Re: Zigate 4.0.0
Publié : 13 janv. 2019, 19:37
par seblang
je suis reparti de zéro et j'ai toujours :
2019-01-13 19:37:29.988 Error: (zigate) ----> Line 294 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate-stable\plugin.py'
2019-01-13 19:37:29.988 Error: (zigate) ----> Line 243 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate-stable\plugin.py'
2019-01-13 19:37:29.988 Error: (zigate) ----> Line 194 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate-stable\z_heartbeat.py'
2019-01-13 19:37:35.112 Error: (zigate) 'onHeartbeat' failed 'AttributeError':''NoneType' object has no attribute 'checkTOwaitFor''.
2019-01-13 19:37:35.112 Error: (zigate) ----> Line 294 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate-stable\plugin.py'
2019-01-13 19:37:35.112 Error: (zigate) ----> Line 243 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate-stable\plugin.py'
2019-01-13 19:37:35.112 Error: (zigate) ----> Line 194 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate-stable\z_heartbeat.py'
ci-joint la copie d'ecran :
- materiel.JPG (37.77 Kio) Consulté 6363 fois
Re: Zigate 4.0.0
Publié : 13 janv. 2019, 20:18
par seblang
pourquoi tu est surpris d'avoir "aucun"? tu m'as dit de mettre "nonne" donc aucun non?
ci-dessous la liste des erreurs depuis n'init du pluggin :
2019-01-13 20:12:22.541 Status: (zigate) Initialized version 4.0.6, author 'zaraki673 pipiche38'
2019-01-13 20:12:22.541 Status: (zigate) Entering work loop.
2019-01-13 20:12:22.651 Status: (zigate) onStart called - Zigate plugin V 4.0.6
2019-01-13 20:12:22.691 Status: (zigate) load PluginConf
2019-01-13 20:12:22.691 Status: (zigate) ZigateMode: ZigBee sendDelay: 0 reTransmit: 1 zTimeOut: 2
2019-01-13 20:12:22.691 Status: (zigate) logFORMAT: 0 logLQI: 0 allowRemoveZigateDevice: 0
2019-01-13 20:12:22.691 Status: (zigate) allowStoreDiscoveryFrames: 0 forceCreationDevice: 0 networkScan: 0 channel: ['0']
2019-01-13 20:12:22.699 Status: (zigate) load ListOfDevice
2019-01-13 20:12:22.712 Status: (zigate) Connection Name: Zigate, Transport: Serial, Address: COM3
2019-01-13 20:12:22.702 Error: (zigate) checkListOfDevice2Devices - Detectecteur chambre 2 - zigate - 5bf4 not found in Plugin Database
2019-01-13 20:12:22.702 Error: (zigate) checkListOfDevice2Devices - Detectecteur chambre 1 - zigate - 85ed not found in Plugin Database
2019-01-13 20:12:22.702 Error: (zigate) checkListOfDevice2Devices - Detectecteur porte terrasse - zigate - 285c not found in Plugin Database
2019-01-13 20:12:22.702 Error: (zigate) checkListOfDevice2Devices - Detectecteur dressing - zigate - 6186 not found in Plugin Database
2019-01-13 20:12:22.702 Error: (zigate) checkListOfDevice2Devices - Detecteur porte garage/interieur - zigate - 5342 not found in Plugin Database
2019-01-13 20:12:22.702 Error: (zigate) checkListOfDevice2Devices - Temperature bureau - zigate - 5540 not found in Plugin Database
2019-01-13 20:12:22.702 Error: (zigate) checkListOfDevice2Devices - zigate - Humi - 5540 - 5540 not found in Plugin Database
2019-01-13 20:12:22.702 Error: (zigate) checkListOfDevice2Devices - zigate - Baro - 5540 - 5540 not found in Plugin Database
2019-01-13 20:12:22.702 Error: (zigate) checkListOfDevice2Devices - Temperature salon - zigate - c2d6 not found in Plugin Database
2019-01-13 20:12:22.702 Error: (zigate) checkListOfDevice2Devices - zigate - Humi - c2d6 - c2d6 not found in Plugin Database
2019-01-13 20:12:22.702 Error: (zigate) checkListOfDevice2Devices - zigate - Baro - c2d6 - c2d6 not found in Plugin Database
2019-01-13 20:12:22.702 Error: (zigate) checkListOfDevice2Devices - Temperature exterieur - zigate - 8c6a not found in Plugin Database
