bonjours,
j'ai ce problème et je ne trouve pas ce qui ce passe.
Pouriez vous m'éclairé s'il vous plaie.
Dans sudo pico ~/.homebridge/config.json j'ai mis ceci sans vraiment trop savoir
"bridge": {
"name": "Homebridge",
"username": "B8:27:EB:A8:68:D3",
"port": 51826,
"pin": "031-45-154"
"description": "Configuration file for (e)xtended Domoticz platform.",
"platforms": [
"platform": "eDomoticz",
"name": "eDomoticz",
"server": "192.168.1.29",
"port":" 2016",
"ssl": 0,
"roomid": 1,
"mqttenable": 1,
"mqttserver": "192.168.1.29",
"mqttport": "1883",
pi@raspberrypi:~ $ sudo homebridge
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdn ... ceRegister>
[2018-1-21 15:31:55] Loaded plugin: homebridge-edomoticz
[2018-1-21 15:31:55] Registering platform 'homebridge-edomoticz.eDomoticz'
[2018-1-21 15:31:55] ---
[2018-1-21 15:31:56] Loaded plugin: homebridge-lockitron
[2018-1-21 15:31:56] Registering accessory 'homebridge-lockitron.Lockitron'
[2018-1-21 15:31:56] ---
[2018-1-21 15:31:56] Loaded config.json with 0 accessories and 1 platforms.
[2018-1-21 15:31:56] Loading 1 platforms...
[2018-1-21 15:31:56] [eDomoticz] Initializing eDomoticz platform...
[2018-1-21 15:31:56] Loading 0 accessories...
Setup Payload:
X-HM://0023ISYWY7PB8
Scan this code with your HomeKit app on your iOS device to pair with Homebridge:
Or enter this code with your HomeKit app on your iOS device to pair with Homebridge:
│ 031-45-154 │
[2018-1-21 15:31:56] Homebridge is running on port 51826.
[2018-1-21 15:31:56] [eDomoticz] There was a problem connecting to Domoticz.
- Error: connect ECONNREFUSED 192.168.1.29:80
homekit siri, error:connect Econnrefused 192. etc
Pierre81260
Revenir à « DomoticZ : Question et réponses »
Aller
- DomoticZ : Généralités
- ↳ DomoticZ : Question et réponses
- ↳ DomoticZ : Les mises à jour
- DomoticZ : les protocoles et les objets
- ↳ Z-Wave
- ↳ ZigBee
- ↳ Le plugin ZigBeeForDomoticZ
- ↳ Toutes les infos sur le plugin ZigBeeForDomoticZ
- ↳ Rfxcom (433 et 866 Mhz)
- ↳ Rflink
- ↳ 1-Wire
- ↳ MQTT
- ↳ Le plugin MQTTMapper
- ↳ MySensors.org
- ↳ Xiaomi
- ↳ Les autres protocoles
- ↳ DIY, ESPEasy, Tasmota
- ↳ OpenKarotz et Domoticz
- ↳ La vidéo-surveillance
- ↳ Les autres objets
- DomoticZ : l'hébergement
- ↳ Raspberry, Linux et autres geekeries
- ↳ Docker, NAS, VM
- ↳ Windows & Domoticz
- DomoticZ : l’automatisation
- ↳ Scripts DzVents, LUA, Blockly, Shell, Python, Perl ...
- ↳ La Bibliothèque Scripts et Tutos (PAS DE QUESTIONS ICI, que des tutos SVP)
- DomoticZ : personnalisation et accès
- ↳ Domoticz et Internet
- ↳ Custom Pages
- ↳ Thèmes et Styles
- ↳ Android Domoticz App 2.0
- ↳ Applis Android et Apple
- Divers
- ↳ Bien utiliser le forum
- ↳ Achat-Vente matériel d'occasion
- ↳ De tout et de rien
- ↳ Présentation de votre installation domotique
