Problème de mise a jour plugin
Re: Problème de mise a jour plugin
@Tc2112, tu peux nous faire des copier/coller en texte de tes logs. On ne peut pas rechercher un texte dans une image.
Tc2112
Message par Tc2112 »
dans Domoticz/matériel, le plugin zigbeefordomoticz est activé qu'une fois
voici le code en texte
freebox@mydomo:~/domoticz/plugins/Domoticz-Zigbee$ sudo python3 -m pip install -r requirements.txt --upgrade
Requirement already satisfied: zigpy in /usr/local/lib/python3.9/dist-packages (from -r requirements.txt (line 2)) (0.64.0)
Collecting zigpy
  Using cached zigpy-0.64.0-py3-none-any.whl (206 kB)
Requirement already satisfied: zigpy-cli in /usr/local/lib/python3.9/dist-packages (from -r requirements.txt (line 3)) (1.0.4)
Collecting zigpy-cli
  Using cached zigpy_cli-1.0.4-py3-none-any.whl (27 kB)
  Using cached zigpy_cli-1.0.3-py3-none-any.whl (27 kB)
Requirement already satisfied: dnspython in /usr/local/lib/python3.9/dist-packages (from -r requirements.txt (line 4)) (2.6.1)
Collecting dnspython
  Using cached dnspython-2.6.1-py3-none-any.whl (307 kB)
Requirement already satisfied: z4d-certified-devices in /usr/local/lib/python3.9/dist-packages (from -r requirements.txt (line 5)) (5.260)
Collecting z4d-certified-devices
  Using cached z4d_certified_devices-5.260-py3-none-any.whl (394 kB)
  Using cached z4d_certified_devices-4.259-py3-none-any.whl (394 kB)
Requirement already satisfied: distro in /usr/local/lib/python3.9/dist-packages (from -r requirements.txt (line 6)) (1.9.0)
Collecting distro
  Using cached distro-1.9.0-py3-none-any.whl (20 kB)
  Using cached distro-1.8.0-py3-none-any.whl (20 kB)
Requirement already satisfied: pyserial-asyncio-fast in /usr/local/lib/python3.9/dist-packages (from -r requirements.txt (line 7)) (0.11)
Collecting pyserial-asyncio-fast
  Using cached pyserial_asyncio_fast-0.11-py3-none-any.whl (8.4 kB)
  Using cached pyserial_asyncio_fast-0.10-py3-none-any.whl (8.3 kB)
Requirement already satisfied: zigpy_znp in /usr/local/lib/python3.9/dist-packages (from -r requirements.txt (line 8)) (0.12.1)
Collecting zigpy_znp
  Using cached zigpy_znp-0.12.1-py3-none-any.whl (120 kB)
Requirement already satisfied: zigpy_deconz in /usr/local/lib/python3.9/dist-packages (from -r requirements.txt (line 9)) (0.23.1)
Collecting zigpy_deconz
  Using cached zigpy_deconz-0.23.1-py3-none-any.whl (32 kB)
Requirement already satisfied: bellows in /usr/local/lib/python3.9/dist-packages (from -r requirements.txt (line 10)) (0.38.4)
Collecting bellows
  Using cached bellows-0.38.4-py3-none-any.whl (230 kB)
Requirement already satisfied: pure-pcapy3==1.0.1 in /usr/local/lib/python3.9/dist-packages (from bellows->-r requirements.txt (line 10)) (1.0.1)
Requirement already satisfied: async-timeout in /usr/local/lib/python3.9/dist-packages (from bellows->-r requirements.txt (line 10)) (4.0.3)
Requirement already satisfied: click-log>=0.2.1 in /usr/local/lib/python3.9/dist-packages (from bellows->-r requirements.txt (line 10)) (0.4.0)
Requirement already satisfied: voluptuous in /usr/local/lib/python3.9/dist-packages (from bellows->-r requirements.txt (line 10)) (0.14.1)
Requirement already satisfied: click in /usr/local/lib/python3.9/dist-packages (from bellows->-r requirements.txt (line 10)) (8.1.7)
Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages (from pure-pcapy3==1.0.1->bellows->-r requirements.txt (line 10)) (52.0.0)
Requirement already satisfied: attrs in /usr/lib/python3/dist-packages (from zigpy->-r requirements.txt (line 2)) (20.3.0)
Requirement already satisfied: aiosqlite>=0.20.0 in /usr/local/lib/python3.9/dist-packages (from zigpy->-r requirements.txt (line 2)) (0.20.0)