2019-01-13 20:12:22.702 Error: (zigate) checkListOfDevice2Devices - zigate - Humi -salon - 8c6a not found in Plugin Database
2019-01-13 20:12:22.710 Error: (zigate) checkListOfDevice2Devices - zigate - Baro - 8c6a - 8c6a not found in Plugin Database
2019-01-13 20:12:22.710 Error: (zigate) checkListOfDevice2Devices - Temperature garage - zigate - 9eef not found in Plugin Database
2019-01-13 20:12:22.710 Error: (zigate) checkListOfDevice2Devices - zigate - Humi - 9eef - 9eef not found in Plugin Database
2019-01-13 20:12:22.710 Error: (zigate) checkListOfDevice2Devices - zigate - Baro - 9eef - 9eef not found in Plugin Database
2019-01-13 20:12:22.712 Error: (zigate) checkListOfDevice2Devices - Detecteur bureau - zigate - d0b8 not found in Plugin Database
2019-01-13 20:12:22.712 Error: (zigate) checkListOfDevice2Devices - Detectecteur fenetre cuisine - zigate - bd37 not found in Plugin Database
2019-01-13 20:12:22.712 Error: (zigate) checkListOfDevice2Devices - zigate - Door - 3a81 - 3a81 not found in Plugin Database
2019-01-13 20:12:22.712 Error: (zigate) checkListOfDevice2Devices - zigate - Temp - 8db2 - 8db2 not found in Plugin Database
2019-01-13 20:12:22.712 Error: (zigate) checkListOfDevice2Devices - zigate - Humi - 8db2 - 8db2 not found in Plugin Database
2019-01-13 20:12:22.712 Error: (zigate) checkListOfDevice2Devices - zigate - Baro - 8db2 - 8db2 not found in Plugin Database
2019-01-13 20:12:22.712 Error: (zigate) checkListOfDevice2Devices - zigate - Door - 49c5 - 49c5 not found in Plugin Database
2019-01-13 20:12:22.712 Error: (zigate) checkListOfDevice2Devices - Detectecteur chambre 2 - zigate - c2fb not found in Plugin Database
2019-01-13 20:12:22.943 OpenZWave: Value_Added: Node: 20 (0x14), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2019-01-13 20:12:23.028 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2019-01-13 20:12:23.040 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2019-01-13 20:12:23.040 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2019-01-13 20:12:23.044 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2019-01-13 20:12:23.044 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: ALARM, Label: Burglar, Instance: 1
2019-01-13 20:12:23.044 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2019-01-13 20:12:23.092 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2019-01-13 20:12:23.128 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2019-01-13 20:12:23.140 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2019-01-13 20:12:23.140 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: CENTRAL SCENE, Label: Scene Count, Instance: 0
2019-01-13 20:12:23.140 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: CENTRAL SCENE, Label: Scene KeyAttribute, Instance: 1
2019-01-13 20:12:23.140 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: CENTRAL SCENE, Label: Scene ID, Instance: 2
2019-01-13 20:12:23.144 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: CENTRAL SCENE, Label: Scene Number, Instance: 128
2019-01-13 20:12:23.148 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: CENTRAL SCENE, Label: Button, Instance: 3
2019-01-13 20:12:23.152 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: CENTRAL SCENE, Label: Scenes Identical, Instance: 4
2019-01-13 20:12:23.200 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2019-01-13 20:12:23.280 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2019-01-13 20:12:23.288 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2019-01-13 20:12:23.292 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2019-01-13 20:12:23.300 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2019-01-13 20:12:23.304 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: ALARM, Label: Smoke, Instance: 1
