Kouki31
Messages : 34 Inscription : 08 mars 2019, 19:05
Message
par Kouki31 » 07 févr. 2024, 19:36
Merci.
J'ai essayer mais j'ai une erreur.
root@domotique:/home/user/domoticz/plugins/Domoticz-Zigbee# command: /usr/bin/python3.9 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-9o8995qu/pure-pcapy3/setup.py'"'"'; __file__='"'"'/tmp/pip-install-9o8995qu/pure-pcapy3/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-install-9o8995qu/pure-pcapy3/pip-egg-info
command:: command not found
root@domotique:/home/user/domoticz/plugins/Domoticz-Zigbee# cwd: /tmp/pip-install-9o8995qu/pure-pcapy3/
cwd:: command not found
root@domotique:/home/user/domoticz/plugins/Domoticz-Zigbee# Complete output (3 lines):
-bash: syntax error near unexpected token `('
root@domotique:/home/user/domoticz/plugins/Domoticz-Zigbee# Traceback (most recent call last):
-bash: syntax error near unexpected token `most'
root@domotique:/home/user/domoticz/plugins/Domoticz-Zigbee# File "<string>", line 1, in <module>
-bash: syntax error near unexpected token `newline'
root@domotique:/home/user/domoticz/plugins/Domoticz-Zigbee# ModuleNotFoundError: No module named 'setuptools'
ModuleNotFoundError:: command not found
root@domotique:/home/user/domoticz/plugins/Domoticz-Zigbee# ----------------------------------------
----------------------------------------: command not found
root@domotique:/home/user/domoticz/plugins/Domoticz-Zigbee# ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
ERROR:: command not found
Par contre je ne peut pas enlever python 3.9 ?
Kouki31
Message
par Kouki31 » 07 févr. 2024, 19:37
Ha oui mon utilisateur c'est "user"
2024-02-07 19:34:05.539 Status: PluginSystem: 2 plugins started.
2024-02-07 19:34:05.196 Error: zigate: (Zigate) failed to load 'plugin.py', Python Path used was '/home/user/domoticz/plugins/Domoticz-Zigbee/:/usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload:/usr/local/lib/python3.9/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.9/dist-packages'.
2024-02-07 19:34:05.199 Error: zigate: Traceback (most recent call last):
2024-02-07 19:34:05.199 Error: zigate: File "/home/user/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 103, in <module>
2024-02-07 19:34:05.199 Error: zigate: import z4d_certified_devices
2024-02-07 19:34:05.199 Error: zigate: ModuleNotFoundError: No module named 'z4d_certified_devices'
2024-02-07 19:34:06.078 Status: 3D: Connecting to 192.168.1.123:1883
2024-02-07 19:34:06.078 Status: 3D: enabled TLS mode
2024-02-07 19:34:06.181 Status: 3D: connected to: 192.168.1.123:1883
2024-02-07 19:34:06.282 Status: 3D: Subscribed
2024-02-07 19:34:07.631 rflink: General/kWh (owl_salon)
2024-02-07 19:34:15.100 deconz: ### Request config
Kouki31
Message
par Kouki31 » 07 févr. 2024, 19:42
Bon je test d'enlever python 3.9
sudo apt-get clean
sudo apt-get autoremove --purge
sudo apt-get remove python3.9
Bon ben ca marche !!!
le plug in s'ouvre je test mais ca semble ok.
Plugin: 7.1.008 [3.213]
Firmware: Zigate - 03a0
Kouki31
Message
par Kouki31 » 07 févr. 2024, 19:45
Merci Beaucoup.
Je ne comprend pas tout mais je vais pouvoir essayer mon nouveau compteur eau Merci.
Kouki31
Message
par Kouki31 » 07 févr. 2024, 19:54
Re bon ...
Marche pas...
2024-02-07 19:48:56.116 Status: User: admin (IP: 192.168.1.101) initiated a switch command (144/couloir_lamp/Off)
2024-02-07 19:48:56.128 Error: zigate: onCommand - Unknown device or GrpMgr not enabled couloir_lamp, unit 8 , id 588e81fffeb984a4
Je suppose que c'est normal ...
J'ai supprimer le plugin pour le réinstaller...
y a un manip pour reintegrer les appareil ou je remet le 5 et je l'update ?
Kouki31
Message
par Kouki31 » 07 févr. 2024, 20:04
Re je sais pas ci c'est une bonne idée encore...
J'ai copier le dossier DATA de mon ancien plugin et la ca marche a moitié...
C'est lent et j'ai Des ellement indefinie....
2024-02-07 20:01:07.553 Sunrise: 08:12:00 SunSet: 17:57:00
2024-02-07 20:01:07.553 Day length: 09:45:00 Sun at south: 13:05:00
2024-02-07 20:01:07.553 Civil twilight start: 07:39:00 Civil twilight end: 18:30:00
2024-02-07 20:01:07.553 Nautical twilight start: 07:02:00 Nautical twilight end: 19:08:00
2024-02-07 20:01:07.553 Astronomical twilight start: 06:25:00 Astronomical twilight end: 19:44:00
2024-02-07 20:01:07.577 Active notification Subsystems: telegram (1/13)
2024-02-07 20:01:07.582 Starting shared server on: :::6144
2024-02-07 20:01:09.583 zigate: Worker thread started.
