[Fermé] 2 petits soucis aprés installation du plugin
Re: 2 petits soucis aprés installation du plugin
Et que dit la commande git status ?
@Keros
après avoir reboot mon pi et avoir relancer l'interface domoticz, j'ai retenter un appairage, j'ai laisser tourner l'appairage pendant une dizaine de minutes pendant lequel j'ai essayer un capteur T°, ouverture porte, bouton poussoir et streap LED sans aucun résultats
voici les Logs
voici les Logs
2022-03-24 14:05:05.092 Status: Domoticz V2022.1 (c)2012-2022 GizMoCuz
2022-03-24 14:05:05.092 Status: Build Hash: c9526851b, Date: 2022-01-31 09:34:32
2022-03-24 14:05:05.092 Status: Startup Path: /home/pi/domoticz/
2022-03-24 14:05:06.748 Status: PluginSystem: Started, Python version '3.7.3', 4 plugin definitions loaded.
2022-03-24 14:05:06.909 Status: WebServer(HTTP) started on address: :: with port 8007
2022-03-24 14:05:07.024 Status: WebServer(SSL) started on address: :: with port 878
2022-03-24 14:05:07.030 Status: TCPServer: shared server started...
2022-03-24 14:05:07.041 Status: RxQueue: queue worker started...
2022-03-24 14:05:09.090 Status: RPI_Monitoring: System: Raspberry Pi
2022-03-24 14:05:09.149 Status: RPI_Monitoring: Hardware Monitor: Started (OStype Raspberry Pi Linux)
2022-03-24 14:05:09.177 Status: Meteo: Using specified location (Lon 3.13308, Lat 50.61829) Unable to find nearest City!
2022-03-24 14:05:09.177 Status: Meteo: Started
2022-03-24 14:05:09.177 Status: SonoffZigBee: Entering work loop.
2022-03-24 14:05:09.177 Status: SonoffZigBee: Started.
2022-03-24 14:05:09.177 Status: ThemesManager: Entering work loop.
2022-03-24 14:05:09.177 Status: ThemesManager: Started.
2022-03-24 14:05:09.177 Status: NotificationSystem: thread started...
2022-03-24 14:05:09.189 Status: PluginSystem: 2 plugins started.
2022-03-24 14:05:09.198 Status: EventSystem: reset all events...
2022-03-24 14:05:09.224 Status: EventSystem: reset all device statuses...
2022-03-24 14:05:09.546 Status: Python EventSystem: Initializing event module.
2022-03-24 14:05:09.546 Status: EventSystem: Started
2022-03-24 14:05:09.546 Status: EventSystem: Queue thread started...
2022-03-24 14:05:09.177 Error: Meteo: Error getting http data!
2022-03-24 14:05:10.743 Status: ThemesManager: Initialized version 1.5.35, author 'ycahome'
2022-03-24 14:05:12.178 Error: Meteo: Error getting http data!
2022-03-24 14:05:13.931 Status: SonoffZigBee: Initialized version 6.0, author 'pipiche38'
2022-03-24 14:05:14.021 Status: SonoffZigBee: PluginAnalytics set to 1
2022-03-24 14:05:14.021 Status: SonoffZigBee: Lang set to fr-FR
2022-03-24 14:05:14.021 Status: SonoffZigBee: channel set to 11
2022-03-24 14:05:14.021 Status: SonoffZigBee: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-04.json
2022-03-24 14:05:14.021 Status: SonoffZigBee: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-03-24 14:05:14.021 Status: SonoffZigBee: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-03-24 14:05:14.021 Status: SonoffZigBee: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/
2022-03-24 14:05:14.021 Status: SonoffZigBee: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/
2022-03-24 14:05:14.021 Status: SonoffZigBee: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2022-03-24 14:05:14.021 Status: SonoffZigBee: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports/
2022-03-24 14:05:14.021 Status: SonoffZigBee: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www/
2022-03-24 14:05:14.021 Status: SonoffZigBee: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/
2022-03-24 14:05:14.021 Status: SonoffZigBee: ControllerInRawMode set to True
2022-03-24 14:05:14.023 Status: SonoffZigBee: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs//PluginZigbee_04.log
2022-03-24 14:05:14.109 Status: SonoffZigBee: Zigate plugin beta6-6.0.124 started
2022-03-24 14:05:14.141 Status: SonoffZigBee: DeviceConf loaded - 23 confs loaded
2022-03-24 14:05:14.712 Status: SonoffZigBee: DeviceConf loaded - 330 confs loaded
2022-03-24 14:05:14.712 Status: SonoffZigBee: load ListOfDevice
2022-03-24 14:05:14.736 Status: SonoffZigBee: 1 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-4.txt
2022-03-24 14:05:14.737 Status: SonoffZigBee: Transport mode: ZigpyZNP
2022-03-24 14:05:18.482 Status: SonoffZigBee: ZigpyTransport: thread_processing_and_sending Thread start.
