[RESOLU] Le webserveur ne demarre plus
Publié : 22 oct. 2020, 17:59
par olicot
j'ai remarque que le webserveur du plugin ne redémarre plus
peut-être après maj de l'OS, Domoticz (actuellement branche beta Version: 2020.2 (build 12496)) et plugin...
L'interface remonte en echec "La connexion a échoué", que ce soit sur une branche stable ou de dev
Le plugin fonctionne étant donné que les sondes renvoient des infos
(exemple :
2020-10-22 17:48:23.005 (zigate) Device Name: 'CHA3 - BARO'
2020-10-22 17:48:23.005 (zigate) Device nValue: 0
2020-10-22 17:48:23.005 (zigate) Device sValue: '989.5;4'
2020-10-22 17:48:23.005 (zigate) Device LastLevel: 0
2020-10-22 17:48:23.005 (zigate) Device Options: {}
Voici un extrait de la log démarrage
2020-10-22 17:48:11.307 Status: (zigate) Started.
2020-10-22 17:48:12.963 Status: (zigate) Entering work loop.
2020-10-22 17:48:12.964 Status: (zigate) Initialized version 4.11, author 'zaraki673 pipiche38'
2020-10-22 17:48:22.989 Status: (zigate) Zigate plugin stable-4.11.007 started
2020-10-22 17:48:22.990 Status: (zigate) Debug: -1
2020-10-22 17:48:23.006 (zigate) DomoticzVersion: 2020.2 (build 12496)
2020-10-22 17:48:23.006 Status: (zigate) load PluginConf
2020-10-22 17:48:23.010 Status: (zigate) enableReadAttributes set to 1
2020-10-22 17:48:23.010 Status: (zigate) channel set to 11
2020-10-22 17:48:23.011 Status: (zigate) filename set to /opt/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-81.json
2020-10-22 17:48:23.011 Status: (zigate) pluginHome set to /opt/domoticz/plugins/Domoticz-Zigate/
2020-10-22 17:48:23.011 Status: (zigate) homedirectory set to /opt/domoticz/plugins/Domoticz-Zigate/
2020-10-22 17:48:23.011 Status: (zigate) pluginData set to /opt/domoticz/plugins/Domoticz-Zigate/Data/
2020-10-22 17:48:23.011 Status: (zigate) pluginConfig set to /opt/domoticz/plugins/Domoticz-Zigate/Conf/
2020-10-22 17:48:23.011 Status: (zigate) pluginOTAFirmware set to /opt/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-10-22 17:48:23.011 Status: (zigate) pluginReports set to /opt/domoticz/plugins/Domoticz-Zigate/Reports/
2020-10-22 17:48:23.011 Status: (zigate) pluginWWW set to /opt/domoticz/plugins/Domoticz-Zigate/www/
2020-10-22 17:48:23.012 Status: (zigate) pluginLogs set to /opt/domoticz/plugins/Domoticz-Zigate/Logs/
2020-10-22 17:48:23.012 Status: (zigate) Switching Heartbeat to 5 s interval
2020-10-22 17:48:23.012 Status: (zigate) Python Version - 3.7.3 (default, Jul 25 2020, 13:03:44)
2020-10-22 17:48:23.012 Status: (zigate) DomoticzVersion: 2020.2 (build 12496)
2020-10-22 17:48:23.012 Status: (zigate) DomoticzHash: f18fc9720-modified
2020-10-22 17:48:23.013 Status: (zigate) DomoticzBuildTime: 2020-10-21 12:12:39
2020-10-22 17:48:23.013 Status: (zigate) Opening DomoticzDB in raw
2020-10-22 17:48:23.028 Status: (zigate) Plugin Database: DeviceList-81.txt
2020-10-22 17:48:23.044 Status: (zigate) DeviceConf loaded
2020-10-22 17:48:23.201 Status: (zigate) load ListOfDevice
2020-10-22 17:48:23.680 Status: (zigate) Entries loaded from /opt/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-81.txt
2020-10-22 17:48:23.694 Status: (zigate) Transport mode: USB
2020-10-22 17:48:23.694 Status: (zigate) ==> Transport Mode: auto
2020-10-22 17:48:23.703 Status: (zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A6007v70-if00-port0
2020-10-22 17:48:23.703 Status: (zigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A6007v70-if00-port0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
je cherche depuis hier soir, je relance le plugin, Domoticz, mais je ne trouve pas d'erreur dans les log
Des idées?
ou comment avoir plus de log afin de trouver une piste ?