2024-02-07 20:01:09.613 deconz: Worker thread started.
2024-02-07 20:01:09.794 rflink: General/kWh (owl_salon)
2024-02-07 20:01:09.613 Status: deconz: Started.
2024-02-07 20:01:09.613 Status: NotificationSystem: thread started...
2024-02-07 20:01:09.613 Status: EventSystem: reset all events...
2024-02-07 20:01:09.613 Status: deconz: Entering work loop.
2024-02-07 20:01:09.615 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_camera.lua
2024-02-07 20:01:09.615 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_tv_salon_on.lua
2024-02-07 20:01:09.615 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_simple.lua
2024-02-07 20:01:09.615 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_bebe.lua
2024-02-07 20:01:09.615 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_salle_de_bain_disco.lua
2024-02-07 20:01:09.615 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_salle_de_bain_mirroir.lua
2024-02-07 20:01:09.615 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_salle_de_bain_prise.lua
2024-02-07 20:01:09.615 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_cuisine.lua
2024-02-07 20:01:09.615 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_dyson.lua
2024-02-07 20:01:09.615 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_canape.lua
2024-02-07 20:01:09.616 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_ventilateur.lua
2024-02-07 20:01:09.616 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_fenetre.lua
2024-02-07 20:01:09.616 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_lamp_salon_test_couleur.lua
2024-02-07 20:01:09.616 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_buanderie_mirroir.lua
2024-02-07 20:01:09.616 Status: dzVents: Write file: /home/user/domoticz/scripts/dzVents/generated_scripts/e_buanderie.lua
2024-02-07 20:01:09.616 Status: EventSystem: reset all device statuses...
2024-02-07 20:01:09.792 Status: rflink: Using serial port: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
2024-02-07 20:01:09.857 Status: TeleinfoUSB: CRC check mode set to 1
2024-02-07 20:01:09.916 Status: Python EventSystem: Initializing event module.
2024-02-07 20:01:09.916 Status: EventSystem: Started
2024-02-07 20:01:09.916 Status: EventSystem: Queue thread started...
2024-02-07 20:01:10.077 deconz: You are not using 127.0.0.1 as IP, so I suppose deCONZ and Domoticz aren't on same machine
2024-02-07 20:01:10.077 deconz: Taking 192.168.1.125 as Domoticz IP
2024-02-07 20:01:10.077 deconz: Adding banned device : 00:15:8d:00:02:36:c2:3f-01-0500
2024-02-07 20:01:10.319 zigate: load PluginConf
2024-02-07 20:01:10.319 zigate: Loading PluginConf - from Domoticz sqlite Db
2024-02-07 20:01:10.319 zigate: /home/user/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-09.json timestamp is 1707331322.797448
2024-02-07 20:01:10.319 zigate: Dz PluginConf is older than Json Dz: 0 Json: 1707331322.797448
2024-02-07 20:01:10.320 zigate: Installing plugin custom page /home/user/domoticz/www/templates/zigate.html
2024-02-07 20:01:10.320 zigate: Starting LoggingManagement thread
2024-02-07 20:01:10.321 zigate: start_logging_thread
2024-02-07 20:01:10.321 zigate: logging_thread - listening
2024-02-07 20:01:10.054 Status: PluginSystem: 2 plugins started.
