Erreur de ma part, j'ai vu ça sur ali ( https://fr.aliexpress.com/item/1005002592402973.html ) et l'ai commandé vu que compatible Zigbee ( sans aller regarder si c était supporté sur le site zigate )
donc pas de bol ça marche pas avec la version actuelle :
c'est reconnu comme un TS0601 , avec les modules
Zigate - TS0601_Temp-0c4314fffe881712-01
Zigate - TS0601_ThermoSetpoint-0c4314fffe881712-01
Zigate - TS0601_ThermoMode_2-0c4314fffe881712-01Code : Tout sélectionner
2021-07-17 21:23:29.386 (Zigate) Decode8002 - NwkId: 9300 Ep: 01 Cluster: ef00 GlobalCommand: False Command: 01 Data: 000012020004000000fb
2021-07-17 21:23:29.387 (Zigate) inRawAps 9300/01 Cluster ef00 Manuf: None Command: 01 Data: 000012020004000000fb Payload: 091701000012020004000000fb
2021-07-17 21:23:29.492 (Zigate) Decode8002 - NwkId: 9300 Ep: 01 Cluster: ef00 GlobalCommand: False Command: 01 Data: 000013020004000002af
2021-07-17 21:23:29.492 (Zigate) inRawAps 9300/01 Cluster ef00 Manuf: None Command: 01 Data: 000013020004000002af Payload: 091801000013020004000002af
2021-07-17 21:23:31.953 (Zigate) Decode8002 - NwkId: 9300 Ep: 01 Cluster: ef00 GlobalCommand: False Command: 01 Data: 000012020004000000fe
2021-07-17 21:23:31.953 (Zigate) inRawAps 9300/01 Cluster ef00 Manuf: None Command: 01 Data: 000012020004000000fe Payload: 091901000012020004000000fe
2021-07-17 21:23:32.059 (Zigate) Decode8002 - NwkId: 9300 Ep: 01 Cluster: ef00 GlobalCommand: False Command: 01 Data: 000013020004000002b0
2021-07-17 21:23:32.059 (Zigate) inRawAps 9300/01 Cluster ef00 Manuf: None Command: 01 Data: 000013020004000002b0 Payload: 091a01000013020004000002b0
2021-07-17 21:23:34.400 (Zigate) Decode8002 - NwkId: 9300 Ep: 01 Cluster: ef00 GlobalCommand: False Command: 01 Data: 000012020004000000fd
2021-07-17 21:23:34.400 (Zigate) inRawAps 9300/01 Cluster ef00 Manuf: None Command: 01 Data: 000012020004000000fd Payload: 091e01000012020004000000fd
2021-07-17 21:23:34.505 (Zigate) Decode8002 - NwkId: 9300 Ep: 01 Cluster: ef00 GlobalCommand: False Command: 01 Data: 000013020004000002a9
2021-07-17 21:23:34.505 (Zigate) inRawAps 9300/01 Cluster ef00 Manuf: None Command: 01 Data: 000013020004000002a9 Payload: 091f01000013020004000002a9 Domoticz Version: 2020.2 (build 12239)
Plugin Zigate: Plugin: 4.11.017 - stable
Firmware: 031e -standart
sur un Pizigate V1
avec un raspberry 3 + ssd
Module Tuya
type Smart air box
La plage de détection de la boîte à air intelligente: formaldéhyde, gaz VOC, CO2, température, humidité L'examen gamme: Formaldéhyde: 0-10.0 (mg/m3) COV: 0-99.9 (ppm) Dioxyde de carbone: 0-1000 (ppm) Température: 0-60 (℃) Humidité: 0-95%
log raw
Version : "3"
ZDeviceName : ""
Status : "inDB"
SQN : "35"
Heartbeat : "241"
RIA : "0"
LQI : 93
Battery : Object {}
Model : "TS0601"
ForceAckCommands : Array[0] []
MacCapa : "8e"
IEEE : "0c4314fffe881712"
Type : "Temp/ThermoSetpoint/ThermoMode_2"
ProfileID : "0104"
ZDeviceID : "0051"
App Version : "68"
Attributes List : Object {}
DeviceType : "FFD"
HW Version : "1"
Last Cmds : Array[10] [[42,"02","9300","0100","0101000000000000010000"],[43,"02","9300","0100","0101000000000000010001"],[44,"02","9300","0100","0101000000000000010002"],[45,"02","9300","0100","0101000000000000010003"],[46,"02","9300","0100","0101000000000000010004"],[47,"02","9300","0100","0101000000000000010005"],[48,"02","9300","0100","0101000000000000010007"],[52,"02","9300","0081","0101011a0010"],[54,"02","9300","0081","010101330010"],[56,"02","9300","0092","010100"]]
LogicalType : "Router"
Manufacturer : ""
Manufacturer Name : "_TZE200_yvx5lh6k"
NbEp : "1"
PowerSource : "Main"
ReadAttributes : Object {"Ep":{"01":{"0000":{"TimeStamp":"17/07/2021 21:38:26","iSQN":{"0000":42,"0001":43,"0002":44,"0003":45,"0004":46,"0005":47,"0007":48},"Attributes":{"0000":"00","0001":"00","0002":"00","0003":"00","0004":"00","0005":"00","0007":"00","ffe2":"00","ffe4":"00","ffdf":"00"},"ZigateRequest":{}}}}}
ReceiveOnIdle : ""
Stack Version : "0"
Stamp : Object {"Time":"2021-07-17 21:40:34","MsgType":"8002","LastSeen":"17/07/2021 21:38:26","LastPing":0}
ZCL Version : "3"
Health : "Live"
Capability : Array[5] ["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"]
PairingInProgress : false
RollingLQI : Array[11] [93,93,93,93,93,93,93,93,93,93,93]
Epv2 : Object {"01":{"ClusterIn":{},"ClusterOut":{},"ProfileID":"0104","ZDeviceID":"0051"}}
ConfigSource : "DeviceConf"
Ep : Object {"01":{"0000":{"0004":"_TZE200_yvx5lh6k","0005":"TS0601","0000":"3","0001":"68","0002":"0","0003":"1","0007":"1","ffe2":"31","ffe4":"0","ffdf":"\u0012\u0000\u0000\u0000\u0000\u0012\u0000\u0000\u0000\u0000\u0012\u0000\u0000\u0000\u0000\u0012"},"0004":{},"ef00":{},"000a":{},"0019":{},"Type":"Temp/ThermoSetpoint/ThermoMode_2","ClusterType":{"103":"Temp","104":"ThermoSetpoint","105":"ThermoMode_2"}}}
ZDeviceVersion : "0001"
Bind : Object {"01":{"0019":{"Target":"0000","Stamp":"17/07/2021 21:16:47","Phase":"binded","Status":"00","i_sqn":40},"ef00":{"Target":"0000","Stamp":"17/07/2021 21:16:47","Phase":"binded","Status":"00","i_sqn":41}}}
WriteAttributes : Object {"Ep":{"01":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0004":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"ef00":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"000a":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}}
Tuya : Object {}
TuyaTransactionId : 3
NwkID : "9300"Voiloi, j'espere avoir envoyé assez d élément.
Merci d'avance
Cyril