Requirement already satisfied: jsonschema in /usr/local/lib/python3.9/dist-packages (from zigpy->-r requirements.txt (line 2)) (4.17.3)
Requirement already satisfied: pyserial-asyncio in /usr/local/lib/python3.9/dist-packages (from zigpy->-r requirements.txt (line 2)) (0.6)
Requirement already satisfied: typing-extensions in /usr/local/lib/python3.9/dist-packages (from zigpy->-r requirements.txt (line 2)) (4.9.0)
Requirement already satisfied: crccheck in /usr/local/lib/python3.9/dist-packages (from zigpy->-r requirements.txt (line 2)) (1.3.0)
Requirement already satisfied: aiohttp in /usr/local/lib/python3.9/dist-packages (from zigpy->-r requirements.txt (line 2)) (3.9.1)
Requirement already satisfied: cryptography in /usr/lib/python3/dist-packages (from zigpy->-r requirements.txt (line 2)) (3.3.2)
Requirement already satisfied: pyserial in /usr/local/lib/python3.9/dist-packages (from pyserial-asyncio-fast->-r requirements.txt (line 7)) (3.5)
Requirement already satisfied: coloredlogs in /usr/local/lib/python3.9/dist-packages (from zigpy-cli->-r requirements.txt (line 3)) (15.0.1)
Requirement already satisfied: zigpy-zigate>=0.11.0 in /usr/local/lib/python3.9/dist-packages (from zigpy-cli->-r requirements.txt (line 3)) (0.11.0)
Requirement already satisfied: zigpy-xbee>=0.18.0 in /usr/local/lib/python3.9/dist-packages (from zigpy-cli->-r requirements.txt (line 3)) (0.19.1)
Requirement already satisfied: scapy in /usr/local/lib/python3.9/dist-packages (from zigpy-cli->-r requirements.txt (line 3)) (2.5.0)
Requirement already satisfied: gpiozero in /usr/local/lib/python3.9/dist-packages (from zigpy-zigate>=0.11.0->zigpy-cli->-r requirements.txt (line 3)) (2.0)
Requirement already satisfied: pyusb>=1.1.0 in /usr/local/lib/python3.9/dist-packages (from zigpy-zigate>=0.11.0->zigpy-cli->-r requirements.txt (line 3)) (1.2.1)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.9/dist-packages (from aiohttp->zigpy->-r requirements.txt (line 2)) (6.0.4)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.9/dist-packages (from aiohttp->zigpy->-r requirements.txt (line 2)) (1.9.4)
Requirement already satisfied: aiosignal>=1.1.2 in /usr/local/lib/python3.9/dist-packages (from aiohttp->zigpy->-r requirements.txt (line 2)) (1.3.1)
Requirement already satisfied: frozenlist>=1.1.1 in /usr/local/lib/python3.9/dist-packages (from aiohttp->zigpy->-r requirements.txt (line 2)) (1.4.1)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy->-r requirements.txt (line 2)) (2.10)
Requirement already satisfied: humanfriendly>=9.1 in /usr/local/lib/python3.9/dist-packages (from coloredlogs->zigpy-cli->-r requirements.txt (line 3)) (10.0)
Requirement already satisfied: colorzero in /usr/local/lib/python3.9/dist-packages (from gpiozero->zigpy-zigate>=0.11.0->zigpy-cli->-r requirements.txt (line 3)) (2.0)
Requirement already satisfied: pyrsistent!=0.17.0,!=0.17.1,!=0.17.2,>=0.14.0 in /usr/lib/python3/dist-packages (from jsonschema->zigpy->-r requirements.txt (line 2)) (0.15.5)
lost
Message par lost »
Pas certain que ce soit le même pb, mais pour ma part en lançant depuis le webui Z4D, j'ai eu une erreur indiquant que plugin.py était modifié... et bloquait.
Et en effet, un git status du répertoire plugin donnait:
On branch stable7
Your branch is behind 'origin/stable7' by 314 commits, and can be fast-forwarded.
  (use "git pull" to update your local branch)
Changes not staged for commit:
  (use "git add <file>..." to update what will be committed)
  (use "git restore <file>..." to discard changes in working directory)
	modified:   plugin.py
Untracked files:
  (use "git add <file>..." to include in what will be committed)
	.gitconfig
	ReportsTransport-stats.json
J'ai donc fait un <sudo> git restore du fichier comme proposé et upgrade relancé via webUI alors OK.