2024-02-07 20:01:10.074 Status: deconz: Initialized version 1.0.29, author 'Smanar'
2024-02-07 20:01:10.086 Status: deconz: Plugin custom pages in date
2024-02-07 20:01:10.304 Status: zigate: Initialized version 7.1, author 'pipiche38'
2024-02-07 20:01:10.311 Status: zigate: Zigbee for Domoticz plugin starting
2024-02-07 20:01:10.311 Status: zigate: Z4D plugin requires python3 3.8 or above and you are running 3.8
2024-02-07 20:01:10.311 Status: zigate: Checking Python modules /home/user/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2024-02-07 20:01:10.320 Status: zigate: PluginAnalytics set to 1
2024-02-07 20:01:10.320 Status: zigate: channel set to 11
2024-02-07 20:01:10.320 Status: zigate: filename set to /home/user/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-09.json
2024-02-07 20:01:10.320 Status: zigate: pluginHome set to /home/user/domoticz/plugins/Domoticz-Zigbee
2024-02-07 20:01:10.320 Status: zigate: homedirectory set to /home/user/domoticz/plugins/Domoticz-Zigbee
2024-02-07 20:01:10.320 Status: zigate: pluginData set to /home/user/domoticz/plugins/Domoticz-Zigbee/Data
2024-02-07 20:01:10.320 Status: zigate: pluginConfig set to /home/user/domoticz/plugins/Domoticz-Zigbee/Conf
2024-02-07 20:01:10.320 Status: zigate: pluginOTAFirmware set to /home/user/domoticz/plugins/Domoticz-Zigbee/OTAFirmware
2024-02-07 20:01:10.320 Status: zigate: pluginReports set to /home/user/domoticz/plugins/Domoticz-Zigbee/Reports
2024-02-07 20:01:10.320 Status: zigate: pluginWWW set to /home/user/domoticz/plugins/Domoticz-Zigbee/www
2024-02-07 20:01:10.320 Status: zigate: pluginLogs set to /home/user/domoticz/plugins/Domoticz-Zigbee/Logs
2024-02-07 20:01:10.320 Status: zigate: expJsonDatabase set to 0
2024-02-07 20:01:10.321 Status: zigate: Please watch plugin log into /home/user/domoticz/plugins/Domoticz-Zigbee/Logs/PluginZigbee_09.log
2024-02-07 20:01:10.325 Status: zigate: Zigbee for Domoticz (z4d) plugin stable7-7.1.008 started
2024-02-07 20:01:10.345 Status: zigate: Loading ZCL Cluster definitions
2024-02-07 20:01:10.346 Status: zigate: - ZCL Cluster 0000 - (V1) Basic loaded
2024-02-07 20:01:10.346 Status: zigate: - ZCL Cluster 0001 - (V1) Power loaded
2024-02-07 20:01:10.346 Status: zigate: - ZCL Cluster 0002 - (V1) Device Temperature Configuration loaded
2024-02-07 20:01:10.346 Status: zigate: - ZCL Cluster 0003 - (V1) Identify loaded
2024-02-07 20:01:10.346 Status: zigate: - ZCL Cluster 0004 - (V1) Groups loaded
2024-02-07 20:01:10.346 Status: zigate: - ZCL Cluster 0005 - (V1) Scenes loaded
2024-02-07 20:01:10.346 Status: zigate: - ZCL Cluster 0006 - (V1) On/Off loaded
2024-02-07 20:01:10.346 Status: zigate: - ZCL Cluster 0007 - (V1) On/Off Switch Configuration loaded
2024-02-07 20:01:10.346 Status: zigate: - ZCL Cluster 0008 - (V1) Level loaded
2024-02-07 20:01:10.347 Status: zigate: - ZCL Cluster 0009 - (V1) Alarms loaded
2024-02-07 20:01:10.347 Status: zigate: - ZCL Cluster 000a - (V1) Time loaded
2024-02-07 20:01:10.347 Status: zigate: - ZCL Cluster 000d - (V1) Analog Output loaded
2024-02-07 20:01:10.347 Status: zigate: - ZCL Cluster 000f - (V1) Binary Input loaded
2024-02-07 20:01:10.347 Status: zigate: - ZCL Cluster 0013 - (V1) Multistate Output loaded
2024-02-07 20:01:10.347 Status: zigate: - ZCL Cluster 0019 - (V1) OTA Upgrade loaded
2024-02-07 20:01:10.347 Status: zigate: - ZCL Cluster 0020 - (V1) Poll Control loaded
2024-02-07 20:01:10.347 Status: zigate: - ZCL Cluster 0102 - (V1) Window Covering loaded
2024-02-07 20:01:10.347 Status: zigate: - ZCL Cluster 0202 - (V1) Fan Control loaded
2024-02-07 20:01:10.347 Status: zigate: - ZCL Cluster 0204 - (V1) Thermostat User Interface Configuration loaded
2024-02-07 20:01:10.348 Status: zigate: - ZCL Cluster 0300 - (V1) Color Control loaded
2024-02-07 20:01:10.348 Status: zigate: - ZCL Cluster 0301 - (V1) Ballast Configuration loaded
