.val / 2"
"default": 0
"name": "config/on"
"name": "config/reachable"
"name": "state/buttonevent"
"name": "state/lastupdated"
"bindings": [
"bind": "unicast",
"src.ep": 1,
"cl": "0x0001",
"report": [
"at": "0x0021",
"dt": "0x20",
"min": 60,
"max": 3600,
"change": "0x00000001"
"bind": "unicast",
"src.ep": 1,
"dst.ep": 1,
"cl": "0x0006"
"bind": "unicast",
"src.ep": 2,
"dst.ep": 1,
"cl": "0x0006"
"bind": "unicast",
"src.ep": 3,
"dst.ep": 1,
"cl": "0x0006"
"Tuya3gangMap": {
"vendor": "Tuya",
"doc": "3-gang remote",
"modelids": ["_TZ3000_ee8nrt2l", "_TZ3000_ygvf9xzp", "_TZ3000_t8hzpgnd", "_TZ3000_wkai4ga5", "_TZ3000_bi6lpsew", "_TZ3400_keyjhapk", "_TYZB02_key8kk7r", "_TZ3400_keyjqthh", "_TZ3400_key8kk7r", "_TZ3000_vp6clf9d", "_TYZB02_keyjqthh", "_TZ3000_peszejy7", "_TZ3000_qzjcsmar", "_TZ3000_owgcnkrh", "_TZ3000_adkvzooy", "_TZ3000_arfwfgoa", "_TZ3000_a7ouggvs", "_TZ3000_rrjr1q0u", "_TZ3000_abci1hiu", "_TZ3000_dfgbtub0", "_TZ3000_rco1yzb1", "_TZ3000_gbm10jnj"],
"map": [Sur windows (a comfirmer, il y a une issue avec ca) mais ca doit etre un de ces liens (tu peux en avoir plusieurs, mais un seul marchera)All DDF provided directly with deCONZ typically reside in /usr/share/deCONZ/devices/ on a Linux system and are loaded first. However, files residing in the home directory of the user running deCONZ (e.g. /home/<DECONZUSER>/.local/share/dresden-elektronik/deCONZ/devices) will override the pre-packaged files to allow users to amend and keep their own files if desired.
C:\Users\XXXXX\AppData\Local\dresden-elektronik\deCONZ\devices
C:\Users\XXXXX\AppData\Local\deCONZ\devicesCode : Tout sélectionner
"sleeper": false,
"status": "Gold",
"subdevices": [
"uuid": [
"$address.ext",
"0x01",
"0x0006"
"items": [
"name": "attr/id"
"name": "attr/name"
"name": "attr/type"
"awake": true,
"read": {
"at": "0x0021",
"cl": "0x0001",
"ep": 1,
"fn": "zcl"
"parse": {
"at": "0x0021",
"cl": "0x0001",
"ep": 1,
"default": 0
"name": "config/on"
"bindings": [
"bind": "unicast",
"src.ep": 1,
"cl": "0x0001",
"report": [
"at": "0x0021",
"dt": "0x20",
"min": 60,
"max": 3600,
"bind": "unicast",
"src.ep": 1,
"dst.ep": 1,
"cl": "0x0006"
"bind": "unicast",
"src.ep": 2,
"dst.ep": 1,
"cl": "0x0006"
"bind": "unicast",
"src.ep": 3,
"dst.ep": 1,
"cl": "0x0006"
}Code : Tout sélectionner