MErci par avance,
Olivier
Re: Le webserveur ne demarre plus
Publié : 22 oct. 2020, 18:25
par pipiche
merci de me donner plus de logs. là je vois bien la 1ere partie du démarrage mais rien après .. Si les sondes ernvoient des infos, ca doit etre également dans les logs !
N'auriez vous pas fait un Erase EEPROM en faisant le flash du firmware en 31d ?
Publié : 22 oct. 2020, 20:14
par olicot
Alors , je n'ai pas (encore) mis à jour la zigate, je suis toujours en 31C
Je viens de relancer Domoticz (cf log ci-dessous) mais je ne constate pas d'erreur concerant le plugin zigate
J'ai egalment désactivé une partie de plugin ,
mais toujours pas d'interface webserver pour le plugin Zigate :-(
2020-10-22 20:08:10.824  Status: Domoticz V2020.2 (build 12496) (c)2012-2020 GizMoCuz
2020-10-22 20:08:10.825  Status: Build Hash: f18fc9720-modified, Date: 2020-10-21 12:12:39
2020-10-22 20:08:10.825  Status: Startup Path: /opt/domoticz/
2020-10-22 20:08:10.882  Sunrise: 08:16:00 SunSet: 18:58:00
2020-10-22 20:08:10.882  Day length: 10:41:00 Sun at south: 13:37:00
2020-10-22 20:08:10.882  Civil twilight start: 07:47:00 Civil twilight end: 19:27:00
2020-10-22 20:08:10.882  Nautical twilight start: 07:13:00 Nautical twilight end: 20:00:00
2020-10-22 20:08:10.882  Astronomical twilight start: 06:40:00 Astronomical twilight end: 20:33:00
2020-10-22 20:08:11.042  Status: PluginSystem: Started, Python version '3.7.3'.
2020-10-22 20:08:11.052  Active notification Subsystems: http, kodi, lms (3/13)
2020-10-22 20:08:11.062  Status: WebServer(HTTP) started on address: :: with port 8080
2020-10-22 20:08:11.158  Status: WebServer(SSL) started on address: :: with port 443
2020-10-22 20:08:11.164  Status: Camera: settings (re)loaded
2020-10-22 20:08:11.166  Starting shared server on: :::6144
2020-10-22 20:08:11.167  Status: TCPServer: shared server started...
2020-10-22 20:08:11.167  Status: RxQueue: queue worker started...
2020-10-22 20:08:13.168  Status: (MA_teleinfo) Teleinfo device uses serial port: /dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller-if00-port0 at 1200 bauds
2020-10-22 20:08:13.178  Status: (MA_teleinfo) CRC checks will be performed on incoming data
2020-10-22 20:08:13.180  Status: XiaomiGateway (ID=23): Delaying worker startup...
2020-10-22 20:08:13.382  Status: RFLink: Using serial port: /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_8553130393035181C191-if00
2020-10-22 20:08:13.388  (MA_RFLink) Temp + Humidity (CHA2 - TEMP)
2020-10-22 20:08:13.391  (MA_RFLink) Temp (Auriol)
2020-10-22 20:08:13.393  (MA_RFLink) Temp + Humidity (CHA1 - TEMP)
2020-10-22 20:08:14.307  Status: RFLink: Controller Initialized!...
2020-10-22 20:08:14.383  Status: RFLink Detected, Version: 1.1 Revision: 48 Build: 4
2020-10-22 20:08:15.940  (MA_RFLink) Temp + Humidity (CHA3 - TEMP)
2020-10-22 20:08:16.579  (MA_RFLink) Wind (Alecto V1)
2020-10-22 20:08:18.180  Status: XiaomiGateway (ID=23): Selected as main Gateway
2020-10-22 20:08:18.181  Status: XiaomiGateway (ID=23): Worker started...
