[Résolu] Optimisation - Détecteur Lexman Ouverture porte / Vibration
YopYop
Re: Optimisation - Détecteur Lexman Ouverture porte / Vibration
Message par YopYop »
C'est ce que j'avais déjà essayé.
Je viens de le refaire et toujours la même erreur.
Au redémarrage du plugin, j'ai une première série d'erreur :
2024-09-01 20:21:52.677 Status: conbee: WebUI Server started on 0.0.0.0:9440
2024-09-01 20:21:52.760 Status: conbee: ++ Started radio deconz port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE3020188-if00
2024-09-01 20:21:52.760 Status: conbee: ++ Use of Zigpy Persistent Db
2024-09-01 20:21:52.908 Status: conbee: Plugin looks to upgrade the Certified Device package
2024-09-01 20:21:56.039 Error: conbee: forwarder_thread - Error while receiving a Coordinator command
2024-09-01 20:21:56.063 Error: conbee: Issue in request 0180020036ff0001040b04010102fdae02000018270900000b09290a00100e0100ff03, dumping stack: Traceback (most recent call last):
2024-09-01 20:21:56.063 File "/home/domotique/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py", line 42, in forwarder_thread
2024-09-01 20:21:56.063 forward_message(self, message)
2024-09-01 20:21:56.063 File "/home/domotique/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/instrumentation.py", line 31, in f_out
2024-09-01 20:21:56.063 result = f_in(self, message)
2024-09-01 20:21:56.063 File "/home/domotique/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py", line 58, in forward_message
2024-09-01 20:21:56.063 self.F_out(message)
2024-09-01 20:21:56.063 File "/home/domotique/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 749, in processFrame
2024-09-01 20:21:56.063 zigbee_receive_message(self, Devices, Data)
2024-09-01 20:21:56.063 File "/home/domotique/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 165, in zigbee_receive_message
2024-09-01 20:21:56.063 _decode_message(self, MsgType, Devices, Data, MsgData, MsgLQI)
2024-09-01 20:21:56.063 File "/home/domotique/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 172, in _decode_message
2024-09-01 20:21:56.063 decoding_method(self, Devices, MsgData, MsgLQI)
2024-09-01 20:21:56.063 File "/home/domotique/domoticz/plugins/Domoticz-Zigbee/Z4D_decoders/z4d_decoder_config_reporting.py", line 38, in Decode8122
2024-09-01 20:21:56.063 self.configureReporting.read_report_configure_response(MsgData, MsgLQI)
2024-09-01 20:21:56.063 AttributeError: 'NoneType' object has no attribute 'read_report_configure_response'
et après l'autre erreur qui revient toutes les 5 secondes.
essayes de refaire un update . SI encore une erreur, merci de mettre egalement le export.json
YopYop
OK, problème résolu après le dernier update.
J'ai pu tester les modifs que tu avais poussées en août.
L'alerte "Tamper" ne se déclenche plus qu'en cas d'ouverture du compartiment des piles comme attendu. Il n'y a plus de fausse détection sur les vibrations ou les ouvertures ou fermetures de porte.
Modération
YopYop
Si pipiche n'a besoin de rien d'autre, je passe effectivement en résolu.
Merci encore pour ton aide.
Re: [Résolu] Optimisation - Détecteur Lexman Ouverture porte / Vibration
super . merci du retour
