[Python] Parrot flower Power
Re: Parrot flower Power
Essaie
Python ./test.py
pour lancer le script.
Python ./test.py
Voilà ce que ça donne
File "./test.py", line 17, in <module>
'client_secret': client_secret,
File "/usr/lib/python2.7/dist-packages/requests/api.py", line 60, in get
return request('get', url, **kwargs)
File "/usr/lib/python2.7/dist-packages/requests/api.py", line 49, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 457, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 606, in send
r.content
File "/usr/lib/python2.7/dist-packages/requests/models.py", line 724, in content
self._content = bytes().join(self.iter_content(CONTENT_CHUNK_SIZE)) or bytes()
File "/usr/lib/python2.7/dist-packages/requests/models.py", line 653, in generate
for chunk in self.raw.stream(chunk_size, decode_content=True):
File "/usr/lib/python2.7/dist-packages/urllib3/response.py", line 256, in stream
data = self.read(amt=amt, decode_content=decode_content)
File "/usr/lib/python2.7/dist-packages/urllib3/response.py", line 186, in read
data = self._fp.read(amt)
File "/usr/lib/python2.7/httplib.py", line 573, in read
s = self.fp.read(amt)
File "/usr/lib/python2.7/socket.py", line 380, in read
data = self._sock.recv(left)
File "/usr/lib/python2.7/dist-packages/urllib3/contrib/pyopenssl.py", line 188, in recv
data = self.connection.recv(*args, **kwargs)
OpenSSL.SSL.ZeroReturnError
PI 2-Aeon Stick-RFXCom : sondes RFX-10 détec.fumées-2 détec.ouverture-7 caméras-NetAtmo+3 modules+Anémo+Pluvio-2 prises Greenwave-1 prise Wemo-3 détec.inondation-1 Parrot Flower-1 détecteur UV-1 hub Harmony-prises RFX- 4 Squeezebox-XPENology+Plex
Hmm, requests pas installé ?
pip install requestsRaspberry pi 3, Dongle RfxCom et Zigate +, plugin de pipiche, Volets Roulants profalux, contrôle d'éclairage, détecteurs de présence, alarme incendie, pilotage livebox ...
Objectif : WAF > 1
Objectif : WAF > 1
Ben si
J'ai essayé avec --upgrade
i@raspberrypi:~/domoticz/scripts$ pip install requests
Requirement already satisfied (use --upgrade to upgrade): requests in /usr/lib/python2.7/dist-packages
Cleaning up...
pi@raspberrypi:~/domoticz/scripts$ pip install requests --upgrade
Downloading/unpacking requests from https://pypi.python.org/packages/2.7/r/requests/requests-2.9.1-py2.py3-none-any.whl#md5=58a444aaa02780ad01983f5f540e67b2
Downloading requests-2.9.1-py2.py3-none-any.whl (501kB): 501kB downloaded
Installing collected packages: requests
Found existing installation: requests 2.4.3
Not uninstalling requests at /usr/lib/python2.7/dist-packages, owned by OS
Can't roll back requests; was not uninstalled
Cleaning up...
Exception:
File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 122, in main
status = self.run(options, args)
File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 295, in run
requirement_set.install(install_options, global_options, root=options.root_path)
File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1436, in install
requirement.install(install_options, global_options, *args, **kwargs)
File "/usr/lib/python2.7/dist-packages/pip/req.py", line 672, in install
self.move_wheel_files(self.source_dir, root=root)
File "/usr/lib/python2.7/dist-packages/pip/req.py", line 902, in move_wheel_files
pycompile=self.pycompile,
File "/usr/lib/python2.7/dist-packages/pip/wheel.py", line 214, in move_wheel_files
clobber(source, lib_dir, True)
File "/usr/lib/python2.7/dist-packages/pip/wheel.py", line 204, in clobber
os.makedirs(destdir)
File "/usr/lib/python2.7/os.py", line 157, in makedirs
mkdir(name, mode)
OSError: [Errno 13] Permission denied: '/usr/local/lib/python2.7/dist-packages/requests-2.9.1.dist-info'
Storing debug log for failure in /home/pi/.pip/pip.logPI 2-Aeon Stick-RFXCom : sondes RFX-10 détec.fumées-2 détec.ouverture-7 caméras-NetAtmo+3 modules+Anémo+Pluvio-2 prises Greenwave-1 prise Wemo-3 détec.inondation-1 Parrot Flower-1 détecteur UV-1 hub Harmony-prises RFX- 4 Squeezebox-XPENology+Plex
Bon il y a un souci mais je ne sais pas où
J'ai passé l'après-midi à réinstaller un système tout neuf
J'ai installé python avec les lignes indiqués dans le tuto
Et quand je lance python test.py, j'ai toujours le même message d'erreur
Merci à ceux qui ont essayé de m'aider
Ca ne fonctionne pas du tout chez moi, je laisse tomberFile "test.py", line 17, in <module>
r.content
J'ai fait un bout de code pour implémenter les logs et j'ai oublié le
en voyant mes erreurs, j'ai pensé à toi :
au début de mon code python.#!/usr/bin/python
# -*- coding: utf-8 -*-
Bref, as-tu bien mis ces deux premières lignes ?pi@raspberrypi ~/domoticz/scripts/python $ ./logger.py
./logger.py: line 1: import: command not found
./logger.py: line 4: syntax error near unexpected token `filename='test_log.log',level=logging.DEBUG,'
./logger.py: line 4: ` format='%(asctime)s -- %(name)s -- %(levelname)s -- %(message)s')'
Merci js-martin
Je viens de mettre les 2 lignes mais c'est toujours pareil
File "test.py", line 19, in <module>
r.content
J'ai essayer de réinstaller mais tout est dans la dernière version
pi@raspberrypi:~/domoticz/scripts$ sudo apt-get install python
python est déjà la plus récente version disponible.
0 mis à jour, 0 nouvellement installés, 0 à enlever et 1 non mis à jour.
pi@raspberrypi:~/domoticz/scripts$ sudo apt-get install python-dev
python-dev est déjà la plus récente version disponible.
pi@raspberrypi:~/domoticz/scripts$ sudo apt-get install python-setuptools
python-setuptools est déjà la plus récente version disponible.
pi@raspberrypi:~/domoticz/scripts$ sudo apt-get install python-pip
python-pip est déjà la plus récente version disponible.
pi@raspberrypi:~/domoticz/scripts$ sudo pip install requests
Cleaning up...
Mais du coup, tu n'as aucun code Python qui fonctionne : exact ?
Un truc basique marche ?
A tout hasard, tu peux me faire un :
pour voir s'il ne serait pas installé ailleurs...
#!/usr/bin/python
# Hello world python program
print "Hello World!";Code : Tout sélectionner
which pythonDomotisation de : mes compteurs EDF, solaire, eau / mon alarme / ma Chaudière Viessamnn / mon congel / ma sonnette. Matériels : Pi2 - RFXTrx433e - Zwave+ Aeotec, ampoules Hue - Détecteur et prises Fibaro - Capteurs Oregon - présentation installation => lien
Donc ça fonctionnepi@raspberrypi:~/domoticz/scripts$ python t.py
Hello World!
pi@raspberrypi:~/domoticz/scripts$ which python
/usr/bin/python