2019-01-13 20:12:23.304 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2019-01-13 20:12:23.324 OpenZWave: Value_Added: Node: 24 (0x18), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2019-01-13 20:12:23.324 OpenZWave: Value_Added: Node: 24 (0x18), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2019-01-13 20:12:23.324 OpenZWave: Value_Added: Node: 24 (0x18), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2019-01-13 20:12:23.324 OpenZWave: Value_Added: Node: 24 (0x18), CommandClass: SENSOR ALARM, Label: Smoke, Instance: 1
2019-01-13 20:12:23.640 (zigate) Connected successfully
2019-01-13 20:12:23.636 Status: (zigate) onConnect called
2019-01-13 20:12:23.640 Status: (zigate) ZigateConf - Setting UTC Time to : 1547406743
2019-01-13 20:12:23.640 Status: (zigate) Start network
2019-01-13 20:12:23.640 Status: (zigate) Zigate enter in discover mode for 254 Secs
2019-01-13 20:12:23.744 Status: (zigate) Major Version Num: 0001
2019-01-13 20:12:23.744 Status: (zigate) Installer Version Number: 030c
2019-01-13 20:12:23.854 Status: (zigate) Decode8015 : Number of devices recently active in Zigate = 13
2019-01-13 20:12:23.854 Status: (zigate) Decode8015 : [00] DevID = 00 Network addr = 5bf4 IEEE = 00158d0001e48b1a RSSI = 117 Power = 00 not found in ListOfDevices
2019-01-13 20:12:23.854 Status: (zigate) Decode8015 : [01] DevID = 01 Network addr = 85ed IEEE = 00158d0001b7baab RSSI = 087 Power = 00 not found in ListOfDevices
2019-01-13 20:12:23.858 Status: (zigate) Decode8015 : [02] DevID = 02 Network addr = 285c IEEE = 00158d0001b95871 RSSI = 125 Power = 00 not found in ListOfDevices
2019-01-13 20:12:23.858 Status: (zigate) Decode8015 : [03] DevID = 03 Network addr = 6186 IEEE = 00158d0001b7abc0 RSSI = 109 Power = 00 not found in ListOfDevices
2019-01-13 20:12:23.862 Status: (zigate) Decode8015 : [04] DevID = 04 Network addr = 5342 IEEE = 00158d0001e48225 RSSI = 142 Power = 00 not found in ListOfDevices
2019-01-13 20:12:23.862 Status: (zigate) Decode8015 : [05] DevID = 05 Network addr = 8c6a IEEE = 00158d0002271565 RSSI = 134 Power = 00 not found in ListOfDevices
2019-01-13 20:12:23.862 Status: (zigate) Decode8015 : [06] DevID = 06 Network addr = 9eef IEEE = 00158d0002272867 RSSI = 126 Power = 00 not found in ListOfDevices
2019-01-13 20:12:23.866 Status: (zigate) Decode8015 : [07] DevID = 07 Network addr = 8db2 IEEE = 00158d0002271cdb RSSI = 155 Power = 00 not found in ListOfDevices
2019-01-13 20:12:23.870 Status: (zigate) Decode8015 : [08] DevID = 08 Network addr = 5540 IEEE = 00158d000227286e RSSI = 134 Power = 00 not found in ListOfDevices
2019-01-13 20:12:23.870 Status: (zigate) Decode8015 : [09] DevID = 09 Network addr = d0b8 IEEE = 00158d0001b91bb3 RSSI = 103 Power = 00 not found in ListOfDevices
2019-01-13 20:12:23.870 Status: (zigate) Decode8015 : [10] DevID = 0a Network addr = bd37 IEEE = 00158d0001de66c1 RSSI = 137 Power = 00 not found in ListOfDevices
2019-01-13 20:12:23.874 Status: (zigate) Decode8015 : [11] DevID = 0b Network addr = 3a81 IEEE = 00158d0001e42e4e RSSI = 162 Power = 00 not found in ListOfDevices
2019-01-13 20:12:23.874 Status: (zigate) Decode8015 : [12] DevID = 0c Network addr = c2fb IEEE = 00158d000274ffed RSSI = 144 Power = 00 not found in ListOfDevices
2019-01-13 20:12:26.136 Status: OpenZWave: Awake Nodes queried
2019-01-13 20:12:31.026 (meteo local) Temp + Humidity + Baro (meteo local)
2019-01-13 20:12:31.026 EventSystem: Event triggered: gestionoff detecteur global hors porte_1
2019-01-13 20:12:31.057 EventSystem: Event triggered: gestionoff detecteur global avec porte_1
