Page 1 sur 2
[Résolu] Error: Zigbee: DeviceExist - Found True some inconsistency Inputs
Publié : 20 oct. 2022, 19:29
par Aile
Depuis ce matin, j'ai l'erreur ci-dessous :
 Error: Zigbee: DeviceExist - Found True some inconsistency Inputs: 0000 ffffffffffffffff instead of 00124b00257cafd2
Le phénomène est survenu sans aucune modification, sur un système qui fonctionnait parfaitement.
J'ai tenté la mise à jour de la dernière beta du plugin , sans succès.
Voici le log depuis le lancement du plugin :
2022-10-20 19:21:19.679 Status: Zigbee: Stop directive received.
2022-10-20 19:21:19.695 Status: Zigbee: Shuting down co-routine
2022-10-20 19:21:19.695 Status: Zigbee: ZigpyTransport: thread_processing_and_sending Thread stop.
2022-10-20 19:21:36.788 Status: Zigbee: Coordinator backup is available: C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Data//Coordinator-05.backup
2022-10-20 19:21:38.958 Status: Zigbee: Statistics on message
2022-10-20 19:21:38.958 Status: Zigbee: PDM load(s) : 0
2022-10-20 19:21:38.958 Status: Zigbee: ZiGate reacting time
2022-10-20 19:21:38.958 Status: Zigbee: Max : 0 sec
2022-10-20 19:21:38.958 Status: Zigbee: Average : 0 sec
2022-10-20 19:21:38.958 Status: Zigbee: ZiGate processing time on Rx
2022-10-20 19:21:38.959 Status: Zigbee: Average : 0 sec
2022-10-20 19:21:38.959 Status: Zigbee: Sent:
2022-10-20 19:21:38.959 Status: Zigbee: TX commands : 91
2022-10-20 19:21:38.959 Status: Zigbee: Max Load (Queue) : 3
2022-10-20 19:21:38.959 Status: Zigbee: Max aPDU (Queue) : 0
2022-10-20 19:21:38.959 Status: Zigbee: Max nPDU (Queue) : 0
2022-10-20 19:21:38.959 Status: Zigbee: TX failed : 0 (0.0%)
2022-10-20 19:21:38.959 Status: Zigbee: TX timeout : 0 (0.0%)
2022-10-20 19:21:38.959 Status: Zigbee: TX data timeout : 0 (0.0%)
2022-10-20 19:21:38.959 Status: Zigbee: TX reTransmit : 0 (0.0%)
2022-10-20 19:21:38.960 Status: Zigbee: TX APS Failure : 0 (0.0%)
2022-10-20 19:21:38.960 Status: Zigbee: TX APS Ack : 16 (17.58%)
2022-10-20 19:21:38.960 Status: Zigbee: TX APS Nck : 0 (0.0%)
2022-10-20 19:21:38.960 Status: Zigbee: Received:
2022-10-20 19:21:38.960 Status: Zigbee: RX frame : 621
2022-10-20 19:21:38.960 Status: Zigbee: RX crc errors : 0 (0.0%)
2022-10-20 19:21:38.960 Status: Zigbee: RX lentgh errors : 0 (0.0%)
2022-10-20 19:21:38.961 Status: Zigbee: RX clusters : 110
2022-10-20 19:21:38.961 Status: Zigbee: RX clusters KO : 0
2022-10-20 19:21:38.961 Status: Zigbee: Operating time : 0 Hours 30 Mins 23 Secs
2022-10-20 19:21:39.125 Status: Zigbee: Exiting work loop.
2022-10-20 19:21:39.203 Status: Zigbee: Stopping threads.
2022-10-20 19:21:39.203 Status: Zigbee: Stopped.
2022-10-20 19:21:44.351 Status: Zigbee: Started.
2022-10-20 19:21:44.351 Status: Zigbee: Entering work loop.