2020-10-22 20:08:18.182  Status: Kodi: Started
2020-10-22 20:08:18.187  Status: (KodiAZWPlayer) Started.
2020-10-22 20:08:18.188  Status: Logitech Media Server: Worker started...
2020-10-22 20:08:18.188  Status: (zigate) Started.
2020-10-22 20:08:18.189  Status: XiaomiGateway (ID=23): Using 192.168.1.100 for local IP address.
2020-10-22 20:08:18.189  Status: Logitech Media Server: 5 player-switch(es) found.
2020-10-22 20:08:18.190  Status: EventSystem: reset all events...
2020-10-22 20:08:18.190  Status: NotificationSystem: thread started...
2020-10-22 20:08:18.195  Status: EventSystem: reset all device statuses...
2020-10-22 20:08:18.246  Status: Logitech Media Server: 17 playlist(s) found.
2020-10-22 20:08:18.283  Kodi: (azw) Starting thread.
2020-10-22 20:08:18.383  Kodi: Starting I/O service thread.
2020-10-22 20:08:18.390  Status: PluginSystem: Entering work loop.
2020-10-22 20:08:18.559  Status: (KodiAZWPlayer) Entering work loop.
2020-10-22 20:08:18.560  Status: (KodiAZWPlayer) Initialized version 2.6.4, author 'dnpwwo'
2020-10-22 20:08:19.262  Status: Logitech Media Server: 3 connected player(s) found.
2020-10-22 20:08:19.311  Status: (zigate) Entering work loop.
2020-10-22 20:08:19.313  Status: (zigate) Initialized version 4.11, author 'zaraki673  pipiche38'
2020-10-22 20:08:19.330  (KodiAZWPlayer) Update 0:'Screensaver' (KodiAZWPlayer - Status)
2020-10-22 20:08:19.339  (KodiAZWPlayer) Update 0:'0' (KodiAZWPlayer - Source)
2020-10-22 20:08:19.348  (KodiAZWPlayer) Update 0:'100' (KodiAZWPlayer - Volume)
2020-10-22 20:08:19.358  (KodiAZWPlayer) Update 0:'0' (KodiAZWPlayer - Playing)
2020-10-22 20:08:19.369  Logitech Media Server: (SqueezeLite) Disconnected
2020-10-22 20:08:19.373  Error: EventSystem: Could not find device in system: ((ID=0: SqueezeLite)
2020-10-22 20:08:19.374  Status: (zigate) Zigate plugin stable-4.11.007 started
2020-10-22 20:08:19.374  Status: (zigate) Debug: 30
2020-10-22 20:08:19.374  (zigate) Debug Mode: 30, We do recommend to leave Verbors to None
2020-10-22 20:08:19.374  (zigate) 'HardwareID':'81'
2020-10-22 20:08:19.374  (zigate) 'HomeFolder':'/opt/domoticz/plugins/Domoticz-Zigate/'
2020-10-22 20:08:19.374  (zigate) 'StartupFolder':'/opt/domoticz/'
2020-10-22 20:08:19.375  (zigate) 'UserDataFolder':'/opt/domoticz/'
2020-10-22 20:08:19.375  (zigate) 'Database':'/opt/domoticz/domoticz.db'
2020-10-22 20:08:19.375  (zigate) 'Language':'fr'
2020-10-22 20:08:19.375  (zigate) 'Version':'4.11'
2020-10-22 20:08:19.375  (zigate) 'Author':'zaraki673  pipiche38'
2020-10-22 20:08:19.375  (zigate) 'Name':'zigate'
2020-10-22 20:08:19.375  (zigate) 'Address':'0.0.0.0'
2020-10-22 20:08:19.375  (zigate) 'Port':'9999'
2020-10-22 20:08:19.375  (zigate) 'SerialPort':'/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A6007v70-if00-port0'
2020-10-22 20:08:19.375  (zigate) 'Key':'Zigate'
2020-10-22 20:08:19.375  (zigate) 'Mode1':'USB'
2020-10-22 20:08:19.375  (zigate) 'Mode3':'False'
2020-10-22 20:08:19.376  (zigate) 'Mode4':'9440'
2020-10-22 20:08:19.376  (zigate) 'Mode6':'30'