2019-01-13 20:12:31.073 (meteo local) Wind (Unknown)
2019-01-13 20:12:31.104 (meteo local) UV (UV)
2019-01-13 20:12:31.151 (meteo local) Rain (Unknown)
2019-01-13 20:12:31.182 (meteo local) General/Visibility (Unknown)
2019-01-13 20:12:31.229 (meteo local) General/Solar Radiation (Unknown)
2019-01-13 20:12:31.292 (meteo flagey darksky) Temp + Humidity + Baro (Meteo local 2)
2019-01-13 20:12:31.338 (meteo flagey darksky) Wind (Unknown)
2019-01-13 20:12:31.385 (meteo flagey darksky) UV (UV Index)
2019-01-13 20:12:31.417 (meteo flagey darksky) Rain (Unknown)
2019-01-13 20:12:31.448 (meteo flagey darksky) General/Visibility (Unknown)
2019-01-13 20:12:31.479 (meteo flagey darksky) General/Custom Sensor (Ozone Sensor)
2019-01-13 20:12:31.510 (Etat global détecteurs hors porte) Lighting 2 (Etat global détecteurs hors porte)
2019-01-13 20:12:31.526 (meteo local) Temp + Humidity + Baro (THB)
2019-01-13 20:12:31.557 (meteo local) Wind (Unknown)
2019-01-13 20:12:31.573 (meteo local) UV (UV)
2019-01-13 20:12:31.620 (meteo local) Rain (Unknown)
2019-01-13 20:12:31.651 (meteo local) General/Visibility (Unknown)
2019-01-13 20:12:31.682 (meteo local) General/Solar Radiation (Unknown)
2019-01-13 20:12:31.713 (Etat global détecteurs avec porte) Lighting 2 (Etat global détecteurs avec porte)
2019-01-13 20:12:31.073 Status: LUA: script_device_givre.lua
2019-01-13 20:12:31.276 Status: EventSystem: Script event triggered: givre
2019-01-13 20:12:38.831 Status: (zigate) Permit Join is On
2019-01-13 20:15:05.020 Error: (zigate) Decode8102 - Receiving a message from unknown device : 8c6a with Data : 2d8c6a0104020000002900020337
2019-01-13 20:15:05.020 Error: (zigate) Decode8102 - Receiving a message from unknown device : 8c6a with Data : 2e8c6a01040500000021000223a2
2019-01-13 20:15:05.020 Error: (zigate) Decode8102 - Receiving a message from unknown device : 8c6a with Data : 2f8c6a01040300000029000203d5
2019-01-13 20:15:05.020 Error: (zigate) Decode8102 - Receiving a message from unknown device : 8c6a with Data : 2f8c6a010403001400280001ff
2019-01-13 20:15:05.020 Error: (zigate) Decode8102 - Receiving a message from unknown device : 8c6a with Data : 2f8c6a0104030010002900022653
2019-01-13 20:15:10.626 Error: (zigate) Decode8102 - Receiving a message from unknown device : 9eef with Data : 689eef01040200000029000203bf
2019-01-13 20:15:10.626 Error: (zigate) Decode8102 - Receiving a message from unknown device : 9eef with Data : 699eef0104050000002100022185
2019-01-13 20:15:10.626 Error: (zigate) Decode8102 - Receiving a message from unknown device : 9eef with Data : 6a9eef01040300000029000203d5
2019-01-13 20:15:10.626 Error: (zigate) Decode8102 - Receiving a message from unknown device : 9eef with Data : 6a9eef010403001400280001ff
2019-01-13 20:15:10.642 Error: (zigate) Decode8102 - Receiving a message from unknown device : 9eef with Data : 6a9eef0104030010002900022655
Re: Zigate 4.0.0
Publié : 13 janv. 2019, 20:48
par seblang
dsl de te prendre autant de temps!
j'ai remis le fichier que j'avais juste sauvegardé apres l'upgrade.
voila le resultat :
2019-01-13 20:43:50.130 Status: (zigate) Initialized version 4.0.6, author 'zaraki673 pipiche38'
2019-01-13 20:43:50.162 Status: (zigate) onStart called - Zigate plugin V 4.0.6
2019-01-13 20:43:50.162 Status: (zigate) load PluginConf
2019-01-13 20:43:50.166 Status: (zigate) ZigateMode: ZigBee sendDelay: 0 reTransmit: 1 zTimeOut: 2
2019-01-13 20:43:50.166 Status: (zigate) logFORMAT: 0 logLQI: 0 allowRemoveZigateDevice: 0
2019-01-13 20:43:50.166 Status: (zigate) allowStoreDiscoveryFrames: 0 forceCreationDevice: 0 networkScan: 0 channel: ['0']
2019-01-13 20:43:50.130 Status: (zigate) Entering work loop.
