J'ai édité le fichier syslog, mais je ne vois pas d' USB disconnect . Peut-être parce que je n'ai pas eu de coupure depuis hier 9h.
Ci joint les données de syslog.
4.755582] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 4.755597] usb 1-1.2: Product: USB to ATA/ATAPI Bridge
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 4.755611] usb 1-1.2: Manufacturer: JMicron
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 4.755626] usb 1-1.2: SerialNumber: 0123456789ABCDEF
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 4.756343] usb 1-1.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 4.756360] usb 1-1.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 4.756376] usb-storage 1-1.2:1.0: USB Mass Storage device detected
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 4.757146] usb-storage 1-1.2:1.0: Quirks match for vid 152d pid 0578: 1000000
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 4.757320] scsi host0: usb-storage 1-1.2:1.0
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 4.854447] usb 1-1.1.1: new high-speed USB device number 6 using dwc_otg
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 4.984861] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 4.984880] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 10.343302] usbcore: registered new interface driver usbserial_generic
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 10.343462] usbserial: USB Serial support registered for generic
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 10.354959] usbcore: registered new interface driver uas
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 10.365755] usbcore: registered new interface driver ftdi_sio
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 10.365849] usbserial: USB Serial support registered for FTDI USB Serial Device
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 10.366197] ftdi_sio 1-1.1.2:1.0: FTDI USB Serial Device converter detected
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 10.366389] usb 1-1.1.2: Detected FT-X
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 10.397905] usb 1-1.1.2: FTDI USB Serial Device converter now attached to ttyUSB0
/var/log/syslog.1:Dec 20 13:14:12 raspberrypi kernel: [ 10.750818] usbcore: registered new interface driver brcmfmac
/var/log/syslog.1:Dec 20 13:15:29 raspberrypi kernel: [ 62.151067] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
/var/log/syslog.1:Dec 20 13:15:29 raspberrypi kernel: [ 62.151181] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
/var/log/syslog.1:Dec 20 13:15:30 raspberrypi kernel: [ 62.328215] usb 1-1.1.2: USB disconnect, device number 4
/var/log/syslog.1:Dec 20 13:15:30 raspberrypi kernel: [ 62.328443] ftdi_sio ttyUSB0: error from flowcontrol urb
/var/log/syslog.1:Dec 20 13:15:30 raspberrypi kernel: [ 62.333730] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
/var/log/syslog.1:Dec 20 13:15:39 raspberrypi kernel: [ 71.904486] usb 1-1.3: new full-speed USB device number 7 using dwc_otg
/var/log/syslog.1:Dec 20 13:15:39 raspberrypi kernel: [ 72.060617] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
/var/log/syslog.1:Dec 20 13:15:39 raspberrypi kernel: [ 72.060644] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
/var/log/syslog.1:Dec 20 13:15:39 raspberrypi kernel: [ 72.060659] usb 1-1.3: Product: RFXtrx433XL
/var/log/syslog.1:Dec 20 13:15:39 raspberrypi kernel: [ 72.060674] usb 1-1.3: Manufacturer: RFXCOM
/var/log/syslog.1:Dec 20 13:15:39 raspberrypi kernel: [ 72.060689] usb 1-1.3: SerialNumber: DO3FNM06
/var/log/syslog.1:Dec 20 13:15:39 raspberrypi kernel: [ 72.067843] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
/var/log/syslog.1:Dec 20 13:15:39 raspberrypi kernel: [ 72.068080] usb 1-1.3: Detected FT-X
/var/log/syslog.1:Dec 20 13:15:39 raspberrypi kernel: [ 72.072832] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
/var/log/syslog.1:Dec 20 13:15:39 raspberrypi mtp-probe: checking bus 1, device 7: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3"
/var/log/syslog.1:Dec 20 13:15:40 raspberrypi mtp-probe: checking bus 1, device 7: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3"
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 0.142204] usbcore: registered new interface driver usbfs
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 0.142269] usbcore: registered new interface driver hub
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 0.142341] usbcore: registered new device driver usb
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi mtp-probe: checking bus 1, device 6: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1"
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi mtp-probe: checking bus 1, device 4: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2"
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi mtp-probe: checking bus 1, device 5: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2"
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 2.018938] usbcore: registered new interface driver lan78xx
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 2.019004] usbcore: registered new interface driver smsc95xx
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 2.948086] dwc_otg 3f980000.usb: DWC OTG Controller
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 2.948124] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 2.948175] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 2.948616] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 2.948634] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 2.948648] usb usb1: Product: DWC OTG Controller
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 2.948663] usb usb1: Manufacturer: Linux 5.10.63-v7+ dwc_otg_hcd
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 2.948677] usb usb1: SerialNumber: 3f980000.usb
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 2.949456] hub 1-0:1.0: USB hub found
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 2.951113] usbcore: registered new interface driver usb-storage
