RFlink
Publié : 12 juil. 2016, 15:09
bonjour,
Domoticz sur Raspberry Version: 3.4834
aucun appareil n’apparaît dans les logs
dans RFlink Loader j'ai bien mais sorties SerialPort Logging :
0;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R42;
10;version;
20;01;VER=1.1;REV=42;BUILD=0a;
20;02;Keeloq;ID=0edb;SWITCH=02;CMD=ON;BAT=OK;
20;03;Keeloq;ID=0edb;SWITCH=04;CMD=ON;BAT=OK;
20;04;Keeloq;ID=0edb;SWITCH=04;CMD=ON;BAT=OK;
20;05;Keeloq;ID=0edb;SWITCH=02;CMD=ON;BAT=OK;
20;06;Keeloq;ID=e764;SWITCH=02;CMD=ON;BAT=OK;
donc RFlink fonctionne
j'ai bien créé mon matériel
2 RFlink Oui RFLink Gateway USB /dev/ttyACM1 Désactiver
log Domoticz
2016-07-12 11:17:20.754 Domoticz V3.4834 (c)2012-2016 GizMoCuz
2016-07-12 11:17:20.754 Build Hash: 8398125, Date: 2016-03-02 07:43:51
2016-07-12 11:17:20.755 System: Raspberry Pi
2016-07-12 11:17:20.755 Startup Path: /home/pi/domoticz/
2016-07-12 11:17:21.159 Sunrise: 04:27:00 SunSet:20:02:00
2016-07-12 11:17:21.160 EventSystem: reset all events...
2016-07-12 11:17:21.259 Active notification subsystems: (0/11)
2016-07-12 11:17:21.292 WebServer(HTTP) started on address: :: with port 8080
2016-07-12 11:17:21.342 WebServer(SSL) started on address: :: with port 443
2016-07-12 11:17:21.356 Proxymanager started.
2016-07-12 11:17:21.371 Starting shared server on: :::6144
2016-07-12 11:17:21.387 TCPServer: shared server started...
2016-07-12 11:17:21.387 RxQueue: queue worker started...
2016-07-12 11:17:23.392 EventSystem: reset all events...
2016-07-12 11:17:23.404 Wunderground: Worker started...
2016-07-12 11:17:23.406 EventSystem: reset all device statuses...
2016-07-12 11:17:23.408 EventSystem: Started
2016-07-12 11:17:23.606 RFLink: Using serial port: /dev/ttyACM1
2016-07-12 11:17:24.404 MySensors: Using serial port: /dev/ttyACM0
2016-07-12 13:03:25.064 (Weather Underground) Temp + Humidity + Baro (THB)
2016-07-12 13:03:25.087 (Weather Underground) Wind (Unknown)
2016-07-12 13:03:25.092 (Weather Underground) Rain (Unknown)
2016-07-12 13:03:25.107 (Weather Underground) General/Visibility (Unknown)
2016-07-12 13:03:25.112 (Weather Underground) General/Solar Radiation (Unknown)
2016-07-12 13:03:49.693 Incoming connection from: 192.168.1.7
mais aucunes trames n'apparaient
j'ai zapé quelque chose ?
Merci pour votre aide
Lucien
10;version;
log Domoticz
Lucien