2019-01-13 20:43:50.170 Status: (zigate) load ListOfDevice
2019-01-13 20:43:50.178 Status: (zigate) Connection Name: Zigate, Transport: Serial, Address: COM3
2019-01-13 20:43:50.599 Status: (zigate) onConnect called
2019-01-13 20:43:50.599 Status: (zigate) ZigateConf - Setting UTC Time to : 1547408630
2019-01-13 20:43:50.599 Status: (zigate) Start network
2019-01-13 20:43:50.599 Status: (zigate) Zigate enter in discover mode for 254 Secs
2019-01-13 20:43:50.707 Status: (zigate) Major Version Num: 0001
2019-01-13 20:43:50.707 Status: (zigate) Installer Version Number: 030c
2019-01-13 20:43:50.812 Status: (zigate) Decode8015 : Number of devices recently active in Zigate = 13
2019-01-13 20:43:50.812 Status: (zigate) Decode8015 : [00] DevID = 00 Network addr = 5bf4 IEEE = 00158d0001e48b1a RSSI = 117 Power = 00 not found in ListOfDevices
2019-01-13 20:43:50.812 Status: (zigate) Decode8015 : [01] DevID = 01 Network addr = 85ed IEEE = 00158d0001b7baab RSSI = 087 Power = 00 not found in ListOfDevices
2019-01-13 20:43:50.812 Status: (zigate) Decode8015 : [02] DevID = 02 Network addr = 285c IEEE = 00158d0001b95871 RSSI = 125 Power = 00 not found in ListOfDevices
2019-01-13 20:43:50.812 Status: (zigate) Decode8015 : [03] DevID = 03 Network addr = 6186 IEEE = 00158d0001b7abc0 RSSI = 110 Power = 00 not found in ListOfDevices
2019-01-13 20:43:50.812 Status: (zigate) Decode8015 : [04] DevID = 04 Network addr = 5342 IEEE = 00158d0001e48225 RSSI = 140 Power = 00 not found in ListOfDevices
2019-01-13 20:43:50.812 Status: (zigate) Decode8015 : [05] DevID = 05 Network addr = 8c6a IEEE = 00158d0002271565 RSSI = 134 Power = 00 not found in ListOfDevices
2019-01-13 20:43:50.816 Status: (zigate) Decode8015 : [06] DevID = 06 Network addr = 9eef IEEE = 00158d0002272867 RSSI = 127 Power = 00 not found in ListOfDevices
2019-01-13 20:43:50.816 Status: (zigate) Decode8015 : [07] DevID = 07 Network addr = 8db2 IEEE = 00158d0002271cdb RSSI = 155 Power = 00 not found in ListOfDevices
2019-01-13 20:43:50.816 Status: (zigate) Decode8015 : [08] DevID = 08 Network addr = 5540 IEEE = 00158d000227286e RSSI = 134 Power = 00 not found in ListOfDevices
2019-01-13 20:43:50.816 Status: (zigate) Decode8015 : [09] DevID = 09 Network addr = d0b8 IEEE = 00158d0001b91bb3 RSSI = 103 Power = 00 not found in ListOfDevices
2019-01-13 20:43:50.816 Status: (zigate) Decode8015 : [10] DevID = 0a Network addr = bd37 IEEE = 00158d0001de66c1 RSSI = 137 Power = 00 not found in ListOfDevices
2019-01-13 20:43:50.816 Status: (zigate) Decode8015 : [11] DevID = 0b Network addr = 3a81 IEEE = 00158d0001e42e4e RSSI = 162 Power = 00 not found in ListOfDevices
2019-01-13 20:43:50.816 Status: (zigate) Decode8015 : [12] DevID = 0c Network addr = c2fb IEEE = 00158d000274ffed RSSI = 144 Power = 00 not found in ListOfDevices
2019-01-13 20:43:50.174 Error: (zigate) checkListOfDevice2Devices - Detectecteur chambre 2 - zigate - 5bf4 not found in Plugin Database
2019-01-13 20:43:50.174 Error: (zigate) checkListOfDevice2Devices - Detectecteur chambre 1 - zigate - 85ed not found in Plugin Database
2019-01-13 20:43:50.174 Error: (zigate) checkListOfDevice2Devices - Detectecteur porte terrasse - zigate - 285c not found in Plugin Database
