[Résolu]Question autour des objets désactivés
Publié : 02 oct. 2024, 21:47
Je suis sous Domoticz beta 2024.7 (build 16251) et le plugin Zigate en version 7.1.012 [5.313].
Sur la page d'accueil au niveau des "Objets du plugin", je vois que j'ai un objet désactivé.
Lorsque je vais dans la Gestion des objets, il apparait bien en "Live" mais "notDB" et "Optimisé".
L'objet en question est : https://zigbee.blakadder.com/Aeotec_ZAG001-C15.html
Voici les infos de l'objet en question :
Est-ce normal qu'il apparaisse en Désactivé ?
Je précise qu'il est bien présent dans le maillage de mon réseau donc fonctionnel.
Merci pare avance.
Cordialement.
{"Filename":"WG001-Z01.json","Configuration":{"_comment":"","_version":"","_blakadder":"","_source":"","Ep":{"01":{"0000":"","0003":"","0019":"","Type":{}},"02":{"0000":"","Type":{}}},"Type":"","ClusterToBind":[],"ConfigureReporting":{},"ReadAttributes":{"0000":[]},"Param":{},"GroupMembership":{}},"rawInfos":{"Version":"3","ZDeviceName":"","Status":"notDB","SQN":"31","Ep":{"01":{"0000":{"0004":"AL001","0005":"WG001-Z01"},"0003":{},"0019":{},"Type":""},"02":{"0000":{"0004":"AL001","0005":"WG001-Z01"},"Type":""}},"Heartbeat":"5194835","RIA":"0","LQI":116,"Battery":{},"Model":"WG001-Z01","ForceAckCommands":[],"MacCapa":"8e","IEEE":"b43522fffe101576","Type":"","ProfileID":"0104","ZDeviceID":"0820","App Version":"","Attributes List":{},"DeviceType":"FFD","HW Version":"","Last Cmds":[],"LogicalType":"Router","Manufacturer":"1310","Manufacturer Name":"AL001","NbEp":"3","PowerSource":"Main","ReadAttributes":{"Ep":{"01":{"0000":{"TimeStamp":1701874228,"iSQN":{"0004":266,"0005":266},"Attributes":{"0004":"00","0005":"00"},"ZigateRequest":{}}},"02":{"0000":{"TimeStamp":1701874228,"iSQN":{"0004":267,"0005":267},"Attributes":{"0004":"00","0005":"00"},"ZigateRequest":{}}},"f2":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}},"ReceiveOnIdle":"On","Stack Version":"","Stamp":{"time":1727898027.3555024,"Time":"2024-10-02 21:40:27","MsgType":"8011","LastSeen":1727898027},"ZCL Version":"","Health":"Live","CertifiedDevice":true,"Max Rx":"0052","WriteAttributes":{"Ep":{"01":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0003":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}},"02":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}},"descriptor_capability":"00","Capability":["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"],"server_mask":"2c00","bitfield":"4001","NeighbourTableSize":8,"Epv2":{"01":{"ProfileID":"0104","ZDeviceID":"0008","ClusterIn":{"0000":{},"0003":{}},"ClusterOut":{"0003":{},"0019":{}}},"02":{"ProfileID":"0104","ZDeviceID":"0820","ClusterIn":{"1000":{},"0000":{},"0003":{}},"ClusterOut":{"1000":{},"0003":{},"0006":{},"0008":{}}}},"Neighbours":[{"SQN":0,"Status":"","TimeStamp":1702064960,"Time":1702064960,"Devices":[{"0000":{"_relationshp":"Parent","_devicetype":"Coordinator","_depth":0,"_lnkqty":247,"_rxonwhenidl":"Rx-On","_IEEE":"00158d0001ed453f","_permitjnt":"??"}},{"0af6":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":43,"_rxonwhenidl":"Rx-On","_IEEE":"60a423fffed5a2c6","_permitjnt":"??"}},{"0d56":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":75,"_rxonwhenidl":"Rx-On","_IEEE":"003c84fffe6a9c5c","_permitjnt":"??"}},{"9f15":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":65,"_rxonwhenidl":"Rx-On","_IEEE":"540f57fffe37c3d5","_permitjnt":"??"}},{"b37d":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":49,"_rxonwhenidl":"Rx-On","_IEEE":"540f57fffee19524","_permitjnt":"??"}},{"bfbc":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":41,"_rxonwhenidl":"Rx-On","_IEEE":"b4e3f9fffe1e575f","_permitjnt":"??"}},{"c0fe":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":123,"_rxonwhenidl":"Rx-On","_IEEE":"003c84fffeb1440b","_permitjnt":"??"}},{"5bea":{"_relationshp":"Child","_devicetype":"End Device","_depth":2,"_lnkqty":116,"_rxonwhenidl":"Rx-Off","_IEEE":"00158d00066f97da","_permitjnt":"Off"}}]},{"SQN":0,"Status":"","TimeStamp":1716039858,"Time":1716039858,"Devices":[{"0000":{"_relationshp":"Parent","_devicetype":"Coordinator","_depth":0,"_lnkqty":171,"_rxonwhenidl":"Rx-On","_IEEE":"00158d0001ed453f","_permitjnt":"??"}},{"0af6":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":39,"_rxonwhenidl":"Rx-On","_IEEE":"60a423fffed5a2c6","_permitjnt":"??"}},{"0d56":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":46,"_rxonwhenidl":"Rx-On","_IEEE":"003c84fffe6a9c5c","_permitjnt":"??"}},{"2220":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":32,"_rxonwhenidl":"Rx-On","_IEEE":"847127fffe937439","_permitjnt":"??"}},{"9f15":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":51,"_rxonwhenidl":"Rx-On","_IEEE":"540f57fffe37c3d5","_permitjnt":"??"}},{"b37d":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":51,"_rxonwhenidl":"Rx-On","_IEEE":"540f57fffee19524","_permitjnt":"??"}},{"bfbc":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":49,"_rxonwhenidl":"Rx-On","_IEEE":"b4e3f9fffe1e575f","_permitjnt":"??"}},{"c0fe":{"_relationshp":"Sibling","_devicetype":"Router","_depth":15,"_lnkqty":144,"_rxonwhenidl":"Rx-On","_IEEE":"003c84fffeb1440b","_permitjnt":"??"}}]}],"ConfigSource":"DeviceConf","RoutingTable":[{"SQN":0,"Status":"Success","TimeStamp":1702064960,"Time":1702064960,"RoutingTableTableSize":16,"Devices":[{"0000":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"f4d6":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"0af6"}},{"03b5":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"0af6"}},{"bfbc":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"bfbc"}},{"32d9":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"0af6"}},{"0af6":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"0af6"}},{"d96d":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"bfbc"}}]},{"SQN":0,"Status":"Success","TimeStamp":1716039858,"Time":1716039858,"RoutingTableTableSize":16,"Devices":[{"0000":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2220":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"0af6"}},{"bfbc":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"bfbc"}},{"0af6":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"0af6"}}]}],"Max Tx":"0052","macapa":"8e","_rawNodeDescriptor":"1310005200522c00008e524001","Max Buffer Size":"52","ConsistencyCheck":"not in DZ","ErrorManagement":0,"RollingLQI":[10,116,61,116,116,116]}}Je précise qu'il est bien présent dans le maillage de mon réseau donc fonctionnel.
Merci pare avance.
Cordialement.