2020-10-22 20:08:19.376  (zigate) 'DomoticzVersion':'2020.2 (build 12496)'
2020-10-22 20:08:19.376  (zigate) 'DomoticzHash':'f18fc9720-modified'
2020-10-22 20:08:19.376  (zigate) 'DomoticzBuildTime':'2020-10-21 12:12:39'
2020-10-22 20:08:19.376  (zigate) Device count: 18
2020-10-22 20:08:19.376  (zigate) Device:           1 - ID: 4680, Name: 'zigate - Zigate Status 81', nValue: 0, sValue: 'Startup'
2020-10-22 20:08:19.376  (zigate) Device ID:       '4680'
2020-10-22 20:08:19.376  (zigate) Device Name:     'zigate - Zigate Status 81'
2020-10-22 20:08:19.376  (zigate) Device nValue:    0
2020-10-22 20:08:19.377  (zigate) Device sValue:   'Startup'
2020-10-22 20:08:19.377  (zigate) Device LastLevel: 0
2020-10-22 20:08:19.377  (zigate) Device Options: {}
2020-10-22 20:08:19.377  (zigate) Device:           2 - ID: 4681, Name: 'zigate - Zigate Notifications 81', nValue: 0, sValue: 'Zigate Channel: 11'
2020-10-22 20:08:19.377  (zigate) Device ID:       '4681'
2020-10-22 20:08:19.377  (zigate) Device Name:     'zigate - Zigate Notifications 81'
2020-10-22 20:08:19.377  (zigate) Device nValue:    0
2020-10-22 20:08:19.377  (zigate) Device sValue:   'Zigate Channel: 11'
2020-10-22 20:08:19.377  (zigate) Device:           3 - ID: 4682, Name: 'EXT1 - LUMI', nValue: 5, sValue: '5'
2020-10-22 20:08:19.378  (zigate) Device ID:       '4682'
2020-10-22 20:08:19.378  (zigate) Device Name:     'EXT1 - LUMI'
2020-10-22 20:08:19.378  (zigate) Device nValue:    5
2020-10-22 20:08:19.378  (zigate) Device sValue:   '5'
2020-10-22 20:08:19.378  (zigate) Device LastLevel: 0
2020-10-22 20:08:19.378  (zigate) Device Options: {}
2020-10-22 20:08:19.378  (zigate) Device:           4 - ID: 4683, Name: 'EXT2 - BAL1 - MOUV', nValue: 1, sValue: 'On'
2020-10-22 20:08:19.378  (zigate) Device ID:       '4683'
2020-10-22 20:08:19.378  (zigate) Device Name:     'EXT2 - BAL1 - MOUV'
2020-10-22 20:08:19.378  (zigate) Device nValue:    1
2020-10-22 20:08:19.378  (zigate) Device sValue:   'On'
2020-10-22 20:08:19.379  (zigate) Device LastLevel: 0
2020-10-22 20:08:19.379  (zigate) Device Options: {}
2020-10-22 20:08:19.379  (zigate) Device:           5 - ID: 4684, Name: 'EXT2 - BAL1 - LUMI', nValue: 0, sValue: '0'
2020-10-22 20:08:19.379  (zigate) Device ID:       '4684'
2020-10-22 20:08:19.379  (zigate) Device Name:     'EXT2 - BAL1 - LUMI'
2020-10-22 20:08:19.379  (zigate) Device nValue:    0
2020-10-22 20:08:19.379  (zigate) Device sValue:   '0'
2020-10-22 20:08:19.379  (zigate) Device:           6 - ID: 4686, Name: 'SAL1 - MOUV', nValue: 0, sValue: 'Off'
2020-10-22 20:08:19.379  (zigate) Device ID:       '4686'
2020-10-22 20:08:19.380  (zigate) Device Name:     'SAL1 - MOUV'
2020-10-22 20:08:19.380  (zigate) Device nValue:    0
2020-10-22 20:08:19.380  (zigate) Device sValue:   'Off'
2020-10-22 20:08:19.380  (zigate) Device LastLevel: 0
2020-10-22 20:08:19.380  (zigate) Device Options: {}
2020-10-22 20:08:19.380  (zigate) Device:           7 - ID: 4687, Name: 'SAL1 - LUMI', nValue: 2, sValue: '2'
2020-10-22 20:08:19.380  (zigate) Device ID:       '4687'
