pour faire suite à mon précedent post, voici mes logs
2019-03-09 10:08:26.062 Status: (Zigate) Entering work loop.
2019-03-09 10:08:26.062 Status: (Zigate) Initialized version 4.0.8, author 'zaraki673 pipiche38'
2019-03-09 10:08:26.114 Status: (Zigate) onStart called - Zigate plugin V 4.0.8
2019-03-09 10:08:26.114 Status: (Zigate) load PluginConf
2019-03-09 10:08:26.115 Status: (Zigate) ZigateMode: ZigBee sendDelay: 0 reTransmit: 1 zTimeOut: 2
2019-03-09 10:08:26.115 Status: (Zigate) logFORMAT: 0 logLQI: 0 allowRemoveZigateDevice: 0
2019-03-09 10:08:26.115 Status: (Zigate) allowStoreDiscoveryFrames: 0 forceCreationDevice: 0 networkScan: 0 channel: ['0']
2019-03-09 10:08:26.122 Status: (Zigate) load ListOfDevice
2019-03-09 10:08:26.123 Status: (Zigate) Entries loaded from /usr/local/domoticz/var/plugins/Domoticz-Zigate/DeviceList-8.txt : 0
2019-03-09 10:08:26.123 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2019-03-09 10:08:26.124 Status: (Zigate) onConnect called
2019-03-09 10:08:26.124 Status: (Zigate) ZigateConf - Setting UTC Time to : 1552122506
2019-03-09 10:08:26.124 Status: (Zigate) Start network
2019-03-09 10:08:26.124 Status: (Zigate) Zigate enter in discover mode for ever
2019-03-09 10:08:26.125 Status: (Zigate) ZLL Touch Link Reset
[Béta]Plugin Zigate USB + Wifi
Re: [Béta]Plugin Zigate USB + Wifi
Si il y a des pros du synology, je les laisserai répondre, mais du point de vue du plugin,Beaupigny a écrit : 09 mars 2019, 10:10 Bonjour,
- Ouverture du port série/USB semble OK. SInon Domoticz aurait rallé
- Il semble que les envoies de commandes sont effectuées , mais aucun retour.
La commande lsusb donne cela comme réponse:
admin@DiskStation:/$ lsusb Bus 004 Device 014: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 rootRe: [Béta]Plugin Zigate USB + Wifi
Sur les Syno il faut ajouter le driver USB serie pour voir la Zigate et autres devices USB qui ne sont pas media de stockages.
cf : http://www.jadahl.com/drivers_6.2/
c'est également lui qui fournit les packages Domoticz pour syno
