rflink
Publié : 03 juil. 2015, 16:39
par ledouble33
bonjour ,
je viens de faire une mise a jour de domoticz avec la derniere version 2563
j ai installer un arduino et suivi les tuto 1 et 2 rflink
je suis aller dans reglage puis materiel est declarer rflink et voici ce que donne les logs mais quand j appuis sur n inporte quel telecommande 433 rien pourquoi les codes n apparaisse pas?
2015-07-03 16:03:45.397 Domoticz V2.2563 (c)2012-2015 GizMoCuz
2015-07-03 16:03:45.399 System: Raspberry Pi
2015-07-03 16:03:45.399 Startup Path: /home/pi/domoticz/
2015-07-03 16:03:45.843 Sunrise: 06:21:00 SunSet:21:50:00
2015-07-03 16:03:45.983 Active notification subsystems: email, http (2/8)
2015-07-03 16:03:45.996 Webserver started on port: 8080
2015-07-03 16:03:49.866 Webserver started on port: 443
2015-07-03 16:03:50.591 Camera: settings (re)loaded
2015-07-03 16:03:52.601 GPIO: WiringPi is now initialized
2015-07-03 16:03:52.604 GPIO: WiringPi is now initialized
2015-07-03 16:03:52.605 GPIO: Worker started...
2015-07-03 16:03:52.607 GPIO: Worker started...
2015-07-03 16:03:52.608 GPIO: WiringPi is now initialized
2015-07-03 16:03:52.615 GPIO: Worker started...
2015-07-03 16:04:03.810 Incoming connection from: 192.168.1.89
2015-07-03 16:04:20.600 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:04:50.736 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:05:20.895 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:05:32.484 RFLink: Using serial port: /dev/ttyACM1
2015-07-03 16:05:51.079 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:06:21.249 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:06:38.679 New sensors allowed for 5 minutes...
2015-07-03 16:06:51.448 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:07:21.896 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:07:52.119 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:08:22.291 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:08:52.465 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:09:22.653 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:09:52.828 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:10:23.237 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:10:53.414 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:11:23.588 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:11:53.774 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:12:23.947 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:12:54.265 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:13:24.491 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:13:54.695 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:14:24.868 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:14:55.048 Hardware Monitor: Fetching data (System sensors)
2015-07-03 16:15:25.251 Hardware Monitor: Fetching data (System sensors)
Re: rflink
Publié : 03 juil. 2015, 20:54
par snips
Une suggestion : rapprocher la télécommande de très tres près du circuit de réception 433mhz.
Si vous recevez qqch c'est que vous avez un problème d'antenne ou avez un circuit très bruité.
Changez le récepteur 433 MHz si vous en avez un deuxieme. Vérifier le câblage.
Re: rflink
Publié : 04 juil. 2015, 21:40
par ledouble33
j ai essayer avec un programme arduino avec le meme recepteur et ca fonctionne bien
