Page 26 sur 120
Re: MyDomoAtHome - ImperiHome
Publié : 27 mars 2016, 15:17
par manuloup
Lol. Mea culpa.
La suite :
pi@raspberrypi /usr/bin $ sudo apt-get install MyDomoAtHome
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
  libboost-dev libboost1.49-dev libc-ares2 libv8-3.14.5
Use 'apt-get autoremove' to remove them.
The following NEW packages will be installed:
  MyDomoAtHome
0 upgraded, 1 newly installed, 0 to remove and 20 not upgraded.
Need to get 0 B/123 kB of archives.
After this operation, 369 kB of additional disk space will be used.
(Reading database ... 102067 files and directories currently installed.)
Unpacking mydomoathome (from .../MyDomoAtHome_0.0.47_all.deb) ...
npm ERR! Error: No compatible version found: prettyjson@'^1.1.2'
npm ERR! Valid install targets:
npm ERR! ["0.0.1","0.1.0","0.1.1","0.1.2","0.1.3","0.1.4","0.2.0","0.2.1","0.3.0","0.3.1","0.4.0","0.5.0","0.6.0","0.7.0","0.7.1","0.8.0","0.8.1","0.9.0","0.10.0","0.11.0","0.11.1","0.12.0","0.12.1","0.13.0","1.0.0","1.1.0","1.1.1","1.1.2","1.1.3"]
npm ERR!     at installTargetsError (/usr/local/lib/node_modules/npm/lib/cache.js:685:10)
npm ERR!     at /usr/local/lib/node_modules/npm/lib/cache.js:607:10
npm ERR!     at saved (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/get.js:138:7)
npm ERR!     at FSReqWrap.oncomplete (fs.js:82:15)
npm ERR! If you need help, you may report this log at:
npm ERR!     <http://github.com/isaacs/npm/issues>
npm ERR! or email it to:
npm ERR!     <npm-@googlegroups.com>
npm ERR! System Linux 4.1.19+
npm ERR! command "/usr/bin/node" "/usr/local/bin/npm" "install" "-g" "forever"
npm ERR! cwd /
npm ERR! node -v v4.2.2
npm ERR! npm -v 1.2.15
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR!     /npm-debug.log
npm ERR! not ok code 0
dpkg: error processing /var/cache/apt/archives/MyDomoAtHome_0.0.47_all.deb (--unpack):
 subprocess new pre-installation script returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Publié : 27 mars 2016, 15:21
par manuloup
Bon, même opération pour npm, je relance.
Publié : 27 mars 2016, 16:10
par manuloup
Bon ben voilà, ça marche :)
Comment voit-on la version de MyDomoAtHome installée ?
J'imagine qu'on le met à jour via APT ?
Merci Emmanuel
Manu
Publié : 27 mars 2016, 16:42
par epierre
manuloup a écrit :Bon ben voilà, ça marche :)
Merci Emmanuel
Manu
bon doc a lettre a jour ☺️
mise a jour par apt, tu as device virtuel avec la version dans IH
Publié : 27 mars 2016, 16:50
par denisb88
Pendant l'install (qui n'est pas encore fini d'ailleurs) j'ai eu ce message
npm WARN optional dep failed, continuing fsevents@1.0.9
C'est grave docteur ?
Publié : 27 mars 2016, 17:01
par epierre
denisb88 a écrit :Pendant l'install (qui n'est pas encore fini d'ailleurs) j'ai eu ce message
non mais je ne sais pas le cacher
Publié : 27 mars 2016, 17:10
par denisb88
Bon je l'ai installé mais problème, avec cette version pendant l'installation, Domoticz a freezé, je l'ai relancé mais toujours en initialisation.
Du coup j'ai relancé le raspberry et là monit ne demarre plus, j'ai ce message
Job for monit.service failed. See 'systemctl status monit.service' and 'journalctl -xn' for details.
La commande donne ceci
monit.service - LSB: service and resource monitoring daemon
Loaded: loaded (/etc/init.d/monit)
Active: failed (Result: exit-code) since Sun 2016-03-27 17:07:46 CEST; 11min ago
Process: 2091 ExecStart=/etc/init.d/monit start (code=exited, status=1/FAILURE)
Alors qu'avant il n'y avait aucun problème
Publié : 27 mars 2016, 17:25
par epierre
si tu avais mis mdah dedans retires le, c'est un pb de conf ici, il n'utilise pas nodejs
Publié : 27 mars 2016, 17:28
par manuloup
Ça fonctionne impec de mon côté, merci Emmanuel.
J'ai même les bonnes valeurs qui apparaissent pour les devices du RPI, alors que ça apparaissait mal avant.
Publié : 27 mars 2016, 17:30
par denisb88
epierre a écrit :si tu avais mis mdah dedans retires le, c'est un pb de conf ici, il n'utilise pas nodejs
Merci mais c'est quoi mdah (je débute)
J'ai réussi à lancer monit avec
sudo /etc/init.d/monit stop
sudo /etc/init.d/monit start
