Error: (Zigate) processNotinDBDevices - Devices already exist. Zigate
Re: Error: (Zigate) processNotinDBDevices - Devices already exist. Zigate
tof92130 a écrit : 28 avr. 2020, 08:40 En l'absence de communication , je redémarre la zigate ce matin
2020-04-28 08:38:54.696 Status: (Zigate) Entries loaded from /usr/local/domoticz/var/plugins/Domoticz-Zigate/Data/DeviceList-12.txt : 2
2020-04-28 08:38:54.697 Status: (Zigate) Transport mode: Wifi
2020-04-28 08:38:54.698 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2020-04-28 08:38:54.698 Status: (Zigate) Connection open: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '192.168.1.54', Port: '9999', Baud: -1, Connected: False, Parent: 'None'
2020-04-28 08:39:04.662 (Zigate) No Firmware Version received from Zigate
2020-04-28 08:39:09.669 (Zigate) No Firmware Version received from Zigate
2020-04-28 08:39:09.669 Error: (Zigate) Transport is not connected, write directive to 'Zigate' ignored.
2020-04-28 08:39:14.626 (Zigate) No Firmware Version received from Zigate
2020-04-28 08:39:19.633 (Zigate) No Firmware Version received from Zigate
2020-04-28 08:39:19.633 (Zigate) Try to get Firmware version once more HB:4
2020-04-28 08:39:24.640 Status: (Zigate) ZigateConf setting Channel(s) to: 0
2020-04-28 08:39:24.640 Status: (Zigate) setChannel - Channel set to : 00000000
2020-04-28 08:39:24.640 Status: (Zigate) Set Zigate as a Coordinator
2020-04-28 08:39:24.640 Status: (Zigate) Set Zigate as a TimeServer
2020-04-28 08:39:24.641 Status: (Zigate) Start network
2020-04-28 08:39:29.648 (Zigate) No Firmware Version received from Zigate
2020-04-28 08:39:34.655 (Zigate) No Firmware Version received from Zigate
2020-04-28 08:39:39.664 (Zigate) No Firmware Version received from Zigate
2020-04-28 08:39:39.664 (Zigate) Try to get Firmware version once more HB:8
2020-04-28 08:39:44.671 (Zigate) No Firmware Version received from Zigate
2020-04-28 08:40:34.640 Error: (Zigate) Plugin is not started ...
2020-04-28 08:40:34.640 Error: (Zigate) - Communication issue with the Zigate
2020-04-28 08:40:34.640 Error: (Zigate) - restart once the plugin, and if this remain the same
Est-ce que la communication avec la partie Wifi est toujours fonctionnelle ?
Via l'interface Web du Module Wifi, regarde si le module Zigate est operationnel
Peut-etre qu'un power Off/On sera pertinent
tof92130
Message par tof92130 »
C'est reparti tout seul et le dispositif est toujours présent. Je rajoute une prise Tradfri et je laisse tourner l'ensemble quelques jours pour vérifier la stabilité du système.
tof92130 a écrit : 21 avr. 2020, 20:50 Version Firmware 031a
git branch
* stable
et ça recommence, tous mes dispositifs zigate (4) ont disparu cette fois, voici le message sous domoticz :
2020-04-21 21:58:04.156 Error: (Zigate) ----> Line 726 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2020-04-21 21:58:04.156 Error: (Zigate) ----> Line 146 in '/usr/local/domoticz/var/plugins/Domoticz
Zigate/Modules/database.py', function WriteDeviceList
2020-04-21 21:58:09.166 Error: (Zigate) 'onHeartbeat' failed 'UnicodeEncodeError'.
2020-04-21 21:58:09.166 Error: (Zigate) ----> Line 883 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2020-04-21 21:58:09.183 Error: (Zigate) ----> Line 726 in '/usr/local/domoticz/var/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
Comme mentionné plus haut dans le thread, n'utilises-tu pas des caractères Speciaux/Accents dans le nom de Friendly Name des Devices ( Interface Web Admin Device Management ) ?
