Compteur d'energie DDS238-2 Zigbee
Plugins DeConz et ZigBee2MQTT
Thorgal
Re: Compteur d'energie DDS238-2 Zigbee
Message par Thorgal »
Oui phoscon est encore au lampes lidl ^^
Nouveau DDf avec convertion des valeurs et correction pr voltage et current
  "schema": "devcap1.schema.json",
  "manufacturername": ["_TZE200_byzdayie", "_TZE200_fsb6zw01", "_TZE200_ewxhg6o9"],
  "modelid": ["TS0601", "TS0601", "TS0601"],
  "product": "Single Phase 65A Din Rail Smart Energy Meter",
  "sleeper": true,
  "status": "Gold",
  "subdevices": [
      "type": "$TYPE_ON_OFF_OUTPUT",
      "restapi": "/lights",
      "uuid": [
        "$address.ext",
        "0x01"
      "items": [
          "name": "attr/id"
          "name": "attr/lastannounced"
          "name": "attr/lastseen"
          "name": "attr/manufacturername"
          "name": "attr/modelid"
          "name": "attr/name"
          "name": "attr/swversion",
          "parse": {"fn": "zcl", "ep": 1, "cl": "0x0000", "at": "0x0001", "script": "tuya_swversion.js"},
          "read": {"fn": "zcl", "ep": 1, "cl": "0x0000", "at": "0x0001"}
          "name": "attr/type"
          "name": "attr/uniqueid"
          "name": "state/on",
          "parse": {"fn": "tuya", "dpid": 1, "eval": "Item.val = Attr.val;" },
          "write": {"fn": "tuya", "dpid": 1, "dt": "0x10", "eval": "Item.val == 1 ? 1 : 0;"},
          "read": {"fn": "tuya"}
          "name": "state/reachable"
      "type": "$TYPE_CONSUMPTION_SENSOR",
      "restapi": "/sensors",
      "uuid": [
        "$address.ext",
        "0x01",
        "0x0702"
      "items": [
          "name": "attr/id"
          "name": "attr/name"
          "name": "attr/type"
          "name": "config/offset",
          "default": 0
          "name": "config/on"
          "name": "config/reachable"
          "name": "state/consumption",
          "parse": {"fn": "tuya", "dpid": 17, "eval": "Item.val = Attr.val * 10;" },
          "read": {"fn": "none"},
          "default": 0
          "name": "state/lastupdated"
      "type": "$TYPE_POWER_SENSOR",
      "uuid": [
        "$address.ext",
        "0x01",
        "0x0b04"
      "items": [
          "name": "attr/id"
          "name": "attr/name"
          "name": "attr/type"
          "default": 0
          "name": "config/on"
          "name": "state/current",
          "parse": {"fn": "tuya", "dpid": 18, "eval": "Item.val = Attr.val / 1000;" },
          "default": 0
          "name": "state/voltage",
          "parse": {"fn": "tuya", "dpid": 20, "eval": "Item.val = Attr.val / 10;" },
          "default": 0
          "name": "state/power",
          "parse": {"fn": "tuya", "dpid": 19, "eval": "Item.val = Attr.val / 10;" },
          "default": 0
J'ai fais ca sans logs d'apres les doc que j'ai donc tu peux avoir a ajouster les valeurs.
Par contre d'apres tes logs, le on/off remonte tres bien dans les logs.
Le widget ne se met pas a jour dans domoticz ? C'est peut etre juste la commande qui deconne et le retour se fait bien ? Mais le Dpid est surement bon.
Il me faudrait vraiment les logs vu de deconz quand tu lances la commande via domoticz, avec les flags "DDF", "info" et "info_l2"
Tu te sert bien d'un widget crée dans la partie "interrupteur" ?
Peut etre une erreur visible dans domoticz (dernier parametre du plugin > "debug info only")
xaxa
Message par xaxa »
Thorgal a écrit : 23 oct. 2022, 19:00
faut que tu m expliques comment faire
oui j essaye avec le widget de domoticz dans la partie "interrupteur"
pour les logs de domoticz il y a beaucoup d infos qui apparaissent, mais je peux pas faire de copier coller
Thorgal
Ca n'a pas ete reactivé depuis ? Une capture d'ecran si tu veux.
Dans deconz / help / debug view, coche les cases "DDF" "info", puis essaye de lancer une commande on/off de domoticz.
Je recherche une ligne commencant par "writeTuyaData"'
xaxa
Message par xaxa »
log de phocon
19:41:22:979 SC tick --> StateRead
19:41:26:051 max transmit errors for node 0x00158D0005BCFCEA, last seen by neighbors 1541 s
19:41:27:826 ZCL attribute report 0x9035EAFFFEBEE1C4 for cluster: 0x0000, ep: 0x01, frame control: 0x08, mfcode: 0x0000
19:41:30:232 90:35:ea:ff:fe:be:e1:c4-01/state/on expression: Item.val = Attr.val; --> false
19:41:30:233 TY_DATA_RESPONSE: seq 70, dpid: 0x01, type: 0x01, length: 1, val: 0
19:41:30:234 TY_DATA_RESPONSE: seq 70, dpid: 0x01, type: 0x01, length: 1, val: 0
19:41:30:235 TY_DATA_RESPONSE: seq 70, dpid: 0x01, type: 0x01, length: 1, val: 0
19:41:31:238 TY_DATA_RESPONSE: seq 70, dpid: 0x12, type: 0x02, length: 4, val: 0
19:41:31:239 TY_DATA_RESPONSE: seq 70, dpid: 0x12, type: 0x02, length: 4, val: 0
19:41:31:240 TY_DATA_RESPONSE: seq 70, dpid: 0x12, type: 0x02, length: 4, val: 0
19:41:32:236 TY_DATA_RESPONSE: seq 70, dpid: 0x13, type: 0x02, length: 4, val: 0
19:41:32:237 TY_DATA_RESPONSE: seq 70, dpid: 0x13, type: 0x02, length: 4, val: 0
19:41:32:238 90:35:ea:ff:fe:be:e1:c4-01-0b04/state/power expression: Item.val = Attr.val; --> 0
19:41:32:239 TY_DATA_RESPONSE: seq 70, dpid: 0x13, type: 0x02, length: 4, val: 0
19:41:33:237 TY_DATA_RESPONSE: seq 70, dpid: 0x14, type: 0x02, length: 4, val: 2276
19:41:33:238 TY_DATA_RESPONSE: seq 70, dpid: 0x14, type: 0x02, length: 4, val: 2276
19:41:33:239 TY_DATA_RESPONSE: seq 70, dpid: 0x14, type: 0x02, length: 4, val: 2276
19:41:34:236 TY_DATA_RESPONSE: seq 70, dpid: 0x11, type: 0x02, length: 4, val: 33075
19:41:34:237 TY_DATA_RESPONSE: seq 70, dpid: 0x11, type: 0x02, length: 4, val: 33075
19:41:34:238 TY_DATA_RESPONSE: seq 70, dpid: 0x11, type: 0x02, length: 4, val: 33075
19:41:36:012 Device TTL 1994 s flags: 0x7
19:41:36:183 max transmit errors for node 0x00158D0005BCFCEA, last seen by neighbors 1551 s
19:41:43:980 SC tick --> StateRead
19:41:46:315 max transmit errors for node 0x00158D0005BCFCEA, last seen by neighbors 1561 s
Thorgal
Soit c'etait juste avant, soit il n'envoit pas la commande du tout, pas de ligne ou deconz envoit la commande "writeTuyaData ....."
Ca peut venir du plugin aussi.
xaxa
Message par xaxa »
pour les logs domoticz
2022-10-23 19:45:22.077 deCONZ : ### Initialisation > configuration
2022-10-23 19:45:22.077 deCONZ : ### Demande de configuration
2022-10-23 19:45:22.078 deCONZ : envoyer la commande /api/211D14A874/config/ avec aucun (0 dans la mémoire tampon)
2022-10-23 19:45:22.078 deCONZ : Faire une demande : http://127.0.0.1:80/api/211D14A874/config/ avec params Aucun
2022-10-23 19:45:22.101 deCONZ : Demande de retour : {"UTC":"2022-10-23T17:45:22","apiversion":"1.16.0","backup":{"errorcode" :0,"status":"idle"},"bridgeid":"00212EFFFF0551F8","datastoreversion":"93","devicename":"ConBee II","dhcp":true,"disablePermitJoinAutoOff":false," factorynew":false,"fwversion":"0x26720700","gateway":"192.168.0.1","internetservices":{"internet":"connecté","remoteaccess":"déconnecté","swupdate":"connecté ","time":"connecté"},"ipaddress":"192.168.0.12","lightlastseeninterval":60,"linkbutton":false,"localtime":"2022-10-23T19:45:22","mac":"b8:27:eb:7a:02:96","modelid":"deCONZ","name":"xavier ","netmask":"255.255.255.0","networkopenduration":180,"panid":57232,"portalconnection":"déconnecté","portalservices":false,"portalstate":{"communication":"déconnecté" ,"incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"aucun","proxyport":0,"replacesbridgeid":null,"rfconnected":true,"starterkitid": "","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"capteurs":[]},"notifier":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""}, "bridge":{"lastinstall":"2022-09-19T22:07:43","state":"noupdates"},"checkforupdate":false,"lastchange":"","state":"noupdates" },"swversion":"2.18.2","timeformat":"24h","timezone":"Europe/Paris","uuid":"95835a03-3cb1-4e4c-91e9-e14f8b329700","websocketnotifyall": true,"websocketport":8088,"whitelist":{"04F0AB8C5D":{"create date":"2022-09-18T08:59:51","last use date":"2022-09-18T09:00 : 48","name":"Phoscon#B1536x722"},"1503E087A4":{"create date":"2022-06-11T15:48:41","last use date":"2022-06-11T15:50:52" ,"name":"Phoscon#B1707x802"},"211D14A874":{"create date":"2021-11-02T11:47:59","dernière utilisation":"2022-10-23T17:45:22 ","name":"Domoticz"},"21BAD682AA":{"create date":"2022-02-26T17:06:24","last use date":"2022-02-26T20:40:55" ,"name":"Phoscon#B1536x722"},"2B11D007A3":{"create date":"2022-01-16T10:00:43","last use date":"2022-01-16T13:35:49 ","name":"Phoscon#B1536x722"},"2CE91D6930":{"create date":"2022-09-09T13:59 :41","last use date":"2022-09-09T17:17:33","name":"Phoscon#B1536x722"},"32B0791C51":{"create date":"2022-10-23T07:52 :57","last use date":"2022-10-23T11:07:55","name":"Phoscon#B1707x802"},"359AE51103":{"create date":"2022-02-04T07 : 26:01","last use date":"2022-02-04T22:25:38","name":"Phoscon#B1536x722"},"3A74931B85":{"create date":"2022-02-16T14 :36:19","last use date":"2022-02-16T15:43:37","name":"Phoscon#B1536x722"},"40FB024699":{"create date":"2022-10- 22T10:28:10","dernière utilisation":"2022-10-22T20:33:51","name":"Phoscon#B2048x885"},"48E3E3D5E5":{"create date":"2022-02-02T05:44:08","last use date":"2022-02-02T06:49:56","name":"Phoscon#B1536x722"} ,"4A5405578B":{"create date":"2022-09-11T09:40:21","dernière utilisation":"2022-09-11T09:43:28","name":"Phoscon#B393x476" },"4E0083FE46":{"create date":"2022-02-13T18:19:38","last use date":"2022-02-13T19:07:39","name":"Phoscon#B1536x722 "},"50ABF7CEE3":{"create date":"2022-09-16T07:23:48","last use date":"2022-09-16T09:20:42","name":"Phoscon# B1536x722"},"63EAC85655":{"create date":"2022-09-15T11:24:08","dernière utilisation":"2022-09-15T16:01:16","name":"Phoscon#B393x476"},"677AB37F38":{"create date":"2022-02-02T10:07:49","dernière utilisation": "2022-02-02T10:08:26","name":"Phoscon#B1280x888"},"68052D6269":{"create date":"2022-06-15T13:58:06","date de la dernière utilisation" :"2022-06-15T14:00:44","name":"Phoscon#B1707x802"},"6C544893C3":{"create date":"2022-02-15T14:35:42","dernière utilisation ":"2022-02-15T19:16:32","name":"Phoscon#B1536x722"},"7DF145313C":{"create date":"2022-01-16T20:10:33","dernière utilisation date":"2022-01-16T22:25:29","name":"Phoscon#B1536x664"},"7FCC806AEC":{"create date":"2022-02-03T07:49:17","dernière utilisation":"2022-02-03T07:49:25","name":"Phoscon#B1536x722"},"815C6C64FE":{ "create date":"2022-02-01T08:22:56","dernière utilisation":"2022-02-01T08:23:11","name":"Phoscon#B1280x552"},"894FF2A293": {"create date":"2021-12-30T07:23:04","last use date":"2021-12-30T07:29:35","name":"Hue Essentials#M2002J9G"},"8CD5B327C1 ":{"create date":"2022-09-01T11:59:34","dernière utilisation":"2022-09-01T18:08:35","name":"Phoscon#B1707x802"}," 920D13DB61":{"create date":"2022-02-05T12:29:17","dernière utilisation":"2022-02-05T12:32:15","name":"Phoscon#B1536x664"},"923AEDB09D":{"create date":"2022-05-14T04:56:59","last use date":"2022-05-14T07:00:01" ,"name":"Phoscon#B1536x722"},"92CA3B095D":{"create date":"2022-09-17T17:16:18","last use date":"2022-09-17T17:26:56 ","name":"Phoscon#B1536x722"},"9CDB67C941":{"create date":"2022-09-11T09:34:11","last use date":"2022-09-11T18:26 : 25","name":"Phoscon#B1536x664"},"9D33C4DC24":{"create date":"2022-01-16T13:28:41","last use date":"2022-01-16T16:08 :43","name":"Phoscon#B1050x886"},"A9695B892C":{"create date":"2022-02-12T19 :28:02","last use date":"2022-02-12T19:30:14","name":"Phoscon#B1050x854"},"AD56472457":{"create date":"2022-01-31T06 :12:08","last use date":"2022-01-31T06:12:29","name":"Phoscon#B1536x722"},"AE15B70A40":{"create date":"2022-09- 25T06:07:53","dernière utilisation":"2022-09-25T07:53:19","name":"Phoscon#B2048x885"},"AE45F85A2B":{"create date":"2022-02 -12T18:13:25","last use date":"2022-02-12T18:15:58","name":"Phoscon#B1229x577"},"AFE58F2E41":{"create date":"2022- 09-20T15:09:12","dernière utilisation":"2022-09-20T16:54:21","name":"Phoscon#B1536x722"},"B1C23FA402":{"create date":"2022-02-13T18:06:47","last use date":"2022-02-15T17:37:19","name":"Phoscon#B1536x722 "},"B5205D77DA":{"create date":"2022-09-08T12:46:49","dernière utilisation":"2022-09-08T13:26:59","name":"Phoscon# B393x728"},"B5C49AC96A":{"create date":"2022-09-24T14:03:06","last use date":"2022-09-24T20:38:58","name":"Phoscon #B1536x722"},"B711D55F67":{"create date":"2022-09-07T15:51:37","dernière utilisation":"2022-09-07T18:18:24","name":" Phoscon#B1536x664"},"BD4A1CFE10":{"date de création":"2022-02-18T16:02:36","date de dernière utilisation":"2022-02-18T21:49:05","name":"Phoscon#B1536x722"},"C01E637223":{"create date":"2022-09-17T11:22:10","dernière date d'utilisation": "2022-09-17T13:45:53","name":"Phoscon#B1536x722"},"C04CDBEDB8":{"create date":"2022-02-19T05:49:05","dernière utilisation" :"2022-02-19T09:09:00","name":"Phoscon#B1536x722"},"CCC2DFD22A":{"create date":"2022-01-16T16:08:27","dernière utilisation ":"2022-01-16T16:08:40","name":"PhoscoPhoscon#B1536x722"},"C04CDBEDB8":{"create date":"2022-02-19T05:49:05","last use date":"2022-02-19T09:09:00","name": "Phoscon#B1536x722"},"CCC2DFD22A":{"create date":"2022-01-16T16:08:27","last use date":"2022-01-16T16:08:40","nom" :" PhoscoPhoscon#B1536x722"},"C04CDBEDB8":{"create date":"2022-02-19T05:49:05","last use date":"2022-02-19T09:09:00","name": "Phoscon#B1536x722"},"CCC2DFD22A":{"create date":"2022-01-16T16:08:27","last use date":"2022-01-16T16:08:40","nom" :" Phosco
