[Résolu] Installation du plugin Zigate fait bugger Domoticz
Publié : 08 févr. 2022, 19:12
Bonjour messieurs,
Je me suis lancer dans domoticz il y a peut j'ai pour cela un RPI3B :
J'ai suivi à la lettre le git https://github.com/zigbeefordomoticz/wi ... c-raspbian (qui est d'ailleurs très bien expliqué)
Le test de ma PiZigate+
Mais lorsque j'installe le plugin Zigate j'ai ce message qui apparait et qui plante mon interface web domoticz
Pouvez-vous m'aidez svp
Merci d'avance,
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debianLe test de ma PiZigate+
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigate $ sudo /home/pi/domoticz/plugins/PiZiGate-tools/test/./PiZiGate_test /dev/ttyAMA0
RPI Model searching ...
Warning !!! you must modify /boot/config.txt
Verifying /boot/cmdline.txt ...
+ /boot/cmdline.txt seems to be OK
Verifying /boot/config.txt ...
+ /boot/config.txt seems to be OK
Warning !!! if it's not the case, you have to execute the following commands :
sudo systemctl disable hciuart
sudo usermod -aG gpio pi
then reboot the PI
Searching /dev/ttyAMA0...
sh: 1: lsof: not found
+ Port : /dev/ttyAMA0 is not used
Verif GPIOs ...
+ GPIO 0 (RESET) --> OK
+ GPIO 2 (FLASH) --> OK
Config GPIOs ...
Opening : /dev/ttyAMA0 ...
+ /dev/ttyAMA0 opened --> OK
+ Packet 01 02 10 10 02 10 02 10 10 03 sent --> OK
+ Packet received --> OK
01 00 03 02 00 02 03 00 00 03
01 80 07 00 02 85 00 00 03
01 80 01 00 22 ce 06 41 50 50 3a 20 4e 4f 54 20 65 6e 74 65 72 69 6e 67 20 41 50 50 5f 76 4e 63 69 53 74 61 72 74 28 29 03
01 80 00 00 09 99 00 00 00 10 00 00 00 00 00 03
01 80 10 00 05 b2 00 05 03 21 00 03
2022-02-08 18:08:34.661 Zigate: Worker thread started.
2022-02-08 18:08:34.661 Status: Zigate: Entering work loop.
2022-02-08 18:08:34.661 Status: Zigate: Started.
2022-02-08 18:08:37.898 Zigate: ZiGate plugin started!
2022-02-08 18:08:37.898 Zigate: load PluginConf
2022-02-08 18:08:37.901 Zigate: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-02-08 18:08:37.901 Zigate: is_domoticz_db_available: True
2022-02-08 18:08:37.902 Zigate: Starting LoggingManagement thread
2022-02-08 18:08:37.902 Zigate: start_logging_thread
2022-02-08 18:08:37.904 Zigate: logging_thread - listening
2022-02-08 18:08:37.895 Status: Zigate: Initialized version 5.1, author 'zaraki673 pipiche38'
2022-02-08 18:08:37.902 Status: Zigate: filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-13.json
2022-02-08 18:08:37.902 Status: Zigate: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2022-02-08 18:08:37.902 Status: Zigate: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2022-02-08 18:08:37.902 Status: Zigate: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2022-02-08 18:08:37.902 Status: Zigate: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2022-02-08 18:08:37.902 Status: Zigate: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2022-02-08 18:08:37.902 Status: Zigate: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2022-02-08 18:08:37.902 Status: Zigate: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2022-02-08 18:08:37.902 Status: Zigate: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2022-02-08 18:08:37.904 Status: Zigate: Log history not found, no error logged
2022-02-08 18:08:37.908 Status: Zigate: Zigate plugin stable5-5.1.018 started
2022-02-08 18:08:37.930 Error: Domoticz(pid:1793, tid:1841('Zigate')) received fatal signal 11 (Segmentation fault)
2022-02-08 18:08:37.930 Error: siginfo address=0x701, address=(nil)
Merci d'avance,
