[RESOLU] Problème Python
Publié : 30 avr. 2019, 23:25
J'ai un problème lors de la mise à jour via ./updatedomo:
Pour info:
Une idée ?
root@domoticz-master:/home/domoticz/domoticz# ./updatedomo
Updating to server revision...
Récupération de origin
HEAD est maintenant à 98723b7da Bumped version
-- Compiling Revision #9701
-- Using builtin Mosquitto library
-- Python3 includes found at: /usr/include/python3.5m
-- Building with I2C support
-- Building with SPI support
-- OPENSSL_LIBRARIES: /usr/lib/x86_64-linux-gnu/libssl.so;/usr/lib/x86_64-linux-gnu/libcrypto.so
-- Boost version: 1.65.1
-- Found the following Boost libraries:
-- thread
-- system
-- chrono
-- date_time
-- atomic
-- Linking against boost static libraries
-- ZLIB libraries found at: /usr/lib/x86_64-linux-gnu/libz.so
-- ZLIB includes found at: /usr/include
-- Curl libraries found at: /usr/lib/x86_64-linux-gnu/libcurl.so
-- Curl includes found at: /usr/include
-- LIBUSB found at: /usr/lib/x86_64-linux-gnu/libusb.so
-- /home/domoticz/open-zwave-read-only/libopenzwave.a
-- /usr/lib/x86_64-linux-gnu/libudev.so
-- GPIO is available
-- Not found telldus-core (telldus-core.h), not adding tellstick support
/usr/bin/c++ ;;-std=c++11;-O3;-DNDEBUG;-I/usr/include/python3.5m;-I/home/domoticz/domoticz/main;-I/home/domoticz/domoticz/tinyxpath;-I/usr/include;-I/usr/include;-I/usr/include;-I/home/domoticz/domoticz/zip;-I/usr/include;-I/home/domoticz/domoticz/hardware/openzwave;-DBUILTIN_MQTT;-DENABLE_PYTHON;-DHAVE_EXECINFO_H;-DHAVE_LINUX_I2C;-DHAVE_LINUX_SPI;-DWWW_ENABLE_SSL;-DWITH_LIBUSB;-DWITH_OPENZWAVE;-DWITH_GPIO -x c++-header -o /home/domoticz/domoticz/stdafx.h.gch/.c++ /home/domoticz/domoticz/main/stdafx.h
-- Using static libgcc/libstdc++
-- Configuring done
-- Generating done
-- Build files have been written to: /home/domoticz/domoticz
[ 1%] Built target minizip
-- Found Git: /usr/bin/git (found version "2.17.1")
[ 1%] Built target revisiontag
[ 1%] Built target domoticz_gch
[ 12%] Built target lua
[ 19%] Built target mqtt
[ 20%] Built target sqlite
[ 21%] Building CXX object CMakeFiles/domoticz.dir/main/EventSystem.cpp.o
cc1plus: warning: ./stdafx.h.gch/.c++: created by a different GCC executable
In file included from /home/domoticz/domoticz/main/../hardware/plugins/PluginMessages.h:3:0,
from /home/domoticz/domoticz/main/EventSystem.cpp:43:
/home/domoticz/domoticz/main/../hardware/plugins/DelayedLink.h:12:10: fatal error: Python.h: Aucun fichier ou dossier de ce type
#include <Python.h>
compilation terminated.
CMakeFiles/domoticz.dir/build.make:182: recipe for target 'CMakeFiles/domoticz.dir/main/EventSystem.cpp.o' failed
make[2]: *** [CMakeFiles/domoticz.dir/main/EventSystem.cpp.o] Error 1
CMakeFiles/Makefile2:72: recipe for target 'CMakeFiles/domoticz.dir/all' failed
make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2
Makefile:151: recipe for target 'all' failed
make: *** [all] Error 2
Compile failed!
Pour info:
root@domoticz-master:/home/domoticz/domoticz# python3 -V
Python 3.6.7
Une idée ?