2020-10-22 20:08:19.380  (zigate) Device Name:     'SAL1 - LUMI'
2020-10-22 20:08:19.380  (zigate) Device nValue:    2
2020-10-22 20:08:19.380  (zigate) Device sValue:   '2'
2020-10-22 20:08:19.381  (zigate) Device Options: {}
2020-10-22 20:08:19.381  (zigate) Device:           8 - ID: 4688, Name: 'SAL1 - SWI2', nValue: 0, sValue: ''
2020-10-22 20:08:19.381  (zigate) Device ID:       '4688'
2020-10-22 20:08:19.381  (zigate) Device Name:     'SAL1 - SWI2'
2020-10-22 20:08:19.381  (zigate) Device nValue:    0
2020-10-22 20:08:19.381  (zigate) Device sValue:   ''
2020-10-22 20:08:19.381  (zigate) Device LastLevel: 0
2020-10-22 20:08:19.381  (zigate) Device Options: {'LevelActions': '|||', 'LevelNames': 'One click|Two clicks|Tree clicks|Four+ clicks', 'LevelOffHidden': 'false', 'SelectorStyle': '1'}
2020-10-22 20:08:19.381  (zigate) Device:           9 - ID: 5195, Name: 'zigate - GL-C-008_ColorControlRGBWW-00124b001f7a1572-0b', nValue: 1, sValue: '100'
2020-10-22 20:08:19.381  (zigate) Device ID:       '5195'
2020-10-22 20:08:19.381  (zigate) Device Name:     'zigate - GL-C-008_ColorControlRGBWW-00124b001f7a1572-0b'
2020-10-22 20:08:19.382  (zigate) Device nValue:    1
2020-10-22 20:08:19.382  (zigate) Device sValue:   '100'
2020-10-22 20:08:19.382  (zigate) Device LastLevel: 100
2020-10-22 20:08:19.382  (zigate) Device Options: {}
2020-10-22 20:08:19.382  (zigate) Device:           11 - ID: 4691, Name: 'CHA1 - TEMP', nValue: 19, sValue: '19.2'
2020-10-22 20:08:19.382  (zigate) Device ID:       '4691'
2020-10-22 20:08:19.382  (zigate) Device Name:     'CHA1 - TEMP'
2020-10-22 20:08:19.382  (zigate) Device nValue:    19
2020-10-22 20:08:19.382  (zigate) Device sValue:   '19.2'
2020-10-22 20:08:19.382  (zigate) Device LastLevel: 0
2020-10-22 20:08:19.383  (zigate) Device:           12 - ID: 4692, Name: 'CHA1 - HUMI', nValue: 72, sValue: '3'
2020-10-22 20:08:19.383  (zigate) Device ID:       '4692'
2020-10-22 20:08:19.383  (zigate) Device Name:     'CHA1 - HUMI'
2020-10-22 20:08:19.383  (zigate) Device nValue:    72
2020-10-22 20:08:19.383  (zigate) Device sValue:   '3'
2020-10-22 20:08:19.383  (zigate) Device LastLevel: 0
2020-10-22 20:08:19.383  (zigate) Device Options: {}
2020-10-22 20:08:19.383  (zigate) Device:           13 - ID: 4693, Name: 'CHA1 - BARO', nValue: 0, sValue: '989.3;4'
2020-10-22 20:08:19.383  (zigate) Device ID:       '4693'
2020-10-22 20:08:19.383  (zigate) Device Name:     'CHA1 - BARO'
2020-10-22 20:08:19.383  (zigate) Device nValue:    0
2020-10-22 20:08:19.384  (zigate) Device sValue:   '989.3;4'
2020-10-22 20:08:19.384  (zigate) Device LastLevel: 0
2020-10-22 20:08:19.384  (zigate) Device Options: {}
2020-10-22 20:08:19.384  (zigate) Device:           16 - ID: 4696, Name: 'CHA2 - TEMP', nValue: 18, sValue: '18.0'
2020-10-22 20:08:19.384  (zigate) Device ID:       '4696'
2020-10-22 20:08:19.384  (zigate) Device Name:     'CHA2 - TEMP'
2020-10-22 20:08:19.384  (zigate) Device nValue:    18
2020-10-22 20:08:19.384  (zigate) Device sValue:   '18.0'
2020-10-22 20:08:19.384  (zigate) Device:           17 - ID: 4697, Name: 'CHA2 - HUMI', nValue: 70, sValue: '3'