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 2.959593] usbcore: registered new interface driver usbhid
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 2.959604] usbhid: USB HID core driver
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 3.284465] usb 1-1: new high-speed USB device number 2 using dwc_otg
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 3.534778] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 3.534797] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 3.535525] hub 1-1:1.0: USB hub found
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 3.854470] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 3.984776] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 3.984794] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 3.985548] hub 1-1.1:1.0: USB hub found
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.304462] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.515620] usb 1-1.2: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 5.08
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.515639] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.515653] usb 1-1.2: Product: USB to ATA/ATAPI Bridge
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.515668] usb 1-1.2: Manufacturer: JMicron
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.515682] usb 1-1.2: SerialNumber: 0123456789ABCDEF
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.516425] usb 1-1.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.516442] usb 1-1.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.516458] usb-storage 1-1.2:1.0: USB Mass Storage device detected
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.521907] usb-storage 1-1.2:1.0: Quirks match for vid 152d pid 0578: 1000000
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.522107] scsi host0: usb-storage 1-1.2:1.0
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.614472] usb 1-1.1.2: new full-speed USB device number 5 using dwc_otg
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.781852] usb 1-1.1.2: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.781871] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.781886] usb 1-1.1.2: Product: RFXtrx433XL
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.781900] usb 1-1.1.2: Manufacturer: RFXCOM
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 4.781914] usb 1-1.1.2: SerialNumber: DO3FNM06
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 5.084472] usb 1-1.1.1: new high-speed USB device number 6 using dwc_otg
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 5.214981] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 5.214999] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 10.065751] usbcore: registered new interface driver usbserial_generic
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 10.065836] usbserial: USB Serial support registered for generic
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 10.077839] usbcore: registered new interface driver ftdi_sio
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 10.077922] usbserial: USB Serial support registered for FTDI USB Serial Device
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 10.078339] ftdi_sio 1-1.1.2:1.0: FTDI USB Serial Device converter detected
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 10.078548] usb 1-1.1.2: Detected FT-X
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 10.133567] usbcore: registered new interface driver uas
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 10.169043] usbcore: registered new interface driver brcmfmac
/var/log/syslog.2.gz:Dec 19 07:37:54 raspberrypi kernel: [ 10.188427] usb 1-1.1.2: FTDI USB Serial Device converter now attached to ttyUSB0
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi mtp-probe: checking bus 1, device 5: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2"
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi mtp-probe: checking bus 1, device 4: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2"
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi mtp-probe: checking bus 1, device 6: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1"
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 0.142086] usbcore: registered new interface driver usbfs
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 0.142151] usbcore: registered new interface driver hub
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 0.142223] usbcore: registered new device driver usb
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 2.019061] usbcore: registered new interface driver lan78xx
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 2.019127] usbcore: registered new interface driver smsc95xx
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 2.948230] dwc_otg 3f980000.usb: DWC OTG Controller
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 2.948268] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 2.948316] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 2.948761] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 2.948779] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 2.948794] usb usb1: Product: DWC OTG Controller
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 2.948808] usb usb1: Manufacturer: Linux 5.10.63-v7+ dwc_otg_hcd
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 2.948823] usb usb1: SerialNumber: 3f980000.usb
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 2.949575] hub 1-0:1.0: USB hub found
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 2.951239] usbcore: registered new interface driver usb-storage
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 2.959737] usbcore: registered new interface driver usbhid
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 2.959748] usbhid: USB HID core driver
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 3.284342] usb 1-1: new high-speed USB device number 2 using dwc_otg
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 3.534659] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 3.534679] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 3.535417] hub 1-1:1.0: USB hub found
