Réinitialisation cause DzVents
Publié : 09 avr. 2019, 11:40
par thomas.mantot
J'utilise Domoticz sur mon serveur unraid via un docker.
Depuis que j'ai mis à jours vers la dernière version disponible : 4.10602 j'ai vu que mon domo faisait que de boucler comme un redémarrage dans les logs :
2019-04-09 11:22:07.198 Status: Domoticz V4.10602 (c)2012-2019 GizMoCuz
2019-04-09 11:22:07.198 Status: Build Hash: ce68fa52, Date: 2019-04-04 20:51:02
2019-04-09 11:22:07.211 Status: Startup Path: /var/lib/domoticz/
2019-04-09 11:22:07.240 Sunrise: 06:53:00 SunSet: 20:11:00
2019-04-09 11:22:07.240 Day length: 13:18:00 Sun at south: 13:05:00
2019-04-09 11:22:07.240 Civil twilight start: 06:21:00 Civil twilight end: 20:43:00
2019-04-09 11:22:07.240 Nautical twilight start: 05:42:00 Nautical twilight end: 21:22:00
2019-04-09 11:22:07.240 Astronomical twilight start: 05:01:00 Astronomical twilight end: 22:04:00
2019-04-09 11:22:07.240 Status: EventSystem: reset all events...
2019-04-09 11:22:07.310 Status: PluginSystem: Started, Python version '3.6.6'.
2019-04-09 11:22:07.318 Active notification Subsystems: email, gcm (2/13)
2019-04-09 11:22:07.319 Status: WebServer(HTTP) started on address: :: with port 8080
2019-04-09 11:22:07.325 Status: WebServer(SSL) started on address: :: with port 1443
2019-04-09 11:22:07.327 Status: Proxymanager started.
2019-04-09 11:22:07.328 Starting shared server on: :::6144
2019-04-09 11:22:07.328 Status: TCPServer: shared server started...
2019-04-09 11:22:07.329 Status: RxQueue: queue worker started...
2019-04-09 11:22:09.329 Status: YeeLight Worker started...
2019-04-09 11:22:09.330 Status: RFXCOM: Worker started...
2019-04-09 11:22:09.330 Status: XiaomiGateway (ID=16): Delaying worker startup...
2019-04-09 11:22:10.341 Status: RFXCOM: Using serial port: /dev/ttyUSB0
2019-04-09 11:22:10.992
2019-04-09 11:22:10.992 Status: RFXCOM: Async Disabled
2019-04-09 11:22:10.993 subtype = Interface Response
Sequence nbr = 2
response on cmnd = Get Status
Transceiver type = 433.92MHz
Firmware version = 1034
Firmware type = Pro XL1
Noise Level: 93
Hardware version = 3.0
Undec off
X10 disabled
ARC enabled
AC enabled
HomeEasy EU disabled
Meiantech/Atlantic disabled
Oregon Scientific enabled
ATI/Cartelectronic disabled
Visonic disabled
Mertik disabled
AD disabled
Hideki disabled
La Crosse disabled
Legrand disabled
MSG4Reserved5 disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON disabled
FineOffset disabled
Lighting4 enabled
Conrad RSL disabled
ByronSX disabled
IMAGINTRONIX disabled
KEELOQ enabled
Home Confort disabled
2019-04-09 11:22:14.330 Status: XiaomiGateway (ID=16): Selected as main Gateway
2019-04-09 11:22:14.331 Status: XiaomiGateway (ID=16): Worker started...
2019-04-09 11:22:14.331 Status: XiaomiGateway (ID=16): Using 192.168.1.40 for local IP address.
2019-04-09 11:22:14.332 Status: EventSystem: reset all events...
2019-04-09 11:22:14.333 Status: EventSystem: reset all device statuses...
2019-04-09 11:22:14.449 Status: Python EventSystem: Initalizing event module.
2019-04-09 11:22:14.450 Status: EventSystem: Started
2019-04-09 11:22:14.450 Status: EventSystem: Queue thread started...
2019-04-09 11:22:14.451 Status: XiaomiGateway: RGB Gateway Detected
2019-04-09 11:22:14.456 (Gateway Xiaomi) Color Switch (Xiaomi RGB Gateway (192.168.1.11))
2019-04-09 11:22:14.469 (Gateway Xiaomi) Lux (Détecteur de luminosité)
2019-04-09 11:22:14.745 Status: PluginSystem: Entering work loop.
2019-04-09 11:22:48.951 (RFXCom) Temp + Humidity (Temperature terrasse)
2019-04-09 11:23:07.202 Status: Domoticz V4.10602 (c)2012-2019 GizMoCuz
2019-04-09 11:23:07.202 Status: Build Hash: ce68fa52, Date: 2019-04-04 20:51:02
2019-04-09 11:23:07.214 Status: Startup Path: /var/lib/domoticz/
2019-04-09 11:23:07.238 Sunrise: 06:53:00 SunSet: 20:11:00
2019-04-09 11:23:07.238 Day length: 13:18:00 Sun at south: 13:05:00
2019-04-09 11:23:07.238 Civil twilight start: 06:21:00 Civil twilight end: 20:43:00
2019-04-09 11:23:07.238 Nautical twilight start: 05:42:00 Nautical twilight end: 21:22:00
2019-04-09 11:23:07.238 Astronomical twilight start: 05:01:00 Astronomical twilight end: 22:04:00
2019-04-09 11:23:07.239 Status: EventSystem: reset all events...