2022-10-20 19:21:45.695 Status: Zigbee: Initialized version 6.4, author 'pipiche38'
2022-10-20 19:21:45.695 Status: Zigbee: Checking Python modules C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\requirements.txt
2022-10-20 19:21:46.257 Status: Zigbee: Checking Python modules C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\requirements.txt
2022-10-20 19:21:46.304 Status: Zigbee: PluginAnalytics set to 1
2022-10-20 19:21:46.304 Status: Zigbee: Lang set to fr-FR
2022-10-20 19:21:46.304 Status: Zigbee: channel set to 24
2022-10-20 19:21:46.304 Status: Zigbee: filename set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Conf/PluginConf-05.json
2022-10-20 19:21:46.304 Status: Zigbee: pluginHome set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\
2022-10-20 19:21:46.304 Status: Zigbee: homedirectory set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\
2022-10-20 19:21:46.304 Status: Zigbee: pluginData set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Data/
2022-10-20 19:21:46.304 Status: Zigbee: pluginConfig set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Conf/
2022-10-20 19:21:46.304 Status: Zigbee: pluginOTAFirmware set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\OTAFirmware/
2022-10-20 19:21:46.304 Status: Zigbee: pluginReports set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Reports/
2022-10-20 19:21:46.304 Status: Zigbee: pluginWWW set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\www/
2022-10-20 19:21:46.304 Status: Zigbee: pluginLogs set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Logs/
2022-10-20 19:21:46.304 Status: Zigbee: ControllerInRawMode set to 1
2022-10-20 19:21:46.304 Status: Zigbee: Please watch plugin log into C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Logs//PluginZigbee_05.log
2022-10-20 19:21:46.335 Status: Zigbee: Zigbee for Domoticz (z4d) plugin beta6-6.4.002 started
2022-10-20 19:21:46.351 Status: Zigbee: DeviceConf loaded - 22 confs loaded
2022-10-20 19:21:46.585 Status: Zigbee: DeviceConf loaded - 365 confs loaded
2022-10-20 19:21:46.585 Status: Zigbee: load ListOfDevice
2022-10-20 19:21:46.648 Status: Zigbee: 15 Entries loaded from C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Data/DeviceList-5.txt
2022-10-20 19:21:46.695 Status: Zigbee: Transport mode: ZigpyZNP
2022-10-20 19:21:47.804 Status: Zigbee: Start Zigpy Transport on ZNP
2022-10-20 19:21:49.288 Météo: Temp + Humidity + Baro (Météo)
2022-10-20 19:21:49.382 Météo: Wind (Vent/Température)
2022-10-20 19:21:49.429 Météo: Rain (Pluie)
2022-10-20 19:21:53.801 Sunrise: 07:55:00 SunSet: 18:44:00
2022-10-20 19:21:53.801 Day length: 10:49:00 Sun at south: 13:19:00
2022-10-20 19:21:53.801 Civil twilight start: 07:26:00 Civil twilight end: 19:13:00
2022-10-20 19:21:53.801 Nautical twilight start: 06:53:00 Nautical twilight end: 19:46:00
2022-10-20 19:21:53.801 Astronomical twilight start: 06:19:00 Astronomical twilight end: 20:19:00
2022-10-20 19:21:53.863 Active notification Subsystems: email, http (2/13)
2022-10-20 19:21:53.879 Starting shared server on: :::6144
2022-10-20 19:21:53.785 Status: Domoticz V2022.1 (build 14500) (c)2012-2022 GizMoCuz
2022-10-20 19:21:53.785 Status: Build Hash: 6524c31e7, Date: 2022-09-08 20:43:18
2022-10-20 19:21:53.785 Status: Startup Path: C:\Program Files (x86)\Domoticz\
2022-10-20 19:21:53.863 Status: PluginSystem: Started, Python version '3.8.10', 4 plugin definitions loaded.
2022-10-20 19:21:53.863 Status: WebServer(HTTP) started on address: :: with port 8080
2022-10-20 19:21:53.879 Status: WebServer(SSL) started on address: :: with port 443
2022-10-20 19:21:53.879 Status: TCPServer: shared server started...
2022-10-20 19:21:53.879 Status: RxQueue: queue worker started...
2022-10-20 19:21:55.935 Status: Consommations: Worker started...
2022-10-20 19:21:55.935 Status: Zigbee: Started.
2022-10-20 19:21:55.935 Status: Météo: Worker started...
2022-10-20 19:21:55.935 Status: Zigbee: Entering work loop.