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 3.854348] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 3.984656] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 3.984675] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 3.985404] hub 1-1.1:1.0: USB hub found
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.304341] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.515498] usb 1-1.2: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 5.08
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.515516] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.515532] usb 1-1.2: Product: USB to ATA/ATAPI Bridge
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.515546] usb 1-1.2: Manufacturer: JMicron
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.515560] usb 1-1.2: SerialNumber: 0123456789ABCDEF
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.522150] usb 1-1.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.522168] usb 1-1.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.522184] usb-storage 1-1.2:1.0: USB Mass Storage device detected
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.523013] usb-storage 1-1.2:1.0: Quirks match for vid 152d pid 0578: 1000000
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.523198] scsi host0: usb-storage 1-1.2:1.0
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.614350] usb 1-1.1.2: new full-speed USB device number 5 using dwc_otg
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.781726] usb 1-1.1.2: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.781744] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.781760] usb 1-1.1.2: Product: RFXtrx433XL
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.781774] usb 1-1.1.2: Manufacturer: RFXCOM
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 4.781790] usb 1-1.1.2: SerialNumber: DO3FNM06
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 5.084350] usb 1-1.1.1: new high-speed USB device number 6 using dwc_otg
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 5.214863] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 5.214881] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 10.059204] usbcore: registered new interface driver uas
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 10.065293] usbcore: registered new interface driver usbserial_generic
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 10.065373] usbserial: USB Serial support registered for generic
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 10.090334] usbcore: registered new interface driver ftdi_sio
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 10.090424] usbserial: USB Serial support registered for FTDI USB Serial Device
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 10.090820] ftdi_sio 1-1.1.2:1.0: FTDI USB Serial Device converter detected
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 10.091011] usb 1-1.1.2: Detected FT-X
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 10.108298] usb 1-1.1.2: FTDI USB Serial Device converter now attached to ttyUSB0
/var/log/syslog.2.gz:Dec 19 07:40:22 raspberrypi kernel: [ 10.250787] usbcore: registered new interface driver brcmfmac
/var/log/syslog.3.gz:Dec 18 10:06:48 raspberrypi kernel: [137756.501135] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
/var/log/syslog.3.gz:Dec 18 10:06:48 raspberrypi kernel: [137756.501239] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
/var/log/syslog.3.gz:Dec 18 18:17:01 raspberrypi kernel: [167169.584251] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
/var/log/syslog.4.gz:Dec 17 10:30:19 raspberrypi kernel: [52766.871099] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
/var/log/syslog.4.gz:Dec 17 10:30:19 raspberrypi kernel: [52766.871214] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
/var/log/syslog.4.gz:Dec 17 18:17:01 raspberrypi kernel: [80769.648103] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
/var/log/syslog.4.gz:Dec 17 18:17:28 raspberrypi kernel: [80796.536436] usb 1-1.1.3: USB disconnect, device number 4
/var/log/syslog.4.gz:Dec 17 18:17:28 raspberrypi kernel: [80796.536858] ftdi_sio ttyUSB0: error from flowcontrol urb
/var/log/syslog.4.gz:Dec 17 18:17:28 raspberrypi kernel: [80796.537759] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
/var/log/syslog.4.gz:Dec 17 18:17:39 raspberrypi kernel: [80807.579832] usb 1-1.1.2: new full-speed USB device number 7 using dwc_otg
/var/log/syslog.4.gz:Dec 17 18:17:40 raspberrypi kernel: [80807.739445] usb 1-1.1.2: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
/var/log/syslog.4.gz:Dec 17 18:17:40 raspberrypi kernel: [80807.739458] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
/var/log/syslog.4.gz:Dec 17 18:17:40 raspberrypi kernel: [80807.739464] usb 1-1.1.2: Product: RFXtrx433XL
/var/log/syslog.4.gz:Dec 17 18:17:40 raspberrypi kernel: [80807.739471] usb 1-1.1.2: Manufacturer: RFXCOM
/var/log/syslog.4.gz:Dec 17 18:17:40 raspberrypi kernel: [80807.739477] usb 1-1.1.2: SerialNumber: DO3FNM06
/var/log/syslog.4.gz:Dec 17 18:17:40 raspberrypi kernel: [80807.746134] ftdi_sio 1-1.1.2:1.0: FTDI USB Serial Device converter detected
/var/log/syslog.4.gz:Dec 17 18:17:40 raspberrypi kernel: [80807.746246] usb 1-1.1.2: Detected FT-X
/var/log/syslog.4.gz:Dec 17 18:17:40 raspberrypi kernel: [80807.747957] usb 1-1.1.2: FTDI USB Serial Device converter now attached to ttyUSB0
/var/log/syslog.4.gz:Dec 17 18:17:40 raspberrypi mtp-probe: checking bus 1, device 7: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2"
/var/log/syslog.5.gz:Dec 16 17:30:25 raspberrypi kernel: [76677.437247] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
/var/log/syslog.5.gz:Dec 16 17:30:25 raspberrypi kernel: [76677.437360] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
/var/log/syslog.5.gz:Dec 16 18:16:01 raspberrypi kernel: [79413.465044] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi mtp-probe: checking bus 1, device 4: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3"
