Page 6 sur 12
Re: Perte de connexion vers volets roulants Legrand Netatmo
Publié : 03 févr. 2020, 09:26
par Wolfen38
Ok donc comme pas le hub je peux pas.
Je vais déjà mettre le reste a jour
Publié : 03 févr. 2020, 12:24
par Wolfen38
Alors, j'ai fait un git pull, suivi d'un checout beta.
Au redémarrage de dz, j'ai ca :
2020-02-03 12:21:31.008 Status: (Zigate) load ListOfDevice
2020-02-03 12:21:31.010 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/./DeviceList-11.txt : 0
2020-02-03 12:21:31.016 Status: (Zigate) Check for Web update finished!
2020-02-03 12:21:31.016 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2020-02-03 12:21:31.020 Status: (Zigate) ZigateConf - Setting UTC Time to : 634047691
2020-02-03 12:21:31.021 Status: (Zigate) Start network
2020-02-03 12:21:31.021 Status: (Zigate) Zigate enter in discover mode for 0 Secs
2020-02-03 12:21:31.256 Status: Python EventSystem: Initalizing event module.
2020-02-03 12:21:31.257 Status: EventSystem: Started
2020-02-03 12:21:31.257 Status: EventSystem: Queue thread started...
2020-02-03 12:21:31.273 Status: (Zigate) Major Version Num: 0003
2020-02-03 12:21:31.274 Status: (Zigate) Installer Version Number: 030f
2020-02-03 12:21:31.382 Status: (Zigate) Decode8015 : Number of devices recently active in Zigate = 30
2020-02-03 12:21:31.382 Status: (Zigate) Decode8015 : [00] DevID = 00 Network addr = 0503 IEEE = 00158d0001f41a12 RSSI = 097 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.383 Status: (Zigate) Decode8015 : [01] DevID = 01 Network addr = a2c0 IEEE = 00158d00016d8632 RSSI = 134 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.383 Status: (Zigate) Decode8015 : [02] DevID = 02 Network addr = 598a IEEE = 00158d00019ca947 RSSI = 071 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.383 Status: (Zigate) Decode8015 : [03] DevID = 03 Network addr = c418 IEEE = 00158d0002499f62 RSSI = 098 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.383 Status: (Zigate) Decode8015 : [04] DevID = 04 Network addr = d801 IEEE = 00158d0002d4870e RSSI = 075 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.383 Status: (Zigate) Decode8015 : [05] DevID = 05 Network addr = 5f53 IEEE = 00158d0001b12866 RSSI = 072 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.383 Status: (Zigate) Decode8015 : [06] DevID = 06 Network addr = 9a8a IEEE = 00158d00016d7de2 RSSI = 055 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.384 Status: (Zigate) Decode8015 : [07] DevID = 07 Network addr = c924 IEEE = 00158d00016c0b11 RSSI = 065 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.389 Status: (Zigate) Decode8015 : [08] DevID = 08 Network addr = ef3d IEEE = 00158d000323fd5e RSSI = 069 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.390 Status: (Zigate) Decode8015 : [09] DevID = 09 Network addr = ad57 IEEE = 00158d000247fe53 RSSI = 128 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.391 Status: (Zigate) Decode8015 : [10] DevID = 0a Network addr = 0c9e IEEE = 00158d0001a922fc RSSI = 084 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.391 Status: (Zigate) Decode8015 : [11] DevID = 0b Network addr = c454 IEEE = 00158d0001d6a9af RSSI = 051 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.391 Status: (Zigate) Decode8015 : [12] DevID = 0c Network addr = 5ec8 IEEE = 00158d0001ab1e15 RSSI = 125 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.391 Status: (Zigate) Decode8015 : [13] DevID = 0e Network addr = 3385 IEEE = 00158d00019dcd87 RSSI = 101 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.392 Status: (Zigate) Decode8015 : [14] DevID = 0f Network addr = 3f2c IEEE = 00158d00016bfcdd RSSI = 137 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.392 Status: (Zigate) Decode8015 : [15] DevID = 10 Network addr = f56e IEEE = 00158d0001d61fd2 RSSI = 108 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.392 Status: (Zigate) Decode8015 : [16] DevID = 12 Network addr = e4e0 IEEE = 00158d00016d7ee4 RSSI = 087 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.392 Status: (Zigate) Decode8015 : [17] DevID = 14 Network addr = 0947 IEEE = 00158d0001dcb5d7 RSSI = 051 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.392 Status: (Zigate) Decode8015 : [18] DevID = 16 Network addr = 996c IEEE = 00158d00019ca979 RSSI = 140 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.392 Status: (Zigate) Decode8015 : [19] DevID = 17 Network addr = 772f IEEE = 00158d0001e45091 RSSI = 090 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.393 Status: (Zigate) Decode8015 : [20] DevID = 18 Network addr = f00d IEEE = 00158d0001dbc895 RSSI = 040 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.393 Status: (Zigate) Decode8015 : [21] DevID = 19 Network addr = ec9b IEEE = 00158d0002286922 RSSI = 062 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.393 Status: (Zigate) Decode8015 : [22] DevID = 28 Network addr = 7304 IEEE = 000d6ffffe2dda40 RSSI = 063 Power = 01 not found in ListOfDevices
