[Bullseye] Erreur plugin python
Publié : 12 déc. 2021, 17:04
Bonjour à tous et à toutes je déterre ce poste, j'ai un souci avec le plugin ZigBee2MTT, voici ce que domoticz me dit.
2021-12-12 00:36:42.294 Error: zigbee: (Zigbee2MQTT) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/zigbee2mqtt/:/usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload:/usr/local/lib/python3.9/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.9/dist-packages'.
2021-12-12 00:36:42.294 Error: zigbee: (zigbee) Module Import failed, exception: 'ModuleNotFoundError'
2021-12-12 00:36:42.294 Error: zigbee: (zigbee) Module Import failed: ' Name: DomoticzEx'
2021-12-12 00:36:42.294 Error: zigbee: (zigbee) Error Line details not available.
J'ai suivi pas mal de tutos rien n'y fait j'ai même utilisé la ligne de commande.
sudo git reset --hard 3725a29
Ça me plante domoticz.
Je sais plus quoi faire, si quelqu'un pouvait m'aider ! .
Ma configuration
Domoticz V2021.1 (c)2012-2021 GizMoCuz
2021-12-12 00:36:40.025 Status: Build Hash: 8547c5b7e, Date: 2021-04-17 17:29:11
2021-12-12 00:36:40.026 Status: Startup Path: /home/pi/domoticz/
2021-12-12 00:36:40.122 Status: PluginSystem: Started, Python version '3.9.2'.
2021-12-12 00:36:40.128 Status: WebServer(HTTP) started on address: :: with port 8080
2021-12-12 00:36:40.134 Status: WebServer(SSL) started on address: :: with port 443
2021-12-12 00:36:40.138 Status: RxQueue: queue worker started...
2021-12-12 00:36:40.138 Status: TCPServer: shared server started...
2021-12-12 00:36:42.139 Status: zigbee: (zigbee) Entering work loop.
2021-12-12 00:36:42.140 Status: zigbee: (zigbee) Started.
2021-12-12 00:36:42.140 Status: NotificationSystem: thread started...
2021-12-12 00:36:42.141 Status: EventSystem: reset all events...
2021-12-12 00:36:42.141 Status: EventSystem: reset all device statuses...
2021-12-12 00:36:42.233 Status: Python EventSystem: Initalizing event module.
2021-12-12 00:36:42.233 Status: EventSystem: Started
2021-12-12 00:36:42.233 Status: EventSystem: Queue thread started...
2021-12-12 00:36:42.556 Status: PluginSystem: 1 plugins started.
Version: 2021.1
Compile Date: 2021-04-17 17:29:11
dzVents Version: 3.1.7
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
en vous remerciant
Ma configuration
Version: 2021.1
en vous remerciant
