Problème au reboot
Publié : 09 mai 2017, 16:16
j ai un soucis au reboot
voici les log
La date du début m'interpelle!
Et surtout domoticz me lance une fermeture des volets à 16h (....after sunset!)
2017-05-09 16:00:02.497 Schedule item started! Name: Volet Ethan, Type: After Sunset, DevID: 6, Time: 2017-05-09 16:00:02
une petite idée!
voici les log
une petite idée!
- 1970-01-01 01:00:15.399 OpenZWave: Driver Ready
1970-01-01 01:00:15.403 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
1970-01-01 01:00:15.404 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
1970-01-01 01:00:15.404 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
1970-01-01 01:00:15.404 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
1970-01-01 01:00:15.404 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
1970-01-01 01:00:15.405 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH MULTILEVEL, Label: Up, Instance: 1
1970-01-01 01:00:15.406 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH MULTILEVEL, Label: Down, Instance: 1
1970-01-01 01:00:15.406 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: BASIC WINDOW COVERING, Label: Open, Instance: 1
1970-01-01 01:00:15.407 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: BASIC WINDOW COVERING, Label: Close, Instance: 1
1970-01-01 01:00:15.410 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
1970-01-01 01:00:15.411 OpenZWave: Value_Added: Node: 14 (0x0e), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
1970-01-01 01:00:15.439 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
1970-01-01 01:00:15.440 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
1970-01-01 01:00:15.441 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: Alarm Type, Instance: 1
1970-01-01 01:00:15.442 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: Alarm Level, Instance: 1
1970-01-01 01:00:15.442 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
1970-01-01 01:00:15.442 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: Smoke, Instance: 1
1970-01-01 01:00:15.443 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: Heat, Instance: 1
1970-01-01 01:00:15.444 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: Burglar, Instance: 1
1970-01-01 01:00:15.444 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: Power Management, Instance: 1
1970-01-01 01:00:15.445 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: ALARM, Label: System, Instance: 1
1970-01-01 01:00:15.446 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: BATTERY, Label: Battery Level, Instance: 1
1970-01-01 01:00:15.447 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: SENSOR ALARM, Label: General, Instance: 1
1970-01-01 01:00:15.448 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: SENSOR ALARM, Label: Smoke, Instance: 1
1970-01-01 01:00:15.449 OpenZWave: Value_Added: Node: 15 (0x0f), CommandClass: SENSOR ALARM, Label: Heat, Instance: 1
1970-01-01 01:00:15.456 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
1970-01-01 01:00:15.457 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
1970-01-01 01:00:15.457 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SENSOR MULTILEVEL, Label: Luminance, Instance: 3
1970-01-01 01:00:15.459 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: BATTERY, Label: Battery Level, Instance: 1
1970-01-01 01:00:15.460 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SENSOR ALARM, Label: General, Instance: 1
1970-01-01 01:00:15.463 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
1970-01-01 01:00:15.464 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
1970-01-01 01:00:15.464 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
1970-01-01 01:00:15.464 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
1970-01-01 01:00:15.464 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
1970-01-01 01:00:15.466 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH MULTILEVEL, Label: Open, Instance: 1
1970-01-01 01:00:15.466 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH MULTILEVEL, Label: Close, Instance: 1
1970-01-01 01:00:15.467 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
