[DzVents] Script de notifications ultime (mais pas que)
denis_brasseur
Re: [DZVents]script de notifications ultime (mais pas que)
Message par denis_brasseur »
papoo a écrit : 07 avr. 2019, 14:07 Je suis intéressé 😃
Enfin un vrai connaisseur :lol: , au moins un.
Tout ceci est sans prétention, mais je compte sur toi pour tes remarques.
original script by rrozema Generic auto-off : https://www.domoticz.com/forum/viewtopic.php?f=72&t=23717&p=205159&hilit=auto+off#p201976
author = papoo
maj : 04/03/2019
this version need a waaren script, Universal function notification :
https://www.domoticz.com/forum/viewtopic.php?f=59&t=26542#p204958
https://pon.fr/dzvents-fonction-de-notification-universelle/
blog url : https://pon.fr/dzvents-script-de-notification-ultime-mais-pas-que
fourm url : https://easydomoticz.com/forum/viewtopic.php?f=17&t=8167
github url : https://github.com/papo-o/domoticz_scripts/blob/master/dzVents/scripts/JsonDescription.lua
This script will run every minute and can automatically send an 'Off' command to turn off any device after
it has been on for some specified time. Each device can be individually configured by putting json coded
settings into the device's description field. The settings currently supported are:
- "auto_off_minutes" : <time in minutes>
- "auto_off_motion_device" : "<name of a motion detection device>"
If "auto_off_minutes" is not set, the device will never be turned off by this script. If
"auto_off_minutes" is set and <time in minutes> is a valid number, the device will be turned off when it
is found to be on plus the device's lastUpdate is at least <time in minutes> minutes old. This behavior
can be further modified by specifying a valid device name after "auto_off_motion_device". When a motion
device is specified and the device's lastUpdate is at least <time in minutes> old, the device will not
be turned off until the motion device is off and it's lastUpdate is also <time in minutes> old.
Specifying "auto_off_motion_device" without specifying "auto_off_minutes" does nothing.
Si "auto_off_minutes" n'est pas défini, le périphérique ne sera jamais désactivé par ce script. Si
"auto_off_minutes" est défini et <temps en minutes> est un nombre valide, le périphérique sera désactivé lorsqu'il
s’avère être allumé plus la dernière mise à jour du périphérique a au moins <heure en minutes> minutes. Ce comportement
peut être encore modifié en spécifiant un nom de périphérique valide après "auto_off_motion_device". Quand une motion
device est spécifié et que lastUpdate du périphérique est au moins <temps en minutes>, le périphérique ne
être éteint jusqu'à ce que l'appareil de mouvement soit éteint et que sa dernière mise à jour soit également <heure en minutes>.
Spécifier "auto_off_motion_device" sans spécifier "auto_off_minutes" ne fait rien.
Example 1: turn off the device after 2 minutes:
Exemple 1: éteignez l'appareil après 2 minutes:
"auto_off_minutes": 2
Example 2: turn off the device when it has been on for 5 minutes and no motion has been detected by
the "Overloop: Motion" device:
Exemple 2: éteignez l'appareil lorsqu'il est allumé depuis 5 minutes et qu'aucun mouvement n'a été détecté par
le dispositif "Overloop: Motion":
"auto_off_minutes": 5,
"auto_off_motion_device": "Overloop: Motion"
Example 3: turn off the device when it has been on for 2 minutes and no motion has been detected by
either of the "Overloop: Motion" or the "Trap: Motion" devices:
exemple 3: éteignez l'appareil lorsqu'il est allumé depuis 2 minutes et qu'aucun mouvement n'a été détecté par
l’un des dispositifs "Overloop: Motion" ou "Trap: Motion":
"auto_off_minutes": 2,
"auto_off_motion_device": {"Overloop: Motion", "Trap: Motion"}
With this new version you can :
- be notified if temperature and or hygrometry exceed min or max threshold.
- be notified if device is on, off or out
you can mix the desired notifications, such as only the maximum temperature rise,
or the minimum and maximum humidity, or do not set quiet hours, or minimum temperature and timout
if you want to use the notification functions, the frequency of notifications is necessary
Avec cette nouvelle version vous pouvez :
- être averti après le délai défini si la température et / ou l'hygrométrie dépassent le seuil minimal ou maximal.