2022-03-24 14:05:18.483 Status: SonoffZigBee: Start Web Server connection
2022-03-24 14:05:18.529 Status: SonoffZigBee: Web backend for Web User Interface started on port: 9440
2022-03-24 14:05:27.143 Status: SonoffZigBee: Accepting new Hardware: Disable (Off)
2022-03-24 14:06:15.787 Status: SonoffZigBee: Number of devices recently active in Zigate = 0
2022-03-24 14:06:15.796 Status: SonoffZigBee: CC1352/CC2652, Z-Stack 3.30+ (znp)
2022-03-24 14:06:15.797 Status: SonoffZigBee: Installer Version Number: 1217
2022-03-24 14:06:15.799 Status: SonoffZigBee: Branch Version: ==> CC1352/CC2652, Z-Stack 3.30+ (znp) <==
2022-03-24 14:06:15.828 Status: SonoffZigBee: Zigbee Coordinator ieee: 00124b0024c99757 , short addr: 0000
2022-03-24 14:06:15.828 Status: SonoffZigBee: Network state UP, PANID: 1a62 extPANID: 0x00124b0024c99757 Channel: 11
2022-03-24 14:06:23.071 Status: SonoffZigBee: Request Disabling Accepting new Hardware
2022-03-24 14:06:23.153 Status: SonoffZigBee: Accepting new Hardware: Disable (Off)
2022-03-24 14:06:28.129 Status: SonoffZigBee: Zigate set to Certification : 1/CE -> CE
2022-03-24 14:06:28.154 Status: SonoffZigBee: Plugin with ZNP, firmware 21-1217 correctly initialized
2022-03-24 14:07:11.133 Error: SonoffZigBee: No transport, write directive to '192.168.1.10:54901' ignored.
2022-03-24 14:07:11.133 Error: SonoffZigBee: No transport, write directive to '192.168.1.10:54899' ignored.
2022-03-24 14:07:54.125 Status: SonoffZigBee: Request Accepting new Hardware for 240 seconds
2022-03-24 14:07:54.224 Status: SonoffZigBee: Accepting new Hardware: Enable (On)
2022-03-24 14:10:14.484 SonoffZigBee: --> Empty queue
2022-03-24 14:10:24.305 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:10:24.305 SonoffZigBee: --> Empty queue
2022-03-24 14:10:34.464 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:10:34.464 SonoffZigBee: --> Empty queue
2022-03-24 14:10:44.601 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:10:44.601 SonoffZigBee: --> Empty queue
2022-03-24 14:10:54.322 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:10:54.322 SonoffZigBee: --> Empty queue
2022-03-24 14:11:04.555 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:11:04.555 SonoffZigBee: --> Empty queue
2022-03-24 14:11:14.412 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:11:14.412 SonoffZigBee: --> Empty queue
2022-03-24 14:11:24.536 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:11:24.536 SonoffZigBee: --> Empty queue
2022-03-24 14:11:34.662 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:11:34.662 SonoffZigBee: --> Empty queue
2022-03-24 14:11:44.484 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:11:44.484 SonoffZigBee: --> Empty queue
2022-03-24 14:11:54.656 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:11:54.656 SonoffZigBee: --> Empty queue
2022-03-24 14:12:04.481 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:12:04.481 SonoffZigBee: --> Empty queue
2022-03-24 14:12:14.609 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:12:14.609 SonoffZigBee: --> Empty queue
2022-03-24 14:12:24.432 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:12:24.432 SonoffZigBee: --> Empty queue
2022-03-24 14:12:34.561 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:12:34.561 SonoffZigBee: --> Empty queue
2022-03-24 14:12:44.733 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:12:44.733 SonoffZigBee: --> Empty queue
2022-03-24 14:12:54.559 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:12:54.559 SonoffZigBee: --> Empty queue
2022-03-24 14:13:04.682 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:13:04.682 SonoffZigBee: --> Empty queue
2022-03-24 14:13:14.515 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:13:14.515 SonoffZigBee: --> Empty queue
2022-03-24 14:13:24.643 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:13:24.643 SonoffZigBee: --> Empty queue
2022-03-24 14:13:34.766 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:13:34.766 SonoffZigBee: --> Empty queue
2022-03-24 14:13:44.597 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:13:44.597 SonoffZigBee: --> Empty queue
2022-03-24 14:13:54.739 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:13:54.739 SonoffZigBee: --> Empty queue
2022-03-24 14:14:04.563 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:14:04.563 SonoffZigBee: --> Empty queue
2022-03-24 14:14:14.735 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:14:14.735 SonoffZigBee: --> Empty queue
2022-03-24 14:14:24.558 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:14:24.558 SonoffZigBee: --> Empty queue
2022-03-24 14:14:34.680 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:14:34.680 SonoffZigBee: --> Empty queue
2022-03-24 14:14:44.809 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:14:44.809 SonoffZigBee: --> Empty queue