1970-01-01 01:00:15.467 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: METER, Label: Energy, Instance: 1
1970-01-01 01:00:15.467 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: METER, Label: Power, Instance: 1
1970-01-01 01:00:15.471 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
1970-01-01 01:00:15.471 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: SENSOR MULTILEVEL, Label: Luminance, Instance: 3
1970-01-01 01:00:15.471 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: METER, Label: Energy, Instance: 1
1970-01-01 01:00:15.471 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: METER, Label: Power, Instance: 1
1970-01-01 01:00:15.472 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: THERMOSTAT MODE, Label: Mode, Instance: 1
1970-01-01 01:00:15.472 OpenZWave: Value_Added: Node: 21 (0x15), CommandClass: THERMOSTAT SETPOINT, Label: Heating 1, Instance: 1
1970-01-01 01:00:15.478 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
1970-01-01 01:00:15.478 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
1970-01-01 01:00:15.479 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
1970-01-01 01:00:15.479 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
1970-01-01 01:00:15.479 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
1970-01-01 01:00:15.481 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Open, Instance: 1
1970-01-01 01:00:15.481 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SWITCH MULTILEVEL, Label: Close, Instance: 1
1970-01-01 01:00:15.481 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
1970-01-01 01:00:15.481 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: METER, Label: Energy, Instance: 1
1970-01-01 01:00:15.482 OpenZWave: Value_Added: Node: 22 (0x16), CommandClass: METER, Label: Power, Instance: 1
1970-01-01 01:00:15.486 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
1970-01-01 01:00:15.487 OpenZWave: Value_Added: Node: 23 (0x17), CommandClass: BATTERY, Label: Battery Level, Instance: 1
1970-01-01 01:00:15.547 MQTT: Connecting to localhost:1883
1970-01-01 01:00:15.554 MySensors: Using serial port: /dev/ttyACM0
1970-01-01 01:00:15.472 (USB ZWave) General/Thermostat Mode (Thermostat Mode sdb)
1970-01-01 01:00:15.674 MQTT: connected to: localhost:1883
1970-01-01 01:00:15.605 (USB ZWave) Thermostat (Consigne temp sdb)
1970-01-01 01:00:15.779 MQTT: Subscribed
1970-01-01 01:00:15.723 (Yeelight) Lighting Limitless/Applamp (Lampe portail)
1970-01-01 01:00:15.854 Incoming connection from: 192.168.1.100
1970-01-01 01:00:15.863 User: Admin initiated a switch command (129/Lampe Lizea/Off)
1970-01-01 01:00:16.485 MySensors: Gateway Ready...
1970-01-01 01:00:16.561 MySensors: Gateway Version: 2.0.1-beta
1970-01-01 01:00:17.064 (OneWire) Temp (Temperature chambre Ehan)
1970-01-01 01:00:17.524 Hardware Monitor: Fetching data (System sensors)
1970-01-01 01:00:18.872 Error: YeeLight: Exception: connect: No route to host
2017-05-09 16:00:01.817 (USB ZWave) Temp (Temperature salle de bain)
2017-05-09 16:00:02.504 OpenZWave: Domoticz has send a Switch command!, Level: 0, NodeID: 13 (0x0d)
2017-05-09 16:00:02.615 Sunrise: 06:25:00 SunSet:20:55:00
2017-05-09 16:00:02.615 EventSystem: reset all events...
2017-05-09 16:00:02.505 (USB ZWave) Light/Switch (Volet Ethan)
2017-05-09 16:00:02.638 Schedule item started! Name: Volet Lizea, Type: After Sunset, DevID: 43, Time: 2017-05-09 16:00:02
2017-05-09 16:00:02.639 OpenZWave: Domoticz has send a Switch command!, Level: 0, NodeID: 18 (0x12)
2017-05-09 16:00:02.640 (USB ZWave) Usage (Unknown)
2017-05-09 16:00:02.644 (USB ZWave) General/kWh (kWh Meter)
2017-05-09 16:00:02.649 (USB ZWave) Light/Switch (Volet Lizea)
2017-05-09 16:00:02.750 Schedule item started! Name: jour_nuit, Type: After Sunset, DevID: 114, Time: 2017-05-09 16:00:02
2017-05-09 16:00:02.754 (Devices virtuels) Lighting 1 (jour_nuit)
2017-05-09 16:00:02.838 Schedule item started! Name: jour_nuit, Type: After Sunrise, DevID: 114, Time: 2017-05-09 16:00:02
2017-05-09 16:00:02.842 (Devices virtuels) Lighting 1 (jour_nuit)
2017-05-09 16:00:02.922 Schedule item started! Name: Consigne temp sdb, Type: On Time, ThermostatID: 72, Time: 2017-05-09 16:00:02