2022-10-23 19:45:22.104 deCONZ : Données classiques : {'UTC' : '2022-10-23T17:45:22', 'apiversion' : '1.16.0', 'backup' : {'errorcode' : 0, 'status' : 'idle'}, 'bridgeid' : '00212EFFFF0551F8', 'datastoreversion' : '93', 'devicename' : 'ConBee II', 'dhcp' : vrai, 'disablePermitJoinAutoOff' : faux, ' factorynew' : Faux, 'fwversion' : '0x26720700', 'gateway' : '192.168.0.1', 'internetservices' : {'internet' : 'connecté', 'remoteaccess' : 'déconnecté', 'swupdate' : 'connecté ', 'time' : 'connected'}, 'ipaddress' : '192.168.0.12', 'lightlastseeninterval' : 60, 'linkbutton' : Faux, 'localtime' : '2022-10-23T19:45:22', 'mac': 'b8:27:eb:7a:02:96', 'modelid': 'deCONZ', 'name': 'xavier', 'netmask': ' 255.255.255.0', 'networkopenduration' : 180, 'panid' : 57232, 'portalconnection' : 'disconnected', 'portalservices' : faux, 'portalstate' : {'communication' : 'disconnected', 'incoming' : faux, 'outgoing' : Faux, 'signedon' : Faux}, 'proxyaddress' : 'none', 'proxyport' : 0, 'replacesbridgeid' : Aucun, 'rfconnected' : Vrai, 'starterkitid' : '', 'swupdate' : {'checkforupdate' : Faux, 'devicetypes' : {'bridge' : Faux, 'lights' : [], 'sensors' : []}, 'notify' : Faux, 'text' : '', 'updatestate' : 0, 'url' : ''}, 'swupdate2' : {'autoinstall' : {'on' : Faux, 'updatetime' : ''}, 'bridge' : {'lastinstall' : '2022-09 -19T22:07:43', 'state' : 'noupdates'}, 'checkforupdate' : Faux, 'lastchange' : '', 'state' : 'noupdates'}, 'swversion' : '2.18.2', ' timeformat' : '24h', 'timezone' : 'Europe/Paris', 'uuid' : '95835a03-3cb1-4e4c-91e9-e14f8b329700', 'websocketnotifyall' : Vrai, 'websocketport' : 8088, 'whitelist' : { '04F0AB8C5D' : {'date de création' : '2022-09-18T08:59:51', 'dernière date d'utilisation' : '2022-09-18T09:00:48', 'nom' : 'Phoscon#B1536x722'} , '1503E087A4' : {'date de création' : '2022-06-11T15:48:41', 'dernière date d'utilisation' : '2022-06-11T15:50:52', 'nom' : 'Phoscon#B1707x802'}, '211D14A874' : { 'create date' : '2021-11-02T11:47:59', 'last use date' : '2022-10-23T17:45:22', 'name' : 'Domoticz'}, '21BAD682AA' : {' date de création' : '2022-02-26T17:06:24', 'dernière date d'utilisation' : '2022-02-26T20:40:55', 'nom' : 'Phoscon#B1536x722'}, '2B11D007A3' : { 'create date' : '2022-01-16T10:00:43', 'last use date' : '2022-01-16T13:35:49', 'name' : 'Phoscon#B1536x722'}, '2CE91D6930' : {'create date' : '2022-09-09T13:59:41', 'last use date' : '2022-09-09T17:17:33', 'name' : 'Phoscon#B1536x722'},'32B0791C51' : {'date de création' : '2022-10-23T07:52:57', 'dernière date d'utilisation' : '2022-10-23T11:07:55', 'nom' : 'Phoscon#B1707x802'} , '359AE51103' : {'date de création' : '2022-02-04T07:26:01', 'dernière date d'utilisation' : '2022-02-04T22:25:38', 'nom' : 'Phoscon#B1536x722' }, '3A74931B85' : {'create date' : '2022-02-16T14:36:19', 'last use date' : '2022-02-16T15:43:37', 'name' : 'Phoscon#B1536x722 '}, '40FB024699' : {'create date' : '2022-10-22T10:28:10', 'last use date' : '2022-10-22T20:33:51', 'name' : 'Phoscon# B2048x885'}, '48E3E3D5E5' : {'date de création' : '2022-02-02T05:44:08', 'date de dernière utilisation' : '2022-02-02T06:49:56', 'name' : 'Phoscon#B1536x722'}, '4A5405578B' : {'create date' : '2022-09-11T09:40:21', 'last use date' : '2022-09-11T09:43:28', 'name' : 'Phoscon#B393x476'}, '4E0083FE46' : {'create date' : '2022-02-13T18:19:38', 'last use date' : '2022-02-13T19:07:39' , 'nom' : 'Phoscon#B1536x722'}, '50ABF7CEE3' : {'date de création' : '2022-09-16T07:23:48', 'dernière date d'utilisation' : '2022-09-16T09:20:42 ', 'nom' : 'Phoscon#B1536x722'}, '63EAC85655' : {'date de création' : '2022-09-15T11:24:08', 'dernière date d'utilisation' : '2022-09-15T16:01 : 16', 'nom' : 'Phoscon#B393x476'}, '677AB37F38' : {'date de création' : '2022-02-02T10:07:49', 'date de dernière utilisation' :'2022-02-02T10:08:26', 'nom' : 'Phoscon#B1280x888'}, '68052D6269' : {'date de création' : '2022-06-15T13:58:06', 'date de la dernière utilisation' : '2022-06-15T14:00:44', 'nom' : 'Phoscon#B1707x802'}, '6C544893C3' : {'date de création' : '2022-02-15T14:35:42', 'date de la dernière utilisation ' : '2022-02-15T19:16:32', 'nom' : 'Phoscon#B1536x722'}, '7DF145313C' : {'date de création' : '2022-01-16T20:10:33', 'dernière utilisation date' : '2022-01-16T22:25:29', 'nom' : 'Phoscon#B1536x664'}, '7FCC806AEC' : {'date de création' : '2022-02-03T07:49:17', 'dernier use date' : '2022-02-03T07:49:25', 'name' : 'Phoscon#B1536x722'}, '815C6C64FE' : {'create date' : '2022-02-01T08 :22:56', 'date de dernière utilisation' : '2022-02-01T08:23:11', 'nom' : 'Phoscon#B1280x552'}, '894FF2A293' : {'date de création' : '2021-12-30T07 :23:04', 'date de dernière utilisation' : '2021-12-30T07:29:35', 'nom' : 'Hue Essentials#M2002J9G'}, '8CD5B327C1' : {'date de création' : '2022-09 -01T11:59:34', 'date de dernière utilisation' : '2022-09-01T18:08:35', 'nom' : 'Phoscon#B1707x802'}, '920D13DB61' : {'date de création' : '2022- 02-05T12:29:17', 'date de dernière utilisation' : '2022-02-05T12:32:15', 'nom' : 'Phoscon#B1536x664'}, '923AEDB09D' : {'date de création' : '2022 -05-14T04:56:59', 'dernière date d'utilisation' : '2022-05-14T07:00:01', 'nom' : 'Phoscon#B1536x722'}, '92CA3B095D' :{'create date' : '2022-09-17T17:16:18', 'last use date' : '2022-09-17T17:26:56', 'name' : 'Phoscon#B1536x722'}, '9CDB67C941' : {'create date' : '2022-09-11T09:34:11', 'last use date' : '2022-09-11T18:26:25', 'name' : 'Phoscon#B1536x664'}, '9D33C4DC24 ' : {'date de création' : '2022-01-16T13:28:41', 'dernière date d'utilisation' : '2022-01-16T16:08:43', 'nom' : 'Phoscon#B1050x886'}, ' A9695B892C' : {'date de création' : '2022-02-12T19:28:02', 'dernière date d'utilisation' : '2022-02-12T19:30:14', 'nom' : 'Phoscon#B1050x854'}, 'AD56472457' : {'date de création' : '2022-01-31T06:12:08', 'dernière date d'utilisation' : '2022-01-31T06:12:29', 'nom' : 'Phoscon#B1536x722'}, 'AE15B70A40' : {'create date' : '2022-09-25T06:07:53', 'last use date' : '2022-09-25T07:53:19', 'name' : 'Phoscon#B2048x885'}, 'AE45F85A2B' : {'date de création' : '2022-02-12T18:13:25', 'dernière date d'utilisation' : '2022-02-12T18:15:58', 'nom' : 'Phoscon#B1229x577'}, 'AFE58F2E41' : {'date de création' : '2022-09-20T15:09:12', 'date de dernière utilisation' : '2022-09-20T16:54:21', 'nom ' : 'Phoscon#B1536x722'}, 'B1C23FA402' : {'date de création' : '2022-02-13T18:06:47', 'dernière date d'utilisation' : '2022-02-15T17:37:19', ' name' : 'Phoscon#B1536x722'}, 'B5205D77DA' : {'create date' : '2022-09-08T12:46:49', 'last use date' : '2022-09-08T13:26:59', 'name' : 'Phoscon#B393x728'}, 'B5C49AC96A' : {'create date' : '2022-09-24T14:03:06', 'last use date' : '2022-09-24T20:38:58', 'nom' : 'Phoscon#B1536x722'}, 'B711D55F67' : {'date de création' : '2022-09-07T15:51:37', 'date de la dernière utilisation' : '2022-09-07T18:18:24', 'nom' : 'Phoscon#B1536x664'}, 'BD4A1CFE10' : {'date de création' : '2022-02-18T16:02:36', 'date de dernière utilisationdate de dernière utilisation' : '2022-09-07T18:18:24', 'nom' : 'Phoscon#B1536x664'}, 'BD4A1CFE10' : {'date de création' : '2022-02-18T16:02:36', 'date de la dernière utilisationdate de dernière utilisation' : '2022-09-07T18:18:24', 'nom' : 'Phoscon#B1536x664'}, 'BD4A1CFE10' : {'date de création' : '2022-02-18T16:02:36', 'date de la dernière utilisation
2022-10-23 19:45:22.104 deCONZ : ### Demander des lumières
2022-10-23 19:45:22.104 deCONZ : envoyer la commande /api/211D14A874/lights/ avec aucun (0 dans la mémoire tampon)
2022-10-23 19:45:22.104 deCONZ : Faire une demande : http://127.0.0.1:80/api/211D14A874/lights/ avec params Aucun
2022-10-23 19:45:22.122 deCONZ : Demande de retour : {"1":{"etag":"219f6f11edbae7fc8f3bb4967c0012d2","hascolor":false,"lastannounced":null,"lastseen":"2022-08- 13T13:21Z","manufacturername":"dresden elektronik","modelid":"ConBee II","name":"Outil de configuration 1","state":{"accessible":true},"swversion":" 0x26720700","type":"Outil de configuration","uniqueid":"00:21:2e:ff:ff:05:51:f8-01"},"12":{"etag":"7a6a2015af12cbc7f659e9d992b30145", "hascolor":false,"lastannounced":"2022-10-21T06:45:52Z","lastseen":"2022-10-23T05:03Z","manufacturername":"Legrand","modelid":"Interrupteur du micromodule","name":"Voyant Marche/Arrêt 12","state":{"alert":"none","on":false,"reachable":true},"swversion": "001c","type":"Lumière marche/arrêt","uniqueid":"00:04:74:00:00:0e:a2:e4-01"},"13":{"etag":" 113abe40ce767d2e702655ab725f27f0","hascolor":false,"lastannounced":null,"lastseen":"2022-10-23T17:45Z","manufacturername":"_TZE200_ewxhg6o9","modelid":"TS0601","name":" Prise intelligente 13","state":{"on":true,"reachable":true},"swversion":null,"type":"Sortie marche/arrêt","uniqueid":"90:35:ea :ff:fe:be:e1:c4-01"},"15":{"etag":"3b460947c4696d3008037885ce66c29f","hascolor":false,"lastannounced":"2022-07-10T17:14:52Z","lastseen":"2022-10-23T05:01Z"," manufacturername":"_TZ3000_8kzqqzu4","modelid":"TS130F","name":"Dispositif couvre-fenêtre 15","state":{"bri":254,"lift":100,"on":true," open":false,"reachable":true},"swversion":null,"type":"Dispositif couvrant la fenêtre","uniqueid":"00:0d:6f:ff:fe:cc:14:16-01 "},"2":{"etag":"79816e3d913440785775d85ab941ff53","hascolor":false,"lastannounced":"2022-10-01T23:48:53Z","dernière vue":"2022-10-01T23:48Z ","manufacturername":"IKEA of Sweden","modelid":"Prise de commande TRADFRI","name":"On/Off plug-in unit 1","state":{"alert":"none","on" :true,"reachable":true},"swversion":"2.0.024","type":"Unité enfichable Marche/Arrêt","uniqueid":"08:6b:d7:ff:fe:06 :04:a5-01"},"3":{"etag":"7584894b5f005e46f8aed49121908e75","hascolor":false,"lastannounced":"2022-06-13T12:52:04Z","lastseen":"2022 -08-13T13:25Z","manufacturername":"IKEA of Sweden","modelid":"Prise de commande TRADFRI","name":"On/Off plug-in unit 2","state":{"alert ":"aucun","on":vrai,"accessible":true},"swversion":"2.0.024","type":"Unité enfichable Marche/Arrêt","uniqueid":"00:0b:3c:ff:fe:f0:38 : 99-01"},"4":{"etag":"905509741de5f503cd502f65124e3ceb","hascolor":false,"lastannounced":"2022-08-14T06:10:37Z","lastseen":"2022-10- 19T06:52Z","manufacturername":"IKEA of Sweden","modelid":"Prise de commande TRADFRI","name":"On/Off plug-in unit 3","state":{"alert":" none","on":true,"reachable":false},"swversion":"2.0.024","type":"On/Off plug-in unit","uniqueid":"08:6b:d7 :ff:fe:05:55:cf-01"},"5":{"etag":"ce324039c98f7d3d8b75ac1dcb875c79","hascolor":false,"lastannounced":"2022-09-26T16:02:46Z","lastseen":"2022-09-26T16:02Z","manufacturername":"IKEA de Suède"," modelid":"Répéteur de signal TRADFRI","name":"Range extender 5","state":{"alert":"none","reachable":true},"swversion":"2.3.070"," type":"Range extender","uniqueid":"00:0d:6f:ff:fe:be:4a:99-01"},"6":{"etag":"bbabc8193dd4729eb695456f3155469a","hascolor": false,"lastannounced":"2022-10-13T06:26:41Z","lastseen":"2022-10-13T06:26Z","manufacturername":"IKEA of Sweden","modelid":"Prise de commande TRADFRI","name":"On/Off plug-in unit 4","state":{"alert":"none","on":true,"reachable":true},"swversion": "2.0.024","type":"Unité enfichable Marche/Arrêt","uniqueid":"5c:02:72:ff:fe:97:04:aa-01"},"7":{ "colorcapabilities":0,"ctmax":65279,"ctmin":0,"etag":"1894a183c57b658fdcb04aaf667be1dc","hascolor":true,"lastannounced":"2022-10-23T13:41:02Z","dernière vue ":"2022-10-23T16:11Z","manufacturername":"IKEA of Sweden","modelid":"Ampoule TRADFRI E27 WS opale 1000lm","name":"Température de couleur lumière 7","état": {"alerte":"aucun","bri":251,"colormode":"ct","ct":250,"on":true,"reachable":false},"swversion":"2.0.029","type":"Température de couleur lumière ","uniqueid":"ec:1b:bd:ff:fe:2f:fc:ee-01"},"8":{"colorcapabilities":16,"ctmax":454,"ctmin":250, "etag":"a8578f2213b79663d18e07995e8fbf43","hascolor":true,"lastannounced":"2022-03-29T16:59:50Z","lastseen":"2022-10-23T17:16Z","manufacturername":"IKEA of Sweden","modelid":"Panneau FLOALT WS 30x90","name":"Température de couleur lumière 8","state":{"alert":"none","bri":60,"colormode":" ct","ct":337,"on":true,"reachable":true},"swversion":"2.3.068","type":"Température de couleur lumière","uniqueid":"84:2e:14:ff:fe:10 : 4d:de-01"}}