2024-02-07 20:01:10.348 Status: zigate: - ZCL Cluster 0400 - (V1) Illuminance Level Sensing loaded
2024-02-07 20:01:10.348 Status: zigate: - ZCL Cluster 0402 - (V1) Temperature Measurement loaded
2024-02-07 20:01:10.348 Status: zigate: - ZCL Cluster 0403 - (V1) Pressure Measurement loaded
2024-02-07 20:01:10.348 Status: zigate: - ZCL Cluster 0405 - (V1) Relative Humidity Measurement loaded
2024-02-07 20:01:10.348 Status: zigate: - ZCL Cluster 0406 - (V1) Occupancy Sensing loaded
2024-02-07 20:01:10.348 Status: zigate: - ZCL Cluster 0700 - (V1) Price loaded
2024-02-07 20:01:10.348 Status: zigate: - ZCL Cluster 0702 - (V1) Metering (Smart Energy) loaded
2024-02-07 20:01:10.348 Status: zigate: - ZCL Cluster 0b01 - (V1) Meter Identification loaded
2024-02-07 20:01:10.349 Status: zigate: - ZCL Cluster 0b04 - (V1) Electrical Measurement loaded
2024-02-07 20:01:10.349 Status: zigate: - ZCL Cluster 0b05 - (V1) Diagnostics loaded
2024-02-07 20:01:10.349 Status: zigate: - ZCL Cluster e000 - (V1) Tuya E000 Private Cluster loaded
2024-02-07 20:01:10.349 Status: zigate: - ZCL Cluster e001 - (V1) Tuya E001 Private Cluster loaded
2024-02-07 20:01:10.349 Status: zigate: - ZCL Cluster e002 - (V1) Tuya E002 Private Cluster loaded
2024-02-07 20:01:10.349 Status: zigate: - ZCL Cluster fcc0 - (V1) LUMI Private Cluster loaded
2024-02-07 20:01:10.350 Status: zigate: - ZCL Cluster ff66 - (V1) Lixee Zlinky private cluster loaded
2024-02-07 20:01:10.351 Status: zigate: DeviceConf loaded - 16 confs loaded
2024-02-07 20:01:10.353 Status: zigate: Local-Device conf loaded - 19 confs loaded
2024-02-07 20:01:10.505 Status: zigate: Certified Devices loaded - 559 confs loaded
2024-02-07 20:01:10.508 Status: zigate: load ListOfDevice
2024-02-07 20:01:10.584 Status: 3D: Connecting to 192.168.1.123:1883
2024-02-07 20:01:10.584 Status: 3D: enabled TLS mode
2024-02-07 20:01:10.684 Status: 3D: connected to: 192.168.1.123:1883
2024-02-07 20:01:10.785 Status: 3D: Subscribed
2024-02-07 20:01:10.937 Status: zigate: 45 Entries loaded from /home/user/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-9.txt
2024-02-07 20:01:10.330 Error: zigate: Urlopen to http://127.0.0.1:8080/json.htm?type=command¶m=gethardware rejected. Error: HTTP Error 404: Not Found
2024-02-07 20:01:10.332 Error: zigate: Urlopen to http://127.0.0.1:8080/json.htm?type=command¶m=gethardware rejected. Error: HTTP Error 404: Not Found
2024-02-07 20:01:11.023 Status: zigate: Transport mode: V2-USB
2024-02-07 20:01:11.551 Status: zigate: ZigateTransport: Serial Connection open: Serial<id=0x7fe08d9e59d0, open=True>(port='/dev/serial/by-id/usb-FTDI_ZiGate_ZIGATE+-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2024-02-07 20:01:11.553 Status: zigate: ZigateTransport: writer_thread Thread start.
2024-02-07 20:01:11.557 Status: zigate: ZigateTransport: thread_processing_and_sending Thread start.
2024-02-07 20:01:11.557 Status: zigate: Start Web Server connection
2024-02-07 20:01:11.558 Status: zigate: Web backend for Web User Interface started on port: 9440
2024-02-07 20:01:11.559 Status: zigate: Plugin looks to upgrade the Certified Device package
2024-02-07 20:01:12.876 Status: zigate: Domoticz Widgets usage is at 32.2 % (173 units free)
2024-02-07 20:01:19.063 deconz: ### Request config
2024-02-07 20:01:19.631 rflink: General/kWh (owl_salon)
2024-02-07 20:01:19.064 Error: deconz: Your python version is missing the requests library
2024-02-07 20:01:19.064 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:01:20.720 rflink: General/kWh (owl_garage)
2024-02-07 20:01:21.198 Status: zigate: ==> Transport Mode switch to full mode
2024-02-07 20:01:21.199 Status: zigate: ZiGate+ (V2)
2024-02-07 20:01:21.199 Status: zigate: Installer Version Number: 03a0
2024-02-07 20:01:21.199 Status: zigate: Branch Version: ==> Production <==