- être averti si l'appareil est allumé, éteint ou éteint hors service
vous pouvez mélanger les notifications souhaitées, telles que uniquement le dépassement de température maxi,
ou  l'hygrométrie mini et maxi, ou ne pas définir d'heures calmes, ou température mini et timeout
si vous souhaitez utiliser les fonctions de notification,  la fréquence de notifications est nécessaire
Example 4 : be notified if temperature or hygrometry exceed min or max threshold
with notifications frequency in minutes and quiet hours notification
Exemple 4: être averti si la température ou l'hygrométrie dépasse les seuils minimal ou maximal
pendant un certain nombre de minutes
avec fréquence de notifications en minutes et notification des heures calmes
 "low_threshold_temp": 10,
 "high_threshold_temp": 40,
 "duration_exceeded_temp": 20,
 "low_threshold_hr": 25,
 "high_threshold_hr": 75,
 "duration_exceeded_hr": 20,
 "frequency_notifications": 60,
 "quiet_hours":"23:00-07:15"
Example 5 : be notified if device is on since x minutes
Exemple 5: être averti si le périphérique est allumé depuis x minutes
 "time_active_notification": 120,
Example 6 : be notified if device is off since x minutes
Exemple 6: être averti si le périphérique est éteint depuis x minutes
 "time_inactive_notification": 2,
Example 7 : be notified if device is out since x minutes
Exemple 7: être averti si le périphérique est hors service depuis x minutes
"timeout_notification": 1440,
Exemple 8 : être averti si un périphérique % dépasse les seuils minimal ou maximal
 "low_threshold_purcent": 10,
 "high_threshold_purcent": 40,
 "duration_exceeded_purcent": 20,
  Exemple 9 :être averti si un périphérique Custom Sensor dépasse les seuils minimal ou maximal
 "low_threshold_custom": 1000,
 "high_threshold_custom": 4000,
  Exemple 10 : être averti si un périphérique Alert dépasse un seuil prédéfini (1,2,3 ou 4)
be notified if an Alert device exceeds a predefined threshold (1,2,3 or 4)
with frequency of notifications in minutes and notification of quiet hours
 "high_threshold_color": 4,
  Exemple 11 : être averti si la batterie d'un périphérique est inférieure un seuil bas
  --Niveau de batterie
 "low_battery_level": 30,
 "high_threshold_temp": -15,
  signalLevel
  Exemple 12 : être averti si le niveau de signal d'un périphérique est inférieure un seuil bas
  --Niveau de captage zwave, rfxcom
 "low_signal_level": 2,
  Exemple 13 : être averti si un périphérique puissance dépasse un seuil haut ou un seuil bas défini
  WActual: Nombre. Courant électrique Watt usage.
  Info: Json Description v0.8: Nom CM180 -type-General -deviceSubType-kWh -hardwareType-RFXCOM - RFXtrx433 USB 433.92MHz Transceiver -state-4249.000;10953081.000
 "low_watt_usage": 0,
 "high_watt_usage": 10000,
  Exemple 13 : être averti si un périphérique intensité dépasse un seuil haut ou un seuil bas défini
  Nom Intensite -type-General -deviceSubType-Current -hardwareType-Dummy (Does nothing, use for virtual switches only) -state-19.31
 "low_current_usage": 0,
 "high_current_usage": 60,
  Exemple 14 allumer l'appareil après 1 minutes:
  Example 14 : turn on the device after 1 minutes:
"auto_on_minutes": 1
--https://easydomoticz.com/dzvents-domoticz-scripts-nont-jamais-ete-plus-faciles/
--https://www.domoticz.com/wiki/DzVents:_next_generation_LUA_scripting#Amp.C3.A8re.2C_1-phase
--permet de lire les valeurs des périphériques avec "duration_exceeded_temp", "low_threshold_hr", "high_threshold_hr" ou  "duration_exceeded_hr"
function managed(dz, id, duration_exceeded, high_threshold, low_threshold)
	test_high_threshold = true
	test_low_threshold = true
	x = 0
	dz.data.managedId.forEach(
		function(item)
			x = x + 1
			if item.data == id then
				timeNotif = tonumber(item.time.minutesAgo)
				local value = dz.data.managedValue.get(x)
				if timeNotif < duration_exceeded then -- on test si l'ancienneté de la valeur est < à la valeur duration_exceeded_temp
					if high_threshold ~= nil then -- si la value est < à la valeur de ref, on passe la variable à false => pas d'envoi de notification
						if value.data <= high_threshold then test_high_threshold = false end