2022-10-23 19:45:22.123 deCONZ : Données classiques : {'1' : {'etag' : '219f6f11edbae7fc8f3bb4967c0012d2', 'hascolor' : Faux, 'lastannounced' : Aucun, 'lastseen' : '2022-08- 13T13:21Z', 'manufacturername' : 'dresden elektronik', 'modelid' : 'ConBee II', 'name' : 'Configuration tool 1', 'state' : {'accessible' : True}, 'swversion' : ' 0x26720700', 'type' : 'Outil de configuration', 'uniqueid' : '00:21:2e:ff:ff:05:51:f8-01'}, '12' : {'etag' : '7a6a2015af12cbc7f659e9d992b30145', 'hascolor' : Faux, 'lastannounced' : '2022-10-21T06:45:52Z', 'lastseen' : '2022-10-23T05:03Z', 'manufacturername' : 'Legrand', 'modelid' : 'Micromodule switch', 'name' : 'On/Off light 12', 'state' : {'alert' : 'none', 'on' : False, 'reachable' : True}, 'swversion' : '001c', 'type' : 'Lumière marche/arrêt', 'uniqueid' : '00:04:74:00:00:0e:a2:e4-01'}, '13' : {'etag' : '113abe40ce767d2e702655ab725f27f0', ' hascolor' : Faux, 'lastannounced' : Aucun, 'lastseen' : '2022-10-23T17:45Z', 'manufacturername' : '_TZE200_ewxhg6o9', 'modelid' : 'TS0601', 'name' : 'Smart plug 13' , 'state' : {'on' : Vrai, 'accessible' : Vrai}, 'swversion' : Aucun, 'type' : 'Activer/Désactiver la sortie', 'uniqueid' : '90:35:ea:ff:fe :be:e1:c4-01'}, '15' : {'etag' : '3b460947c4696d3008037885ce66c29f', 'hascolor' : Faux, 'lastannounced' : '2022-07-10T17:14:52Z', 'dernière vue' : '2022-10-23T05:01Z', 'nom du fabricant' : '_TZ3000_8kzqqzu4', 'modelid' : 'TS130F', 'name' : 'Dispositif couvre-fenêtre 15', 'state' : {'bri' : 254, 'lift' : 100, 'on' : vrai, 'open' : faux, 'accessible' : vrai }, 'swversion' : Aucun, 'type' : 'Dispositif couvrant la fenêtre', 'uniqueid' : '00:0d:6f:ff:fe:cc:14:16-01'}, '2' : {'etag ' : '79816e3d913440785775d85ab941ff53', 'hascolor' : False, 'lastannounced' : '2022-10-01T23:48:53Z', 'lastseen' : '2022-10-01T23:48Z', 'nom du fabricant' : 'IKEA of Sweden ', 'modelid': 'TRADFRI control outlet', 'name': 'On/Off plug-in unit 1', 'state': {'alert': 'none', 'on': True, 'reachable': True}, 'swversion' : '2.0.024', 'type' : 'Unité enfichable marche/arrêt', 'uniqueid' : '08:6b:d7:ff:fe:06:04:a5-01'}, ' 3' : {'etag' : '7584894b5f005e46f8aed49121908e75', 'hascolor' : Faux, 'lastannounced' : '2022-06-13T12:52:04Z', 'lastseen' : '2022-08-13T13:25Z', 'nom du fabricant ' : 'IKEA of Sweden', 'modelid' : 'TRADFRI control outlet', 'name' : 'On/Off plug-in unit 2', 'state' : {'alert' : 'none', 'on' : Vrai, 'accessible' : Vrai}, 'swversion' : '2.0.024', 'type' :'On/Off plug-in unit', 'uniqueid' : '00:0b:3c:ff:fe:f0:38:99-01'}, '4' : {'etag' : '905509741de5f503cd502f65124e3ceb', 'hascolor ' : Faux, 'lastannounced' : '2022-08-14T06:10:37Z', 'lastseen' : '2022-10-19T06:52Z', 'manufacturername' : 'IKEA of Sweden', 'modelid' : 'TRADFRI control outlet', 'name': 'On/Off plug-in unit 3', 'state': {'alert': 'none', 'on': True, 'reachable': False}, 'swversion': ' 2.0.024', 'type' : 'Unité enfichable Marche/Arrêt', 'uniqueid' : '08:6b:d7:ff:fe:05:55:cf-01'}, '5' : {' etag' : 'ce324039c98f7d3d8b75ac1dcb875c79', 'hascolor' : faux, 'lastannounced' : '2022-09-26T16:02:46Z','lastseen' : '2022-09-26T16:02Z', 'manufacturername' : 'IKEA of Sweden', 'modelid' : 'TRADFRI signal repeater', 'name' : 'Range extender 5', 'state' : {' alert' : 'none', 'accessible' : True}, 'swversion' : '2.3.070', 'type' : 'Range extender', 'uniqueid' : '00:0d:6f:ff:fe:be : 4a:99-01'}, '6' : {'etag' : 'bbabc8193dd4729eb695456f3155469a', 'hascolor' : Faux, 'lastannounced' : '2022-10-13T06:26:41Z', 'dernière vue' : '2022- 10-13T06:26Z', 'manufacturername' : 'IKEA of Sweden', 'modelid' : 'TRADFRI control outlet', 'name' : 'On/Off plug-in unit 4', 'state' : {'alert' : 'aucun', 'activé' : Vrai,'accessible' : True}, 'swversion' : '2.0.024', 'type' : 'Activer/Désactiver l'unité enfichable', 'uniqueid' : '5c:02:72:ff:fe:97:04 : aa-01'}, '7' : {'colorcapabilities' : 0, 'ctmax' : 65279, 'ctmin' : 0, 'etag' : '1894a183c57b658fdcb04aaf667be1dc', 'hascolor' : Vrai, 'lastannounced' : '2022- 10-23T13:41:02Z', 'dernière vue' : '2022-10-23T16:11Z', 'nom du fabricant' : 'IKEA de Suède', 'id du modèle' : 'ampoule TRADFRI E27 WS opale 1000lm', 'nom' : 'Color temperature light 7', 'state' : {'alert' : 'none', 'bri' : 251, 'colormode' : 'ct', 'ct' : 250, 'on' : vrai, 'reachable' : Faux}, 'swversion' : '2.0.029', 'type' :'Température de couleur lumière', 'uniqueid' : 'ec:1b:bd:ff:fe:2f:fc:ee-01'}, '8' : {'colorcapabilities' : 16, 'ctmax' : 454, 'ctmin ' : 250, 'etag' : 'a8578f2213b79663d18e07995e8fbf43', 'hascolor' : vrai, 'lastannounced' : '2022-03-29T16:59:50Z', 'dernière vue' : '2022-10-23T17:16Z', 'nom du fabricant ': 'IKEA of Sweden', 'modelid': 'FLOALT panel WS 30x90', 'name': 'Color temperature light 8', 'state': {'alert': 'none', 'bri': 60, ' colormode' : 'ct', 'ct' : 337, 'on' : Vrai, 'accessible' : Vrai}, 'swversion' : '2.3.068', 'type' : 'Température de couleur lumière', 'uniqueid' : '84:2e:14:ff:fe:10:4d:de-01'}}Température de couleur lumière', 'uniqueid' : 'ec:1b:bd:ff:fe:2f:fc:ee-01'}, '8' : {'colorcapabilities' : 16, 'ctmax' : 454, 'ctmin' : 250, 'etag' : 'a8578f2213b79663d18e07995e8fbf43', 'hascolor' : vrai, 'lastannounced' : '2022-03-29T16:59:50Z', 'lastseen' : '2022-10-23T17:16Z', 'nom du fabricant' : 'IKEA of Sweden', 'modelid': 'FLOALT panel WS 30x90', 'name': 'Color temperature light 8', 'state': {'alert': 'none', 'bri': 60, 'colormode ' : 'ct', 'ct' : 337, 'on' : Vrai, 'accessible' : Vrai}, 'swversion' : '2.3.068', 'type' : 'Température de couleur lumière', 'uniqueid' : ' 84:2e:14:ff:fe:10:4d:de-01'}}Température de couleur lumière', 'uniqueid' : 'ec:1b:bd:ff:fe:2f:fc:ee-01'}, '8' : {'colorcapabilities' : 16, 'ctmax' : 454, 'ctmin' : 250, 'etag' : 'a8578f2213b79663d18e07995e8fbf43', 'hascolor' : vrai, 'lastannounced' : '2022-03-29T16:59:50Z', 'lastseen' : '2022-10-23T17:16Z', 'nom du fabricant' : 'IKEA of Sweden', 'modelid': 'FLOALT panel WS 30x90', 'name': 'Color temperature light 8', 'state': {'alert': 'none', 'bri': 60, 'colormode ' : 'ct', 'ct' : 337, 'on' : Vrai, 'accessible' : Vrai}, 'swversion' : '2.3.068', 'type' : 'Température de couleur lumière', 'uniqueid' : ' 84:2e:14:ff:fe:10:4d:de-01'}}}}}}}}}}'uniqueid' : 'ec:1b:bd:ff:fe:2f:fc:ee-01'}, '8' : {'colorcapabilities' : 16, 'ctmax' : 454, 'ctmin' : 250, 'etag ' : 'a8578f2213b79663d18e07995e8fbf43', 'hascolor' : vrai, 'lastannounced' : '2022-03-29T16:59:50Z', 'lastseen' : '2022-10-23T17:16Z', 'nom du fabricant' : 'IKEA of Sweden ', 'modelid' : 'FLOALT panel WS 30x90', 'name' : 'Color temperature light 8', 'state' : {'alert' : 'none', 'bri' : 60, 'colormode' : 'ct' , 'ct' : 337, 'on' : Vrai, 'accessible' : Vrai}, 'swversion' : '2.3.068', 'type' : 'Température de couleur lumière', 'uniqueid' : '84:2e:14 :ff:fe:10:4d:de-01'}}'uniqueid' : 'ec:1b:bd:ff:fe:2f:fc:ee-01'}, '8' : {'colorcapabilities' : 16, 'ctmax' : 454, 'ctmin' : 250, 'etag ' : 'a8578f2213b79663d18e07995e8fbf43', 'hascolor' : vrai, 'lastannounced' : '2022-03-29T16:59:50Z', 'lastseen' : '2022-10-23T17:16Z', 'nom du fabricant' : 'IKEA of Sweden ', 'modelid' : 'FLOALT panel WS 30x90', 'name' : 'Color temperature light 8', 'state' : {'alert' : 'none', 'bri' : 60, 'colormode' : 'ct' , 'ct' : 337, 'on' : Vrai, 'accessible' : Vrai}, 'swversion' : '2.3.068', 'type' : 'Température de couleur lumière', 'uniqueid' : '84:2e:14 :ff:fe:10:4d:de-01'}}fe:2f:fc:ee-01'}, '8' : {'colorcapabilities' : 16, 'ctmax' : 454, 'ctmin' : 250, 'etag' : 'a8578f2213b79663d18e07995e8fbf43', 'hascolor' : Vrai, ' lastannounced' : '2022-03-29T16:59:50Z', 'lastseen' : '2022-10-23T17:16Z', 'manufacturername' : 'IKEA of Sweden', 'modelid' : 'FLOALT panel WS 30x90', 'name' : 'Color temperature light 8', 'state' : {'alert' : 'none', 'bri' : 60, 'colormode' : 'ct', 'ct' : 337, 'on' : vrai, 'accessible' : True}, 'swversion' : '2.3.068', 'type' : 'Température de couleur lumière', 'uniqueid' : '84:2e:14:ff:fe:10:4d:de-01' }}fe:2f:fc:ee-01'}, '8' : {'colorcapabilities' : 16, 'ctmax' : 454, 'ctmin' : 250, 'etag' : 'a8578f2213b79663d18e07995e8fbf43', 'hascolor' : Vrai, ' lastannounced' : '2022-03-29T16:59:50Z', 'lastseen' : '2022-10-23T17:16Z', 'manufacturername' : 'IKEA of Sweden', 'modelid' : 'FLOALT panel WS 30x90', 'name' : 'Color temperature light 8', 'state' : {'alert' : 'none', 'bri' : 60, 'colormode' : 'ct', 'ct' : 337, 'on' : vrai, 'accessible' : True}, 'swversion' : '2.3.068', 'type' : 'Température de couleur lumière', 'uniqueid' : '84:2e:14:ff:fe:10:4d:de-01' }}ctmax' : 454, 'ctmin' : 250, 'etag' : 'a8578f2213b79663d18e07995e8fbf43', 'hascolor' : vrai, 'lastannounced' : '2022-03-29T16:59:50Z', 'dernière vue' : '2022-10- 23T17:16Z', 'manufacturername' : 'IKEA of Sweden', 'modelid' : 'FLOALT panel WS 30x90', 'name' : 'Color temperature light 8', 'state' : {'alert' : 'none', 'bri' : 60, 'colormode' : 'ct', 'ct' : 337, 'on' : vrai, 'accessible' : vrai}, 'swversion' : '2.3.068', 'type' : 'Température de couleur light', 'uniqueid' : '84:2e:14:ff:fe:10:4d:de-01'}}ctmax' : 454, 'ctmin' : 250, 'etag' : 'a8578f2213b79663d18e07995e8fbf43', 'hascolor' : vrai, 'lastannounced' : '2022-03-29T16:59:50Z', 'dernière vue' : '2022-10- 23T17:16Z', 'manufacturername' : 'IKEA of Sweden', 'modelid' : 'FLOALT panel WS 30x90', 'name' : 'Color temperature light 8', 'state' : {'alert' : 'none', 'bri' : 60, 'colormode' : 'ct', 'ct' : 337, 'on' : vrai, 'accessible' : vrai}, 'swversion' : '2.3.068', 'type' : 'Température de couleur light', 'uniqueid' : '84:2e:14:ff:fe:10:4d:de-01'}}'2022-03-29T16:59:50Z', 'lastseen' : '2022-10-23T17:16Z', 'manufacturername' : 'IKEA of Sweden', 'modelid' : 'FLOALT panel WS 30x90', 'name' : 'Température de couleur lumière 8', 'état' : {'alert' : 'none', 'bri' : 60, 'colormode' : 'ct', 'ct' : 337, 'on' : vrai, 'joignable' : True}, 'swversion' : '2.3.068', 'type' : 'Température de couleur lumière', 'uniqueid' : '84:2e:14:ff:fe:10:4d:de-01'}}'2022-03-29T16:59:50Z', 'lastseen' : '2022-10-23T17:16Z', 'manufacturername' : 'IKEA of Sweden', 'modelid' : 'FLOALT panel WS 30x90', 'name' : 'Température de couleur lumière 8', 'état' : {'alert' : 'none', 'bri' : 60, 'colormode' : 'ct', 'ct' : 337, 'on' : vrai, 'joignable' : True}, 'swversion' : '2.3.068', 'type' : 'Température de couleur lumière', 'uniqueid' : '84:2e:14:ff:fe:10:4d:de-01'}}bri' : 60, 'colormode' : 'ct', 'ct' : 337, 'on' : vrai, 'accessible' : vrai}, 'swversion' : '2.3.068', 'type' : 'Température de couleur de la lumière ', 'identifiant unique' : '84:2e:14:ff:fe:10:4d:de-01'}}bri' : 60, 'colormode' : 'ct', 'ct' : 337, 'on' : vrai, 'accessible' : vrai}, 'swversion' : '2.3.068', 'type' : 'Température de couleur de la lumière ', 'identifiant unique' : '84:2e:14:ff:fe:10:4d:de-01'}}
2022-10-23 19:45:22.124 deCONZ : ### Appareil > 1 Nom : Outil de configuration 1 Type : Détails de l'outil de configuration :{'accessible' : True} et []
2022-10-23 19:45:22.124 deCONZ : Dispositif de saut (inutile) : 00:21:2e:ff:ff:05:51:f8-01
2022-10-23 19:45:22.124 deCONZ : ### Appareil > 12 Nom : Voyant marche/arrêt 12 Type : Voyant marche/arrêt Détails :{'alert' : 'none', 'on' : False, 'accessible ' : Vrai} et []
2022-10-23 19:45:22.141 deCONZ : ### Mise à jour de l'appareil (Lumière du Jardin) : {'nValue' : 0, 'sValue' : 'off'}, IGNORED , no changes !