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi mtp-probe: checking bus 1, device 6: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1"
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi mtp-probe: checking bus 1, device 5: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2"
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 0.142001] usbcore: registered new interface driver usbfs
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 0.142067] usbcore: registered new interface driver hub
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 0.142138] usbcore: registered new device driver usb
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 2.019338] usbcore: registered new interface driver lan78xx
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 2.019404] usbcore: registered new interface driver smsc95xx
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 2.948507] dwc_otg 3f980000.usb: DWC OTG Controller
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 2.948546] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 2.948607] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 2.949059] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 2.949077] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 2.949092] usb usb1: Product: DWC OTG Controller
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 2.949107] usb usb1: Manufacturer: Linux 5.10.63-v7+ dwc_otg_hcd
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 2.949121] usb usb1: SerialNumber: 3f980000.usb
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 2.949864] hub 1-0:1.0: USB hub found
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 2.951566] usbcore: registered new interface driver usb-storage
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 2.959897] usbcore: registered new interface driver usbhid
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 2.959909] usbhid: USB HID core driver
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 3.294342] usb 1-1: new high-speed USB device number 2 using dwc_otg
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 3.544652] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 3.544681] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 3.545473] hub 1-1:1.0: USB hub found
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 3.864317] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 3.994577] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 3.994596] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 3.995264] hub 1-1.1:1.0: USB hub found
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.314316] usb 1-1.1.3: new full-speed USB device number 4 using dwc_otg
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.470471] usb 1-1.1.3: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.470490] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.470505] usb 1-1.1.3: Product: RFXtrx433XL
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.470520] usb 1-1.1.3: Manufacturer: RFXCOM
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.470534] usb 1-1.1.3: SerialNumber: DO3FNM06
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.544321] usb 1-1.2: new high-speed USB device number 5 using dwc_otg
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.755493] usb 1-1.2: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 5.08
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.755512] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.755527] usb 1-1.2: Product: USB to ATA/ATAPI Bridge
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.755542] usb 1-1.2: Manufacturer: JMicron
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.755556] usb 1-1.2: SerialNumber: 0123456789ABCDEF
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.756307] usb 1-1.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.756323] usb 1-1.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.756339] usb-storage 1-1.2:1.0: USB Mass Storage device detected
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.757092] usb-storage 1-1.2:1.0: Quirks match for vid 152d pid 0578: 1000000
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.757266] scsi host0: usb-storage 1-1.2:1.0
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.854317] usb 1-1.1.1: new high-speed USB device number 6 using dwc_otg
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.984735] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 4.984754] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 10.411103] usbcore: registered new interface driver usbserial_generic
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 10.411204] usbserial: USB Serial support registered for generic
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 10.440304] usbcore: registered new interface driver ftdi_sio
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 10.440517] usbserial: USB Serial support registered for FTDI USB Serial Device
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 10.441047] ftdi_sio 1-1.1.3:1.0: FTDI USB Serial Device converter detected
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 10.441364] usb 1-1.1.3: Detected FT-X
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 10.469569] usb 1-1.1.3: FTDI USB Serial Device converter now attached to ttyUSB0
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 10.477487] usbcore: registered new interface driver uas
/var/log/syslog.5.gz:Dec 16 19:50:37 raspberrypi kernel: [ 10.587284] usbcore: registered new interface driver brcmfmac
/var/log/syslog.6.gz:Dec 15 18:10:43 raspberrypi kernel: [95798.700351] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
/var/log/syslog.6.gz:Dec 15 18:10:43 raspberrypi kernel: [95798.700459] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
/var/log/syslog.6.gz:Dec 15 18:16:01 raspberrypi kernel: [96117.007740] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi mtp-probe: checking bus 1, device 4: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2"