2024-02-07 20:01:21.253 Status: zigate: Upgrade Serial line to RTS/CTS HW flow control
2024-02-07 20:01:29.092 deconz: ### Request config
2024-02-07 20:01:29.092 Error: deconz: Your python version is missing the requests library
2024-02-07 20:01:29.092 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:01:31.171 Status: zigate: Zigbee Coordinator ieee: 00158d0005007277 , short addr: 0000
2024-02-07 20:01:31.171 Status: zigate: Network state UP, PANID: d6a5 extPANID: 0x03590ffd2a9a648a Channel: 11
2024-02-07 20:01:32.661 rflink: General/kWh (owl_garage)
2024-02-07 20:01:36.071 Status: zigate: Request Disabling Accepting new Hardware
2024-02-07 20:01:36.557 Status: zigate: Accepting new Hardware: Disable (Off)
2024-02-07 20:01:36.769 Status: zigate: Number of devices recently active in Coordinator = 69
2024-02-07 20:01:36.769 Status: zigate: [00] DevID: 00 Network addr: eb7f IEEE: 2c1165fffe20a1ef LQI: 000 power: 02 Model: TS011F-multiprise ( )
2024-02-07 20:01:36.769 Status: zigate: [01] DevID: 01 Network addr: 93ce IEEE: bc33acfffe4e790e LQI: 088 power: 01 Model: TS011F-multiprise ( )
2024-02-07 20:01:36.769 Status: zigate: [02] DevID: 02 Network addr: a81a IEEE: bc33acfffe4e74bb LQI: 048 power: 01 Model: TS011F-multiprise ( )
2024-02-07 20:01:36.770 Status: zigate: [03] DevID: 03 Network addr: 5d76 IEEE: 0c4314fffef9e0d8 LQI: 112 power: 01 Model: TS011F-multiprise ( )
2024-02-07 20:01:36.770 Status: zigate: [04] DevID: 04 Network addr: ec30 IEEE: 0c4314fffe6ff325 LQI: 089 power: 01 Model: TS011F ( )
2024-02-07 20:01:36.770 Status: zigate: [05] DevID: 05 Network addr: 79df IEEE: 50325ffffe4e0928 LQI: 099 power: 01 Model: TS011F ( )
2024-02-07 20:01:36.770 Status: zigate: [06] DevID: 06 Network addr: 6d84 IEEE: 5c0272fffe24bee0 LQI: 045 power: 01 Model: TS0505A ( )
2024-02-07 20:01:36.770 Status: zigate: [07] DevID: 07 Network addr: 52f8 IEEE: 588e81fffeb984a4 LQI: 068 power: 02 Model: TS0502A ( )
2024-02-07 20:01:36.770 Status: zigate: [08] DevID: 08 Network addr: 6312 IEEE: 0c4314fffef63e30 LQI: 049 power: 01 Model: TS011F-multiprise ( )
2024-02-07 20:01:36.770 Status: zigate: [09] DevID: 09 Network addr: 0ada IEEE: bc33acfffe65ec95 LQI: 080 power: 01 Model: TS011F ( )
2024-02-07 20:01:36.770 Status: zigate: [10] DevID: 0a Network addr: e927 IEEE: 50325ffffe4e0948 LQI: 071 power: 01 Model: TS011F ( )
2024-02-07 20:01:36.771 Status: zigate: [11] DevID: 0b Network addr: bdd1 IEEE: 0c4314fffef63dfd LQI: 035 power: 01 Model: TS011F-multiprise ( )
2024-02-07 20:01:36.771 Status: zigate: [12] DevID: 0c Network addr: adc4 IEEE: bc33acfffe34c74a LQI: 063 power: 01 Model: TS011F-multiprise ( )
2024-02-07 20:01:36.771 Status: zigate: [13] DevID: 0d Network addr: e116 IEEE: 50325ffffe39a298 LQI: 000 power: 01 Model: TS011F-multiprise ( )
2024-02-07 20:01:36.771 Status: zigate: [14] DevID: 0e Network addr: 0c91 IEEE: ec1bbdfffea962a3 LQI: 000 power: 01 Model: TS011F ( )
2024-02-07 20:01:36.771 Status: zigate: [15] DevID: 0f Network addr: 11a5 IEEE: bc33acfffe641824 LQI: 000 power: 01 Model: TS011F ( )
2024-02-07 20:01:36.771 Status: zigate: [16] DevID: 10 Network addr: bb53 IEEE: 50325ffffe5eacb5 LQI: 086 power: 01 Model: TS011F ( )
2024-02-07 20:01:36.771 Status: zigate: [17] DevID: 11 Network addr: 9130 IEEE: 60a423fffe47f4da LQI: 068 power: 01 Model: TS0505A ( )
2024-02-07 20:01:36.771 Status: zigate: [18] DevID: 12 Network addr: 3de0 IEEE: cc86ecfffeeba097 LQI: 075 power: 01 Model: TS011F ( )
2024-02-07 20:01:36.772 Status: zigate: [19] DevID: 13 Network addr: e795 IEEE: cc86ecfffeea961d LQI: 083 power: 01 Model: TS011F ( )
2024-02-07 20:01:36.772 Status: zigate: [20] DevID: 14 Network addr: 3c74 IEEE: bc33acfffec6dfa2 LQI: 090 power: 01 Model: TS011F ( )
2024-02-07 20:01:36.772 Status: zigate: [21] DevID: 15 Network addr: 01dd IEEE: a4c13862cbf1fd3f LQI: 053 power: 01 Model: TS0004 ( )
