[LUA] Vigicrue
ebretteville
Re: [LUA] Vigicrue
Message par ebretteville »
Est-ce moi mais malgré le passage a
-- Parameters to change according to you needs
debug=false
J'ai toujours les notifications dans telegram.
chatainsim
Re: [LUA] Vigicrue
Message par chatainsim »
Le debug à false affiche juste moins d'infos dans les logs de domoticz.
Il faut commenter la ligne 56 : commandArray['SendNotification'] pour ne plus avoir les notifications
ebretteville
Re: [LUA] Vigicrue
Ligne 76 plutôt non?!
debug=false
-- Json config loadfile
config = '/home/pi/domoticz/scripts/vigicrue/vigicrue.json'
-- for Windows
-- config = 'C:\\Program Files (x86)\\Domoticz\\scripts\\vigicrue.json'
-- JSON.lua path
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
-- for Windows
--json = (loadfile "C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\JSON.lua")()
-- Curl path
curl = '/usr/bin/curl'
-- for Windows
-- curl = 'C:\\cygwin\\bin\\curl'
-- End of parameters
time = os.date("*t")
-- Function to update sensor
local function update(idx, value1)
    local cmd = idx..'|0|'..value1
    --print(cmd)
    table.insert (commandArray, { ['UpdateDevice'] = cmd } )
local function sendnotif(station, result, type, channel)
    if (type == "height") then
        local cmd = 'Water level is high for station '..station..'#Current level is '..result..'m for'..station..'#0#sound#extradata#'..channel
        if (debug) then print("NotifHeight: "..cmd) end
    elseif (type == "speed") then
        local cmd = 'Water speed level is high for station '..station..'#Current speed level: '..result..'m3/s for '..station..'#0#sound#extradata#'..channel
        if (debug) then print("NotifSpeed: "..cmd) end
    table.insert (commandArray, { ['SendNotification'] = "cmd" } )
    if (debug) then print("Notif: Sent") end
-- function to get data from url
local function getdata(urlh,urls)
    local DataHeight = assert(io.popen(curl..' -s "'..urlh..'"'))
    local BlocJsonHeight = DataHeight:read('*all')
    DataHeight:close()
    local JsonHeight = json:decode(BlocJsonHeight)
    local Height = JsonHeight.Serie.ObssHydro
    local Name = JsonHeight.Serie.LbStationHydro
    local DataSpeed = assert(io.popen(curl..' -s "'..urls..'"'))
    local BlocJsonSpeed = DataSpeed:read('*all')
    DataSpeed:close()
    local JsonSpeed = json:decode(BlocJsonSpeed)
    local Speed = JsonSpeed.Serie.ObssHydro
    return Height, Speed, Name
if (time.min == 0 or time.min == 30) then
    local file = assert(io.open(config, "r"))
    local json_text = file:read("*all")
    file:close()
    local Conf = json:decode(json_text)
    Station = Conf.station
    for k,v in pairs(Station) do
        local IDStation = v
        local IDXHeight = Conf.idx.height[v]
        local IDXSpeed = Conf.idx.speed[v]
        local NotifHeightV = Conf.notifications.height[v].value
        local NotifHeightA = Conf.notifications.height[v].active
        local NotifSpeedV = Conf.notifications.speed[v].value
        local NotifSpeedA = Conf.notifications.speed[v].active
        local urlHeight = 'https://www.vigicrues.gouv.fr/services/observations.json/index.php?CdStationHydro='..IDStation..'&GrdSerie=H&FormatSortie=simple'
        local urlSpeed = 'https://www.vigicrues.gouv.fr/services/observations.json/index.php?CdStationHydro='..IDStation..'&GrdSerie=Q&FormatSortie=simple'
        ResultHeight,ResultSpeed,StationName=getdata(urlHeight,urlSpeed)
        if (#ResultHeight ~= 0) then
                if (debug) then print("ResultHeight: "..ResultHeight[#ResultHeight][2]) end
                update(IDXHeight, ResultHeight[#ResultHeight][2])
                if (NotifHeightA == "true") then
                    if (tostring(ResultHeight[#ResultHeight][2]) > NotifHeightV) then
			table.insert(commandArray, {['SendNotification'] = 'Water level is high for station '..StationName..'#Current level is '..ResultHeight[#ResultHeight][2]..'m for '..StationName..'#0#sound#extradata#telegram'})
                if (debug) then print('Height level is empty.') end
        if (#ResultSpeed ~= 0) then
                if (debug=true) then print("ResultSpeed: "..ResultSpeed[#ResultSpeed][2]) end
                update(IDXSpeed, ResultSpeed[#ResultSpeed][2])
                if (NotifSpeedA == "true") then
                    if (tostring(ResultSpeed[#ResultSpeed][2]) > NotifSpeedV) then
			table.insert(commandArray, {['SendNotification'] = 'Water speed level is high for station '..StationName..'#Current speed level: '..ResultSpeed[#ResultSpeed][2]..'m3/s for '..StationName..'#0#sound#extradata#telegram'})
                if (debug=true) then print('Speed is empty.') end
ebretteville
Re: [LUA] Vigicrue
chatainsim a écrit : 12 oct. 2021, 14:08 Le debug à false affiche juste moins d'infos dans les logs de domoticz.