					if low_threshold ~= nil then -- si la value est > à la valeur de ref, on passe la variable à false => pas d'envoi de notification
						if value.data >= low_threshold then test_low_threshold = false end
	return test_high_threshold, test_low_threshold
	--test_high_threshold, test_low_threshold = managed(dz, id, duration_exceeded, high_threshold, low_threshold)
local scriptName = 'Json Description'
local scriptVersion = '0.8'
return {
	active = true,
	on = {
		-- timer triggers
		timer = {
			'every minute'
	-- custom logging level for this script
	logging = {
				-- level    =   domoticz.LOG_DEBUG,
				--  level    =   domoticz.LOG_INFO,             -- Seulement un niveau peut être actif; commenter les autres
				level    =   domoticz.LOG_ERROR,            -- Only one level can be active; comment others
				-- level    =   domoticz.LOG_MODULE_EXEC_INFO,
				marker = scriptName..' v'..scriptVersion
	--permet de stocker les valeurs des périphériques avec "duration_exceeded_" sous /home/pi/domoticz/scripts/dzVents/data/__data_JsonDescription.lua
   data = {
		managedValue = { history = true, maxItems = 3600, maxHours = 6 }, --, maxMinutes = 1
		managedId = { history = true, maxItems = 3600, maxHours = 6 }, --, maxMinutes = 1
	execute = function(domoticz, triggeredItem, info)
	    local cnt = 0
        local SubSystem             =  {
										-- table with one or more notification systems.
										-- uncomment the notification systems that you want to be used
										-- Can be one or more of
										-- domoticz.NSS_GOOGLE_CLOUD_MESSAGING,
										domoticz.NSS_PUSHOVER,
										-- domoticz.NSS_HTTP,
										-- domoticz.NSS_KODI,
										-- domoticz.NSS_LOGITECH_MEDIASERVER,
										-- domoticz.NSS_NMA,
										-- domoticz.NSS_PROWL,
										-- domoticz.NSS_PUSHALOT,
										--domoticz.NSS_PUSHBULLET,
										-- domoticz.NSS_PUSHOVER,
										-- domoticz.NSS_PUSHSAFER,
										-- domoticz.NSS_TELEGRAM,
	local subject				= "/!\\ Attention /!\\"           -- sujet des notifications
		domoticz.devices().forEach(
			function(device)
				cnt = cnt + 1
				local frequency_notifications = nil
				local quiet_hours = nil
				local message = nil
				--domoticz.log('Nom '.. device.name .. '-type-' .. device.deviceType.. '-deviceSubType-'..device.deviceSubType .. '-hardwareType-' .. device.hardwareType .. '-state-'..device.state, domoticz.LOG_INFO)
				--2019-03-09 19:17:00.732 Status: dzVents: Info: Json Description v0.72: Nom Memory_Usage type General deviceSubType Percentage
                local description = device.description
                local j = string.find(tostring(description), '^{.*}$')
                if description ~= nil and description ~= '' and j ~= nil then
                    local ok, settings = pcall( domoticz.utils.fromJSON, description)
                    if ok and settings then
                    -- fréquence de notification
                        if settings.frequency_notifications ~= nil then
                            frequency_notifications = settings.frequency_notifications
                            domoticz.log('la fréquence de notification pour '.. device.name .. ' est de  ' .. settings.frequency_notifications.." minutes", domoticz.LOG_INFO)
                    -- période silencieuse
                        if settings.quiet_hours ~= nil then
                            quiet_hours = settings.quiet_hours
                            domoticz.log('la période silencieuse de notification pour '.. device.name .. ' est fixée à  ' .. quiet_hours, domoticz.LOG_INFO)
						if device.temperature ~= nil and settings.high_threshold_temp ~= nil then  -- seuil haut température
							domoticz.log(device.name .. ' a un seuil temperature haute défini à  ' .. settings.high_threshold_temp..'°C', domoticz.LOG_INFO)
						if device.temperature ~= nil and settings.low_threshold_temp ~= nil then  -- seuil bas température
							domoticz.log(device.name .. ' a un seuil temperature basse défini à  ' .. settings.low_threshold_temp..'°C', domoticz.LOG_INFO)
						if device.percentage ~= nil and settings.high_threshold_purcent ~= nil then  -- seuil haut %
