Soucis mise a jour vers 7.1.022
Publié : 02 juin 2025, 18:01
Salut
J'ai un soucis avec mes 2 zigates, zigate v1 en wifi et zigate v2 en usb.
J'ai essayé de faire la mise a jour( je suis en 7.1.021) par le webui, ca a l'air de fonctionner, mais au redémarrage je suis toujours sur 7.1.021
J'ai essayé via le terminal, il me dit que c'est deja a jour....
Et au démarrage j'ai ces erreurs :
2025-06-02 17:57:12.083 Error: Zigate: Call to function 'onHeartbeat' failed, exception details:
2025-06-02 17:57:12.083 Status: Zigate: Zigbee4Domoticz plugin: upgrade available: 7.1.022
2025-06-02 17:57:12.084 Status: Zigate: Z4D found a recent plugin version (7.1.022) on gitHub. You are on (7.1.021) ***
2025-06-02 17:57:12.084 Error: Zigate: Traceback (most recent call last):
2025-06-02 17:57:12.084 Error: Zigate: File "/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py", line 1635, in onHeartbeat
2025-06-02 17:57:12.084 Error: Zigate: _plugin.onHeartbeat()
2025-06-02 17:57:12.085 Error: Zigate: File "/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py", line 908, in onHeartbeat
2025-06-02 17:57:12.085 Error: Zigate: _check_plugin_version( self )
2025-06-02 17:57:12.085 Error: Zigate: File "/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py", line 1773, in _check_plugin_version
2025-06-02 17:57:12.085 Error: Zigate: if is_zigate_firmware_available(
2025-06-02 17:57:12.085 Error: Zigate: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-06-02 17:57:12.085 Error: Zigate: File "/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/checkingUpdate.py", line 168, in is_zigate_firmware_available
2025-06-02 17:57:12.085 Error: Zigate: if int(availfirmMinor, 16) > int(currentFirmwareVersion, 16):
2025-06-02 17:57:12.085 Error: Zigate: TypeError: int() can't convert non-string with explicit base
2025-06-02 17:57:12.111 Error: ZigateV2: Call to function 'onHeartbeat' failed, exception details:
2025-06-02 17:57:12.111 Status: ZigateV2: Zigbee4Domoticz plugin: upgrade available: 7.1.022
2025-06-02 17:57:12.111 Status: ZigateV2: Z4D found a recent plugin version (7.1.022) on gitHub. You are on (7.1.021) ***
2025-06-02 17:57:12.112 Error: ZigateV2: Traceback (most recent call last):
2025-06-02 17:57:12.112 Error: ZigateV2: File "/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py", line 1635, in onHeartbeat
2025-06-02 17:57:12.112 Error: ZigateV2: _plugin.onHeartbeat()
2025-06-02 17:57:12.112 Error: ZigateV2: File "/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py", line 908, in onHeartbeat
2025-06-02 17:57:12.112 Error: ZigateV2: _check_plugin_version( self )
2025-06-02 17:57:12.112 Error: ZigateV2: File "/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py", line 1773, in _check_plugin_version
2025-06-02 17:57:12.112 Error: ZigateV2: if is_zigate_firmware_available(
2025-06-02 17:57:12.112 Error: ZigateV2: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-06-02 17:57:12.112 Error: ZigateV2: File "/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/checkingUpdate.py", line 168, in is_zigate_firmware_available
2025-06-02 17:57:12.112 Error: ZigateV2: if int(availfirmMinor, 16) > int(currentFirmwareVersion, 16):
2025-06-02 17:57:12.112 Error: ZigateV2: TypeError: int() can't convert non-string with explicit base