2024-02-07 20:01:36.772 Status: zigate: [22] DevID: 16 Network addr: 7094 IEEE: 60a423fffe6b6e9f LQI: 054 power: 01 Model: TS0505A ( )
2024-02-07 20:01:36.772 Status: zigate: [23] DevID: 17 Network addr: 3aa3 IEEE: 84fd27fffe8035da LQI: 000 power: 02 Model: TS004F-_TZ3000_xabckq1v ( )
2024-02-07 20:01:36.772 Status: zigate: [24] DevID: 18 Network addr: 89af IEEE: bc33acfffe5a8126 LQI: 060 power: 01 Model: TS0505A ( )
2024-02-07 20:01:36.772 Status: zigate: [25] DevID: 19 Network addr: 15f7 IEEE: 60a423fffee26f4c LQI: 000 power: 02 Model: TS0601-2Gangs-switch ( )
2024-02-07 20:01:36.772 Status: zigate: [26] DevID: 1a Network addr: fb06 IEEE: 60a423fffe3e5758 LQI: 000 power: 02 Model: TS0505A ( )
2024-02-07 20:01:36.773 Status: zigate: [27] DevID: 1b Network addr: c563 IEEE: 588e81fffeeddeeb LQI: 068 power: 01 Model: TS0505A ( )
2024-02-07 20:01:36.773 Status: zigate: [28] DevID: 1c Network addr: 784e IEEE: 60a423fffee664ef LQI: 004 power: 02 Model: TS0505A ( )
2024-02-07 20:01:36.773 Status: zigate: [29] DevID: 1d Network addr: 2d3c IEEE: 60a423fffee66462 LQI: 000 power: 02 Model: TS0505A ( )
2024-02-07 20:01:36.773 Status: zigate: [30] DevID: 1e Network addr: 262f IEEE: a4c138757be7f5e1 LQI: 004 power: 02 Model: TS0001 ( )
2024-02-07 20:01:36.773 Status: zigate: [31] DevID: 1f Network addr: 8790 IEEE: a4c138737d36e483 LQI: 000 power: 02 Model: TS0004 ( )
2024-02-07 20:01:36.773 Status: zigate: [32] DevID: 20 Network addr: 0d14 IEEE: a4c138d7b53c93bb LQI: 000 power: 02 Model: TS0201 ( )
2024-02-07 20:01:36.773 Status: zigate: [33] DevID: 21 Network addr: a540 IEEE: 60a423fffe530063 LQI: 004 power: 02 Model: TS0505A ( )
2024-02-07 20:01:36.774 Status: zigate: [34] DevID: 22 Network addr: 092e IEEE: 60a423fffe7bec1f LQI: 047 power: 01 Model: TS0505A ( )
2024-02-07 20:01:36.774 Status: zigate: [35] DevID: 23 Network addr: c21e IEEE: 60a423fffe52efd5 LQI: 000 power: 02 Model: TS0505A ( )
2024-02-07 20:01:36.774 Status: zigate: [36] DevID: 24 Network addr: 3d17 IEEE: 60a423fffe0e3963 LQI: 000 power: 01 Model: TS011F ( )
2024-02-07 20:01:36.774 Status: zigate: [37] DevID: 25 Network addr: 1d1f IEEE: bc33acfffef4c4f7 LQI: 000 power: 01 Model: TS0505A ( )
2024-02-07 20:01:36.774 Status: zigate: [38] DevID: 26 Network addr: 41a0 IEEE: 0c4314fffe6fee69 LQI: 078 power: 01 Model: TS011F ( )
2024-02-07 20:01:36.774 Status: zigate: [39] DevID: 27 Network addr: c24f IEEE: 60a423fffe70c126 LQI: 059 power: 01 Model: TS0505A ( )
2024-02-07 20:01:36.774 Status: zigate: [40] DevID: 28 Network addr: a369 IEEE: 588e81fffef2d3e0 LQI: 072 power: 01 Model: TS0505A ( )
2024-02-07 20:01:36.775 Status: zigate: [41] DevID: 29 Network addr: 1d2a IEEE: 0017880109aaaaf4 LQI: 000 power: 02 Model: RWL022 ( )
2024-02-07 20:01:36.775 Status: zigate: [42] DevID: 2a Network addr: a35d IEEE: 60a423fffe482caa LQI: 000 power: 01 not found in plugin database!
2024-02-07 20:01:36.775 Status: zigate: [43] DevID: 2b Network addr: 5a2b IEEE: bc33acfffed85adb LQI: 000 power: 02 not found in plugin database!
2024-02-07 20:01:36.775 Status: zigate: [44] DevID: 2c Network addr: 1774 IEEE: b4e3f9fffe1a1203 LQI: 000 power: 02 not found in plugin database!
2024-02-07 20:01:36.775 Status: zigate: [45] DevID: 2d Network addr: 0402 IEEE: b4e3f9fffe78122f LQI: 000 power: 01 not found in plugin database!
2024-02-07 20:01:36.775 Status: zigate: [46] DevID: 2e Network addr: 0da6 IEEE: bc33acfffe4c80d4 LQI: 004 power: 02 not found in plugin database!
2024-02-07 20:01:36.775 Status: zigate: [47] DevID: 2f Network addr: 9753 IEEE: 50325ffffe39aad2 LQI: 000 power: 02 not found in plugin database!
2024-02-07 20:01:36.775 Status: zigate: [48] DevID: 30 Network addr: 5783 IEEE: 847127fffed41b0b LQI: 000 power: 02 Model: TS0044 ( )
2024-02-07 20:01:36.775 Status: zigate: [49] DevID: 31 Network addr: bada IEEE: 5c0272fffe94411b LQI: 004 power: 02 not found in plugin database!