2019-01-13 20:43:50.174 Error: (zigate) checkListOfDevice2Devices - Detectecteur dressing - zigate - 6186 not found in Plugin Database
2019-01-13 20:43:50.174 Error: (zigate) checkListOfDevice2Devices - Detecteur porte garage/interieur - zigate - 5342 not found in Plugin Database
2019-01-13 20:43:50.174 Error: (zigate) checkListOfDevice2Devices - Temperature bureau - zigate - 5540 not found in Plugin Database
2019-01-13 20:43:50.174 Error: (zigate) checkListOfDevice2Devices - zigate - Humi - 5540 - 5540 not found in Plugin Database
2019-01-13 20:43:50.174 Error: (zigate) checkListOfDevice2Devices - zigate - Baro - 5540 - 5540 not found in Plugin Database
2019-01-13 20:43:50.174 Error: (zigate) checkListOfDevice2Devices - Temperature salon - zigate - c2d6 not found in Plugin Database
2019-01-13 20:43:50.174 Error: (zigate) checkListOfDevice2Devices - zigate - Humi - c2d6 - c2d6 not found in Plugin Database
2019-01-13 20:43:50.174 Error: (zigate) checkListOfDevice2Devices - zigate - Baro - c2d6 - c2d6 not found in Plugin Database
2019-01-13 20:43:50.174 Error: (zigate) checkListOfDevice2Devices - Temperature exterieur - zigate - 8c6a not found in Plugin Database
2019-01-13 20:43:50.178 Error: (zigate) checkListOfDevice2Devices - zigate - Humi -salon - 8c6a not found in Plugin Database
2019-01-13 20:43:50.178 Error: (zigate) checkListOfDevice2Devices - zigate - Baro - 8c6a - 8c6a not found in Plugin Database
2019-01-13 20:43:50.178 Error: (zigate) checkListOfDevice2Devices - Temperature garage - zigate - 9eef not found in Plugin Database
2019-01-13 20:43:50.178 Error: (zigate) checkListOfDevice2Devices - zigate - Humi - 9eef - 9eef not found in Plugin Database
2019-01-13 20:43:50.178 Error: (zigate) checkListOfDevice2Devices - zigate - Baro - 9eef - 9eef not found in Plugin Database
2019-01-13 20:43:50.178 Error: (zigate) checkListOfDevice2Devices - Detecteur bureau - zigate - d0b8 not found in Plugin Database
2019-01-13 20:43:50.178 Error: (zigate) checkListOfDevice2Devices - Detectecteur fenetre cuisine - zigate - bd37 not found in Plugin Database
2019-01-13 20:43:50.178 Error: (zigate) checkListOfDevice2Devices - zigate - Door - 3a81 - 3a81 not found in Plugin Database
2019-01-13 20:43:50.178 Error: (zigate) checkListOfDevice2Devices - zigate - Temp - 8db2 - 8db2 not found in Plugin Database
2019-01-13 20:43:50.178 Error: (zigate) checkListOfDevice2Devices - zigate - Humi - 8db2 - 8db2 not found in Plugin Database
2019-01-13 20:43:50.178 Error: (zigate) checkListOfDevice2Devices - zigate - Baro - 8db2 - 8db2 not found in Plugin Database
2019-01-13 20:43:50.178 Error: (zigate) checkListOfDevice2Devices - zigate - Door - 49c5 - 49c5 not found in Plugin Database
2019-01-13 20:43:50.178 Error: (zigate) checkListOfDevice2Devices - Detectecteur chambre 2 - zigate - c2fb not found in Plugin Database
2019-01-13 20:43:53.161 Status: OpenZWave: Awake Nodes queried
2019-01-13 20:43:58.624 (meteo local) Temp + Humidity + Baro (meteo local)
2019-01-13 20:43:58.624 EventSystem: Event triggered: gestionoff detecteur global hors porte_1
2019-01-13 20:43:58.656 (meteo local) Wind (Unknown)
2019-01-13 20:43:58.656 EventSystem: Event triggered: gestionoff detecteur global avec porte_1
2019-01-13 20:43:58.671 (meteo local) UV (UV)
