Nouveau firmware rflink R35
Publié : 09 déc. 2015, 17:13
Gros travail de la stunt team
R35: - Added: Full A OK Controller/Motor support
- Added: Brel motor support
- Added: Krippl temperature/humidity sensor support
- Added: Elro DB270 doorbell
- Added: InoValley SM302 Temperature&Humidity sensor (Thanks: Pirion)
- Added: EZ6 Temperature&Humidity sensor
- Added: Alecto SA30 & SA33 Smoke Alarm
- Added: Xiron RS8751E3 Weather sensor
- Added: LightwaveRF (initial support, testers needed)
- Added: support for Oregon sensor simulator
- Fixed: Oregon OWL CM119, CM160, CM180
- Fixed: Oregon UV800 uv index value
- Fixed: Corrected WH440 temperature values
- Fixed: Improved Philips SBC
- Fixed: Improved Chacon EMW200
- Fixed: Improved FA500 false positive detection
- Fixed: Removed a slash in the UPM/Esic name
- Fixed: Mertik transmit improved
- Fixed: Optimized the Auriol/Xiron plugin
- Fixed: LaCrosse negative temperatures and extended allowed pulse range (Thanks: VeryBitter)
- Fixed: Alecto v1 Windspeed value
- Fixed: Improved Otio remote signal handling
- Fixed: corrected WH2 handling for Tesa WH1150 sensor (Thanks: Pirion)
- Fixed: Lacrosse rain - wind needs some more work (Thanks: Arie)
- Tested: tested and working: Lidl / Libra TR502MSV switches
- Tested: tested and working: Avidsen door contact 102539
http://sourceforge.net/projects/rflink/files/