2024-02-07 20:01:36.775 Status: zigate: [50] DevID: 32 Network addr: cb15 IEEE: 8cf681fffe274b71 LQI: 004 power: 02 not found in plugin database!
2024-02-07 20:01:36.776 Status: zigate: [51] DevID: 33 Network addr: 02fe IEEE: a4c13870dd4b9c24 LQI: 000 power: 02 Model: TS0201 ( )
2024-02-07 20:01:36.776 Status: zigate: [52] DevID: 34 Network addr: 424f IEEE: 842e14fffe2c1c21 LQI: 000 power: 02 not found in plugin database!
2024-02-07 20:01:36.776 Status: zigate: [53] DevID: 35 Network addr: 5e0d IEEE: 588e81fffec814a1 LQI: 004 power: 02 not found in plugin database!
2024-02-07 20:01:36.776 Status: zigate: [54] DevID: 36 Network addr: 6749 IEEE: 842e14fffe3591e4 LQI: 004 power: 02 not found in plugin database!
2024-02-07 20:01:36.776 Status: zigate: [55] DevID: 37 Network addr: 468b IEEE: 842e14fffe2c3af6 LQI: 004 power: 02 not found in plugin database!
2024-02-07 20:01:36.776 Status: zigate: [56] DevID: 38 Network addr: e86d IEEE: 2c1165fffe84052c LQI: 004 power: 02 not found in plugin database!
2024-02-07 20:01:36.776 Status: zigate: [57] DevID: 39 Network addr: 43b4 IEEE: 2c1165fffee15a22 LQI: 000 power: 02 not found in plugin database!
2024-02-07 20:01:36.776 Status: zigate: [58] DevID: 3a Network addr: 2682 IEEE: 540f57fffe9416dd LQI: 000 power: 02 not found in plugin database!
2024-02-07 20:01:36.776 Status: zigate: [59] DevID: 3b Network addr: 9dbf IEEE: 60a423fffe3e4844 LQI: 000 power: 02 not found in plugin database!
2024-02-07 20:01:36.776 Status: zigate: [60] DevID: 3c Network addr: 5c07 IEEE: 00124b00245cc588 LQI: 000 power: 02 not found in plugin database!
2024-02-07 20:01:36.777 Status: zigate: [61] DevID: 3d Network addr: 4cb5 IEEE: bc33acfffe4e7423 LQI: 000 power: 02 not found in plugin database!
2024-02-07 20:01:36.777 Status: zigate: [62] DevID: 3e Network addr: bb94 IEEE: a4c138dc0abedde2 LQI: 000 power: 02 not found in plugin database!
2024-02-07 20:01:36.777 Status: zigate: [63] DevID: 3f Network addr: fe2c IEEE: a4c138acab9a6213 LQI: 004 power: 02 not found in plugin database!
2024-02-07 20:01:36.777 Status: zigate: [64] DevID: 40 Network addr: b8db IEEE: a4c13869b962343d LQI: 000 power: 02 not found in plugin database!
2024-02-07 20:01:36.777 Status: zigate: [65] DevID: 41 Network addr: e824 IEEE: a4c138edd19a4c85 LQI: 000 power: 02 not found in plugin database!
2024-02-07 20:01:36.777 Status: zigate: [66] DevID: 42 Network addr: 5698 IEEE: 2c1165fffed8ffca LQI: 004 power: 02 not found in plugin database!
2024-02-07 20:01:36.777 Status: zigate: [67] DevID: 43 Network addr: 7e12 IEEE: 00158d0005d2b035 LQI: 004 power: 02 not found in plugin database!
2024-02-07 20:01:36.777 Status: zigate: [68] DevID: 44 Network addr: a02a IEEE: 00158d0005d245ad LQI: 004 power: 02 not found in plugin database!
