OWON THS 317 & MQTT Auto Discovery Client Gateway with LAN interface
Publié : 04 janv. 2023, 17:23
par calou033
J'ai une sonde OWON THS 317 qui est reconnu par zigbee2mqtt mais pas de device découvert par le plugin MQTT Auto Discovery Client Gateway with LAN interface.
Comment l'installer dans domoticz ?
Ci dessous les entrées pour cette sonde du serveur mosquitto
mosquitto_sub -h localhost -t "homeassistant/sensor/0x3c6a2cfffed2455b/battery/config"
{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x3c6a2cfffed2455b"],"manufacturer":"OWON","model":"Temperature sensor (THS317-ET)","name":"Sonde wired 01"},"device_class":"battery","enabled_by_default":true,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/Sonde wired 01","name":"Sonde wired 01 battery","state_class":"measurement","state_topic":"zigbee2mqtt/Sonde wired 01","unique_id":"0x3c6a2cfffed2455b_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}
mosquitto_sub -h localhost -t "homeassistant/sensor/0x3c6a2cfffed2455b/temperature/config"
{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x3c6a2cfffed2455b"],"manufacturer":"OWON","model":"Temperature sensor (THS317-ET)","name":"Sonde wired 01"},   "device_class":"temperature","enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/Sonde wired 01","name":"Sonde wired 01 temperature","state_class":"measurement","state_topic":"zigbee2mqtt/Son   de wired 01","unique_id":"0x3c6a2cfffed2455b_temperature_zigbee2mqtt","unit_of_measurement":"°C","value_template":"{{ value_json.temperature }}"}
mosquitto_sub -h localhost -t "homeassistant/sensor/0x3c6a2cfffed2455b/linkquality/config"
{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x3c6a2cfffed2455b"],"manufacturer":"OWON","model":"Temperature sensor (THS317-ET)","name":"Sonde wired 01"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/Sonde wired 01","name":"Sonde wired 01 linkquality","state_class":"measurement","state_topic":"zigbee2mqtt/Sonde wired 01","unique_id":"0x3c6a2cfffed2455b_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}
