voilà , mais je ne vois pas de changement par rapport à tout à l'heure
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigate/Logs $ tail -50f PluginZigbee_15.log
2022-05-30 13:08:23,659 INFO : [ZiGateForwarder_15] timeout_widget unit Zigate - TS0601-SmartAir_Temp-0c4314fffe881712-01 -> True from 26:26.2
2022-05-30 13:08:23,673 INFO : [ZiGateForwarder_15] timeout_widget unit Zigate - TS0601-SmartAir_Humi-0c4314fffe881712-01 -> True from 62:1
2022-05-30 13:08:23,701 INFO : [ZiGateForwarder_15] timeout_widget unit SmartAir_CarbonDioxyde -> True from 0:2
2022-05-30 13:08:23,720 INFO : [ZiGateForwarder_15] timeout_widget unit SmartAir_CH2O -> True from 0:0.0
2022-05-30 13:08:23,750 INFO : [ZiGateForwarder_15] Receive NACK from c74d clusterId: 0000 Status: a7
2022-05-30 13:08:30,130 INFO : [ZiGateForwarder_15] timeout_widget unit Zigate - Switch9696 -> True from 0:Off
2022-05-30 13:08:30,150 INFO : [ZiGateForwarder_15] timeout_widget unit Zigate - Power-a4c1383480069696-01 -> True from 0:0
2022-05-30 13:08:30,171 INFO : [ZiGateForwarder_15] timeout_widget unit Zigate - Ampere-a4c1383480069696-01 -> True from 0:0.0
2022-05-30 13:08:30,212 INFO : [ZiGateForwarder_15] Receive NACK from 2c7b clusterId: 0000 Status: a7
2022-05-30 13:08:36,610 INFO : [ZiGateForwarder_15] timeout_widget unit Zigate - radiateur -> True from 0:Off
2022-05-30 13:08:36,626 INFO : [ZiGateForwarder_15] Receive NACK from b5df clusterId: 0000 Status: a7
2022-05-30 13:08:43,121 INFO : [ZiGateForwarder_15] timeout_widget unit Zigate - ColorControlRGBWW-0c4314fffe08bbc5-01 -> True from 1:100
2022-05-30 13:08:43,145 INFO : [ZiGateForwarder_15] Receive NACK from 70ab clusterId: 0000 Status: a7
2022-05-30 13:08:49,634 INFO : [ZiGateForwarder_15] timeout_widget unit Zigate - TS0001_Switch-a4c138304af0d905-01 -> True from 0:Off
2022-05-30 13:08:49,651 INFO : [ZiGateForwarder_15] Receive NACK from 836b clusterId: 0000 Status: a7
2022-05-30 13:08:56,100 INFO : [ZiGateForwarder_15] timeout_widget unit Zigbee d637-01 -> True from 0:Off
2022-05-30 13:08:56,120 INFO : [ZiGateForwarder_15] timeout_widget unit Zigbee d637-02 -> True from 0:Off
2022-05-30 13:08:56,143 INFO : [ZiGateForwarder_15] timeout_widget unit Zigbee d637-03 -> True from 0:Off
2022-05-30 13:08:56,165 INFO : [ZiGateForwarder_15] Receive NACK from 3554 clusterId: 0000 Status: a7
2022-05-30 13:11:59,585 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
2022-05-30 13:17:52,969 INFO : [ZiGateForwarder_15] ------> Ampere3 : 0.0;0;0 from Attribute: 0508
2022-05-30 13:18:07,284 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
2022-05-30 13:19:23,234 INFO : [ZiGateForwarder_15] ------> Ampere3 : 2.0;0;0 from Attribute: 0508
2022-05-30 13:19:37,944 INFO : [ZiGateForwarder_15] ------> Ampere3 : 3.0;0;0 from Attribute: 0508
2022-05-30 13:19:52,858 INFO : [ZiGateForwarder_15] ------> Ampere3 : 2.0;0;0 from Attribute: 0508
2022-05-30 13:20:07,841 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
2022-05-30 13:21:08,854 INFO : [ZiGateForwarder_15] ------> Ampere3 : 0.0;0;0 from Attribute: 0508
2022-05-30 13:21:24,305 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
2022-05-30 13:21:51,497 INFO : [ZiGateForwarder_15] ------> Ampere3 : 0.0;0;0 from Attribute: 0508
2022-05-30 13:22:07,176 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
2022-05-30 13:23:07,933 INFO : [ZiGateForwarder_15] ------> Ampere3 : 0.0;0;0 from Attribute: 0508
2022-05-30 13:24:17,696 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
2022-05-30 13:24:32,692 INFO : [ZiGateForwarder_15] ------> Ampere3 : 0.0;0;0 from Attribute: 0508
2022-05-30 13:24:59,963 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
2022-05-30 13:25:15,275 INFO : [ZiGateForwarder_15] ------> Ampere3 : 0.0;0;0 from Attribute: 0508
2022-05-30 13:28:09,205 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
2022-05-30 13:28:29,028 INFO : [ZiGateForwarder_15] ------> Ampere3 : 0.0;0;0 from Attribute: 0508
2022-05-30 13:29:46,577 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
2022-05-30 13:30:15,516 INFO : [ZiGateForwarder_15] ------> Ampere3 : 0.0;0;0 from Attribute: 0508
2022-05-30 13:32:00,150 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
2022-05-30 13:32:14,656 INFO : [ZiGateForwarder_15] ------> Ampere3 : 0.0;0;0 from Attribute: 0508
2022-05-30 13:32:48,281 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
2022-05-30 13:33:03,062 INFO : [ZiGateForwarder_15] ------> Ampere3 : 0.0;0;0 from Attribute: 0508
2022-05-30 13:33:18,025 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
2022-05-30 13:33:33,107 INFO : [ZiGateForwarder_15] ------> Ampere3 : 0.0;0;0 from Attribute: 0508
2022-05-30 13:37:14,917 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
2022-05-30 13:37:48,906 INFO : [ZiGateForwarder_15] ------> Ampere3 : 0.0;0;0 from Attribute: 0508
2022-05-30 13:38:04,024 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
2022-05-30 13:44:08,081 INFO : [ZiGateForwarder_15] ------> Ampere3 : 0.0;0;0 from Attribute: 0508
2022-05-30 13:44:23,831 INFO : [ZiGateForwarder_15] ------> Ampere3 : 1.0;0;0 from Attribute: 0508
à moins qu'il faille que j'attende que l'injection change d'état. ( ce qui me semblerait logique ) vu que je suis en plein routage donc une conso proche de 0
( à ce que j'en comprnds 0x0508 c'est la remonté par le module du courant efficace )