2020-02-03 12:21:31.393 Status: (Zigate) Decode8015 : [23] DevID = 29 Network addr = 3a03 IEEE = 00047400008aed69 RSSI = 060 Power = 01 not found in ListOfDevices
2020-02-03 12:21:31.393 Status: (Zigate) Decode8015 : [24] DevID = 2a Network addr = 1696 IEEE = 000d6ffffe2fe576 RSSI = 052 Power = 01 not found in ListOfDevices
2020-02-03 12:21:31.394 Status: (Zigate) Decode8015 : [25] DevID = 2b Network addr = c1c2 IEEE = 00047400008aaa9a RSSI = 110 Power = 01 not found in ListOfDevices
2020-02-03 12:21:31.394 Status: (Zigate) Decode8015 : [26] DevID = 2c Network addr = 7622 IEEE = 00047400008aaad6 RSSI = 078 Power = 01 not found in ListOfDevices
2020-02-03 12:21:31.394 Status: (Zigate) Decode8015 : [27] DevID = 2d Network addr = 12e4 IEEE = 00047400008aed61 RSSI = 078 Power = 01 not found in ListOfDevices
2020-02-03 12:21:31.394 Status: (Zigate) Decode8015 : [28] DevID = 2e Network addr = dfd8 IEEE = 00047400008aac16 RSSI = 128 Power = 01 not found in ListOfDevices
2020-02-03 12:21:31.394 Status: (Zigate) Decode8015 : [29] DevID = 2f Network addr = aa25 IEEE = 00047400008af27c RSSI = 042 Power = 01 not found in ListOfDevices
2020-02-03 12:21:38.236 Status: Netatmo: No Weather Station devices found...
2020-02-03 12:21:40.425 (Thermostat) General/Percentage (Thermostat batterie)
2020-02-03 12:21:40.451 (Thermostat) Temp (Thermostat Température)
2020-02-03 12:21:40.465 (Thermostat) Thermostat (Thermostat Réglage)
2020-02-03 12:21:41.283 (Zigate) Start Network status : Success
2020-02-03 12:21:41.385 (Zigate) Ping - received
2020-02-03 12:21:41.181 Status: (Zigate) Decode8009 : Zigate addresses ieee: 00158d0001eded91 , short addr: 0000
2020-02-03 12:21:41.181 Status: (Zigate) Decode8009 - Network state UP, PANID: dd89 extPANID: 0xbbb048ca88a57dfa Channel: 11
2020-02-03 12:21:41.385 Status: (Zigate) Permit Join is On
2020-02-03 12:21:54.004 Error: OpenZWave: Driver Failed!!
2020-02-03 12:21:56.160 Error: (Zigate) Decode8102 - Receiving a message from unknown device : f56e with Data : b0f56e010000ff0200420013100121a60b21a81324010000000021d3002060
2020-02-03 12:22:01.386 Error: (Zigate) Decode8102 - Receiving a message from unknown device : 1696 with Data : 58169601000600000010000100
Ca fait un peu peur, j'ai l'impression que ca dit qu'il trouve aucun device....
Et maintenant, quand je refait un git pull, ca me dit ca
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigate $ git pull
Pas d'information de suivi distant pour la branche actuelle.
Veuillez spécifier une branche avec laquelle fusionner.
Référez-vous à git-pull(1) pour de plus amples détails.
git pull <distant> <branche>
Si vous souhaitez indiquer l'information de suivi distant pour cette branche, vous pouvez le faire avec :
git branch --set-upstream-to=origin/<branche> beta
A chaque fois que j'ai tenté la beta, j'ai eu des galères... c'est pour ca que je repassai systématiquement en stable.... Je comprends pas toutes ces erreurs
Publié : 03 févr. 2020, 13:06
par pipiche
Comment fais-tu pour passer sur la branche bêta ?
Publié : 03 févr. 2020, 13:07
par Wolfen38
Git checkout beta
Publié : 03 févr. 2020, 13:08
par pipiche
Et comment le plugins a-t-il été installé?
Publié : 03 févr. 2020, 13:11
par Wolfen38
Ça depuis le temps je me rappelle plus du tout.
J'avais du suivre un tuto sur github je pense
Publié : 03 févr. 2020, 13:13
par pipiche
Et quand tu as fait le git checkout beta il n’y a pas eu d’erreur?
Publié : 03 févr. 2020, 13:15
par Wolfen38
Non,
par contre en relancant dz ca me marquait version beta 4.1, donc j'ai voulu faire un git pull a nouveau, et la ca marquait le message que j'ai ecrit plus haut
Publié : 03 févr. 2020, 13:16
par pipiche
Ah mon avis t’es sur un truc complètement désynchronisé .
Il faudrait que tu repartes d’un git clone frais et récent
Il faudra simplement que tu recopies les répertoires Conf et Data de la version stable
Publié : 03 févr. 2020, 13:18
par Wolfen38
Et tu vois comment le régler ?