2020-10-22 20:08:19.385  (zigate) Device ID:       '4697'
2020-10-22 20:08:19.385  (zigate) Device Name:     'CHA2 - HUMI'
2020-10-22 20:08:19.385  (zigate) Device nValue:    70
2020-10-22 20:08:19.385  (zigate) Device sValue:   '3'
2020-10-22 20:08:19.385  (zigate) Device LastLevel: 0
2020-10-22 20:08:19.385  (zigate) Device Options: {}
2020-10-22 20:08:19.385  (zigate) Device:           18 - ID: 4698, Name: 'CHA2 - BARO', nValue: 0, sValue: '988.7;4'
2020-10-22 20:08:19.385  (zigate) Device ID:       '4698'
2020-10-22 20:08:19.385  (zigate) Device Name:     'CHA2 - BARO'
2020-10-22 20:08:19.385  (zigate) Device nValue:    0
2020-10-22 20:08:19.385  (zigate) Device sValue:   '988.7;4'
2020-10-22 20:08:19.386  (zigate) Device LastLevel: 0
2020-10-22 20:08:19.386  (zigate) Device Options: {}
2020-10-22 20:08:19.386  (zigate) Device:           21 - ID: 4701, Name: 'CHA3 - TEMP', nValue: 19, sValue: '19.6'
2020-10-22 20:08:19.386  (zigate) Device ID:       '4701'
2020-10-22 20:08:19.386  (zigate) Device Name:     'CHA3 - TEMP'
2020-10-22 20:08:19.386  (zigate) Device nValue:    19
2020-10-22 20:08:19.386  (zigate) Device sValue:   '19.6'
2020-10-22 20:08:19.386  (zigate) Device:           22 - ID: 4702, Name: 'CHA3 - HUMI', nValue: 68, sValue: '1'
2020-10-22 20:08:19.386  (zigate) Device ID:       '4702'
2020-10-22 20:08:19.386  (zigate) Device Name:     'CHA3 - HUMI'
2020-10-22 20:08:19.387  (zigate) Device nValue:    68
2020-10-22 20:08:19.387  (zigate) Device sValue:   '1'
2020-10-22 20:08:19.387  (zigate) Device LastLevel: 0
2020-10-22 20:08:19.387  (zigate) Device Options: {}
2020-10-22 20:08:19.387  (zigate) Device:           23 - ID: 4703, Name: 'CHA3 - BARO', nValue: 0, sValue: '989.5;4'
2020-10-22 20:08:19.387  (zigate) Device ID:       '4703'
2020-10-22 20:08:19.387  (zigate) Device Name:     'CHA3 - BARO'
2020-10-22 20:08:19.387  (zigate) Device nValue:    0
2020-10-22 20:08:19.387  (zigate) Device sValue:   '989.5;4'
2020-10-22 20:08:19.387  (zigate) DomoticzVersion: 2020.2 (build 12496)
2020-10-22 20:08:19.388  Status: (zigate) load PluginConf
2020-10-22 20:08:19.391  Status: (zigate) enableReadAttributes set to 1
2020-10-22 20:08:19.392  Status: (zigate) channel set to 11
2020-10-22 20:08:19.392  Status: (zigate) filename set to /opt/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-81.json
2020-10-22 20:08:19.392  Status: (zigate) pluginHome set to /opt/domoticz/plugins/Domoticz-Zigate/
2020-10-22 20:08:19.392  Status: (zigate) homedirectory set to /opt/domoticz/plugins/Domoticz-Zigate/
2020-10-22 20:08:19.392  Status: (zigate) pluginData set to /opt/domoticz/plugins/Domoticz-Zigate/Data/
2020-10-22 20:08:19.392  Status: (zigate) pluginConfig set to /opt/domoticz/plugins/Domoticz-Zigate/Conf/
2020-10-22 20:08:19.392  Status: (zigate) pluginOTAFirmware set to /opt/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-10-22 20:08:19.392  Status: (zigate) pluginReports set to /opt/domoticz/plugins/Domoticz-Zigate/Reports/
2020-10-22 20:08:19.392  Status: (zigate) pluginWWW set to /opt/domoticz/plugins/Domoticz-Zigate/www/