2022-10-20 19:21:56.013 Status: EventSystem: reset all events...
2022-10-20 19:21:56.013 Status: Carte-mère: Hardware Monitor: Started (OStype Windows)
2022-10-20 19:21:56.013 Status: NotificationSystem: thread started...
2022-10-20 19:21:56.013 Status: dzVents: Write file: C:\Program Files (x86)\Domoticz\scripts\dzVents\generated_scripts\Notifications.lua
2022-10-20 19:21:56.013 Status: dzVents: Write file: C:\Program Files (x86)\Domoticz\scripts\dzVents\generated_scripts\global_data.lua
2022-10-20 19:21:56.013 Status: EventSystem: reset all device statuses...
2022-10-20 19:21:56.154 Status: RF Link: Using serial port: COM3
2022-10-20 19:21:56.263 Status: Python EventSystem: Initializing event module.
2022-10-20 19:21:56.263 Status: EventSystem: Started
2022-10-20 19:21:56.263 Status: EventSystem: Queue thread started...
2022-10-20 19:21:56.372 Status: PluginSystem: 2 plugins started.
2022-10-20 19:21:57.107 Status: RF Link: Controller Initialized!...
2022-10-20 19:21:57.185 Status: RF Link: RFLink Detected, Version: 1.1 Revision: 48 Build: 4
2022-10-20 19:21:57.841 Status: Zigbee: Initialized version 6.4, author 'pipiche38'
2022-10-20 19:21:57.841 Status: Zigbee: Checking Python modules C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\requirements.txt
2022-10-20 19:21:58.357 (Commandes Infrarouge) Updating device from 0:'Off' to have values 0:'Off'.
2022-10-20 19:21:58.372 ($Infrarouge - RF Commandes) Updating device from 0:'Off' to have values 0:'Off'.
2022-10-20 19:21:58.513 Status: Zigbee: Checking Python modules C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\requirements.txt
2022-10-20 19:21:58.591 Status: Zigbee: PluginAnalytics set to 1
2022-10-20 19:21:58.591 Status: Zigbee: Lang set to fr-FR
2022-10-20 19:21:58.607 Status: Zigbee: channel set to 24
2022-10-20 19:21:58.622 Status: Zigbee: filename set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Conf/PluginConf-05.json
2022-10-20 19:21:58.622 Status: Zigbee: pluginHome set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\
2022-10-20 19:21:58.638 Status: Zigbee: homedirectory set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\
2022-10-20 19:21:58.653 Status: Zigbee: pluginData set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Data/
2022-10-20 19:21:58.653 Status: Zigbee: pluginConfig set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Conf/
2022-10-20 19:21:58.669 Status: Zigbee: pluginOTAFirmware set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\OTAFirmware/
2022-10-20 19:21:58.669 Status: Zigbee: pluginReports set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Reports/
2022-10-20 19:21:58.685 Status: Zigbee: pluginWWW set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\www/
2022-10-20 19:21:58.685 Status: Zigbee: pluginLogs set to C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Logs/
2022-10-20 19:21:58.685 Status: Zigbee: ControllerInRawMode set to 1
2022-10-20 19:21:58.685 Status: Zigbee: Please watch plugin log into C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Logs//PluginZigbee_05.log
2022-10-20 19:21:58.700 Status: Incoming connection from: 127.0.0.1
2022-10-20 19:21:58.700 Status: Zigbee: Zigbee for Domoticz (z4d) plugin beta6-6.4.002 started
2022-10-20 19:21:58.700 Status: Zigbee: DeviceConf loaded - 22 confs loaded
2022-10-20 19:21:58.966 Status: Zigbee: DeviceConf loaded - 365 confs loaded
2022-10-20 19:21:58.966 Status: Zigbee: load ListOfDevice
2022-10-20 19:21:59.060 Status: Zigbee: 15 Entries loaded from C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigbee\Data/DeviceList-5.txt
2022-10-20 19:21:59.107 Status: Zigbee: Transport mode: ZigpyZNP
2022-10-20 19:22:00.411 Status: Zigbee: Start Zigpy Transport on ZNP
2022-10-20 19:22:00.427 Status: Zigbee: Starting radio znp port: COM4
2022-10-20 19:22:00.427 Status: Zigbee: Start Web Server connection
2022-10-20 19:22:00.427 Status: Zigbee: ZigpyTransport: thread_processing_and_sending Thread start.