2019-04-09 11:23:07.305 Status: PluginSystem: Started, Python version '3.6.6'.
2019-04-09 11:23:07.312 Active notification Subsystems: email, gcm (2/13)
2019-04-09 11:23:07.314 Status: WebServer(HTTP) started on address: :: with port 8080
2019-04-09 11:23:07.321 Status: WebServer(SSL) started on address: :: with port 1443
2019-04-09 11:23:07.322 Status: Proxymanager started.
2019-04-09 11:23:07.323 Starting shared server on: :::6144
2019-04-09 11:23:07.323 Status: TCPServer: shared server started...
2019-04-09 11:23:07.324 Status: RxQueue: queue worker started...
2019-04-09 11:23:09.324 Status: YeeLight Worker started...
2019-04-09 11:23:09.325 Status: RFXCOM: Worker started...
2019-04-09 11:23:09.326 Status: XiaomiGateway (ID=16): Delaying worker startup...
2019-04-09 11:23:10.337 Status: RFXCOM: Using serial port: /dev/ttyUSB0
2019-04-09 11:23:10.988
2019-04-09 11:23:10.989 Status: RFXCOM: Async Disabled
2019-04-09 11:23:10.989 subtype = Interface Response
Sequence nbr = 2
Noise Level: 91
Undec off
X10 disabled
ARC enabled
AC enabled
Visonic disabled
Mertik disabled
AD disabled
Hideki disabled
La Crosse disabled
Legrand disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON disabled
FineOffset disabled
Lighting4 enabled
Conrad RSL disabled
ByronSX disabled
KEELOQ enabled
2019-04-09 11:23:14.326 Status: XiaomiGateway (ID=16): Selected as main Gateway
2019-04-09 11:23:14.326 Status: XiaomiGateway (ID=16): Worker started...
2019-04-09 11:23:14.326 Status: XiaomiGateway (ID=16): Using 192.168.1.40 for local IP address.
2019-04-09 11:23:14.327 Status: EventSystem: reset all events...
2019-04-09 11:23:14.328 Status: EventSystem: reset all device statuses...
2019-04-09 11:23:14.416 Status: XiaomiGateway: RGB Gateway Detected
2019-04-09 11:23:14.421 (Gateway Xiaomi) Color Switch (Xiaomi RGB Gateway (192.168.1.11))
2019-04-09 11:23:14.432 (Gateway Xiaomi) Lux (Détecteur de luminosité)
2019-04-09 11:23:14.444 Status: Python EventSystem: Initalizing event module.
2019-04-09 11:23:14.444 Status: EventSystem: Started
2019-04-09 11:23:14.444 Status: EventSystem: Queue thread started...
2019-04-09 11:23:14.744 Status: PluginSystem: Entering work loop.
2019-04-09 11:23:27.952 (RFXCom) Temp + Humidity (Temperature terrasse)
2019-04-09 11:23:52.774 (Gateway Xiaomi) Temp (Xiaomi Temperature)
2019-04-09 11:23:52.776 (Gateway Xiaomi) Humidity (Humidité WC)
2019-04-09 11:24:06.950 (RFXCom) Temp + Humidity (Temperature terrasse)
2019-04-09 11:24:07.197 Status: Domoticz V4.10602 (c)2012-2019 GizMoCuz
2019-04-09 11:24:07.197 Status: Build Hash: ce68fa52, Date: 2019-04-04 20:51:02
2019-04-09 11:24:07.209 Status: Startup Path: /var/lib/domoticz/
2019-04-09 11:24:07.234 Sunrise: 06:53:00 SunSet: 20:11:00
2019-04-09 11:24:07.234 Day length: 13:18:00 Sun at south: 13:05:00
2019-04-09 11:24:07.234 Civil twilight start: 06:21:00 Civil twilight end: 20:43:00
2019-04-09 11:24:07.234 Nautical twilight start: 05:42:00 Nautical twilight end: 21:22:00
2019-04-09 11:24:07.234 Astronomical twilight start: 05:01:00 Astronomical twilight end: 22:04:00
2019-04-09 11:24:07.234 Status: EventSystem: reset all events...
2019-04-09 11:24:07.301 Status: PluginSystem: Started, Python version '3.6.6'.
2019-04-09 11:24:07.308 Active notification Subsystems: email, gcm (2/13)
2019-04-09 11:24:07.309 Status: WebServer(HTTP) started on address: :: with port 8080
2019-04-09 11:24:07.316 Status: WebServer(SSL) started on address: :: with port 1443
2019-04-09 11:24:07.317 Status: Proxymanager started.
2019-04-09 11:24:07.318 Starting shared server on: :::6144
2019-04-09 11:24:07.319 Status: TCPServer: shared server started...