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi mtp-probe: checking bus 1, device 5: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3"
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi mtp-probe: checking bus 1, device 6: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1"
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 0.141949] usbcore: registered new interface driver usbfs
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 0.142014] usbcore: registered new interface driver hub
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 0.142086] usbcore: registered new device driver usb
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 2.019012] usbcore: registered new interface driver lan78xx
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 2.019080] usbcore: registered new interface driver smsc95xx
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 2.948182] dwc_otg 3f980000.usb: DWC OTG Controller
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 2.948221] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 2.948270] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 2.948716] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 2.948735] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 2.948750] usb usb1: Product: DWC OTG Controller
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 2.948765] usb usb1: Manufacturer: Linux 5.10.63-v7+ dwc_otg_hcd
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 2.948780] usb usb1: SerialNumber: 3f980000.usb
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 2.949528] hub 1-0:1.0: USB hub found
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 2.951183] usbcore: registered new interface driver usb-storage
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 2.959718] usbcore: registered new interface driver usbhid
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 2.959730] usbhid: USB HID core driver
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 3.284267] usb 1-1: new high-speed USB device number 2 using dwc_otg
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 3.534572] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 3.534590] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 3.535317] hub 1-1:1.0: USB hub found
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 3.854263] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 3.984580] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 3.984599] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 3.985334] hub 1-1.1:1.0: USB hub found
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.304255] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.515469] usb 1-1.2: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 5.08
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.515487] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.515502] usb 1-1.2: Product: USB to ATA/ATAPI Bridge
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.515517] usb 1-1.2: Manufacturer: JMicron
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.515531] usb 1-1.2: SerialNumber: 0123456789ABCDEF
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.522094] usb 1-1.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.522110] usb 1-1.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.522126] usb-storage 1-1.2:1.0: USB Mass Storage device detected
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.522882] usb-storage 1-1.2:1.0: Quirks match for vid 152d pid 0578: 1000000
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.523081] scsi host0: usb-storage 1-1.2:1.0
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.614333] usb 1-1.1.3: new full-speed USB device number 5 using dwc_otg
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.780423] usb 1-1.1.3: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.780443] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.780458] usb 1-1.1.3: Product: RFXtrx433XL
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.780472] usb 1-1.1.3: Manufacturer: RFXCOM
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 4.780488] usb 1-1.1.3: SerialNumber: DO3FNM06
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 5.084331] usb 1-1.1.1: new high-speed USB device number 6 using dwc_otg
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 5.214775] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 5.214794] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 10.135135] usbcore: registered new interface driver uas
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 10.207589] usbcore: registered new interface driver brcmfmac
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 10.258551] usbcore: registered new interface driver usbserial_generic
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 10.258629] usbserial: USB Serial support registered for generic
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 10.292921] usbcore: registered new interface driver ftdi_sio
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 10.293082] usbserial: USB Serial support registered for FTDI USB Serial Device
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 10.293577] ftdi_sio 1-1.1.3:1.0: FTDI USB Serial Device converter detected
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 10.293801] usb 1-1.1.3: Detected FT-X
/var/log/syslog.6.gz:Dec 15 20:12:12 raspberrypi kernel: [ 10.329608] usb 1-1.1.3: FTDI USB Serial Device converter now attached to ttyUSB0
/var/log/syslog.7.gz:Dec 14 14:44:41 raspberrypi kernel: [587153.892753] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
/var/log/syslog.7.gz:Dec 14 14:44:41 raspberrypi kernel: [587153.892855] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
/var/log/syslog.7.gz:Dec 14 15:32:36 raspberrypi kernel: [590029.021163] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
/var/log/syslog.7.gz:Dec 14 15:32:38 raspberrypi kernel: [590030.961771] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
/var/log/syslog.7.gz:Dec 14 15:32:43 raspberrypi kernel: [590036.170665] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