2022-10-23 19:45:22.141 deCONZ : ### Appareil > 13 Nom : prise intelligente 13 Type : sortie marche/arrêt Détails : {'on' : vrai, 'accessible' : vrai} et []
2022-10-23 19:45:22.142 deCONZ : ### Mise à jour de l'appareil (deCONZ - Smart plug 9) : {'nValue' : 1, 'sValue' : 'on'}, IGNORED , no changes !
2022-10-23 19:45:22.142 deCONZ : ### Appareil > 15 Nom :Dispositif de couverture de fenêtre 15 Type :Dispositif de couverture de fenêtre Détails :{'bri' : 254, 'lift' : 100, 'on' : Vrai, 'ouvert' : Faux, 'accessible' : Vrai} et []
2022-10-23 19:45:22.143 deCONZ : ### Mise à jour de l'appareil (Volet roulant) : {'nValue' : 1, 'sValue' : '100'}, IGNORED , no changes !
2022-10-23 19:45:22.143 deCONZ : ### Appareil > 2 Nom : Unité enfichable Marche/Arrêt 1 Type : Unité enfichable Marche/Arrêt Détails :{'alerte' : 'aucun', 'on ' : Vrai, 'accessible' : Vrai} et []
2022-10-23 19:45:22.144 deCONZ : ### Mise à jour de l'appareil (ikea - On/Off unit 1 cuisine) : {'nValue' : 1, 'sValue' : 'on'}, IGNORED , no changes !
2022-10-23 19:45:22.144 deCONZ : ### Appareil > 3 Nom : Unité enfichable On/Off 2 Type : Unité enfichable On/Off Détails :{'alert' : 'none', 'on ' : Vrai, 'accessible' : Vrai} et []
2022-10-23 19:45:22.145 deCONZ : ### Mise à jour de l'appareil (ikea - Unité On/Off 2 Wifinfo) : {'nValue' : 1, 'sValue' : 'on'}, IGNORED , no changes !
2022-10-23 19:45:22.145 deCONZ : ### Appareil > 4 Nom : Unité enfichable marche/arrêt 3 Type : Unité enfichable marche/arrêt Détails :{'alert' : 'none', 'on ' : vrai, 'accessible' : faux} et []
2022-10-23 19:45:22.145 deCONZ : ### Mettre à jour l'appareil (ikea- On/Off unit 3 vmc cave) : {'nValue' : 1, 'sValue' : 'on', 'TimedOut' : 1}
2022-10-23 19:45:22.172 deCONZ : ### Appareil > 5 Nom : Prolongateur de portée 5 Type : Prolongateur de portée Détails :{'alert' : 'none', 'reachable' : True} et []
2022-10-23 19:45:22.173 deCONZ : ### Mise à jour de l'appareil (deCONZ - Range extender 6) : {'nValue' : 0, 'sValue' : 'Off'}, IGNORED , no changes !
2022-10-23 19:45:22.173 deCONZ : ### Appareil > 6 Nom : Unité enfichable On/Off 4 Type : Unité enfichable On/Off Détails :{'alert' : 'none', 'on ' : Vrai, 'accessible' : Vrai} et []
2022-10-23 19:45:22.174 deCONZ : ### Mettre à jour l'appareil (ikea - Unité On/Off 4) : {'nValue' : 1, 'sValue' : 'on'}, IGNORED , no changes !
2022-10-23 19:45:22.174 deCONZ : ### Appareil > 7 Nom : Voyant de température de couleur 7 Type : Voyant de température de couleur Détails :{'alert' : 'none', 'bri' : 251, 'colormode' : 'ct', 'ct' : 250, 'on' : vrai, 'accessible' : faux} et []
2022-10-23 19:45:22.175 deCONZ : ### Mise à jour de l'appareil (deCONZ - Lumière de température de couleur 2) : {'nValue' : 1, 'sValue' : '98', 'Color' : '{"m" :2,"r":0,"g":0,"b":0,"t":132,"ww":132,"cw":123}', 'TimedOut' : 1}
2022-10-23 19:45:22.236 deCONZ : ### Appareil > 8 Nom : Voyant de température de couleur 8 Type : Voyant de température de couleur Détails :{'alert' : 'none', 'bri' : 60, 'colormode' : 'ct', 'ct' : 337, 'on' : Vrai, 'accessible' : Vrai} et []
2022-10-23 19:45:22.237 deCONZ : ### Mise à jour de l'appareil (Panneau_led) : {'nValue' : 1, 'sValue' : '23', 'Color' : '{"m":2,"r ":0,"g":0,"b":0,"t":187,"ww":187,"cw":68}'}
2022-10-23 19:45:22.279 deCONZ : ### Demander des capteurs
2022-10-23 19:45:22.279 deCONZ : envoyer la commande /api/211D14A874/sensors/ avec aucun (0 dans la mémoire tampon)
2022-10-23 19:45:22.280 deCONZ : Faire une demande : http://127.0.0.1:80/api/211D14A874/sensors/ avec params Aucun
2022-10-23 19:45:22.301 deCONZ : Demande de retour : {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30 },"etag":"3881cd7d93012ff7adb1fd85d84c7ce7","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":true,"daylight":false ,"lastupdated":"2022-10-23T17:45:11.767","status":210,"sunrise":"2022-10-23T06:24:01","sunset":"2022-10-23T16 : 48:17"},"swversion":"1.0","type":"Lumière du jour","uniqueid":"00:21:2e:ff:ff:05:51:f8-01"},"11" :{"config":{"battery":88,"on":true,"accessible":true},"ep":1,"etag":"f93d3c05e093d20201c05f646e5f21fc","lastannounced":"2022-10-22T09:01:17Z","lastseen":"2022-10-22T20:34Z", "manufacturername":"Heiman","mode":1,"modelid":"RC-EF-3.0","name":"Télécommande","state":{"buttonevent":4002,"lastupdated": "2022-10-22T20:34:06.106"},"swversion":"2020.8.5","type":"ZHASwitch","uniqueid":"8c:f6:81:ff:fe:f2:50 : d0-01-0501"},"12":{"config":{"battery":100,"on":true,"accessible":false,"temperature":0},"ep":1," etag":"337cc8f25ca66ff7d05a09d0ed93ce76","dernière annonce":"2022-09-24T14:05:54Z","lastseen":"2022-09-24T14:15Z","manufacturername":"LUMI","modelid":"lumi.sensor_magnet","name":" Boîte aux lettres","state":{"lastupdated":"2022-09-24T14:15:49.650","open":false},"type":"ZHAOpenClose","uniqueid":"00:15 : 8d:00:06:89:f1:58-01-0006"},"14":{"config":{"battery":71,"enrolled":0,"on":true,"pending": [],"accessible":false},"ep":1,"etag":"ffff75752179b08a7a4d277ab81387cf","lastannounced":"2022-09-17T12:24:49Z","lastseen":"2022-09-17T13 :26Z","nomfabricant":"eWeLink","IDmodèle":"DS01","name":"Capteur de fenêtre/porte","state":{"lastupdated":"2022-09-17T12:24:49.852","lowbattery":false,"open":true,"altéré" :false},"type":"ZHAOpenClose","uniqueid":"00:12:4b:00:23:97:17:e8-01-0500"},"16":{"config":{" on":true,"accessible":true},"etag":"0d41419a597f24c27c6e11375d42bd13","manufacturername":"Phoscon","modelid":"PHOSCON_FSM_FLAG","name":"CLIP-Sensor CTDIM-TOOGLE"," state":{"flag":false,"lastupdated":"2022-10-23T17:45:11.477"},"swversion":"1.0","type":"CLIPGenericFlag","uniqueid":"0c : 43:14:ff:fe:48:35 :5a-01-1000-ct-dim-toogle-3-1665730268297"},"2":{"config":{"battery":100,"on":true,"pending":[],"accessible" :true,"selftest":false,"sensitivity":1},"ep":1,"etag":"09ab24a5d1de35ba5b02bebe530a676b","lastannounced":null,"lastseen":"2022-10-23T17:45Z", "manufacturername":"LUMI","modelid":"lumi.sensor_smoke","name":"Capteur de fumée","state":{"fire":false,"lastupdated":"2021-11-02T12:30 :01.854","lowbattery":false,"test":false},"swversion":"20170314","type":"ZHAFire","uniqueid":"00:15:8d:00:05:bc : fc:ea-01-0500"},"23":{"config":{"offset":0,"on":true,"accessible":true},"etag":"113abe40ce767d2e702655ab725f27f0","lastannounced":null,"lastseen":"2022-10-23T17:45Z" ,"manufacturername":"_TZE200_ewxhg6o9","modelid":"TS0601","name":"Consommation 23","state":{"consommation":33075,"lastupdated":"2022-10-23T17:14 : 04.329"},"type":"ZHAConsumption","uniqueid":"90:35:ea:ff:fe:be:e1:c4-01-0702"},"24":{"config":{" offset":0,"on":true,"accessible":true},"etag":"cf253343d09d9ad47c456652f769f39e","lastannounced":null,"lastseen":"2022-10-23T17:45Z","manufacturername":"_TZE200_ewxhg6o9","modelid":"TS0601","name":"Power 24","state":{"current":0,"lastupdated":"2022-10-23T17:43:24.401" ,"power":0,"voltage":0},"type":"ZHAPower","uniqueid":"90:35:ea:ff:fe:be:e1:c4-01-0b04"}," 3":{"config":{"alert":"aucun","batterie":87,"group":"2","on":true,"accessible":true},"ep":1, "etag":"ffd4854404bd12f88658e3ddeba3a579","lastannounced":"2022-10-14T06:45:50Z","lastseen":"2022-10-23T17:07Z","manufacturername":"IKEA de Suède","mode ":3,"id_modèle":"Télécommande TRADFRI","name":"Télécommande TRÅDFRI","state":{"buttonevent":1002,"lastupdated":"2022-10-23T17:07:04.907"},"swversion":"2.3. 014","type":"ZHASwitch","uniqueid":"0c:43:14:ff:fe:48:35:5a-01-1000"},"4":{"config":{"on ":true,"accessible":true},"etag":"979788fc676e95a863002c9515c7fdc9","manufacturername":"Phoscon","modelid":"PHOSCON_FSM_FLAG","name":"CLIP-Sensor PUSHDIM-TOOGLE","état ":{"flag":false,"lastupdated":"2022-10-23T17:45:11.475"},"swversion":"1.0","type":"CLIPGenericFlag","uniqueid":"0c:43 :14:ff:fe:48:35:5a-01-1000-pushdim-toogle-3-Tue Nov 02 2021 14:19:39 GMT+0100 (heure normale d'Europe centrale)"},"5":{"config ":{"battery":80,"group":"4","on":true,"accessible":false},"ep":1,"etag":"2284aef802fc1ae333aafc38b3b68d03","lastannounced":"2022 -09-28T18:02:52Z","lastseen":"2022-09-28T18:02Z","manufacturername":"Legrand","mode":1,"modelid":"Interrupteur à distance","nom" :"Interrupteur à distance","state":{"buttonevent":1002,"lastupdated":"2022-09-28T18:02:52.325"},"swversion":"001e","type":"ZHASwitch", "uniqueid":"00:04:74:00:00:af:4b:c6-01-0006"},"6":{"config":{"battery":88,"offset":0,"on":true,"reachable":false},"ep":1,"etag":"79636ba419a2356020aa399b492bb7f7","lastannounced ":null,"lastseen":"2022-10-23T17:45Z","manufacturername":"LUMI","modelid":"lumi.weather","name":"Multi Sensor","state":{ "lastupdated":"2022-10-23T16:43:54.842","temperature":2085},"swversion":"20161129","type":"ZHATemperature","uniqueid":"00:15:8d : 00:04:18:3b:92-01-0402"},"7":{"config":{"battery":88,"offset":0,"on":true,"accessible":false} ","ep":1,"etag":"07a1154895874697b736dbb8cc2ea113","lastannounced":null,"lastseen":"2022-10-23T17:45Z","manufacturername":"LUMI","modelid":"lumi.weather","name":"Humidité 7", "state":{"humidity":9619,"lastupdated":"2022-10-23T16:43:54.875"},"swversion":"20161129","type":"ZHAHumidity","uniqueid":"00 :15:8d:00:04:18:3b:92-01-0405"},"8":{"config":{"battery":88,"offset":0,"on":true," accessible":false},"ep":1,"etag":"2fc829b3205aa55c9e4545e6967e4e49","lastannounced":null,"lastseen":"2022-10-23T17:45Z","manufacturername":"LUMI","modelid":"lumi.weather","name":"Pression 8","state":{"lastupdated":"2022-10-23T16:43:54.882","pression":1012},"swversion": "20161129","type":"ZHAPressure","uniqueid":"00:15:8d:00:04:18:3b:92-01-0403"}}