2019-01-13 20:43:58.703 (meteo local) Rain (Unknown)
2019-01-13 20:43:58.734 (meteo local) General/Visibility (Unknown)
2019-01-13 20:43:58.781 (meteo local) General/Solar Radiation (Unknown)
2019-01-13 20:43:58.812 (meteo local) Temp + Humidity + Baro (THB)
2019-01-13 20:43:58.859 (meteo local) Wind (Unknown)
2019-01-13 20:43:58.906 (meteo local) UV (UV)
2019-01-13 20:43:58.937 (meteo local) Rain (Unknown)
2019-01-13 20:43:58.984 (meteo local) General/Visibility (Unknown)
2019-01-13 20:43:58.703 Status: LUA: script_device_givre.lua
2019-01-13 20:43:59.031 (meteo local) General/Solar Radiation (Unknown)
2019-01-13 20:43:59.078 (Etat global détecteurs hors porte) Lighting 2 (Etat global détecteurs hors porte)
2019-01-13 20:43:59.124 (meteo flagey darksky) Temp + Humidity + Baro (Meteo local 2)
2019-01-13 20:43:59.140 (meteo flagey darksky) Wind (Unknown)
2019-01-13 20:43:59.156 (meteo flagey darksky) UV (UV Index)
2019-01-13 20:43:59.187 (meteo flagey darksky) Rain (Unknown)
2019-01-13 20:43:59.218 (meteo flagey darksky) General/Visibility (Unknown)
2019-01-13 20:43:59.249 (meteo flagey darksky) General/Custom Sensor (Ozone Sensor)
2019-01-13 20:43:59.281 (Etat global détecteurs avec porte) Lighting 2 (Etat global détecteurs avec porte)
2019-01-13 20:43:58.999 Status: EventSystem: Script event triggered: givre
2019-01-13 20:44:05.867 Status: (zigate) Permit Join is On
2019-01-13 20:45:02.605 Status: LUA: <font color='#f3031d'>=========== Point de rosee et point de givrage (v1.0) ===========</font>
2019-01-13 20:45:02.605 Status: LUA: <font color='#f3031d'>--- --- --- Temperature Ext : 1.92</font>
2019-01-13 20:45:02.605 Status: LUA: <font color='#f3031d'>--- --- --- Point de Rosee : 3.03</font>
2019-01-13 20:45:02.605 Status: LUA: <font color='#f3031d'>=========== La temperature du point de rosee est superieure a la temperature. Puisque la temperature du point de rosee ne peut etre superieure a la temperature de l'air , l'humidite relative a ete fixee à nil ===========</font>
2019-01-13 20:45:10.252 Error: (zigate) Decode8102 - Receiving a message from unknown device : d0b8 with Data : e9d0b8010000ff010042001d0121e50b03280d0421a8430521f000062401000000000a210000641000
ci-dessous mon fichier device :
5bf4 : {'Ep': {'01': {'0000': {}, '0003': {}, 'ffff': {}, '0006': {}}}, 'Status': 'inDB', 'Heartbeat': '39398', 'RIA': '81', 'Battery': {}, 'Model': 'lumi.sensor_magnet.aq2', 'MacCapa': '80', 'IEEE': '00158d0001e48b1a', 'Type': 'Door', 'ProfileID': '0104', 'ZDeviceID': '5f01'}
85ed : {'Ep': {'01': {'0000': {}, '0003': {}, 'ffff': {}, '0006': '00'}}, 'Status': 'inDB', 'Heartbeat': '39399', 'RIA': '110', 'Battery': {}, 'Model': 'lumi.sensor_magnet.aq2', 'MacCapa': '80', 'IEEE': '00158d0001b7baab', 'Type': 'Door', 'ProfileID': '0104', 'ZDeviceID': '5f01'}
285c : {'Ep': {'01': {'0000': {}, '0003': {}, 'ffff': {}, '0006': '00'}}, 'Status': 'inDB', 'Heartbeat': '39398', 'RIA': '119', 'Battery': 102, 'Model': 'lumi.sensor_magnet.aq2', 'MacCapa': '80', 'IEEE': '00158d0001b95871', 'Type': 'Door', 'ProfileID': '0104', 'ZDeviceID': '5f01'}
6186 : {'Ep': {'01': {'0000': {}, '0006': {}}}, 'Status': 'inDB', 'Heartbeat': '39396', 'RIA': '63', 'Battery': {}, 'Model': 'lumi.sensor_magnet.aq2', 'MacCapa': '80', 'IEEE': '00158d0001b7abc0', 'Type': 'Door', 'ProfileID': {}, 'ZDeviceID': {}}
