[Résolu] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
Publié : 02 avr. 2022, 22:22
J'ai réinstallé le plugin v6. Le firmware est le 3.21.
Tous les tests avec TestGUI (https://zigate.fr/documentation/tester- ... /?seq_no=2) fonctionne jusqu'à l'inclusion.
Les logs domoticz:
Merci de votre aide
Les logs domoticz:
2022-04-02 22:06:35.247 ZiGateV6: Worker thread started.
2022-04-02 22:06:35.247 Status: ZiGateV6: Entering work loop.
2022-04-02 22:06:35.247 Status: ZiGateV6: Started.
2022-04-02 22:06:37.052 Status: Python EventSystem: Initializing event module.
2022-04-02 22:06:38.821 ZiGateV6: Zigbee for Domoticz plugin started!
2022-04-02 22:06:38.847 ZiGateV6: load PluginConf
2022-04-02 22:06:38.851 ZiGateV6: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-04-02 22:06:38.851 ZiGateV6: is_domoticz_db_available: True
2022-04-02 22:06:38.852 ZiGateV6: /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-49.json timestamp is 1648927519.5731952
2022-04-02 22:06:38.852 ZiGateV6: Dz PluginConf is older than Json Dz: 0 Json: 1648927519.5731952
2022-04-02 22:06:38.854 ZiGateV6: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-04-02 22:06:38.854 ZiGateV6: is_domoticz_db_available: True
2022-04-02 22:06:38.857 ZiGateV6: Starting LoggingManagement thread
2022-04-02 22:06:38.858 ZiGateV6: start_logging_thread
2022-04-02 22:06:38.860 ZiGateV6: logging_thread - listening
2022-04-02 22:06:38.815 Status: ZiGateV6: Initialized version 6.1, author 'pipiche38'
2022-04-02 22:06:38.856 Status: ZiGateV6: PluginAnalytics set to 1
2022-04-02 22:06:38.856 Status: ZiGateV6: Lang set to fr-FR
2022-04-02 22:06:38.856 Status: ZiGateV6: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-49.json
2022-04-02 22:06:38.856 Status: ZiGateV6: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-04-02 22:06:38.856 Status: ZiGateV6: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee/
2022-04-02 22:06:38.856 Status: ZiGateV6: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/
2022-04-02 22:06:38.857 Status: ZiGateV6: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/
2022-04-02 22:06:38.857 Status: ZiGateV6: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware/
2022-04-02 22:06:38.857 Status: ZiGateV6: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports/
2022-04-02 22:06:38.857 Status: ZiGateV6: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www/
2022-04-02 22:06:38.857 Status: ZiGateV6: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/
2022-04-02 22:06:38.860 Status: ZiGateV6: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs//PluginZigbee_49.log
2022-04-02 22:06:38.880 Status: ZiGateV6: Zigate plugin stable6-6.1.001 started
2022-04-02 22:06:38.954 Status: ZiGateV6: DeviceConf loaded - 23 confs loaded
2022-04-02 22:06:38.924 Error: ZiGateV6: Device creation failed, Domoticz settings prevent accepting new devices.
2022-04-02 22:06:38.924 Error: ZiGateV6: createAdminWidget - Fail to create Zigate Status 49. ID: -1, Name: 'Zigate Status 49', nValue: 0, sValue: ''
2022-04-02 22:06:38.924 Error: ZiGateV6: createNotificationWidget - Fail to create Zigate Notifications 49. ID: -1, Name: 'Zigate Notifications 49', nValue: 0, sValue: ''
2022-04-02 22:06:39.834 ZiGateV6: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-04-02 22:06:39.834 ZiGateV6: is_domoticz_db_available: True
2022-04-02 22:06:39.843 ZiGateV6: is_domoticz_db_available: Fashion: True , Major: 2022, Minor: 1
2022-04-02 22:06:39.843 ZiGateV6: is_domoticz_db_available: True
2022-04-02 22:06:39.837 Status: ZiGateV6: DeviceConf loaded - 331 confs loaded
2022-04-02 22:06:39.838 Status: ZiGateV6: load ListOfDevice
2022-04-02 22:06:39.846 Status: ZiGateV6: 0 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-49.txt
2022-04-02 22:06:39.849 Status: ZiGateV6: Transport mode: USB
2022-04-02 22:06:40.502 Status: ZiGateV6: ZigateTransport: Serial Connection open: Serial<id=0x606afcd0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2022-04-02 22:06:40.512 Status: ZiGateV6: ZigateTransport: writer_thread Thread start.
2022-04-02 22:06:40.514 Status: ZiGateV6: ZigateTransport: thread_processing_and_sending Thread start.
2022-04-02 22:06:40.539 Status: ZiGateV6: Start Web Server connection
2022-04-02 22:06:40.570 Status: ZiGateV6: Web backend for Web User Interface started on port: 9440
2022-04-02 22:07:53.069 Error: ZiGateV6: [ 61] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-04-02 22:07:53.099 Error: ZiGateV6: [ ] Stop the plugin and check the Coordinator connectivity.
2022-04-02 22:07:54.071 Error: ZiGateV6: [ 62] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-04-02 22:07:54.105 Error: ZiGateV6: [ ] Stop the plugin and check the Coordinator connectivity.
2022-04-02 22:07:55.074 Error: ZiGateV6: [ 63] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
pi@domoticz-tours:~ $ dmesg | grep tty
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
[ 0.001130] printk: console [tty1] enabled
[ 3.085943] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.125713] printk: console [ttyAMA0] enabled
[ 4.591322] kgdboc=ttyAMA0,115200
[ 7.044344] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 9.347728] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 9.350644] cdc_acm 1-1.5:1.0: ttyACM1: USB ACM device
[ 9.607584] usb 1-1.2.4: pl2303 converter now attached to ttyUSB0
[ 33.814647] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[ 34.401615] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
pi@domoticz-tours:~ $ ls -l /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 0 avril 2 22:21 /dev/ttyUSB0
pi@domoticz-tours:~ $ ls -l /dev/serial/by-id/*
lrwxrwxrwx 1 root root 13 avril 2 22:06 /dev/serial/by-id/usb-0658_0200-if00 -> ../../ttyACM1
lrwxrwxrwx 1 root root 13 avril 2 22:06 /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_55639313133351F08022-if00 -> ../../ttyACM0
lrwxrwxrwx 1 root root 13 avril 2 22:06 /dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller-if00-port0 -> ../../ttyUSB0