2022-10-23 19:45:22.303 deCONZ : Données classiques : {'1' : {'config' : {'configured' : Vrai, 'on' : Vrai, 'sunriseoffset' : 30, 'sunsetoffset' : -30 }, 'etag' : '3881cd7d93012ff7adb1fd85d84c7ce7', 'manufacturername' : 'Philips', 'modelid' : 'PHDL00', 'name' : 'Daylight', 'state' : {'dark' : vrai, 'daylight' : faux , 'dernière mise à jour' : '2022-10-23T17:45:11.767', 'status' : 210, 'sunrise' : '2022-10-23T06:24:01', 'sunset' : '2022-10-23T16 : 48:17'}, 'swversion' : '1.0', 'type' : 'Lumière du jour', 'uniqueid' : '00:21:2e:ff:ff:05:51:f8-01'}, '11' : {'config' : {'battery' : 88, 'on' : Vrai, 'joignable' : Vrai}, 'ep' : 1, 'etag' : 'f93d3c05e093d20201c05f646e5f21fc', 'lastannounced' : '2022-10-22T09:01:17Z', 'lastseen' : '2022-10-22T20:34Z', 'nom du fabricant' : 'Heiman' , 'mode' : 1, 'modelid' : 'RC-EF-3.0', 'name' : 'Télécommande', 'state' : {'buttonevent' : 4002, 'lastupdated' : '2022-10-22T20 : 34:06.106'}, 'swversion' : '2020.8.5', 'type' : 'ZHASwitch', 'uniqueid' : '8c:f6:81:ff:fe:f2:50:d0-01-0501'} , '12' : {'config' : {'battery' : 100, 'on' : Vrai, 'accessible' : False, 'temperature' : 0}, 'ep' : 1, 'etag' : '337cc8f25ca66ff7d05a09d0ed93ce76', 'dernière annonce' : '2022-09-24T14:05:54Z', 'dernière vue' :'2022-09-24T14:15Z', 'manufacturername' : 'LUMI', 'modelid' : 'lumi.sensor_magnet', 'name' : 'Boite aux lettres', 'state' : {'lastupdated' : '2022- 09-24T14:15:49.650', 'open' : False}, 'type' : 'ZHAOpenClose', 'uniqueid' : '00:15:8d:00:06:89:f1:58-01-0006'} , '14' : {'config' : {'battery' : 71, 'enrolled' : 0, 'on' : vrai, 'pending' : [], 'accessible' : false}, 'ep' : 1, ' etag' : 'ffff75752179b08a7a4d277ab81387cf', 'lastannounced' : '2022-09-17T12:24:49Z', 'lastseen' : '2022-09-17T13:26Z', 'nom du fabricant' : 'eWeLink', 'ID de modèle' : ' DS01', 'nom' : 'Capteur de fenêtre/porte', 'état' : {'lastupdated' : '2022-09-17T12:24:49.852', 'lowbattery' : Faux, 'open' : Vrai, 'tampered' : False}, 'type' : 'ZHAOpenClose', 'uniqueid' : '00:12 :4b:00:23:97:17:e8-01-0500'}, '16' : {'config' : {'on' : Vrai, 'accessible' : Vrai}, 'etag' : '0d41419a597f24c27c6e11375d42bd13', 'manufacturername' : 'Phoscon', 'modelid' : 'PHOSCON_FSM_FLAG', 'name' : 'CLIP-Sensor CTDIM-TOOGLE', 'state' : {'flag' : False, 'lastupdated' : '2022-10-23T17 :45:11.477'}, 'swversion' : '1.0', 'type' : 'CLIPGenericFlag', 'uniqueid' : '0c:43:14:ff:fe:48:35:5a-01-1000-ct- dim-toogle-3-1665730268297'}, '2' : {'config' : {'batterie' : 100, 'on' : vrai, 'pending' : [], 'reachable' : vrai, 'selftest' : faux, 'sensitivity' : 1}, 'ep' : 1, 'etag' : '09ab24a5d1de35ba5b02bebe530a676b', 'lastannounced' : aucun , 'dernier' : '2022-10-23T17:45Z', 'manufacturername' : 'LUMI', 'modelid' : 'lumi.sensor_smoke', 'name' : 'Smoke Sensor', 'state' : {'fire' : False, 'lastupdated' : '2021-11-02T12:30:01.854', 'lowbattery' : False, 'test' : False}, 'swversion' : '20170314', 'type' : 'ZHAFire', 'uniqueid ' : '00:15:8d:00:05:bc:fc:ea-01-0500'}, '23' : {'config' : {'offset' : 0, 'on' : vrai, 'accessible' : Vrai}, 'etag' : '113abe40ce767d2e702655ab725f27f0', 'lastannounced' : Aucun, 'lastseen' : '2022-10-23T17:45Z', 'manufacturername' : '_TZE200_ewxhg6o9', 'modelid' : 'TS0601', 'name' : 'Consommation' 23', 'state' : 'Consommation' 23' ' : {'consommation' : 33075, 'lastupdated' : '2022-10-23T17:14:04.329'}, 'type' : 'ZHAConsumption', 'uniqueid' : '90:35:ea:ff:fe:be :e1:c4-01-0702'}, '24' : {'config' : {'offset' : 0, 'on' : Vrai, 'accessible' : Vrai}, 'etag' : 'cf253343d09d9ad47c456652f769f39e', 'lastannounced ' : Aucun, 'dernière vue' : '2022-10-23T17:45Z', 'manufacturername' : '_TZE200_ewxhg6o9', 'modelid' : 'TS0601', 'name' : 'Power 24', 'state' :{'current' : 0, 'lastupdated' : '2022-10-23T17:43:24.401', 'power' : 0, 'voltage' : 0}, 'type' : 'ZHAPower', 'uniqueid' : '90 :35:ea:ff:fe:be:e1:c4-01-0b04'}, '3' : {'config' : {'alert' : 'none', 'battery' : 87, 'group' : ' 2', 'on' : Vrai, 'joignable' : Vrai}, 'ep' : 1, 'etag' : 'ffd4854404bd12f88658e3ddeba3a579', 'lastannounced' : '2022-10-14T06:45:50Z', 'lastseen' : '2022-10-23T17:07Z', 'manufacturername': 'IKEA of Sweden', 'mode': 3, 'modelid': 'TRADFRI remote control', 'name': 'TRÅDFRI remote control', 'state': {'buttonevent' : 1002, 'dernière mise à jour' : '2022-10-23T17:07:04.907'},'swversion' : '2.3.014', 'type' : 'ZHASwitch', 'uniqueid' : '0c:43:14:ff:fe:48:35:5a-01-1000'}, '4' : { 'config' : {'on' : vrai, 'accessible' : vrai}, 'etag' : '979788fc676e95a863002c9515c7fdc9', 'manufacturername' : 'Phoscon', 'modelid' : 'PHOSCON_FSM_FLAG', 'name' : 'CLIP-Sensor PUSHDIM-TOOGLE', 'state' : {'flag' : Faux, 'lastupdated' : '2022-10-23T17:45:11.475'}, 'swversion' : '1.0', 'type' : 'CLIPGenericFlag', ' uniqueid' : '0c:43:14:ff:fe:48:35:5a-01-1000-pushdim-toogle-3-Tue Nov 02 2021 14:19:39 GMT+0100 (heure normale d'Europe centrale) '}, '5' : {'config' : {'battery' : 80, 'group' : '4', 'on' :Vrai, 'accessible' : Faux}, 'ep' : 1, 'etag' : '2284aef802fc1ae333aafc38b3b68d03', 'lastannounced' : '2022-09-28T18:02:52Z', 'lastseen' : '2022-09-28T18 : 02Z', 'manufacturername' : 'Legrand', 'mode' : 1, 'modelid' : 'Remote switch', 'name' : 'Remote switch', 'state' : {'buttonevent' : 1002, 'lastupdated' : '2022-09-28T18:02:52.325'}, 'swversion' : '001e', 'type' : 'ZHASwitch', 'uniqueid' : '00:04:74:00:00:af:4b:c6- 01-0006'}, '6' : {'config' : {'battery' : 88, 'offset' : 0, 'on' : vrai, 'accessible' : faux}, 'ep' : 1, 'etag' : '79636ba419a2356020aa399b492bb7f7', 'dernier annoncé' : Aucun, 'lastseen' : '2022-10-23T17:45Z', 'manufacturername' : 'LUMI', 'modelid' : 'lumi.weather', 'name' : 'Multi Sensor', 'state' : {'lastupdated' : ' 2022-10-23T16:43:54.842', 'temperature' : 2085}, 'swversion' : '20161129', 'type' : 'ZHATemperature', 'uniqueid' : '00:15:8d:00:04:18 :3b:92-01-0402'}, '7' : {'config' : {'battery' : 88, 'offset' : 0, 'on' : vrai, 'joignable' : faux}, 'ep' : 1, 'etag' : '07a1154895874697b736dbb8cc2ea113', 'lastannounced' : Aucun, 'lasteen' : '2022-10-23T17:45Z', 'manufacturername' : 'LUMI', 'modelid' : 'lumi.weather', 'name ' : 'Humidité 7', 'état' : {'humidité' : 9619, 'lastupdated' : '2022-10-23T16:43:54.875'}, 'swversion' : '20161129', 'type' : 'ZHAHumidity', 'uniqueid' : '00:15:8d:00 :04:18:3b:92-01-0405'}, '8' : {'config' : {'battery' : 88, 'offset' : 0, 'on' : vrai, 'joignable' : faux}, 'ep' : 1, 'etag' : '2fc829b3205aa55c9e4545e6967e4e49', 'lastannounced' : Aucun, 'lastseen' : '2022-10-23T17:45Z', 'manufacturername' : 'LUMI', 'modelid' : 'lumi.weather ', 'nom' : 'Pression 8', 'état' : {'dernière mise à jour' : '2022-10-23uniqueid' : '00:15:8d:00:04:18:3b:92-01-0405'}, '8' : {'config' : {'battery' : 88, 'offset' : 0, 'on ' : Vrai, 'accessible' : Faux}, 'ep' : 1, 'etag' : '2fc829b3205aa55c9e4545e6967e4e49', 'lastannounced' : Aucun, 'lastseen' : '2022-10-23T17:45Z', 'nom du fabricant' : ' LUMI', 'modelid' : 'lumi.weather', 'name' : 'Pressure 8', 'state' : {'lastupdated' : '2022-10-23uniqueid' : '00:15:8d:00:04:18:3b:92-01-0405'}, '8' : {'config' : {'battery' : 88, 'offset' : 0, 'on ' : Vrai, 'accessible' : Faux}, 'ep' : 1, 'etag' : '2fc829b3205aa55c9e4545e6967e4e49', 'lastannounced' : Aucun, 'lastseen' : '2022-10-23T17:45Z', 'nom du fabricant' : ' LUMI', 'modelid' : 'lumi.weather', 'name' : 'Pressure 8', 'state' : {'lastupdated' : '2022-10-23manufacturername' : 'LUMI', 'modelid' : 'lumi.weather', 'name' : 'Pressure 8', 'state' : {'lastupdated' : '2022-10-23manufacturername' : 'LUMI', 'modelid' : 'lumi.weather', 'name' : 'Pressure 8', 'state' : {'lastupdated' : '2022-10-23
2022-10-23 19:45:22.304 deCONZ : ### Appareil > 1 45:11.767', 'status' : 210, 'sunrise' : '2022-10-23T06:24:01', 'sunset' : '2022-10-23T16:48:17'} et {'configured' : vrai , 'on' : Vrai, 'sunriseoffset' : 30, 'sunsetoffset' : -30}
2022-10-23 19:45:22.305 deCONZ : ### Mise à jour de l'appareil (deCONZ - Lumière du jour) : {'nValue' : 0, 'sValue' : 'Off'}, IGNORED , aucun changement !
2022-10-23 19:45:22.305 deCONZ : ### Appareil > 11 Nom : Type de télécommande : ZHASwitch Détails :{'buttonevent' : 4002, 'lastupdated' : '2022-10-22T20:34:06.106'} et {'battery' : 88, 'on' : Vrai, 'joignable' : Vrai}
2022-10-23 19:45:22.306 deCONZ : ### Mettre à jour l'appareil (deCONZ - Télécommande) : {'nValue' : 0, 'sValue' : 'Off', 'BatteryLevel' : 88}, IGNORED , aucun changement !
2022-10-23 19:45:22.306 deCONZ: ### Device > 12 Name:Boite aux lettres Type:ZHAOpenClose Details:{'lastupdated': '2022-09-24T14:15:49.650', 'open': False } et {'battery' : 100, 'on' : vrai, 'accessible' : faux, 'temperature' : 0}
xaxa
Message par xaxa »
2022-10-23 19:45:22.307 deCONZ : ### Mise à jour de l'appareil (Boites aux lettres) : {'nValue' : 0, 'sValue' : 'Closed', 'BatteryLevel' : 100, 'TimedOut' : 1}
2022-10-23 19:45:22.321 deCONZ : ### Appareil > 14 Nom : Type de capteur de fenêtre/porte : ZHAOpenClose Détails :{'lastupdated' : '2022-09-17T12:24:49.852', 'lowbattery' : Faux, 'ouvert' : Vrai, 'tampered' : Faux} et {'battery' : 71, 'enrolled' : 0, 'on' : Vrai, 'pending' : [], 'reachable' : False}
2022-10-23 19:45:22.322 deCONZ : ### Mise à jour de l'appareil (deCONZ - OpenClose 13) : {'nValue' : 1, 'sValue' : 'Open', 'BatteryLevel' : 71, 'TimedOut' : 1 }
2022-10-23 19:45:22.338 deCONZ : ### Périphérique > 16 Nom : CLIP-Sensor CTDIM-TOOGLE Type : CLIPGenericFlag Détails : {'flag' : False, 'lastupdated' : '2022-10-23T17:45 :11.477'} et {'on' : Vrai, 'joignable' : Vrai}
2022-10-23 19:45:22.339 deCONZ : ### Mise à jour de l'appareil (deCONZ - CLIP-Sensor CTDIM-TOOGLE) : {'nValue' : 0, 'sValue' : 'Off'}, IGNORED , aucun changement !
2022-10-23 19:45:22.339 deCONZ : ### Appareil > 2 Nom : Capteur de fumée Type : ZHAFire Détails :{'fire' : False, 'lastupdated' : '2021-11-02T12:30:01.854', 'lowbattery' : Faux, 'test' : Faux} et {'battery' : 100, 'on' : Vrai, 'pending' : [], 'reachable' : Vrai, 'selftest' : Faux, 'sensitivity' : 1 }
2022-10-23 19:45:22.340 deCONZ : ### Update device (Xiaomi - Detecteur incendie) : {'nValue' : 0, 'sValue' : 'Off', 'BatteryLevel' : 100}, IGNORED , aucun changement !
2022-10-23 19:45:22.340 deCONZ : ### Appareil > 23 Nom : Consommation 23 Type : ZHAConsumption Détails :{'consommation' : 33075, 'lastupdated' : '2022-10-23T17:14:04.329'} et {'offset' : 0, 'on' : Vrai, 'accessible' : Vrai}
2022-10-23 19:45:22.342 deCONZ : ### Mise à jour de l'appareil (deCONZ - Consommation 23) : {'nValue' : 0, 'sValue' : '33075.0'}, IGNORED , aucun changement !
