[RESOLU] Xiaomi vaccum
Publié : 03 oct. 2017, 09:22
Voilà après avoir suivi le tuto suivant et les liens inclus: https://github.com/mrin/domoticz-mirobot-plugin + https://github.com/rytilahti/python-miio et là
Je n'arrive toujours pas à déclencher ou voir mon aspirateur.
Voilà les logs:
Le retour de la commande ssh suivante:
Et pourtant token et ip sont spécifiés pour moi cf capture d'écran:
Ma compagne a baptisé le xiaomi vacuum nono d'où les interrupteurs...
Merci à vous
Voilà les logs:
2017-10-03 08:59:28.501 New sensors allowed for 5 minutes...
2017-10-03 08:59:29.870 Error: (nono) Response mirobo-wrapper exception:
2017-10-03 08:59:29.870 CConnection_connect, connect request from 'onHeartbeat' ignored. Plugin is stopping.
2017-10-03 08:59:31.462 RFLink: 20;39;Alecto V4;ID=5a9a;TEMP=00b9;HUM=80;
2017-10-03 08:59:31.630 (RFLink) Temp + Humidity (Escalier Cave)
2017-10-03 08:59:45.513 RFLink: 20;3A;Alecto V4;ID=5ae9;TEMP=00c7;HUM=72;
2017-10-03 08:59:45.680 (RFLink) Temp + Humidity (Etage)
2017-10-03 08:59:52.621 Error: (nono) Response mirobo-wrapper exception:
2017-10-03 08:59:52.621 CConnection_connect, connect request from 'onHeartbeat' ignored. Plugin is stopping.
2017-10-03 08:59:52.621 Error: PluginSystem: Exception processing message.
2017-10-03 08:59:52.622 Error: PluginSystem: Exception processing message.
2017-10-03 08:59:52.622 CConnection_connect, connect request from 'onHeartbeat' ignored. Plugin is stopping.
2017-10-03 09:00:01.379 Starting automatic database backup procedure...
2017-10-03 09:00:06.463 RFLink: 20;3B;Alecto V4;ID=5a9a;TEMP=00b9;HUM=80;
2017-10-03 09:00:16.103 Error: (nono) Response mirobo-wrapper exception:
2017-10-03 09:00:16.103 CConnection_connect, connect request from 'onHeartbeat' ignored. Plugin is stopping.
2017-10-03 09:00:20.516 RFLink: 20;3C;Alecto V4;ID=5ae9;TEMP=00c7;HUM=72;
2017-10-03 09:00:25.983 Ending automatic database backup procedure...
2017-10-03 09:00:25.995 Error: EventSystem: in YeeLIght Desk: [string "--Temp Blanc Lamp Bureau yeelight..."]:7: attempt to index global 'devicechanged' (a nil value)
2017-10-03 09:00:26.221 (RFLink) Temp + Humidity (Escalier Cave)
2017-10-03 09:00:26.385 (RFLink) Temp + Humidity (Etage)
2017-10-03 09:00:38.798 Error: (nono) Response mirobo-wrapper exception:
2017-10-03 09:00:38.799 Error: PluginSystem: Exception processing message.
2017-10-03 09:00:38.799 (onHeartbeat) Failed to connect to IKEA tradfri COAP-adapter! Status: 111 Description: Connection refused
2017-10-03 09:00:38.799 CConnection_connect, connect request from 'onHeartbeat' ignored. Plugin is stopping.
2017-10-03 09:00:38.800 CConnection_connect, connect request from 'onHeartbeat' ignored. Plugin is stopping.
2017-10-03 09:00:41.465 RFLink: 20;3D;Alecto V4;ID=5a9a;TEMP=00b9;HUM=80;
2017-10-03 09:00:41.654 (RFLink) Temp + Humidity (Escalier Cave) Code : Tout sélectionner
Last login: Tue Oct 3 08:18:55 2017 from 185.189.113.40
pi@domoticz-tours:~ $ mirobo
You have to give ip and token!
Merci à vous
