Je n'ai pas LED qui clignote sur la Zigate!!
Mais la je viens de re-appairer 2 capteurs :
-1 qui ne marche plus et supprimé
-1 qui ne marche plus mais pas supprimé
Resultat celui qui a ete supprimé ne fonctionne pas mais l'autre est OK.
2019-11-05 16:17:54.392 (Zigate) TxPower set to: 00
2019-11-05 16:17:54.099 Status: (Zigate) Zigate set to Certification : CE
2019-11-05 16:17:54.100 Status: (Zigate) Start Web Server connection
2019-11-05 16:17:54.103 Status: (Zigate) Web backend for Web User Interface started on port: 9440
2019-11-05 16:17:54.103 Status: (Zigate) Plugin with Zigate firmware 031a correctly initialized
2019-11-05 16:17:54.252 Status: (Zigate) checkPluginVersion - Upgrade available: 4.5.6
2019-11-05 16:17:54.252 Status: (Zigate) There is a newer plugin version available on gitHub
2019-11-05 16:17:54.099 Error: (Zigate) ATTENTION: the WebServer part is not supported with this version of Domoticz. Please upgrade to a version greater than 4.10901
2019-11-05 16:18:02.919 (Zigate) UpdateDevice - ( Capteur SDB) 0:20.6;75.1;3;993.2;4
2019-11-05 16:18:02.920 (Zigate) UpdateDevice - ( Capteur SDB) 0:20.6;75.1;3
2019-11-05 16:18:02.926 EventSystem: Event triggered: Radiateur SDB_4
2019-11-05 16:18:02.929 (Zigate) UpdateDevice - ( Capteur SDB) 0:20.6;75.1;3;993.0;4
2019-11-05 16:18:02.950 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d000274365e-01) 0:993.0;4
2019-11-05 16:18:02.953 (Zigate) UpdateDevice - ( Capteur SDB) 0:20.6;75.1;3;993.4;4
2019-11-05 16:18:02.955 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d000274365e-01) 0:993.4;4
2019-11-05 16:18:02.926 Status: OFF OFF
2019-11-05 16:18:30.464 (Xiaomi Gateway) Color Switch (Xiaomi RGB Gateway (192.168.0.17))
2019-11-05 16:18:30.467 (Xiaomi Gateway) Lux (Xiaomi Gateway Lux)
2019-11-05 16:18:34.522 (Zigate) Decode004d - rebind clusters for 1947
2019-11-05 16:18:34.521 Status: (Zigate) Device Annoucement ShortAddr: 1947, IEEE: 00158d00027a3827
2019-11-05 16:18:34.521 Status: (Zigate) NetworkID : 1947 is replacing 6167 and is attached to IEEE : 00158d00027a3827
2019-11-05 16:19:02.382 (Xiaomi Gateway) Color Switch (Xiaomi RGB Gateway (192.168.0.17))
2019-11-05 16:19:02.385 (Xiaomi Gateway) Lux (Xiaomi Gateway Lux)
2019-11-05 16:19:02.622 (Zigate) Decode004d - rebind clusters for 90ac
2019-11-05 16:19:02.621 Status: (Zigate) Device Annoucement ShortAddr: 90ac, IEEE: 00158d00027a3827
2019-11-05 16:19:02.621 Status: (Zigate) NetworkID : 90ac is replacing 1947 and is attached to IEEE : 00158d00027a3827
2019-11-05 16:19:06.272 (Zigate) Decode004d - rebind clusters for 90ac
2019-11-05 16:19:06.272 Status: (Zigate) Device Annoucement ShortAddr: 90ac, IEEE: 00158d00027a3827
2019-11-05 16:19:33.317 (Xiaomi Gateway) Color Switch (Xiaomi RGB Gateway (192.168.0.17))
2019-11-05 16:19:33.321 (Xiaomi Gateway) Lux (Xiaomi Gateway Lux)
2019-11-05 16:19:53.273 (Xiaomi Gateway) Color Switch (Xiaomi RGB Gateway (192.168.0.17))
2019-11-05 16:19:53.277 (Xiaomi Gateway) Lux (Xiaomi Gateway Lux)
2019-11-05 16:20:24.204 (Xiaomi Gateway) Color Switch (Xiaomi RGB Gateway (192.168.0.17))