2022-10-23 19:45:22.342 deCONZ : ### Appareil > 24 Nom : Alimentation 24 Type : ZHAPower Détails : {'current' : 0, 'lastupdated' : '2022-10-23T17:43:24.401', 'power' : 0, 'voltage' : 0} et {'offset' : 0, 'on' : vrai, 'accessible' : vrai}
2022-10-23 19:45:22.344 deCONZ : ### Mise à jour de l'appareil (deCONZ - Power 24) : {'nValue' : 0, 'sValue' : '0'}, IGNORED , no changes !
2022-10-23 19:45:22.344 deCONZ : ### Appareil > 3 Nom : Télécommande TRÅDFRI Type : ZHASwitch Détails :{'buttonevent' : 1002, 'lastupdated' : '2022-10-23T17:07:04.907' } et {'alert' : 'none', 'battery' : 87, 'group' : '2', 'on' : Vrai, 'joignable' : Vrai}
2022-10-23 19:45:22.345 deCONZ : ### Mise à jour de l'appareil (deCONZ - Télécommande TRADFRI) : {'nValue' : 0, 'sValue' : 'Off', 'BatteryLevel' : 87}, IGNORED , no changements !
2022-10-23 19:45:22.345 deCONZ : ### Appareil > 4 Nom : CLIP-Sensor PUSHDIM-TOOGLE Type : CLIPGenericFlag Détails :{'flag' : False, 'lastupdated' : '2022-10-23T17:45 :11.475'} et {'on' : Vrai, 'joignable' : Vrai}
2022-10-23 19:45:22.346 deCONZ : ### Mise à jour de l'appareil (deCONZ - CLIP-Sensor PUSHDIM-TOOGLE) : {'nValue' : 0, 'sValue' : 'Off'}, IGNORED , aucun changement !
2022-10-23 19:45:22.346 deCONZ : ### Appareil > 5 Nom : Type de commutateur à distance : ZHASwitch Détails :{'buttonevent' : 1002, 'lastupdated' : '2022-09-28T18:02:52.325'} et {'batterie' : 80, 'groupe' : '4', 'on' : vrai, 'joignable' : faux}
2022-10-23 19:45:22.347 deCONZ : ### Mise à jour de l'appareil (deCONZ - switch Legrand) : {'nValue' : 0, 'sValue' : 'Off', 'BatteryLevel' : 80, 'TimedOut' : 1 }
2022-10-23 19:45:22.364 deCONZ : ### Appareil > 6 Nom : Type de capteur multiple : ZHATemperature Details :{'lastupdated' : '2022-10-23T16:43:54.842', 'temperature' : 2085} et {'battery' : 88, 'offset' : 0, 'on' : vrai, 'accessible' : faux}
2022-10-23 19:45:22.365 deCONZ : ### Mettre à jour l'appareil (Xiaomi-Température) : {'nValue' : 0, 'sValue' : '20.85', 'BatteryLevel' : 88, 'TimedOut' : 1}
2022-10-23 19:45:22.380 deCONZ : ### Appareil > 7 Nom : Humidity 7 Type : ZHAHumidity Details :{'humidity' : 9619, 'lastupdated' : '2022-10-23T16:43:54.875'} et {'battery' : 88, 'offset' : 0, 'on' : vrai, 'accessible' : faux}
2022-10-23 19:45:22.381 deCONZ : ### Mettre à jour l'appareil (Xiaomi- Humidite) : {'nValue' : 96, 'sValue' : '3', 'BatteryLevel' : 88, 'TimedOut' : 1}
2022-10-23 19:45:22.397 deCONZ : ### Appareil > 8 Nom : Pression 8 Type : ZHAPressure Détails : {'lastupdated' : '2022-10-23T16:43:54.882', 'pression' : 1012} et {'battery' : 88, 'offset' : 0, 'on' : vrai, 'accessible' : faux}
2022-10-23 19:45:22.398 deCONZ : ### Mise à jour de l'appareil (Xiaomi - Baromètre) : {'nValue' : 0, 'sValue' : '1012;3', 'BatteryLevel' : 88, 'TimedOut' : 1}
2022-10-23 19:45:22.415 deCONZ : ### Demander des groupes
2022-10-23 19:45:22.415 deCONZ : envoyer la commande /api/211D14A874/groups/ avec aucun (0 dans la mémoire tampon)
2022-10-23 19:45:22.415 deCONZ : Faire une demande : http://127.0.0.1:80/api/211D14A874/groups/ avec params Aucun
2022-10-23 19:45:22.454 deCONZ : Demande de retour : {"1":{"action":{"alert":"none","bri":127,"colormode":"hs","ct ":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership" :[],"etag":"1a43c41f05adc7652150cd6fd9297ab8","id":"1","lights":["3","2","4","6"],"name":"prises ikea" ,"scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"2":{"action":{"alert":" aucun","bri":127,"colormode":"hs","ct":0,"effect":"aucun","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["3" ],"etag":"4661c4f92dea34957f728261ad00466f","id":"2","lights":[],"name":"Télécommande TRADFRI ","scenes":[],"state":{"all_on" :false,"any_on":false},"type":"LightGroup","uniqueid":"0c:43:14:ff:fe:48:35:5a"},"3":{"action": {"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false," sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"ad3a3976e124d31c98e158110fff4fef","id":"3","lights":["8"],"name":"led ikea","scenes":[],"state":{"all_on": false,"any_on":false},"type":"LightGroup"},"4":{"action":{"alert":"none","bri":127,"colormode":"hs", "ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]}," devicemembership":["5"],"etag":"ad3a3976e124d31c98e158110fff4fef","id":"4","lights":[],"name":"Interrupteur à distance 5","scenes":[]," state":{"all_on":false,"any_on":false},"type":"LightGroup","uniqueid":"00:04:74:00:00:af:4b:c6"},"5":{"action":{"alert" :"aucun","bri":127,"colormode":"hs","ct":0,"effect":"aucun","hue":0,"on":false,"sat":127 ,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"ede0e1956793d0ae7ecfdc158ca43d84","id":"5","lights":["12"] ,"name":"legrand","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"6":{"action ":{"alert":"aucun","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]}," devicemembership":[],"etag":"ede0e1956793d0ae7ecfdc158ca43d84","id":"6","lights":["15"],"name":"Volet Roulant","scenes":[],"state ":{"all_on":false,"any_on":false},"type":"LightGroup"},"7":{"action":{"alert":"none","bri":127," colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[ 0,0]},"devicemembership":[],"etag":"ede0e1956793d0ae7ecfdc158ca43d84","id":"7","lights":[],"name":"Routeur","scenes":[],"state":{"all_on":false,"any_on":false} ,"type":"LightGroup"},"8":{"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effet ":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag ":"c3007ba5cffb5ffe07e72cdf5f39ffee","id":"8","lights":["13"],"name":"compteur","scenes":[],"state":{"all_on":true, "any_on":true},"type":"LightGroup"}}
2022-10-23 19:45:22.456 deCONZ : Données classiques : {'1' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct ' : 0, 'effect' : 'none', 'hue' : 0, 'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag': '1a43c41f05adc7652150cd6fd9297ab8', 'id': '1', 'lights': ['3', '2', '4', '6'], 'name': 'prises ikea' , 'scenes' : [], 'state' : {'all_on' : False, 'any_on' : False}, 'type' : 'LightGroup'}, '2' : {'action' : {'alert' : ' aucun', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effet' : 'aucun','hue' : 0, 'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : ['3'], 'etag' : ' 4661c4f92dea34957f728261ad00466f', 'id' : '2', 'lights' : [], 'name' : 'TRADFRI remote control ', 'scenes' : [], 'state' : {'all_on' : False, 'any_on' : False}, 'type' : 'LightGroup', 'uniqueid' : '0c:43:14:ff:fe:48:35:5a'}, '3' : {'action' : {'alert' : 'aucun ', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'none', 'hue' : 0, 'on' : false, 'sat' : 127, 'scene ' : Aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'ad3a3976e124d31c98e158110fff4fef', 'id' : '3', 'lights' : ['8'], 'name' : 'led ikea', 'scenes' : [], 'state' : {'all_on' : False, 'any_on ' : Faux}, 'type' : 'LightGroup'}, '4' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'none', 'hue' : 0, 'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : [ '5'], 'etag' : 'ad3a3976e124d31c98e158110fff4fef', 'id' : '4', 'lights' : [], 'name' : 'Remote switch 5', 'scenes' : [], 'state' : { 'all_on' : faux, 'any_on' : faux}, 'type' : 'LightGroup', 'uniqueid' : '00:04:74:00:00:af:4b:c6'}, '5' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'none', 'hue' : 0, 'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'ede0e1956793d0ae7ecfdc158ca43d84', 'id' : '5', 'lights' : ['12'], 'name' : 'legrand', 'scenes ' : [], 'state' : {'all_on' : False, 'any_on' : False}, 'type' : 'LightGroup'}, '6' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'aucun', 'hue' : 0,'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'ede0e1956793d0ae7ecfdc158ca43d84', 'id' : '6 ', 'lights' : ['15'], 'name' : 'Volet Roulant', 'scenes' : [], 'state' : {'all_on' : False, 'any_on' : False}, 'type' : 'LightGroup'}, '7' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'none' , 'hue' : 0, 'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'ede0e1956793d0ae7ecfdc158ca43d84' , 'id' : '7', 'lumières' : [], 'nom' : 'Router', 'scenes' : [], 'state' : {'all_on' : False, 'any_on' : False}, 'type' : 'LightGroup'}, '8' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'none', 'hue' : 0, 'on' : faux, 'sat' : 127 , 'scene' : Aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'c3007ba5cffb5ffe07e72cdf5f39ffee', 'id' : '8', 'lights' : ['13'] , 'name' : 'compteur', 'scenes' : [], 'state' : {'all_on' : Vrai, 'any_on' : Vrai}, 'type' : 'LightGroup'}}LightGroup'}, '8' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'none', 'hue' : 0, 'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'c3007ba5cffb5ffe07e72cdf5f39ffee', 'id' : '8', 'lights' : ['13'], 'name' : 'compteur', 'scenes' : [], 'state' : {'all_on' : Vrai, 'any_on' : Vrai} , 'type' : 'GroupeLumière'}}LightGroup'}, '8' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'none', 'hue' : 0, 'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'c3007ba5cffb5ffe07e72cdf5f39ffee', 'id' : '8', 'lights' : ['13'], 'name' : 'compteur', 'scenes' : [], 'state' : {'all_on' : Vrai, 'any_on' : Vrai} , 'type' : 'GroupeLumière'}}scene' : Aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'c3007ba5cffb5ffe07e72cdf5f39ffee', 'id' : '8', 'lights' : ['13'], ' name' : 'compteur', 'scenes' : [], 'state' : {'all_on' : Vrai, 'any_on' : Vrai}, 'type' : 'LightGroup'}}scene' : Aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'c3007ba5cffb5ffe07e72cdf5f39ffee', 'id' : '8', 'lights' : ['13'], ' name' : 'compteur', 'scenes' : [], 'state' : {'all_on' : Vrai, 'any_on' : Vrai}, 'type' : 'LightGroup'}}
2022-10-23 19:45:22.457 deCONZ: ### Groupe > 1 Nom:prises ikea
2022-10-23 19:45:22.457 deCONZ : ### Groupe > 2 Nom : télécommande TRADFRI
2022-10-23 19:45:22.457 deCONZ: ### Groupe > 3 Nom:led ikea
2022-10-23 19:45:22.457 deCONZ : ### Groupe > 4 Nom : Interrupteur à distance 5
2022-10-23 19:45:22.457 deCONZ: ### Groupe > 5 Nom:legrand
2022-10-23 19:45:22.457 deCONZ: ### Groupe > 6 Nom:Volet Roulant
2022-10-23 19:45:22.457 deCONZ : ### Groupe > 7 Nom : Routeur
2022-10-23 19:45:22.458 deCONZ: ### Groupe > 8 Nom:compteur
2022-10-23 19:45:22.511 deCONZ : onConnect appelé
2022-10-23 19:45:22.563 deCONZ : onMessage appelé
2022-10-23 19:45:22.563 deCONZ : WebSocket Handshake : HTTP/1.1 101 Switching Protocols ***Mise à niveau : websocket ***Connexion : mise à niveau ***Sec-WebSocket-Accept : V0htEbn5FhIA1xfQRyG3yU1aG9c= ***Serveur : deconz ***Access-Control-Allow-Credentials : faux ***Access-Control-Allow-Methods : GET ***Access-Control-Allow-Headers : type de contenu ***Access-Control-Allow-Origin : http ://127.0.0.1 ***Date : dim. 23 octobre 2022 17:45:22 GMT *** ***
2022-10-23 19:45:22.563 deCONZ : ### Données WebSocket : {'e' : 'changed', 'id' : '13', 'r' : 'lights', 'state' : {'on ' : Vrai, 'accessible' : Vrai}, 't' : 'événement', 'uniqueid' : '90:35:ea:ff:fe:be:e1:c4-01'}
2022-10-23 19:45:22.565 deCONZ : ### Mise à jour de l'appareil (deCONZ - Smart plug 9) : {'nValue' : 1, 'sValue' : 'on'}, IGNORED , no changes !
2022-10-23 19:45:22.717 deCONZ : onMessage appelé
2022-10-23 19:45:22.718 deCONZ : ### Données WebSocket : {'attr' : {'id' : '1', 'lastannounced' : Aucun, 'dernière vue' : '2022-10-23T17:45Z ', 'nom du fabricant' : 'dresden elektronik', 'modelid' : 'ConBee II', 'name' : 'Outil de configuration 1', 'swversion' : '0x26720700', 'type' : 'Outil de configuration', 'uniqueid' : '00:21:2e:ff:ff:05:51:f8-01'}, 'e' : 'modifié', 'id' : '1', 'r' : 'feux', 't' : 'événement', 'identifiant unique' : '00:21:2e:ff:ff:05:51:f8-01'}
2022-10-23 19:45:22.718 deCONZ : Appareil banni/ignoré > 1 (feux)
2022-10-23 19:45:23.770 deCONZ : onMessage appelé
2022-10-23 19:45:23.771 deCONZ : ### Données WebSocket : {'e' : 'changed', 'id' : '13', 'r' : 'lights', 'state' : {'on ' : Faux, 'accessible' : Vrai}, 't' : 'événement', 'uniqueid' : '90:35:ea:ff:fe:be:e1:c4-01'}
2022-10-23 19:45:23.772 deCONZ : ### Mise à jour de l'appareil (deCONZ - Smart plug 9) : {'nValue' : 0, 'sValue' : 'off'}
2022-10-23 19:45:23.791 deCONZ : ### Données WebSocket : {'e' : 'changed', 'id' : '8', 'r' : 'groups', 'state' : {'all_on ' : Faux, 'any_on' : Faux}, 't' : 'événement'}
2022-10-23 19:45:23.792 deCONZ : ### Mise à jour de l'appareil (deCONZ - compteur) : {'nValue' : 0, 'sValue' : 'off'}
2022-10-23 19:45:24.357 deCONZ : onMessage appelé
2022-10-23 19:45:24.358 deCONZ : ### Données WebSocket : {'e' : 'modifié', 'id' : '24', 'r' : 'capteurs', 'état' : {'actuel ' : 0, 'lastupdated' : '2022-10-23T17:45:24.335', ​​'power' : 0, 'voltage' : 0}, 't' : 'event', 'uniqueid' : '90:35 : ea:ff:fe:be:e1:c4-01-0b04'}
2022-10-23 19:45:24.361 deCONZ : ### Mise à jour de l'appareil (deCONZ - Power 24) : {'nValue' : 0, 'sValue' : '0'}, IGNORED , no changes !