							domoticz.log(device.name .. ' a un seuil % haut défini à  ' .. settings.high_threshold_purcent..'%', domoticz.LOG_INFO)
						if device.percentage ~= nil and settings.low_threshold_purcent ~= nil then  -- seuil bas %
							domoticz.log(device.name .. ' a un seuil % bas défini à  ' .. settings.low_threshold_purcent..'%', domoticz.LOG_INFO)
						--sensorType
						if device.sensorType ~= nil and settings.high_threshold_custom ~= nil then  -- seuil haut sensorType
							domoticz.log(device.name .. ' a un seuil haut défini à  ' .. settings.high_threshold_custom..' '..device.sensorUnit, domoticz.LOG_INFO)
						if device.sensorType ~= nil and settings.low_threshold_custom ~= nil then  -- seuil bas sensorType
							domoticz.log(device.name .. ' a un seuil bas défini à  ' .. settings.low_threshold_custom..' '..device.sensorUnit, domoticz.LOG_INFO)
						--low_watt_usage
						if device.WhActual ~= nil and settings.low_watt_usage ~= nil then  -- seuil bas sensorType
							domoticz.log(device.name .. ' a un seuil bas défini à  ' .. settings.low_watt_usage..' Wh', domoticz.LOG_INFO)
						if device.WhActual ~= nil and settings.high_watt_usage ~= nil then  -- seuil bas sensorType
							domoticz.log(device.name .. ' a un seuil haut défini à  ' .. settings.high_watt_usage..' Wh', domoticz.LOG_INFO)
						if device.current ~= nil and settings.low_current_usage ~= nil then  -- seuil bas sensorType
							domoticz.log(device.name .. ' a un seuil bas défini à  ' .. settings.low_current_usage..' A', domoticz.LOG_INFO)
						if device.current ~= nil and settings.high_current_usage ~= nil then  -- seuil bas sensorType
							domoticz.log(device.name .. ' a un seuil haut défini à  ' .. settings.high_current_usage..' A', domoticz.LOG_INFO)
						if device.state == 'Off' or device.state == 'Close' then    -- Alarme dispositif inactif
							if settings.time_active_notification ~= nil then
								domoticz.log('Le délai est fixé à '.. settings.time_active_notification.. ' minutes.', domoticz.LOG_INFO)
						elseif device.state == 'On' or device.state == 'Open' then   -- Alarme dispositif actif
							if settings.time_inactive_notification ~= nil then
								domoticz.log('Le délai est fixé à '.. settings.time_inactive_notification.. ' minutes.', domoticz.LOG_INFO)
						-- Alarme dispositif injoignable
                        if settings.timeout_notification and device.timedOut then
                            domoticz.log(device.name .. ' est injoignable. Sa dernière activité remonte à ' .. device.lastUpdate.minutesAgo .. ' minutes.', domoticz.LOG_INFO)
                            message = device.name .. ' est injoignable depuis '.. settings.timeout_notification ..' minutes'
                            domoticz.helpers.managedNotify(domoticz, subject, message, SubSystem, frequency_notifications , quiet_hours)
						--batterie
						if device.batteryLevel ~= nil and device.batteryLevel ~= 255 and settings.low_battery_level ~= nil then
							domoticz.log('Le niveau de batterie de '.. device.name .. ' est de  ' .. device.batteryLevel .. '%', domoticz.LOG_INFO)
							if settings.low_battery_level ~= nil and device.batteryLevel < settings.low_battery_level then  -- seuil bas batterie
								domoticz.log(device.name .. ' a un niveau de batterie de ' .. device.batteryLevel..'%', domoticz.LOG_INFO)
								message = 'Le niveau de batterie '.. device.name .. ' est inférieur au seuil défini ('..settings.low_battery_level..'%). Valeur : '..tostring(domoticz.utils.round(device.batteryLevel, 1)) ..'%'
								--domoticz.log(message, domoticz.LOG_INFO)
						--low_signal_level
						if device.signalLevel ~= nil and settings.low_signal_level ~= nil then
							domoticz.log('Le niveau de signal de '.. device.name .. ' est de  ' .. device.signalLevel, domoticz.LOG_INFO)
							if settings.low_signal_level ~= nil and device.signalLevel < settings.low_signal_level then  -- seuil bas signal
								domoticz.log(device.name .. ' a un niveau de signal de ' .. device.signalLevel, domoticz.LOG_INFO)