Problème: Je n'ai aucun souvenir d'avoir modifié ce fichier depuis la dernière MAJ. D'ailleurs celui restauré est idem sur un diff et la date du fichier était idem le reste (date upgrade plugin précédent) avant restauration aussi.
Bon, au final redémarrage OK et tout semble rouler! Merci Pipiche!
Tc2112
Cela ne fonctionne pas pour moi
Tc2112 a écrit : 18 mai 2024, 21:13 dans Domoticz/matériel, le plugin zigbeefordomoticz est activé qu'une fois
Collecting zigpy
Collecting distro
Collecting bellows
et maintenant si tu relances domoticz et le plugin , ca donne quoi ?
j'ai l'impression qu'il y a un mix de modules python installé via apt-get et d'autres via pip, et que ceux installé via apt-get ne sont pas vu de domoticz
que se passe-t-il si tu fais un
sudo apt-get remove attrs
puis tu fais
Tc2112
Bonjour Pipiche
J'ai fais :
freebox@mydomo:~/domoticz/plugins/Domoticz-Zigbee$ sudo apt-get remove attrs
résultat :
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package attrs
puis :
résultat:
Collecting zigpy
Collecting distro
Collecting bellows
puis sudo reboot
toujours pareil le plugins zigbee ne demarre pas
log domoticz au demarrage :
2024-05-20 07:15:56.635 Status: zigate: Started.
2024-05-20 07:15:56.635 Status: zigate: Entering work loop.
2024-05-20 07:15:56.638 Status: Ping: Worker started...
2024-05-20 07:15:56.638 Status: NotificationSystem: thread started...
2024-05-20 07:15:56.639 Status: EventSystem: reset all events...
2024-05-20 07:15:56.643 Status: EventSystem: reset all device statuses...
2024-05-20 07:15:56.828 Status: PluginSystem: 1 plugins started.
2024-05-20 07:15:56.907 Status: Python EventSystem: Initializing event module.
2024-05-20 07:15:56.916 Status: EventSystem: Queue thread started...
2024-05-20 07:15:56.916 Status: EventSystem: Started
2024-05-20 07:15:57.641 Status: MQTT: Connecting to localhost:1883
2024-05-20 07:15:57.684 Status: EventSystem: Script event triggered: conso
2024-05-20 07:15:57.841 Status: MQTT: connected to: localhost:1883
2024-05-20 07:15:57.253 Error: zigate: (Zigate) failed to load 'plugin.py', Python Path used was '/home/freebox/domoticz/plugins/Domoticz-Zigbee/:/usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload:/usr/local/lib/python3.9/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.9/dist-packages'.
2024-05-20 07:15:57.257 Error: zigate: Traceback (most recent call last):
2024-05-20 07:15:57.257 Error: zigate: File "/home/freebox/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 127, in <module>
2024-05-20 07:15:57.257 Error: zigate: from Classes.ZigpyTopology import ZigpyTopology
2024-05-20 07:15:57.257 Error: zigate: File "/home/freebox/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTopology.py", line 19, in <module>
2024-05-20 07:15:57.257 Error: zigate: import zigpy.types as t
2024-05-20 07:15:57.257 Error: zigate: File "/usr/local/lib/python3.9/dist-packages/zigpy/types/__init__.py", line 4, in <module>
2024-05-20 07:15:57.257 Error: zigate: from .named import * # noqa: F401,F403
2024-05-20 07:15:57.257 Error: zigate: File "/usr/local/lib/python3.9/dist-packages/zigpy/types/named.py", line 8, in <module>
2024-05-20 07:15:57.257 Error: zigate: import attrs
2024-05-20 07:15:57.257 Error: zigate: ModuleNotFoundError: No module named 'attrs'
Le sous menu Zigate dans le menu Personnalisé n'apparait toujours pas
La commande de remove n'ayant pas fonctionner, y-avait aucune raison que ca fasse fonctionner le plugin.
essayes c a:
apt-get remove python-attr
puis
Tc2112
Toujours pareil
commande :
sudo apt-get remove python-attr
resultat :
freebox@mydomo:~/domoticz/plugins/Domoticz-Zigbee$ sudo apt-get remove python-attr
E: Unable to locate package python-attr
commande :
resultat:
Collecting zigpy
Collecting distro
Collecting bellows
Je peu pas t’aider plus . C’est un problème Debian et un mix de modules python via apt-get et pip.
N’utilisant pas Debian, je peu pas t’aider plus