2022-03-24 14:14:54.542 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:14:54.542 SonoffZigBee: --> Empty queue
2022-03-24 14:15:04.569 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:15:04.569 SonoffZigBee: --> Empty queue
2022-03-24 14:15:14.559 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:15:14.560 SonoffZigBee: --> Empty queue
2022-03-24 14:15:24.582 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:15:24.582 SonoffZigBee: --> Empty queue
2022-03-24 14:15:34.607 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:15:34.607 SonoffZigBee: --> Empty queue
2022-03-24 14:15:44.633 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:15:44.633 SonoffZigBee: --> Empty queue
2022-03-24 14:15:54.606 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:15:54.606 SonoffZigBee: --> Empty queue
2022-03-24 14:16:04.630 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:16:04.630 SonoffZigBee: --> Empty queue
2022-03-24 14:16:14.860 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:16:14.860 SonoffZigBee: --> Empty queue
2022-03-24 14:16:24.685 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:16:24.685 SonoffZigBee: --> Empty queue
2022-03-24 14:16:34.815 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:16:34.815 SonoffZigBee: --> Empty queue
2022-03-24 14:16:44.944 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:16:44.944 SonoffZigBee: --> Empty queue
2022-03-24 14:16:54.769 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:16:54.769 SonoffZigBee: --> Empty queue
2022-03-24 14:17:04.926 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:17:04.926 SonoffZigBee: --> Empty queue
2022-03-24 14:17:14.749 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:17:14.749 SonoffZigBee: --> Empty queue
2022-03-24 14:17:24.870 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:17:24.870 SonoffZigBee: --> Empty queue
2022-03-24 14:17:35.017 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:17:35.017 SonoffZigBee: --> Empty queue
2022-03-24 14:17:44.841 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:17:44.841 SonoffZigBee: --> Empty queue
2022-03-24 14:17:55.004 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:17:55.004 SonoffZigBee: --> Empty queue
2022-03-24 14:18:04.838 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:18:04.838 SonoffZigBee: --> Empty queue
2022-03-24 14:18:14.963 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:18:14.963 SonoffZigBee: --> Empty queue
2022-03-24 14:18:24.787 SonoffZigBee: Assisted Pairing: Polling: []
2022-03-24 14:18:24.787 SonoffZigBee: --> Empty queue
2022-03-24 14:18:28.798 SonoffZigBee: Disable Assisted pairing
2022-03-24 14:18:28.804 Status: SonoffZigBee: Request Disabling Accepting new Hardware
2022-03-24 14:18:28.922 Status: SonoffZigBee: Accepting new Hardware: Disable (Off)
2022-03-24 14:26:11.519 Status: ::ffff:192.168.1.10 -> handle abandoned timeout (status=6)
2022-03-24 14:26:16.982 Status: ::ffff:192.168.1.10 -> handle abandoned timeout (status=6) Mon installation viewtopic.php?f=21&t=12218
voila ce quelle me donne
Sur quel port USB la clef SonOff est-elle branchée ?
Est-ce un PI4 ? as-tu un Disk SSD ?
Brancher la clef SonOFF sur un port USB2 (dans le cas d'un PI4 et de préférence mettre une rallonge. pour que la clef ne subisse pas les interférences du PI)
je suis sur un RPI 3B+, j'utilise 3 des 4 ports, le 1er pour la carte X820v3 qui a sa propre alim ou est branché un HDD 160G, sur les 2 autres ports j'ai le dongle sonoff et un dongle Z-wave+
J’éloignerai le sonoff de tout ce monde sans un premier temps .
Autre chose quel version de firmware as tu sur le sonoff ? Je sais qu’une récente a des problèmes pour les appairage
je l'ai flasher avec le firmware sonoff pour augmenter ces restrictions matériel
une question, y aurait il un conflit entre le plugin zigbeefordomoticz et zigbee2mqtt si je souhaites utiliser les 2 ?
Donc tu es peut-être dans le cas du bug sur le firmware. Essayes d’en récupérer un plus ancien.
Oui il va falloir choisir z2m avec un broker mqtt au milieu ou z4d et un accès direct sans appli au milieu
Bon après avoir relu ton post, le firmware est firmware 21-1217 soit la dernière version de la branche master, ce qui me semble correcte.
Peux-tu essayer la commande suivante
A partir du repertoire du plugin ( domoticz/plugin/Domoticz-Zigbee )
( tu remplaces part le port utilisé pour le SonOff)
Cela va scanner les différents channels Zigbee et tu va pouvoir voir lequel a le moins d’interférences
je te suggère de basculer sur ce canal, après quoi tu re-essayes un appairage
python2 -m zigpy_znp.tools.energy_scan /dev/ttyxxxxxCela va scanner les différents channels Zigbee et tu va pouvoir voir lequel a le moins d’interférences