								message = 'Le niveau de signal '.. device.name .. ' est inférieur au seuil défini ('..settings.low_signal_level..'). Valeur : '..device.signalLevel
						--low_watt_usage
							domoticz.log('Le niveau de puissance de '.. device.name .. ' est de  ' .. device.WhActual..' Wh', domoticz.LOG_INFO)
							if settings.low_watt_usage ~= nil and device.WhActual < settings.low_watt_usage then  -- seuil bas puissance
								domoticz.log(device.name .. ' a un niveau de puissance de ' .. device.WhActual..' Wh', domoticz.LOG_INFO)
								message = 'Le niveau de puissance '.. device.name .. ' est inférieur au seuil défini ('..settings.low_watt_usage..'). Valeur : '..device.WhActual..' Wh'
							if settings.high_watt_usage ~= nil and device.WhActual > settings.high_watt_usage then  -- seuil haut puissance
								message = 'Le niveau de puissance '.. device.name .. ' est superieur au seuil défini ('..settings.high_watt_usage..'). Valeur : '..device.WhActual..' Wh'
						--low_current_usage
							domoticz.log('Le niveau de '.. device.name .. ' est de  ' .. tostring(domoticz.utils.round(device.current, 0))..' A', domoticz.LOG_INFO)
							if settings.low_current_usage ~= nil and device.current < settings.low_current_usage then  -- seuil bas intensite
								domoticz.log(device.name .. ' a un niveau de ' .. tostring(domoticz.utils.round(device.current, 0)), domoticz.LOG_INFO)
								message = 'Le niveau de '.. device.name .. ' est inférieur au seuil défini ('..settings.low_current_usage..'). Valeur : '..tostring(domoticz.utils.round(device.current, 0))..' A'
						--current
							if settings.high_current_usage ~= nil and device.current > settings.high_current_usage then  -- seuil haut intensite
								message = 'Le niveau '.. device.name .. ' est superieur au seuil défini ('..settings.high_current_usage..'). Valeur : '..tostring(domoticz.utils.round(device.current, 0))..' A'
                            domoticz.log(device.name .. ' est à l\'état ' .. device.state, domoticz.LOG_INFO)
                            if settings.time_inactive_notification ~= nil and device.lastUpdate.minutesAgo >= settings.time_inactive_notification then
                                domoticz.log(device.name .. ' est inactif depuis ' .. device.lastUpdate.minutesAgo .. ' minutes. Le délai est fixé à '.. settings.time_inactive_notification.. ' minutes.', domoticz.LOG_INFO)
                                message = 'Le délai d\'inactivité fixé à '.. settings.time_inactive_notification .. ' minutes pour '.. device.name .. ' est dépassé'
                        elseif device.temperature ~= nil or device.humidity ~= nil then
                        -- Alarme température
                            if device.temperature ~= nil and (settings.low_threshold_temp ~= nil or settings.high_threshold_temp ~= nil) then
								--on teste settings.duration_exceeded_temp
								if settings.duration_exceeded_temp ~= nil then
									domoticz.data.managedValue.add(domoticz.utils.round(device.temperature, 2))
									domoticz.data.managedId.add(device.id)
									if settings.high_threshold_temp ~= nil then high_threshold_temp = settings.high_threshold_temp else high_threshold_temp = nil end
									if settings.low_threshold_temp ~= nil then low_threshold_temp = settings.low_threshold_temp else low_threshold_temp = nil end
									test_high_threshold, test_low_threshold = managed(domoticz, device.id, settings.duration_exceeded_temp, high_threshold_temp, low_threshold_temp)
                                domoticz.log('La température mesurée par '.. device.name .. ' est de  ' .. tostring(domoticz.utils.round(device.temperature, 1)) ..'°C', domoticz.LOG_INFO)
                                if settings.low_threshold_temp ~= nil and device.temperature < settings.low_threshold_temp and test_low_threshold == true then  -- seuil bas température
                                    message = 'La température mesurée par '.. device.name .. ' est inférieure au seuil défini ('..settings.low_threshold_temp..'°C). Valeur : '..tostring(domoticz.utils.round(device.temperature, 1)) ..'°C'
										domoticz.data.managedValue.add(settings.low_threshold_temp)
