Re: script non exécuté de manière aléatoire
Publié : 18 sept. 2020, 12:44
Merci Denis pour l'info
Reprenez le contrôle de votre domotique
https://easydomoticz.com/forum/
2020-09-18 18:39:56.721 (Dummy) Light/Switch (Bureau)
2020-09-18 18:39:56.399 Status: User: Admin initiated a switch command (146/Bureau/Set Level)
2020-09-18 18:39:57.109 (système 1W) Temp (Temp convertisseur)
2020-09-18 18:39:57.210 (système 1W) RFXSensor (U_Convert)
2020-09-18 18:39:57.257 (système 1W) RFXSensor (U_alim)
2020-09-18 18:39:57.307 (système 1W) RFXSensor (Unknown)
2020-09-18 18:39:57.355 (système 1W) General/Solar Radiation (Solar Radiation)
2020-09-18 18:39:58.844 (système 1W) Temp (T_Baptiste)
2020-09-18 18:39:58.433 Status: LUA: requette----------------------------------------------------------Bureau----- A07V1Oo
2020-09-18 18:39:59.646 (système 1W) Temp (CH4)
2020-09-18 18:40:00.456 (système 1W) Temp (Hotte poêle)
2020-09-19 08:03:01.015 Status: Schedule item started! Name: Bureau, Type: On Time, DevID: 146, Time: 2020-09-19 08:03:01
2020-09-19 08:03:01.124 (Dummy) Light/Switch (Bureau)
2020-09-19 08:03:02.739 Status: LUA: requette----------------------------------------------------------Bureau----- A07V1Oo
2020-09-18 20:30:00.352 Status: EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_chauffage_ventilateur_chambre.lua
2020-09-18 20:30:01.228 Status: Schedule item started! Name: SAM_S_porte, Type: On Time, DevID: 136, Time: 2020-09-18 20:30:01
2020-09-18 20:30:01.951 (système 1W) Temp (Buanderie)
2020-09-18 20:30:02.518 (système 1W) Temp (grenier)
2020-09-18 20:30:02.544 Status: EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_tension_pic_DS2438_fichier.lua
2020-09-18 20:30:02.628 (Dummy) Light/Switch (SAM_S_porte)
2020-09-18 20:30:02.674 Status: Schedule item started! Name: SAM_W_porte, Type: On Time, DevID: 138, Time: 2020-09-18 20:30:01
2020-09-18 20:30:02.676 Delaying switch [SAM_W_porte] action (Set Level) for 5 seconds
2020-09-18 20:30:02.678 Status: Schedule item started! Name: ENTREE, Type: On Time, DevID: 178, Time: 2020-09-18 20:30:01
2020-09-18 20:30:02.706 (système 1W) Lighting 2 (Vent_chambre)
2020-09-18 20:30:02.803 (système 1W) Temp (T_Emilie)
2020-09-18 20:30:02.918 (Dummy) Light/Switch (ENTREE)
2020-09-18 20:30:02.919 Status: EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_eau_usb.lua
2020-09-18 20:30:02.974 Status: EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_chauffage_ventilateur_SAM.lua
2020-09-18 20:30:03.020 (système 1W) Temp (T_SAM)
2020-09-18 20:30:03.065 Status: LUA: ---------------script volets sud chambres------mini int 21.0 mini ext 24.0 mini grenier 30.0°C
2020-09-18 20:30:03.180 Status: LUA: ---------------script volets ouest SAM------mini int 21.0 mini ext 24.0 mini grenier 30.0°C T_nord 21.4°C
2020-09-18 20:30:03.805 (système 1W) Lighting 2 (Vent_SAM)
2020-09-18 20:30:03.941 Status: EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_hauteur_cuve_fichier.lua
2020-09-18 20:30:04.001 (système 1W) Temp (Temperature)
2020-09-18 20:30:04.173 (système 1W) RFXSensor (U_Convert)
2020-09-18 20:30:04.237 (système 1W) RFXSensor (U_alim)
2020-09-18 20:30:04.285 (système 1W) RFXSensor (Unknown)
2020-09-18 20:30:04.343 (système 1W) General/Solar Radiation (Solar Radiation)
2020-09-18 20:30:04.784 (système 1W) Temp (Temp convertisseur)
2020-09-18 20:30:04.881 (système 1W) RFXSensor (U_Convert)
2020-09-18 20:30:04.948 (système 1W) RFXSensor (U_alim)
2020-09-18 20:30:04.998 (système 1W) RFXSensor (Unknown)
2020-09-18 20:30:05.047 (système 1W) General/Solar Radiation (Solar Radiation)
2020-09-18 20:30:05.098 (Teleinfo ) General/kWh (Teleinfo kWh Heures Creuses)
2020-09-18 20:30:05.167 (Teleinfo ) General/kWh (Teleinfo kWh Heures Pleines)
2020-09-18 20:30:05.272 (Teleinfo ) P1 Smart Meter (EDF)
2020-09-18 20:30:05.288 Status: LUA: requette---------------------------------------------------------------- SAM_S_porte----- A11V1Of
2020-09-18 20:30:05.357 (Teleinfo ) Current (Teleinfo_Courant)
2020-09-18 20:30:05.428 (Teleinfo ) General/Percentage (Teleinfo Pourcentage de Charge)
2020-09-18 20:30:06.500 (système 1W) Temp (T_Baptiste)
2020-09-18 20:30:07.312 (système 1W) Temp (CH4)
2020-09-18 20:30:07.729 (Dummy) Light/Switch (SAM_W_porte)
2020-09-18 20:30:08.114 (système 1W) Temp (Hotte poêle)
2020-09-18 20:30:08.926 (système 1W) Temp (gaine grenier)
2020-09-18 20:30:09.733 (système 1W) Temp (T_sud)
2020-09-18 20:30:09.770 Status: LUA: requette-----------------------------------------------------------SAM_W_porte----- A10V1Of
2020-09-18 20:30:10.583 (système 1W) Temp (T_nord)