2022-10-23 19:45:25.012 deCONZ : onMessage appelé
xaxa
Re: Compteur d'energie DDS238-2 Zigbee
Message par xaxa »
2022-10-23 19:45:58.075 deCONZ: onHeartbeat called
2022-10-23 19:45:58.075 deCONZ: ### Initialisation > config
2022-10-23 19:45:43.941 Lever : 08:06:00 Coucher du soleil : 18:46:00
2022-10-23 19:45:43.941 Durée du jour : 10:40:00 Dim au sud : 13:26:00
2022-10-23 19:45:43.941 Début du crépuscule civil : 07:37:00 Fin du crépuscule civil : 19:15:00
2022-10-23 19:45:43.941 Début crépuscule nautique : 07:03:00 Fin crépuscule nautique : 19:48:00
2022-10-23 19:45:43.942 Début du crépuscule astronomique : 06:30:00 Fin du crépuscule astronomique : 20:22:00
2022-10-23 19:45:43.893 Statut : Domoticz V2022.1 (c)2012-2022 GizMoCuz
2022-10-23 19:45:43.897 Statut : Build Hash : c9526851b, Date : 2022-01-31 09:34:32
2022-10-23 19:45:43.899 Statut : Chemin de démarrage : /home/pi/domoticz/
2022-10-23 19:45:44.072 Sous-systèmes de notification actifs : fcm, télégramme (2/13)
2022-10-23 19:45:44.160 Démarrage du serveur partagé sur : :::6144
2022-10-23 19:45:44.063 Statut : PluginSystem : Démarré, Python version '3.7.3', 9 définitions de plugin chargées.
2022-10-23 19:45:44.076 Statut : WebServer (HTTP) a démarré à l'adresse : :: avec le port 8080
2022-10-23 19:45:44.088 Statut : WebServer (SSL) a démarré à l'adresse : :: avec le port 443
2022-10-23 19:45:44.095 Statut : Caméra : paramètres (re)chargés
2022-10-23 19:45:44.160 Statut : TCPServer : serveur partagé démarré...
2022-10-23 19:45:44.162 Statut : RxQueue : le travailleur de la file d'attente a démarré...
2022-10-23 19:45:44.882 Statut : Connexion entrante depuis : 192.168.0.16
2022-10-23 19:45:44.087 Erreur : [web:443] paramètres SSL DH manquants dans le fichier ./server_cert.pem
2022-10-23 19:45:46.185 Mi 10 : le fil de travail a démarré.
2022-10-23 19:45:46.185 deCONZ : le fil de travail a démarré.
2022-10-23 19:45:46.186 Gestionnaire de plugins : le thread de travail a démarré.
2022-10-23 19:45:46.185 Statut : Ping : Le travailleur a commencé...
2022-10-23 19:45:46.185 Statut : Mi 10 : Entrée dans la boucle de travail.
2022-10-23 19:45:46.185 Statut : Mi 10 : Démarré.
2022-10-23 19:45:46.186 Statut : Gestionnaire de plugins : Entrée dans la boucle de travail.
2022-10-23 19:45:46.186 Statut : Gestionnaire de plugins : Démarré.
2022-10-23 19:45:46.186 Statut : NotificationSystem : le fil a commencé...
2022-10-23 19:45:46.186 Statut : EventSystem : réinitialiser tous les événements...
2022-10-23 19:45:46.189 Statut : dzVents : Écrire le fichier : /home/pi/domoticz/scripts/dzVents/generated_scripts/heure_demarage_Domoticz.lua
2022-10-23 19:45:46.189 Statut : dzVents : Écrire le fichier : /home/pi/domoticz/scripts/dzVents/generated_scripts/monit_ping_restart.lua
2022-10-23 19:45:46.190 Statut : dzVents : Écrire le fichier : /home/pi/domoticz/scripts/dzVents/generated_scripts/sonnette_telegram.lua
2022-10-23 19:45:46.190 Statut : dzVents : Écrire le fichier : /home/pi/domoticz/scripts/dzVents/generated_scripts/Generic auto-off.lua
2022-10-23 19:45:46.190 Statut : dzVents : Écrire le fichier : /home/pi/domoticz/scripts/dzVents/generated_scripts/BouttonRF 1.lua
2022-10-23 19:45:46.190 Statut : dzVents : Écrire le fichier : /home/pi/domoticz/scripts/dzVents/generated_scripts/BouttonRF 2.lua
2022-10-23 19:45:46.190 Statut : dzVents : Écrire le fichier : /home/pi/domoticz/scripts/dzVents/generated_scripts/BouttonRF 3.lua
2022-10-23 19:45:46.191 Statut : dzVents : Écrire le fichier : /home/pi/domoticz/scripts/dzVents/generated_scripts/telecomande bouton A.lua
2022-10-23 19:45:46.191 Statut : dzVents : Écrire le fichier : /home/pi/domoticz/scripts/dzVents/generated_scripts/telecomande bouton B.lua
2022-10-23 19:45:46.191 Statut : dzVents : Écrire le fichier : /home/pi/domoticz/scripts/dzVents/generated_scripts/telecomande bouton B1.lua
2022-10-23 19:45:46.191 Statut : EventSystem : réinitialiser tous les statuts de l'appareil...
2022-10-23 19:45:46.365 Statut : RFLink : Utilisation du port série : /dev/ttyUSB0
2022-10-23 19:45:46.447 Statut : PluginSystem : 3 plugins démarrés.
2022-10-23 19:45:46.665 Statut : zwave : utilisation de la configuration dans : /home/pi/domoticz/Config/
2022-10-23 19:45:46.718 Statut : zwave : Démarrage...
2022-10-23 19:45:46.719 Statut : zwave : Version : 1.6-1911-gc6a420ef
2022-10-23 19:45:46.932 Statut : Python EventSystem : Initialisation du module d'événement.
2022-10-23 19:45:46.935 Statut : EventSystem : Démarré
2022-10-23 19:45:46.938 Statut : EventSystem : le fil de file d'attente a démarré...
2022-10-23 19:45:47.208 Mi 10 : Masque de journalisation de débogage défini sur : AUCUN
2022-10-23 19:45:47.496 Plugins Manager : Masque de journalisation de débogage défini sur : PYTHON
2022-10-23 19:45:47.520 Gestionnaire de plugins : Installation de la page personnalisée du plugin...
2022-10-23 19:45:47.520 Gestionnaire de plugins : copie des fichiers de /home/pi/domoticz/plugins/plugins-manager/frontend vers /home/pi/domoticz/www/templates
2022-10-23 19:45:47.541 Gestionnaire de plugins : installation de la page personnalisée du plugin terminée.
2022-10-23 19:45:47.164 Statut : MQTT : Connexion à l'hôte local : 1883
2022-10-23 19:45:47.203 Statut : Mi 10 : Version initialisée 0.0.2, auteur 'heggink'
2022-10-23 19:45:47.291 Statut : RFLink : Contrôleur initialisé !...
2022-10-23 19:45:47.369 Statut : MQTT : connecté à : localhost:1883
2022-10-23 19:45:47.395 Statut : RFLink : RFLink détecté, Version : 1.1 Révision : 48 Build : 4
2022-10-23 19:45:47.487 Statut : Gestionnaire de plugins : Version initialisée 1.0.0
2022-10-23 19:45:48.508 deCONZ : Domoticz et deCONZ sont installés sur la même machine.
2022-10-23 19:45:48.509 deCONZ : Masque de journalisation de débogage défini sur : PYTHON
2022-10-23 19:45:48.510 deCONZ : Ajout d'un appareil interdit : 00:15:8d:00:02:36:c2:3f-01-0500
2022-10-23 19:45:49.338 zwave : Value_Added : Node : 4 (0x04), CommandClass : SWITCH BINARY, Label : Instance 1 : Switch, Instance : 1, Index : 0
2022-10-23 19:45:49.339 zwave : Value_Added : Node : 4 (0x04), CommandClass : SWITCH BINARY, Label : Instance 2 : Switch, Instance : 2, Index : 0
2022-10-23 19:45:49.341 zwave : Value_Added : Node : 8 (0x08), CommandClass : SWITCH BINARY, Label : Instance 1 : Switch, Instance : 1, Index : 0
2022-10-23 19:45:49.342 zwave : Value_Added : Node : 8 (0x08), CommandClass : SWITCH BINARY, Label : Instance 2 : Switch, Instance : 2, Index : 0
2022-10-23 19:45:49.144 Statut : zwave : une erreur DNS s'est produite
2022-10-23 19:45:49.144 Statut : zwave : ManufacturerSpecificDB Ready
2022-10-23 19:45:49.336 Statut : zwave : pilote prêt
2022-10-23 19:45:52.354 Statut : zwave : Notification de dépassement de délai reçue de HomeID : 4173369607, NodeID : 4 (0x04)
2022-10-23 19:45:58.400 deCONZ : ### Appareil > 23 Nom : Consommation 23 Type : ZHAConsumption Détails :{'consommation' : 33075, 'lastupdated' : '2022-10-23T17:14:04.329'} et {'offset' : 0, 'on' : Vrai, 'accessible' : Vrai}
2022-10-23 19:45:58.402 deCONZ : ### Mise à jour de l'appareil (deCONZ - Consommation 23) : {'nValue' : 0, 'sValue' : '33075.0'}, IGNORED , aucun changement !
2022-10-23 19:45:58.402 deCONZ : ### Appareil > 24 Nom : Alimentation 24 Type : ZHAPower Détails :{'current' : 0, 'lastupdated' : '2022-10-23T17:45:54.333', 'power' : 0, 'voltage' : 0} et {'offset' : 0, 'on' : vrai, 'accessible' : vrai}
2022-10-23 19:45:58.403 deCONZ : ### Mise à jour de l'appareil (deCONZ - Power 24) : {'nValue' : 0, 'sValue' : '0'}, IGNORED , no changes !
2022-10-23 19:45:58.404 deCONZ : ### Appareil > 3 Nom : Télécommande TRÅDFRI Type : ZHASwitch Détails :{'buttonevent' : 1002, 'lastupdated' : '2022-10-23T17:07:04.907' } et {'alert' : 'none', 'battery' : 87, 'group' : '2', 'on' : Vrai, 'joignable' : Vrai}
2022-10-23 19:45:58.405 deCONZ : ### Mise à jour de l'appareil (deCONZ - Télécommande TRADFRI) : {'nValue' : 0, 'sValue' : 'Off', 'BatteryLevel' : 87}, IGNORED , no changements !
2022-10-23 19:45:58.405 deCONZ : ### Appareil > 4 Nom : CLIP-Sensor PUSHDIM-TOOGLE Type : CLIPGenericFlag Détails : {'flag' : False, 'lastupdated' : '2022-10-23T17:45 :11.475'} et {'on' : Vrai, 'joignable' : Vrai}
2022-10-23 19:45:58.406 deCONZ : ### Mise à jour de l'appareil (deCONZ - CLIP-Sensor PUSHDIM-TOOGLE) : {'nValue' : 0, 'sValue' : 'Off'}, IGNORED , aucun changement !