J'ai une vieille version....
chatainsim
Re: [LUA] Vigicrue
C'est dans le fichier vigicrue.json qu'il faut faire les modifs du coup
Mettre active a false
ebretteville
Re: [LUA] Vigicrue
debug=true
-- Station ID, from one to many
Station = {'K490003010'}
-- IDX of sensor for height value | STATION_ID='IDX_SENSOR'
SIDXHeight = {K490003010='439'} -- SIDXHeight = {K490003010='215', L800001020='218'}
-- IDX of sensor for speed value | STATION_ID='IDX_SENSOR'
SIDXSpeed = {K490003010='440'}
-- JSON.lua path
-- Curl path
    --print(cmd)
    DataHeight:close()
    DataSpeed:close()
local function test_error(url)
    local DataTest = assert(io.popen(curl..' -s --max-time 8 "'..url..'"'))
    local BlocJsonTest = DataTest:read('*all')
    DataTest:close()
    JsonTest = json:decode(BlocJsonTest)
    Test = JsonTest[1].error_msg
        local IDStation = v
        local IDXHeight = SIDXHeight[v]
        local IDXSpeed = SIDXSpeed[v]
        local status, retval = pcall(test_error,urlHeight);
        if (status) then
            print("Error, station inconnu")
           commandArray['SendNotification']='subject#Erreur, station '..IDStation..' inconnu ou problème temporaire du site Vigicrue, merci de vérifier : '..urlHeight..'#0#sound#extradata#telegram'
            ResultHeight,ResultSpeed=getdata(urlHeight,urlSpeed)
                if (debug) then print("ResultSpeed: "..ResultSpeed[#ResultSpeed][2]) end
                if (debug) then print('Speed is empty.') end
Voilà le code et je ne comprends pas, pas d'erreurs dans les logs, mais mes devices ne sont pas updatés
ebretteville
Re: [LUA] Vigicrue
Un petit up car j'ai tenté le passage à vigicrue v2 et je n'arrive plus à faire fonctionner l'outil. Les idx sont à jours, l'id station actualisé (j'en ai qu'une à suivre, peut-être la syntaxe indiqué dans mon message précédent est inadapté), l'arborsecence pour le fichier LUA.json est actualisé.
Je ne vois pas ce qui peut ne pas fonctionner
chatainsim
Re: [LUA] Vigicrue
A priori tu avais bien déjà la V2, non ?
celle ci : https://github.com/chatainsim/scripts_d ... icrue2.lua
Pas d'erreur dans les logs ?
as tu activé le mode debug ?
Après, je ne m'en sert plus depuis un moment.
Il faut que je replonge dans le code pour voir ce si côté vigicrue, leurs données ont changées.
ebretteville
Re: [LUA] Vigicrue
j'étais sans doutes sur la v1, non pas forcément d'erreurs dans les logs malgré les debug=true.
Je reste en vigilance sur le fil. Ce plugin lua en bord de rivière pour moi est un vrai plus j'avoue. Bravo pour le boulot
chatainsim
Re: [LUA] Vigicrue
Je viens de faire l'essai avec ta station et je n'ai pas de problème.
debug=true
SIDXHeight = {K490003010='610'}
SIDXSpeed = {K490003010='609'}
-- JSON.lua path
-- Curl path
    --print(cmd)
    DataHeight:close()
    DataSpeed:close()
    DataTest:close()
        local IDStation = v
        if (status) then
Est-ce que le chemin vers le fichier JSON.lua est le bon ?
Les IDX sont corrects ?
Edit: je viens de voir une erreur dans ton script :
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() <-- il te manque les deux parenthèses en fin de ligne