/var/log/syslog.7.gz:Dec 14 15:32:46 raspberrypi kernel: [590038.726676] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
/var/log/syslog.7.gz:Dec 14 15:33:10 raspberrypi kernel: [590063.336294] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
/var/log/syslog.7.gz:Dec 14 15:33:13 raspberrypi kernel: [590065.965401] ftdi_sio ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 0.141996] usbcore: registered new interface driver usbfs
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 0.142061] usbcore: registered new interface driver hub
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 0.142132] usbcore: registered new device driver usb
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 2.017576] usbcore: registered new interface driver lan78xx
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 2.017643] usbcore: registered new interface driver smsc95xx
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 2.946734] dwc_otg 3f980000.usb: DWC OTG Controller
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 2.946773] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 2.946835] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 2.947286] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 2.947304] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 2.947319] usb usb1: Product: DWC OTG Controller
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 2.947333] usb usb1: Manufacturer: Linux 5.10.63-v7+ dwc_otg_hcd
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 2.947348] usb usb1: SerialNumber: 3f980000.usb
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 2.948088] hub 1-0:1.0: USB hub found
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 2.949792] usbcore: registered new interface driver usb-storage
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 2.958150] usbcore: registered new interface driver usbhid
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 2.958162] usbhid: USB HID core driver
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 3.284316] usb 1-1: new high-speed USB device number 2 using dwc_otg
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 3.524597] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 3.524616] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 3.525382] hub 1-1:1.0: USB hub found
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 3.844307] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 3.974566] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 3.974584] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 3.975246] hub 1-1.1:1.0: USB hub found
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi mtp-probe: checking bus 1, device 6: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1"
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi mtp-probe: checking bus 1, device 5: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2"
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi mtp-probe: checking bus 1, device 4: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3"
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.294314] usb 1-1.1.3: new full-speed USB device number 4 using dwc_otg
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.451693] usb 1-1.1.3: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.451712] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.451728] usb 1-1.1.3: Product: RFXtrx433XL
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.451742] usb 1-1.1.3: Manufacturer: RFXCOM
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.451757] usb 1-1.1.3: SerialNumber: DO3FNM06
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.524300] usb 1-1.2: new high-speed USB device number 5 using dwc_otg
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.735471] usb 1-1.2: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 5.08
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.735489] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.735504] usb 1-1.2: Product: USB to ATA/ATAPI Bridge
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.735518] usb 1-1.2: Manufacturer: JMicron
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.735533] usb 1-1.2: SerialNumber: 0123456789ABCDEF
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.736284] usb 1-1.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.736301] usb 1-1.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.736317] usb-storage 1-1.2:1.0: USB Mass Storage device detected
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.737077] usb-storage 1-1.2:1.0: Quirks match for vid 152d pid 0578: 1000000
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.737257] scsi host0: usb-storage 1-1.2:1.0
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.834310] usb 1-1.1.1: new high-speed USB device number 6 using dwc_otg
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.964734] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 4.964752] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 10.250489] usbcore: registered new interface driver usbserial_generic
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 10.250572] usbserial: USB Serial support registered for generic
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 10.275867] usbcore: registered new interface driver ftdi_sio
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 10.275967] usbserial: USB Serial support registered for FTDI USB Serial Device
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 10.276302] ftdi_sio 1-1.1.3:1.0: FTDI USB Serial Device converter detected
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 10.276500] usb 1-1.1.3: Detected FT-X
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 10.288575] usb 1-1.1.3: FTDI USB Serial Device converter now attached to ttyUSB0
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 10.308985] usbcore: registered new interface driver uas
/var/log/syslog.7.gz:Dec 14 15:33:49 raspberrypi kernel: [ 10.506518] usbcore: registered new interface driver brcmfmac