2020-10-22 20:08:19.392  Status: (zigate) pluginLogs set to /opt/domoticz/plugins/Domoticz-Zigate/Logs/
2020-10-22 20:08:19.393  Status: (zigate) Switching Heartbeat to 5 s interval
2020-10-22 20:08:19.393  Status: (zigate) Python Version - 3.7.3 (default, Jul 25 2020, 13:03:44)
[GCC 8.3.0]
2020-10-22 20:08:19.393  Status: (zigate) DomoticzVersion: 2020.2 (build 12496)
2020-10-22 20:08:19.393  Status: (zigate) DomoticzHash: f18fc9720-modified
2020-10-22 20:08:19.393  Status: (zigate) DomoticzBuildTime: 2020-10-21 12:12:39
2020-10-22 20:08:19.394  Status: (zigate) Opening DomoticzDB in raw
2020-10-22 20:08:19.405  Status: (zigate) Plugin Database: DeviceList-81.txt
2020-10-22 20:08:19.420  Status: (zigate) DeviceConf loaded
2020-10-22 20:08:19.545  Status: (zigate) load ListOfDevice
2020-10-22 20:08:19.677  Status: (zigate) Entries loaded from /opt/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-81.txt
2020-10-22 20:08:19.690  Status: (zigate) Transport mode: USB
2020-10-22 20:08:19.691  Status: (zigate) ==> Transport Mode: auto
2020-10-22 20:08:19.699  Status: (zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A6007v70-if00-port0
2020-10-22 20:08:19.700  Status: (zigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A6007v70-if00-port0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2020-10-22 20:08:19.790  Status: Python EventSystem: Initalizing event module.
2020-10-22 20:08:19.791  Status: EventSystem: Started
2020-10-22 20:08:19.792  Status: EventSystem: Queue thread started...
2020-10-22 20:08:19.805  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:08:19.850  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:08:19.894  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:08:19.939  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:08:23.604  (MA_RFLink) Temp + Humidity (CUI1 - TEMP - CONG)
2020-10-22 20:08:23.614  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:08:30.915  (MA_RFLink) Temp + Humidity (EXT1 - TEMP - DKW2012)
2020-10-22 20:08:30.926  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:08:30.935  (MA_RFLink) Rain (EXT1 - PLUIE - DKW2012)
2020-10-22 20:08:30.957  (MA_RFLink) Wind (EXT1 - VENT - DKW2012)
2020-10-22 20:08:30.981  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:08:31.026  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:08:32.054  (MA_RFLink) Temp + Humidity (EXT2 - TEMP)
2020-10-22 20:08:32.064  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:08:37.689  (MA_RFLink) Temp + Humidity (SDB1 - TEMP)
2020-10-22 20:08:37.701  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:08:45.320  (MA_RFLink) Temp + Humidity (CHA2 - TEMP)
2020-10-22 20:08:45.332  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:08:45.920  (MA_RFLink) Temp (Auriol)
2020-10-22 20:08:46.876  (MA_RFLink) Temp + Humidity (CHA1 - TEMP)
2020-10-22 20:08:46.887  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:08:50.343  Error: CConnection_connect, connect request from 'KodiAZWPlayer' ignored. Transport is connecting.