2019-11-05 16:20:24.206 (Xiaomi Gateway) Lux (Xiaomi Gateway Lux)
2019-11-05 16:21:02.110 (Xiaomi Gateway) Color Switch (Xiaomi RGB Gateway (192.168.0.17))
2019-11-05 16:21:02.113 (Xiaomi Gateway) Lux (Xiaomi Gateway Lux)
2019-11-05 16:21:02.381 Status: (Zigate) Device Annoucement ShortAddr: 3448, IEEE: 00158d00027aef4a
2019-11-05 16:21:14.577 Status: (Zigate) [0] NEW OBJECT: 3448 TimeOut in 0045 restarting at 0x004d
2019-11-05 16:21:14.577 Status: (Zigate) [0] NEW OBJECT: 3448 Request Model Name
2019-11-05 16:21:29.608 Status: (Zigate) [1] NEW OBJECT: 3448 TimeOut in 0045 restarting at 0x004d
2019-11-05 16:21:29.608 Status: (Zigate) [1] NEW OBJECT: 3448 Request Model Name
2019-11-05 16:21:44.673 Status: (Zigate) [2] NEW OBJECT: 3448 TimeOut in 0045 restarting at 0x004d
2019-11-05 16:21:44.673 Status: (Zigate) [2] NEW OBJECT: 3448 Request Model Name
2019-11-05 16:21:59.672 Status: (Zigate) [3] NEW OBJECT: 3448 TimeOut in 0045 restarting at 0x004d
2019-11-05 16:21:59.672 Status: (Zigate) [3] NEW OBJECT: 3448 Request Model Name
2019-11-05 16:22:14.750 Status: (Zigate) [4] NEW OBJECT: 3448 TimeOut in 0045 restarting at 0x004d
2019-11-05 16:22:14.751 Status: (Zigate) [4] NEW OBJECT: 3448 Request Model Name
2019-11-05 16:22:19.740 (Zigate) processNotinDB - not able to find response from 3448 stop process at 0045
2019-11-05 16:22:19.754 (Zigate) processNotinDB - RIA: 5 waitForDomoDeviceCreation: False, capturePairingInfos: 0 Model: {}
2019-11-05 16:22:19.755 (Zigate) processNotinDB - Collected Infos are : {'Attributes List': {}, 'Capability': ['Reduced-Function Device', 'Standard security', 'NwkAddr should be allocated'], 'ZDeviceName': '', 'MacCapa': '80', 'Stamp': {'MsgType': ' 4d', 'Time': '2019-11-05 16:21:02'}, 'Model': {}, 'Heartbeat': '1', 'Manufacturer': '', 'ZDeviceID': {}, 'NbEp': '', 'Health': '', 'Status': 'UNKNOW', 'Type': {}, 'Ep': {}, 'Battery': {}, 'LogicalType': '', 'ReadAttributes': {'TimeStamps': {'06-0000': 1572967334, '01-0000': 1572967334, '02-0000': 1572967334, '09-0000': 1572967334, '03-0000': 1572967334}, 'Ep': {'09': {'0000': {}}, '06': {'0000': {}}, '01': {'0000': {}}, '02': {'0000': {}}, '03': {'0000': {}}}}, 'Stack Version': '', 'Last Cmds': [(1572967334.7546873, '0100', None), (1572967334.8686926, '0100', None), (1572967334.9747036, '0100', None), (1572967335.0806897, '0100', None), (1572967335.1866872, '0100', None)], 'ReceiveOnIdle': '', 'PowerSource': '', 'App Version': '', 'RIA': '5', 'Version': '3', 'HW Version': '', 'RSSI': {}, 'Maufacturer Name': '', 'IEEE': '00158d00027aef4a', 'ProfileID': {}, 'ZCL Version': '', 'SQN': '', 'DeviceType': ''}
2019-11-05 16:22:19.975 (Zigate) Permit Join status: 00
2019-11-05 16:22:19.975 (Zigate) ---> self.permitTojoin['Starttime']: 1572967064
2019-11-05 16:22:19.975 (Zigate) ---> Current time : 1572967339
2019-11-05 16:22:19.975 (Zigate) ---> self.Ping['Permit'] (prev) : On
2019-11-05 16:22:19.975 (Zigate) ---> self.Ping['Permit'] (new ) : Off
2019-11-05 16:22:19.740 Status: (Zigate) [5] NEW OBJECT: 3448 Not able to get all needed attributes on time