2019-04-09 11:24:07.319 Status: RxQueue: queue worker started...
2019-04-09 11:24:09.320 Status: YeeLight Worker started...
2019-04-09 11:24:09.320 Status: RFXCOM: Worker started...
2019-04-09 11:24:09.321 Status: XiaomiGateway (ID=16): Delaying worker startup...
2019-04-09 11:24:10.332 Status: RFXCOM: Using serial port: /dev/ttyUSB0
2019-04-09 11:24:10.984
2019-04-09 11:24:10.985 Status: RFXCOM: Async Disabled
2019-04-09 11:24:10.985 subtype = Interface Response
Sequence nbr = 2
Noise Level: 91
Undec off
X10 disabled
ARC enabled
AC enabled
Visonic disabled
Mertik disabled
AD disabled
Hideki disabled
La Crosse disabled
Legrand disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON disabled
FineOffset disabled
Lighting4 enabled
Conrad RSL disabled
ByronSX disabled
KEELOQ enabled
2019-04-09 11:24:14.322 Status: XiaomiGateway (ID=16): Selected as main Gateway
2019-04-09 11:24:14.322 Status: XiaomiGateway (ID=16): Worker started...
2019-04-09 11:24:14.322 Status: XiaomiGateway (ID=16): Using 192.168.1.40 for local IP address.
2019-04-09 11:24:14.322 Status: EventSystem: reset all events...
2019-04-09 11:24:14.323 Status: EventSystem: reset all device statuses...
2019-04-09 11:24:14.386 Status: XiaomiGateway: RGB Gateway Detected
2019-04-09 11:24:14.392 (Gateway Xiaomi) Color Switch (Xiaomi RGB Gateway (192.168.1.11))
2019-04-09 11:24:14.403 (Gateway Xiaomi) Lux (Détecteur de luminosité)
2019-04-09 11:24:14.439 Status: Python EventSystem: Initalizing event module.
2019-04-09 11:24:14.439 Status: EventSystem: Started
2019-04-09 11:24:14.439 Status: EventSystem: Queue thread started...
2019-04-09 11:24:14.740 Status: PluginSystem: Entering work loop.
2019-04-09 11:24:45.971 (RFXCom) Temp + Humidity (Temperature terrasse)
2019-04-09 11:25:07.199 Status: Domoticz V4.10602 (c)2012-2019 GizMoCuz
2019-04-09 11:25:07.199 Status: Build Hash: ce68fa52, Date: 2019-04-04 20:51:02
2019-04-09 11:25:07.212 Status: Startup Path: /var/lib/domoticz/
2019-04-09 11:25:07.242 Sunrise: 06:53:00 SunSet: 20:11:00
2019-04-09 11:25:07.242 Day length: 13:18:00 Sun at south: 13:05:00
2019-04-09 11:25:07.242 Civil twilight start: 06:21:00 Civil twilight end: 20:43:00
2019-04-09 11:25:07.242 Nautical twilight start: 05:42:00 Nautical twilight end: 21:22:00
2019-04-09 11:25:07.242 Astronomical twilight start: 05:01:00 Astronomical twilight end: 22:04:00
2019-04-09 11:25:07.242 Status: EventSystem: reset all events...
2019-04-09 11:25:07.309 Status: PluginSystem: Started, Python version '3.6.6'.
2019-04-09 11:25:07.316 Active notification Subsystems: email, gcm (2/13)
2019-04-09 11:25:07.317 Status: WebServer(HTTP) started on address: :: with port 8080
2019-04-09 11:25:07.324 Status: WebServer(SSL) started on address: :: with port 1443
2019-04-09 11:25:07.326 Status: Proxymanager started.
2019-04-09 11:25:07.327 Starting shared server on: :::6144
2019-04-09 11:25:07.327 Status: TCPServer: shared server started...
2019-04-09 11:25:07.327 Status: RxQueue: queue worker started...
2019-04-09 11:25:09.328 Status: YeeLight Worker started...
2019-04-09 11:25:09.329 Status: RFXCOM: Worker started...
2019-04-09 11:25:09.330 Status: XiaomiGateway (ID=16): Delaying worker startup...
2019-04-09 11:25:10.340 Status: RFXCOM: Using serial port: /dev/ttyUSB0
2019-04-09 11:25:10.992
2019-04-09 11:25:10.993 Status: RFXCOM: Async Disabled
2019-04-09 11:25:10.993 subtype = Interface Response
Sequence nbr = 2
Noise Level: 93
Undec off
X10 disabled
ARC enabled
AC enabled
Visonic disabled
Mertik disabled
AD disabled
Hideki disabled
La Crosse disabled
Legrand disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON disabled
FineOffset disabled
Lighting4 enabled
Conrad RSL disabled
ByronSX disabled
KEELOQ enabled
En désactivant les événements, pas de problème (alors que avant la mise à jour pas de soucis).
Mais j'utilise beaucoup de script alors j'ai encore cherché et en faite ça le fait plus quand je désactive DzVents que je n'utilise pas du tout d'ailleurs.
C'est étrange