2020-10-22 20:08:50.500  (MA_RFLink) Temp + Humidity (SAL1 - TEMP)
2020-10-22 20:08:50.513  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:08:51.201  (MA_RFLink) Temp + Humidity (CHA3 - TEMP)
2020-10-22 20:08:51.214  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:08:58.733  (MA_RFLink) Temp + Humidity (CUI1 - TEMP - CONG)
2020-10-22 20:08:58.746  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:09:07.277  (MA_RFLink) UV (Oregon UVN1x8)
2020-10-22 20:09:07.290  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:09:12.692  (MA_RFLink) Temp + Humidity (SDB1 - TEMP)
2020-10-22 20:09:12.702  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:09:13.822  Error: MA_teleinfo hardware (3) nothing received for more than 1 Minute!....
2020-10-22 20:09:14.822  Error: Restarting: MA_teleinfo
2020-10-22 20:09:16.860  Status: (MA_teleinfo) Teleinfo device uses serial port: /dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller-if00-port0 at 1200 bauds
2020-10-22 20:09:16.872  Status: (MA_teleinfo) CRC checks will be performed on incoming data
2020-10-22 20:09:18.921  (MA_RFLink) Temp + Humidity (EXT1 - TEMP - DKW2012)
2020-10-22 20:09:18.931  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:09:18.949  (MA_RFLink) Rain (EXT1 - PLUIE - DKW2012)
2020-10-22 20:09:18.976  (MA_RFLink) Wind (EXT1 - VENT - DKW2012)
2020-10-22 20:09:18.988  Status: EventSystem: Script event triggered: script_device_etatMaison
2020-10-22 20:09:19.034  Status: EventSystem: Script event triggered: script_device_etatMaison
Publié : 22 oct. 2020, 20:37
par pipiche
Quel type de Zigate est-ce ? USB ? DIN ? de quelle couleur est la carte ou se trouve le connecteur USB ?
Ete-vous certain du chemin d'accès au port USB ?
Publié : 22 oct. 2020, 21:08
par olicot
Merci Pipiche pour le temps passé.
je viens de débrancher / rebranché l'un après l'autre , et c'est tombé en marche (pourtant j'ai eu quelque coupure electrique avec le vent d'autan, et des reboot manuel)
je ne pige pas, pas d'erreur dans les log
Il s'agit d'un zigate usb "bleu", l'une des premieres, acquise lors de l'operation kickstart
Mais tout refonctionne, plus qu'a upgrader en 31D ;-)
Publié : 22 oct. 2020, 21:49
par pipiche
olicot a écrit : 22 oct. 2020, 21:08 Merci Pipiche pour le temps passé.
Vérifies il est possible que le port USB change .... et du coup ca pointé peut-etre pas sur la bonne
Maintenant j'ai noté qu'il y a un soucis coté plugin qui est un peu silencieux
Re: [RESOLU] Le webserveur ne demarre plus
Publié : 23 oct. 2020, 13:40
par olicot
En principe, le nom ne devrait pas changé au reboot, c'est pour ça que j'utilise les port usb par nom et non par Id ( /dev/ttyUSBx)..
Mais effectivement, suite à la maj de l'OS, il y a peut-etre eu un changement du nom, chose que je n'ai pas vérifié, et pour les quel les log ne m'ont mis sur aucune piste...
Publié : 23 oct. 2020, 18:35
Pour information, il est possible de rendre le nom des périphériques USB persistant : https://easydomoticz.com/mon-premier-pe ... e-z-wave-2 ou https://www.domoticz.com/wiki/PersistentUSBDevices