                                if settings.high_threshold_temp ~= nil and device.temperature > settings.high_threshold_temp and test_high_threshold == true then  -- seuil haut température
                                    message = 'La température mesurée par '.. device.name ..' est supérieure au seuil défini ('..settings.high_threshold_temp..'°C). Valeur : '..tostring(domoticz.utils.round(device.temperature, 1)) ..'°C'
										domoticz.data.managedValue.add(settings.high_threshold_temp)
                        -- alarme hygrométrie
                            if device.humidity ~= nil and (settings.low_threshold_hr ~= nil or settings.high_threshold_hr ~= nil)  then
								--on teste settings.duration_exceeded_hr
								if settings.duration_exceeded_hr ~= nil then
									domoticz.data.managedValue.add(device.humidity)
									if settings.high_threshold_hr ~= nil then high_threshold_hr = settings.high_threshold_hr else high_threshold_hr = nil end
									if settings.low_threshold_hr ~= nil then low_threshold_hr = settings.low_threshold_hr else low_threshold_hr = nil end
									test_high_threshold, test_low_threshold = managed(domoticz, device.id, settings.duration_exceeded_hr, high_threshold_hr, low_threshold_hr)
                                domoticz.log('L\'hygrometrie mesurée par '.. device.name .. ' est de  ' .. tostring(device.humidity)..'%hr', domoticz.LOG_INFO)
                                if settings.low_threshold_hr ~= nil and device.humidity < settings.low_threshold_hr and test_low_threshold == true then -- seuil bas hygrométrie
                                    domoticz.log(device.name .. ' a un seuil hygrometrie bassse défini à  ' .. settings.low_threshold_hr..'%hr', domoticz.LOG_INFO)
                                    message = 'L\'humidité mesurée par '.. device.name .. ' est inférieure au seuil défini ('..settings.low_threshold_hr..'%hr). Valeur : '..tostring(device.humidity)..'%hr'
										domoticz.data.managedValue.add(settings.low_threshold_hr)
                                if settings.high_threshold_hr and device.humidity > settings.high_threshold_hr and test_high_threshold == true then -- seuil haut hygrométrie
                                    domoticz.log(device.name .. ' a un seuil hygrometrie haute défini à  ' .. settings.high_threshold_hr..'%hr', domoticz.LOG_INFO)
                                    message = 'L\'humidité mesurée par '.. device.name .. ' est supérieure au seuil défini ('..settings.high_threshold_hr..'%hr). Valeur : '..tostring(device.humidity)..'%hr'
										domoticz.data.managedValue.add(settings.high_threshold_hr)
                            if settings.time_active_notification ~= nil and device.lastUpdate.minutesAgo >= settings.time_active_notification then
                                domoticz.log(device.name .. ' est actif depuis ' .. device.lastUpdate.minutesAgo .. ' minutes. Le délai est fixé à '.. settings.time_active_notification.. ' minutes.', domoticz.LOG_INFO)
                                message = 'Le délai fixé à '.. settings.time_active_notification .. ' minutes pour '.. device.name .. ' est dépassé'
                                                        -- auto on
							if settings.auto_on_minutes ~= nil and device.lastUpdate.minutesAgo >= settings.auto_on_minutes then
                                if settings.state == 'Off' then
                                    domoticz.log('Allumage de '..device.name .. ' car inactif depuis ' .. settings.auto_on_minutes .. ' minutes.', domoticz.LOG_INFO)
                                    device.switchOn()
                                                        -- auto off
                            if settings.auto_off_minutes ~= nil and device.lastUpdate.minutesAgo >= settings.auto_off_minutes then
                                if settings.auto_off_motion_device == nil then
                                    domoticz.log('Extinction de '..device.name .. ' car actif depuis ' .. settings.auto_off_minutes .. ' minutes.', domoticz.LOG_INFO)
                                    device.switchOff()
                                elseif type(settings.auto_off_motion_device) == "string" then