2024-02-07 20:01:39.075 deconz: ### Request config
2024-02-07 20:01:39.075 Error: deconz: Your python version is missing the requests library
2024-02-07 20:01:39.075 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:01:41.089 Status: zigate: coordinator set to Certification : 1/CE -> CE
2024-02-07 20:01:43.471 Status: zigate: ota_scan_folder Following Firmware have been loaded
2024-02-07 20:01:43.471 Status: zigate: Plugin with Zigate+, firmware 03a0 correctly initialized
2024-02-07 20:01:44.662 rflink: General/kWh (owl_garage)
2024-02-07 20:01:49.051 deconz: ### Request config
2024-02-07 20:01:49.052 Error: deconz: Your python version is missing the requests library
2024-02-07 20:01:49.052 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:01:56.661 rflink: General/kWh (owl_garage)
2024-02-07 20:01:59.077 deconz: ### Request config
2024-02-07 20:01:59.077 Error: deconz: Your python version is missing the requests library
2024-02-07 20:01:59.077 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:02:07.631 rflink: General/kWh (owl_salon)
2024-02-07 20:02:08.660 rflink: General/kWh (owl_garage)
2024-02-07 20:02:09.055 deconz: ### Request config
2024-02-07 20:02:09.055 Error: deconz: Your python version is missing the requests library
2024-02-07 20:02:09.055 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:02:19.085 deconz: ### Request config
2024-02-07 20:02:19.635 rflink: General/kWh (owl_salon)
2024-02-07 20:02:19.085 Error: deconz: Your python version is missing the requests library
2024-02-07 20:02:19.085 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:02:20.719 rflink: General/kWh (owl_garage)
2024-02-07 20:02:29.060 deconz: ### Request config
2024-02-07 20:02:29.060 Error: deconz: Your python version is missing the requests library
2024-02-07 20:02:29.060 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:02:31.631 rflink: General/kWh (owl_salon)
2024-02-07 20:02:32.660 rflink: General/kWh (owl_garage)
2024-02-07 20:02:35.887 zigate: UpdateDevice - ( salon_cadre) 0:Off
2024-02-07 20:02:35.846 Status: User: admin (IP: 192.168.1.101) initiated a switch command (244/salon_cadre/Off)
2024-02-07 20:02:39.094 deconz: ### Request config
2024-02-07 20:02:39.094 Error: deconz: Your python version is missing the requests library
2024-02-07 20:02:39.094 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:02:43.631 rflink: General/kWh (owl_salon)
2024-02-07 20:02:44.660 rflink: General/kWh (owl_garage)
2024-02-07 20:02:49.072 deconz: ### Request config
2024-02-07 20:02:49.072 Error: deconz: Your python version is missing the requests library
2024-02-07 20:02:49.072 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:02:55.631 rflink: General/kWh (owl_salon)
2024-02-07 20:02:56.662 rflink: General/kWh (owl_garage)
2024-02-07 20:02:59.097 deconz: ### Request config
2024-02-07 20:02:59.097 Error: deconz: Your python version is missing the requests library
2024-02-07 20:02:59.097 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:03:00.047 Status: zigate: Erase Log History
2024-02-07 20:03:07.631 rflink: General/kWh (owl_salon)
2024-02-07 20:03:08.661 rflink: General/kWh (owl_garage)
2024-02-07 20:03:09.075 deconz: ### Request config
2024-02-07 20:03:09.075 Error: deconz: Your python version is missing the requests library
2024-02-07 20:03:09.075 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:03:10.213 zigate: UpdateDevice - ( salon_cadre) 1:51
2024-02-07 20:03:10.195 Status: User: admin (IP: 192.168.1.101) initiated a switch command (244/salon_cadre/On)
2024-02-07 20:03:19.100 deconz: ### Request config
2024-02-07 20:03:19.635 rflink: General/kWh (owl_salon)
2024-02-07 20:03:19.100 Error: deconz: Your python version is missing the requests library
2024-02-07 20:03:19.100 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:03:29.081 deconz: ### Request config
2024-02-07 20:03:29.081 Error: deconz: Your python version is missing the requests library
2024-02-07 20:03:29.081 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:03:31.631 rflink: General/kWh (owl_salon)
2024-02-07 20:03:32.660 rflink: General/kWh (owl_garage)
2024-02-07 20:03:39.056 deconz: ### Request config
2024-02-07 20:03:39.056 Error: deconz: Your python version is missing the requests library
2024-02-07 20:03:39.056 Error: deconz: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-02-07 20:03:43.631 rflink: General/kWh (owl_salon)
2024-02-07 20:03:44.660 rflink: General/kWh (owl_garage)
Messages : 4677 Inscription : 04 avr. 2018, 16:16
Contact :
Message
par pipiche » 07 févr. 2024, 20:17
tu as un plugin "deconz" qui semble raller ?
Si vous appréciez ce que je fais, vous pouvez contribuer par un don
Paypal , ce qui me permettra notamment l'achat d’équipements et de les tester/valider pour le plugin.
Wiki
ici
Messages : 6638 Inscription : 23 juil. 2019, 20:57
Message
par Keros » 07 févr. 2024, 20:25
Je lui ai déjà posé la
question , il serait sur un deuxième coordinateur.
Mais, il est vrai qu'un petit nettoyage des logs avant de nous les transmettre aurait été apprécié.
Kouki31
Message
par Kouki31 » 07 févr. 2024, 20:31
Merci.
Mon second coordinateur avec deconz n'est toujours pas content mais il me sert pour quelque capteur que j'espere enfin passé sous zeegbee donc j'espere l'enlever...
Par contre imposible d'appairer le compteur "d'eau"...
Kouki31
Message
par Kouki31 » 07 févr. 2024, 21:37
RE RE RE...
Bon je ne comprend pas mais 1 compteur d'eau et apparue plus de 5 aprés l'avoir appairer je ne sais combien de fois...
La je vais aux dodo.
Merci de votre aide.