2022-10-23 19:45:58.406 deCONZ : ### Appareil > 5 Nom : Type de commutateur à distance : ZHASwitch Détails :{'buttonevent' : 1002, 'lastupdated' : '2022-09-28T18:02:52.325'} et {'batterie' : 80, 'groupe' : '4', 'on' : vrai, 'joignable' : faux}
2022-10-23 19:45:58.407 deCONZ : ### Mise à jour de l'appareil (deCONZ - switch Legrand) : {'nValue' : 0, 'sValue' : 'Off', 'BatteryLevel' : 80, 'TimedOut' : 1 }
2022-10-23 19:45:58.422 deCONZ : ### Appareil > 6 Nom : Type de capteur multiple : ZHATemperature Details :{'lastupdated' : '2022-10-23T16:43:54.842', 'temperature' : 2085} et {'battery' : 88, 'offset' : 0, 'on' : vrai, 'accessible' : faux}
2022-10-23 19:45:58.423 deCONZ : ### Mettre à jour l'appareil (Xiaomi-Température) : {'nValue' : 0, 'sValue' : '20.85', 'BatteryLevel' : 88, 'TimedOut' : 1}
2022-10-23 19:45:58.441 deCONZ : ### Appareil > 7 Nom : Humidity 7 Type : ZHAHumidity Details :{'humidity' : 9619, 'lastupdated' : '2022-10-23T16:43:54.875'} et {'battery' : 88, 'offset' : 0, 'on' : vrai, 'accessible' : faux}
2022-10-23 19:45:58.442 deCONZ : ### Mettre à jour l'appareil (Xiaomi- Humidite) : {'nValue' : 96, 'sValue' : '3', 'BatteryLevel' : 88, 'TimedOut' : 1}
2022-10-23 19:45:58.479 deCONZ : ### Appareil > 8 Nom : Pression 8 Type : ZHAPressure Détails :{'lastupdated' : '2022-10-23T16:43:54.882', 'pression' : 1012} et {'battery' : 88, 'offset' : 0, 'on' : vrai, 'accessible' : faux}
2022-10-23 19:45:58.480 deCONZ : ### Mise à jour de l'appareil (Xiaomi - Baromètre) : {'nValue' : 0, 'sValue' : '1012;3', 'BatteryLevel' : 88, 'TimedOut' : 1}
2022-10-23 19:45:58.514 deCONZ : ### Demander des groupes
2022-10-23 19:45:58.515 deCONZ : envoyer la commande /api/211D14A874/groups/ avec aucun (0 dans la mémoire tampon)
2022-10-23 19:45:58.515 deCONZ : Faire une demande : http://127.0.0.1:80/api/211D14A874/groups/ avec params Aucun
2022-10-23 19:45:58.542 deCONZ : Demande de retour : {"1":{"action":{"alert":"none","bri":127,"colormode":"hs","ct ":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership" :[],"etag":"3f3779cc374ce7e849086472b344c0cd","id":"1","lights":["3","2","4","6"],"name":"prises ikea" ,"scenes":[],"state":{"all_on":true,"any_on":true},"type":"LightGroup"},"2":{"action":{"alert":" aucun","bri":127,"colormode":"hs","ct":0,"effect":"aucun","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["3" ],"etag":"4661c4f92dea34957f728261ad00466f","id":"2","lights":[],"name":"Télécommande TRADFRI ","scenes":[],"state":{"all_on" :false,"any_on":false},"type":"LightGroup","uniqueid":"0c:43:14:ff:fe:48:35:5a"},"3":{"action": {"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false," sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"da8ee466f326b9647354615557cab103","id":"3","lights":["8"],"name":"led ikea","scenes":[],"state":{"all_on": true,"any_on":true},"type":"LightGroup"},"4":{"action":{"alert":"none","bri":127,"colormode":"hs", "ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]}," devicemembership":["5"],"etag":"ad3a3976e124d31c98e158110fff4fef","id":"4","lights":[],"name":"Interrupteur à distance 5","scenes":[]," state":{"all_on":false,"any_on":false},"type":"LightGroup","uniqueid":"00:04:74:00:00:af:4b:c6"},"5":{"action":{"alert":" aucun","bri":127,"colormode":"hs","ct":0,"effect":"aucun","hue":0,"on":false,"sat":127," scene":null,"xy":[0,0]},"devicemembership":[],"etag":"35184fe6d800654a4d6b9069eda2c653","id":"5","lights":["12"]," name":"legrand","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"6":{"action": {"alert":"aucun","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership": [],"etag":"ede0e1956793d0ae7ecfdc158ca43d84","id":"6","lights":["15"],"name":"Volet Roulant","scenes":[],"state":{ "all_on":false,"any_on":false},"type":"LightGroup"},"7":{"action":{"alert":"none","bri":127,"colormode": "hs","ct":0,"effect":"aucun","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0 ]},"devicemembership":[],"etag":"ede0e1956793d0ae7ecfdc158ca43d84","id":"7","lights":[],"name":"Routeur","scenes":[],"state":{"all_on":false,"any_on":false},"type ":"LightGroup"},"8":{"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":" none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":" aaa0b1d6595940b8f52abe4ae1d82c0d","id":"8","lights":["13"],"name":"compteur","scenes":[],"state":{"all_on":false,"any_on" :false},"type":"LightGroup"}}"lights":[],"name":"Routeur","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}," 8":{"action":{"alert":"aucun","bri":127,"colormode":"hs","ct":0,"effect":"aucun","hue":0 ,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"aaa0b1d6595940b8f52abe4ae1d82c0d","id":" 8","lights":["13"],"name":"compteur","scenes":[],"state":{"all_on":false,"any_on":false},"type": "Groupe de lumière"}}"lights":[],"name":"Routeur","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}," 8":{"action":{"alert":"aucun","bri":127,"colormode":"hs","ct":0,"effect":"aucun","hue":0 ,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"aaa0b1d6595940b8f52abe4ae1d82c0d","id":" 8","lights":["13"],"name":"compteur","scenes":[],"state":{"all_on":false,"any_on":false},"type": "Groupe de lumière"}}Routeur","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"8":{"action":{"alert" :"aucun","bri":127,"colormode":"hs","ct":0,"effect":"aucun","hue":0,"on":false,"sat":127 ,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"aaa0b1d6595940b8f52abe4ae1d82c0d","id":"8","lights":["13"] ,"name":"compteur","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}}Routeur","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"},"8":{"action":{"alert" :"aucun","bri":127,"colormode":"hs","ct":0,"effect":"aucun","hue":0,"on":false,"sat":127 ,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"aaa0b1d6595940b8f52abe4ae1d82c0d","id":"8","lights":["13"] ,"name":"compteur","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}}type":"LightGroup"},"8":{"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect": "none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag": "aaa0b1d6595940b8f52abe4ae1d82c0d","id":"8","lights":["13"],"name":"compteur","scenes":[],"state":{"all_on":false,"any_on ":false},"type":"LightGroup"}}type":"LightGroup"},"8":{"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect": "none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag": "aaa0b1d6595940b8f52abe4ae1d82c0d","id":"8","lights":["13"],"name":"compteur","scenes":[],"state":{"all_on":false,"any_on ":false},"type":"LightGroup"}}none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":" aaa0b1d6595940b8f52abe4ae1d82c0d","id":"8","lights":["13"],"name":"compteur","scenes":[],"state":{"all_on":false,"any_on" :false},"type":"LightGroup"}}none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":" aaa0b1d6595940b8f52abe4ae1d82c0d","id":"8","lights":["13"],"name":"compteur","scenes":[],"state":{"all_on":false,"any_on" :false},"type":"LightGroup"}}"Groupe de lumière"}}"Groupe de lumière"}}
2022-10-23 19:45:58.544 deCONZ : Données classiques : {'1' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct ' : 0, 'effect' : 'none', 'hue' : 0, 'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag': '3f3779cc374ce7e849086472b344c0cd', 'id': '1', 'lights': ['3', '2', '4', '6'], 'name': 'prises ikea' , 'scenes' : [], 'state' : {'all_on' : Vrai, 'any_on' : Vrai}, 'type' : 'LightGroup'}, '2' : {'action' : {'alert' : ' aucun', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effet' : 'aucun','hue' : 0, 'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : ['3'], 'etag' : ' 4661c4f92dea34957f728261ad00466f', 'id' : '2', 'lights' : [], 'name' : 'TRADFRI remote control ', 'scenes' : [], 'state' : {'all_on' : False, 'any_on' : False}, 'type' : 'LightGroup', 'uniqueid' : '0c:43:14:ff:fe:48:35:5a'}, '3' : {'action' : {'alert' : 'aucun ', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'none', 'hue' : 0, 'on' : false, 'sat' : 127, 'scene ' : Aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'da8ee466f326b9647354615557cab103', 'id' : '3', 'lights' : ['8'], 'name' : 'led ikea', 'scenes' : [], 'state' : {'all_on' : vrai, 'any_on ' : Vrai}, 'type' : 'LightGroup'}, '4' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'none', 'hue' : 0, 'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : [ '5'], 'etag' : 'ad3a3976e124d31c98e158110fff4fef', 'id' : '4', 'lights' : [], 'name' : 'Remote switch 5', 'scenes' : [], 'state' : { 'all_on' : faux, 'any_on' : faux}, 'type' : 'LightGroup', 'uniqueid' : '00:04:74:00:00:af:4b:c6'}, '5' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'none', 'hue' : 0, 'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : '35184fe6d800654a4d6b9069eda2c653', 'id' : '5', 'lights' : ['12'], 'name' : 'legrand', 'scenes ' : [], 'state' : {'all_on' : False, 'any_on' : False}, 'type' : 'LightGroup'}, '6' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'aucun', 'hue' : 0,'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'ede0e1956793d0ae7ecfdc158ca43d84', 'id' : '6 ', 'lights' : ['15'], 'name' : 'Volet Roulant', 'scenes' : [], 'state' : {'all_on' : False, 'any_on' : False}, 'type' : 'LightGroup'}, '7' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'none' , 'hue' : 0, 'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'ede0e1956793d0ae7ecfdc158ca43d84' , 'id' : '7', 'lumières' : [], 'nom' : 'Router', 'scenes' : [], 'state' : {'all_on' : False, 'any_on' : False}, 'type' : 'LightGroup'}, '8' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'none', 'hue' : 0, 'on' : faux, 'sat' : 127 , 'scene' : Aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'aaa0b1d6595940b8f52abe4ae1d82c0d', 'id' : '8', 'lights' : ['13'] , 'name' : 'compteur', 'scenes' : [], 'state' : {'all_on' : False, 'any_on' : False}, 'type' : 'LightGroup'}}LightGroup'}, '8' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'none', 'hue' : 0, 'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'aaa0b1d6595940b8f52abe4ae1d82c0d', 'id' : '8', 'lights' : ['13'], 'name' : 'compteur', 'scenes' : [], 'state' : {'all_on' : False, 'any_on' : False} , 'type' : 'GroupeLumière'}}LightGroup'}, '8' : {'action' : {'alert' : 'none', 'bri' : 127, 'colormode' : 'hs', 'ct' : 0, 'effect' : 'none', 'hue' : 0, 'on' : faux, 'sat' : 127, 'scene' : aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'aaa0b1d6595940b8f52abe4ae1d82c0d', 'id' : '8', 'lights' : ['13'], 'name' : 'compteur', 'scenes' : [], 'state' : {'all_on' : False, 'any_on' : False} , 'type' : 'GroupeLumière'}}'scene' : Aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'aaa0b1d6595940b8f52abe4ae1d82c0d', 'id' : '8', 'lights' : ['13'], 'name' : 'compteur', 'scenes' : [], 'state' : {'all_on' : False, 'any_on' : False}, 'type' : 'LightGroup'}}'scene' : Aucun, 'xy' : [0, 0]}, 'devicemembership' : [], 'etag' : 'aaa0b1d6595940b8f52abe4ae1d82c0d', 'id' : '8', 'lights' : ['13'], 'name' : 'compteur', 'scenes' : [], 'state' : {'all_on' : False, 'any_on' : False}, 'type' : 'LightGroup'}}
2022-10-23 19:45:58.544 deCONZ: ### Groupe > 1 Nom:prises ikea
2022-10-23 19:45:58.545 deCONZ : ### Groupe > 2 Nom : télécommande TRADFRI
2022-10-23 19:45:58.545 deCONZ: ### Groupe > 3 Nom:led ikea
2022-10-23 19:45:58.545 deCONZ : ### Groupe > 4 Nom : Interrupteur à distance 5
2022-10-23 19:45:58.545 deCONZ: ### Groupe > 5 Nom:legrand
2022-10-23 19:45:58.545 deCONZ: ### Groupe > 6 Nom:Volet Roulant
2022-10-23 19:45:58.546 deCONZ : ### Groupe > 7 Nom : Routeur
2022-10-23 19:45:58.546 deCONZ: ### Groupe > 8 Nom:compteur
2022-10-23 19:45:58.598 deCONZ : onConnect appelé
2022-10-23 19:45:58.649 deCONZ : onMessage appelé
2022-10-23 19:45:58.650 deCONZ : WebSocket Handshake : HTTP/1.1 101 Switching Protocols ***Mise à niveau : websocket ***Connexion : mise à niveau ***Sec-WebSocket-Accept : V0htEbn5FhIA1xfQRyG3yU1aG9c= ***Serveur : deconz ***Access-Control-Allow-Credentials : faux ***Access-Control-Allow-Methods : GET ***Access-Control-Allow-Headers : type de contenu ***Access-Control-Allow-Origin : http ://127.0.0.1 ***Date : dim. 23 octobre 2022 17:45:58 GMT *** ***
2022-10-23 19:45:58.490 Statut : zwave : Notification de dépassement de délai reçue de HomeID : 4173369607, NodeID : 4 (0x04)
je l ai envoyé en plusieurs parie
xaxa
Message par xaxa »
j ai refait les logs de phoscon
19:59:20:044 max transmit errors for node 0x00158D0005BCFCEA, last seen by neighbors 841 s
19:59:22:291 90:35:ea:ff:fe:be:e1:c4-01/state/on expression: Item.val = Attr.val; --> false
19:59:22:292 TY_DATA_RESPONSE: seq 16, dpid: 0x01, type: 0x01, length: 1, val: 0
19:59:22:293 TY_DATA_RESPONSE: seq 16, dpid: 0x01, type: 0x01, length: 1, val: 0
19:59:23:297 TY_DATA_RESPONSE: seq 16, dpid: 0x12, type: 0x02, length: 4, val: 0
19:59:23:298 TY_DATA_RESPONSE: seq 16, dpid: 0x12, type: 0x02, length: 4, val: 0
19:59:23:299 TY_DATA_RESPONSE: seq 16, dpid: 0x12, type: 0x02, length: 4, val: 0
19:59:24:294 TY_DATA_RESPONSE: seq 16, dpid: 0x13, type: 0x02, length: 4, val: 0
19:59:24:295 TY_DATA_RESPONSE: seq 16, dpid: 0x13, type: 0x02, length: 4, val: 0
19:59:24:296 90:35:ea:ff:fe:be:e1:c4-01-0b04/state/power expression: Item.val = Attr.val; --> 0
19:59:24:297 TY_DATA_RESPONSE: seq 16, dpid: 0x13, type: 0x02, length: 4, val: 0
19:59:25:295 TY_DATA_RESPONSE: seq 16, dpid: 0x14, type: 0x02, length: 4, val: 2269
19:59:25:297 TY_DATA_RESPONSE: seq 16, dpid: 0x14, type: 0x02, length: 4, val: 2269
19:59:25:298 TY_DATA_RESPONSE: seq 16, dpid: 0x14, type: 0x02, length: 4, val: 2269
19:59:25:299 TY_DATA_RESPONSE: seq 16, dpid: 0x14, type: 0x02, length: 4, val: 2269
19:59:26:294 TY_DATA_RESPONSE: seq 16, dpid: 0x11, type: 0x02, length: 4, val: 33075
19:59:26:295 TY_DATA_RESPONSE: seq 16, dpid: 0x11, type: 0x02, length: 4, val: 33075
19:59:26:296 TY_DATA_RESPONSE: seq 16, dpid: 0x11, type: 0x02, length: 4, val: 33075
19:59:29:632 SC tick --> StateRead
19:59:30:174 max transmit errors for node 0x00158D0005BCFCEA, last seen by neighbors 851 s
19:59:31:639 90:35:ea:ff:fe:be:e1:c4-01/state/on expression: Item.val = Attr.val; --> true
19:59:31:641 TY_DATA_RESPONSE: seq 16, dpid: 0x01, type: 0x01, length: 1, val: 1
19:59:31:653 TY_DATA_RESPONSE: seq 16, dpid: 0x01, type: 0x01, length: 1, val: 1
19:59:31:655 TY_DATA_RESPONSE: seq 16, dpid: 0x01, type: 0x01, length: 1, val: 1
19:59:31:656 TY_DATA_RESPONSE: seq 16, dpid: 0x01, type: 0x01, length: 1, val: 1
19:59:31:657 TY_DATA_RESPONSE: seq 16, dpid: 0x01, type: 0x01, length: 1, val: 1
19:59:35:957 90:35:ea:ff:fe:be:e1:c4-01/state/on expression: Item.val = Attr.val; --> false
19:59:35:958 TY_DATA_RESPONSE: seq 16, dpid: 0x01, type: 0x01, length: 1, val: 0
19:59:35:964 TY_DATA_RESPONSE: seq 16, dpid: 0x01, type: 0x01, length: 1, val: 0
19:59:35:965 TY_DATA_RESPONSE: seq 16, dpid: 0x01, type: 0x01, length: 1, val: 0
19:59:35:966 TY_DATA_RESPONSE: seq 16, dpid: 0x01, type: 0x01, length: 1, val: 0
19:59:40:314 max transmit errors for node 0x00158D0005BCFCEA, last seen by neighbors 861 s
j ai fait un coup on un coup off
Thorgal
Message par Thorgal »
Pas besoin de redemarrer le plugin, je recherche juste la requete faite par le plugin, exemple chez moi quand j'essaye d'allumer une lampe.
2022-10-23 20:06:40.020 Deconz: onCommand called for Unit 8: Parameter 'On', Level: 29, Hue:
2022-10-23 20:06:40.020 Deconz: Send Command /api/601785FDF/lights/3/state with {'on': True, 'bri': 74} (0 in buffer)
2022-10-23 20:06:40.020 Deconz: Making Request: http://127.0.0.1:80/api/601785FDF/lights/3/state with params {'on': True, 'bri': 74}
2022-10-23 20:06:40.048 Deconz: Request Return: [{"success":{"/lights/3/state/on":true}},{"success":{"/lights/3/state/bri":74}}]
2022-10-23 20:06:40.049 Deconz: Classic Data : [{'success': {'/lights/3/state/on': True}}, {'success': {'/lights/3/state/bri': 74}}]
2022-10-23 20:06:40.004 Status: User: Admin (IP: 192.168.1.81) initiated a switch command (36/Deconz - Dimmer salon/On)
Mais dans tes logs le widget se met bien a jour
Mais oui je pense que le probleme est du coté du plugin car il n'y a pas de commande visible du coté deconz, doit y avoir un probleme de synthaxe.
Edit :
Je pense que le widget dans domoticz n'est pas le bon et que le plugin envoit une commande setlevel/bri en meme temps.