                                    local motion_device = domoticz.devices(settings.auto_off_motion_device)
                                    if motion_device.state == 'Off' then
                                        domoticz.log('Extinction de '.. device.name .. ' car aucune détection de mouvement dans la piece depuis ' .. settings.auto_off_minutes .. ' minutes.', domoticz.LOG_INFO)
                                        device.switchOff()
                                elseif type(settings.auto_off_motion_device) == "table" then
                                    local off = true
                                    for i,v in ipairs(settings.auto_off_motion_device) do
                                        if domoticz.devices(v).state ~= 'Off' then
                                            off = false
                                    if off then
										device.switchOff()
						elseif device.sensorType ~= nil and (settings.high_threshold_custom ~= nil or settings.low_threshold_custom ~= nil)  then
						--alarme custom sensor
							domoticz.log('La valeur mesurée par '.. device.name .. ' est de  ' .. tostring(domoticz.utils.round(device.state, 1)) .. device.sensorUnit, domoticz.LOG_INFO)
							if settings.low_threshold_custom ~= nil and tonumber(device.state) < settings.low_threshold_custom then  -- seuil bas %
								domoticz.log(device.name .. ' a un seuil bas défini à  ' .. settings.low_threshold_custom..device.sensorUnit, domoticz.LOG_INFO)
								message = 'La valeur mesurée par '.. device.name .. ' est inférieure au seuil défini ('..settings.low_threshold_custom..device.sensorUnit..'). Valeur : '..tostring(domoticz.utils.round(device.state, 1))..device.sensorUnit
							if settings.high_threshold_custom ~= nil and tonumber(device.state) > settings.high_threshold_custom then  -- seuil haut %
								domoticz.log(device.name .. ' a un seuil haut défini à  ' .. settings.high_threshold_custom..device.sensorUnit, domoticz.LOG_INFO)
								message = 'La valeur mesurée par '.. device.name ..' est supérieure au seuil défini ('..settings.high_threshold_custom..device.sensorUnit..'). Valeur : '..tostring(domoticz.utils.round(device.state, 1))..device.sensorUnit
						elseif device.percentage ~= nil and (settings.high_threshold_purcent ~= nil or settings.low_threshold_purcent ~= nil)  then
							if settings.duration_exceeded_purcent ~= nil then
								domoticz.data.managedValue.add(device.percentage)
								if settings.high_threshold_purcent ~= nil then high_threshold_purcent = settings.high_threshold_purcent else high_threshold_purcent = nil end
								if settings.low_threshold_purcent ~= nil then low_threshold_purcent = settings.low_threshold_purcent else low_threshold_purcent = nil end
								test_high_threshold, test_low_threshold = managed(domoticz, device.id, settings.duration_exceeded_purcent, high_threshold_purcent, low_threshold_purcent)
						--alarme pourcentage
							domoticz.log('La valeur mesurée par '.. device.name .. ' est de  ' .. tostring(domoticz.utils.round(device.percentage, 1)) ..'%', domoticz.LOG_INFO)
							if settings.low_threshold_purcent ~= nil and device.percentage < settings.low_threshold_purcent and test_low_threshold == true then  -- seuil bas %
								message = 'La valeur mesurée par '.. device.name .. ' est inférieure au seuil défini ('..settings.low_threshold_purcent..'%). Valeur : '.. tostring(domoticz.utils.round(device.percentage, 1)) ..'%'
									domoticz.data.managedValue.add(settings.low_threshold_purcent)
							if settings.high_threshold_purcent ~= nil and device.percentage > settings.high_threshold_purcent and test_high_threshold == true then  -- seuil haut %
								message = 'La valeur mesurée par '.. device.name ..' est supérieure au seuil défini ('..settings.high_threshold_purcent..'%). Valeur : '.. tostring(domoticz.utils.round(device.percentage, 1)) ..'%'
									domoticz.data.managedValue.add(settings.high_threshold_purcent)
						elseif device.color ~= nil and settings.high_threshold_color ~= nil  then
							-- notification alerte