2022-10-20 19:22:00.630 Status: Zigbee: Started radio znp port: COM4
2022-10-20 19:22:00.949 Status: Zigbee: Domoticz Widgets usage is at 6.7 % (238 units free)
2022-10-20 19:22:00.949 Status: Zigbee: Web backend for Web User Interface started on port: 9440
2022-10-20 19:22:01.886 Queued asynchronous read aborted (127.0.0.1:57609), [2] End of file.
2022-10-20 19:22:02.574 Matériel factice: Light/Switch (Présence)
2022-10-20 19:22:02.574 Status: EventSystem: Script event triggered: Présence
2022-10-20 19:22:02.699 Status: EventSystem: Script event triggered: Ping
2022-10-20 19:22:03.949 (Statut BroadLink) Updating device from 1:'On' to have values 1:'FIN de remotePlugin'.
2022-10-20 19:22:03.964 (Statut BroadLink) Updating device from 1:'FIN de remotePlugin' to have values 1:'On'.
2022-10-20 19:22:03.980 Queued asynchronous read aborted (127.0.0.1:57614), [2] End of file.
Le périphérique 00124b00257cafd2 correspond au coordinateur Sonoff.
La version de Domoticz est la 2022.1 build 14500.
Re: Error: Zigbee: DeviceExist - Found True some inconsistency Inputs
Publié : 20 oct. 2022, 22:57
par pipiche
serait-il possible d'avoir les logs sous la forme d'un fichier.
fichier log Domoticz
fichier logs du plugin
Merci d'avance
Publié : 21 oct. 2022, 09:33
par Aile
Bonjour pipiche,
Certains de mes appareils ménagers ayant perdu l'heure, j'ai examiné les logs du PC et j'ai vu qu'il y avait effectivement eu une panne de courant le 20 octobre à 5h43:46.
Ca fait plusieurs mois que je dois mettre un onduleur sur mon Domoticz. Bien fait pour moi :evil: !
En tous cas, le problème fait suite à cette panne de courant.
Les logs Zigbee sont en pièce jointe.
Malheureusement, je ne peux pas joindre le log Domoticz, puisque les événements les plus anciens datent du 20/10 à 23h00 (le message d'erreur sature le log...)
Publié : 21 oct. 2022, 10:49
par pipiche
peux-tu me donner le fichier Data/DeviceList-05.txt après avoir arrété le plugin
Publié : 21 oct. 2022, 17:28
par Aile
Voila :) !
Publié : 21 oct. 2022, 17:57
par pipiche
Assez etrange
peux-tu activer les logs suivants
- debugTransportZigpyZNP
relancer le plugin et le laisser démarrer et me refournir les logs du plugin .
As-tu essayer de faire un stop du plugin et/ou de Domoticz
débrancher la clef
attendre 2 minutes
rebrancher la clef
et relancer ?
Est-ce que l'antenne (si il y en a est bien vissée sur la clef) ?
Publié : 21 oct. 2022, 19:40
par Aile
Voila le log Zigbee en pièce jointe.
Le débranchement de la clef après arrêt de Domoticz n'a rien donné.
Publié : 21 oct. 2022, 20:03
par pipiche
j'ai remonté le problème coté zigpy
https://github.com/zigpy/zigpy-znp/issues/188
Voyons ce qu'ils disent.
Sinon l'alternative que je vois c'est de repartir avec une initialisation (en prenant quelques precaution)
il suffirait de juste re-appairer les objets sans rien perdre coté Domoticz. Dis moi si ca te convient, et je te dis quoi faire
Publié : 22 oct. 2022, 09:08
par Aile
Merci du coup de main, pipiche.
Ok pour la réinitialisation, mais ne faut-il pas attendre la réponse de zigpy pour pouvoir faire un diagnostic de l'erreur ?
Publié : 22 oct. 2022, 10:12
par pipiche
as-tu la possibilité de passer sur la branche beta du plugin
git pull
git checkout beta6
et relancer le plugin
dis moi ce que ca donne ?