5342 : {'Ep': {'01': {'0000': {}, '0003': {}, 'ffff': {}, '0006': '00'}}, 'Status': 'inDB', 'Heartbeat': '39398', 'RIA': '291', 'Battery': {}, 'Model': 'lumi.sensor_magnet.aq2', 'MacCapa': '80', 'IEEE': '00158d0001e48225', 'Type': 'Door', 'ProfileID': '0104', 'ZDeviceID': '5f01'}
5540 : {'Ep': {'01': {'0000': {}, '0403': 3.562507894773809e+222, '0402': 19.8, '0405': 45.4}}, 'Status': 'inDB', 'Heartbeat': '39396', 'RIA': '591', 'Battery': 100, 'Model': 'lumi.weather', 'MacCapa': '80', 'IEEE': '00158d000227286e', 'Type': 'Temp/Humi/Baro', 'ProfileID': {}, 'ZDeviceID': {}}
c2d6 : {'Ep': {'01': {'0000': {}, '0405': 78.1, '0403': 2.792677408856994e+133, '0402': 23.9, '0003': {}, 'ffff': {}}}, 'Status': 'inDB', 'Heartbeat': '39397', 'RIA': '13', 'Battery': {}, 'Model': 'lumi.weather', 'MacCapa': '80', 'IEEE': '00158d0002271cdb', 'Type': 'Temp/Humi/Baro', 'ProfileID': '0104', 'ZDeviceID': '5f01'}
8c6a : {'Ep': {'01': {'0000': {}, '0402': 7.2, '0405': 95.5, '0403': 3.5587660762785204e+222}}, 'Status': 'inDB', 'Heartbeat': '39396', 'RIA': '541', 'Battery': {}, 'Model': 'lumi.weather', 'MacCapa': '80', 'IEEE': '00158d0002271565', 'Type': 'Temp/Humi/Baro', 'ProfileID': {}, 'ZDeviceID': {}}
9eef : {'Ep': {'01': {'0000': {}, '0402': 9.1, '0405': 85.5, '0403': 3.562296093726906e+222, '0003': {}, 'ffff': {}}}, 'Status': 'inDB', 'Heartbeat': '39397', 'RIA': '460', 'Battery': {}, 'Model': 'lumi.weather', 'MacCapa': '80', 'IEEE': '00158d0002272867', 'Type': 'Temp/Humi/Baro', 'ProfileID': '0104', 'ZDeviceID': '5f01'}
d0b8 : {'Ep': {'01': {'0000': {}, '0006': {}, '0003': {}, 'ffff': {}}}, 'Status': 'inDB', 'Heartbeat': '39397', 'RIA': '62', 'Battery': 104, 'Model': 'lumi.sensor_magnet.aq2', 'MacCapa': '80', 'IEEE': '00158d0001b91bb3', 'Type': 'Door', 'ProfileID': '0104', 'ZDeviceID': '5f01'}
bd37 : {'Ep': {'01': {'0000': {}, '0006': '00'}}, 'Status': 'inDB', 'Heartbeat': '39396', 'RIA': '117', 'Battery': {}, 'Model': 'lumi.sensor_magnet.aq2', 'MacCapa': '80', 'IEEE': '00158d0001de66c1', 'Type': 'Door', 'ProfileID': {}, 'ZDeviceID': {}}
3a81 : {'Ep': {'01': {'0000': {}, '0006': '01'}}, 'Status': 'inDB', 'Heartbeat': '39396', 'RIA': '183', 'Battery': {}, 'Model': 'lumi.sensor_magnet.aq2', 'MacCapa': '80', 'IEEE': '00158d0001e42e4e', 'Type': 'Door', 'ProfileID': {}, 'ZDeviceID': {}}
8db2 : {'Ep': {'01': {'0000': {}, '0402': 23.4, '0405': 37.8, '0403': 3.3794515539803967e+157, '0003': {}, 'ffff': {}}}, 'Status': 'inDB', 'Heartbeat': '39399', 'RIA': '783', 'Battery': 100, 'Model': {}, 'MacCapa': '80', 'IEEE': '00158d0002271cdb', 'Type': 'Temp/Humi/Baro/', 'ProfileID': '0104', 'ZDeviceID': '5f01'}
49c5 : {'Ep': {'01': {'0000': {}, '0006': {}}}, 'Status': 'inDB', 'Heartbeat': '39396', 'RIA': '4', 'Battery': 102, 'Model': 'lumi.sensor_magnet.aq2', 'MacCapa': '80', 'IEEE': '00158d000274ffed', 'Type': 'Door', 'ProfileID': {}, 'ZDeviceID': {}}
c2fb : {'Ep': {'01': {'0000': {}, '0003': {}, 'ffff': {}, '0006': '00'}}, 'Status': 'inDB', 'Heartbeat': '39412', 'RIA': '74', 'Battery': {}, 'Model': 'lumi.sensor_magnet.aq2', 'MacCapa': '80', 'IEEE': '00158d000274ffed', 'Type': 'Door', 'ProfileID': '0104', 'ZDeviceID': '5f01'}