							domoticz.log('Le seuil d\'alerte de '.. device.name .. ' est de  ' .. tostring(device.color), domoticz.LOG_INFO)
							message = 'Le seuil d\'alerte de  '.. device.name ..' est supérieur au seuil défini ('..settings.high_threshold_color..'). Valeur : '.. tostring(device.color) ..' alerte : '.. tostring(device.text)
						domoticz.log( 'la description de '.. device.name ..' n\'est pas au format json. Ignorer cet appareil.', domoticz.LOG_ERROR)
						domoticz.log('--------------------------------------------------------------------------------------------------', domoticz.LOG_INFO)
		domoticz.log(tostring(cnt) .. ' devices scannés.', domoticz.LOG_INFO)
papoo
Message par papoo »
tout me semble au mieux. je n'ai pas pu tout testé
je viens de mettre à jour le github et le script de la première page
merci
https://pon.fr github
vrolland
Message par vrolland »
Ca a l'air très intéressant tout ça, je vais tester, merci bien
Pi3 - Raspbian wheezy 4.14.98-v7
Domoticz V4.10619
papoo
Message par papoo »
nouvelle version 1.0 permettant la sélection du ou des systèmes de notification pour chaque device individuellement
papoo
Re: [DZVents] script de notifications ultime (mais pas que)
Message par papoo »
Nouvelle version 1.01
denis_brasseur
papoo a écrit : 06 mai 2019, 22:12 nouvelle version 1.0 permettant la sélection du ou des systèmes de notification pour chaque device individuellement
Bonjour papoo,
dans le cas ou l'on met en place ce nouveau script sans ajouté "subsystems" : "PUSHOVER" (par exemple), qu'adviendra il des notifications par défaut ?
Je crois comprendre que depuis la fonction originale de waaren, en l'absence de ce paramètre, c'est l'ensemble des notifications par défaut qui s'applique.
 -- 3rd parm (notification subsystem) optional but required if any of the next parms in use (when nil defaults to all)
papoo
Re: [DZVents] Script de notifications ultime (mais pas que)
Message par papoo »
Oui c’est exactement ça
Le paramètre subSystems est donc facultatif si l’on souhaite utiliser l’ensemble des systèmes de notification
Par contre si l’on souhaite personnaliser les notifications pour les hiérarchiser il devient très facile d’envoyer les alarmes température sur un système et les timeout sur un autre par exemple
elfedelanuit
Message par elfedelanuit »
J'ai un problème d'envoi des notifications avec le script.
J'ai ce message d'erreur dans les logs :
Error: GCM: Can not connect to GCM API URL
Notification sent (gcm) => Failed
J'ai une ligne de status :
2019-07-09 00:11:00.518 Status: dzVents: Debug: - SendNotification = /!\ Attention /!\#La température mesurée par Extérieur est supérieure au seuil défini (12°C). Valeur : 12.3°C#0#pushover##
Mon json pour la sonde est très basique pour le test :
"high_threshold_temp": 12
Je suis en version 2.4.23 pour dzVents :
2019-07-09 00:14:08.229 Status: dzVents: Debug: dzVents version: 2.4.23
Je précise que je reçois bien les notifications des mes autres scripts (LUA).
Bonne soirée.
papoo
Message par papoo »
ton log comporte une indication de notification via GCM (google cloud messaging) qui me semble t'il n'est plus actif
et pushover. quel est le système de notification que tu utilises réellement?
essai de définir un seul système de notification à la fois dans le json
"subsystems" : "PUSHOVER",
ensuite test gcm sans pushover voir si les deux fonctionnent séparément
"subsystems" : "GCM",
et fait nous un retour du fonctionnement de l'un et l'autre stp
elfedelanuit
papoo a écrit : 09 juil. 2019, 21:21 ton log comporte une indication de notification via GCM (google cloud messaging) qui me semble t'il n'est plus actif
Je me sers juste de GCM dans mes scripts. Il me semble que GCM avait été corrigé dans le github de Domoticz pour utiliser FIREBASE.
Voici le json de test :
et un extrait des logs :
2019-07-10 14:31:00.343 Status: dzVents: Info: Json Description v1.01: ------ Finished notifications
2019-07-10 14:31:00.343 Status: EventSystem: Script event triggered: /home/domoticz/dzVents/runtime/dzVents.lua
2019-07-10 14:31:00.356 Status: Notification: /!\ Attention /!\
2019-07-10 14:31:00.696 Error: GCM: Can not connect to GCM API URL
Bonne journée.
